Page 14 of 120
Re: Domoticz app 2.0
Posted: Monday 28 December 2015 20:15
by Derik
i wanna try the app on my tablet with 4.4 kitkat...
I cannot see the app in playstore..
Is there a other option to install it?
Posted: Monday 28 December 2015 20:27
by rniekolaas
I don't know what I'm doing wrong. I have the premium version installed, but I can not get any connection to Domoticz.
I have installed Domoticz 2.3530 on a Pi. I tried serveral server-settings (http/https with ports 8080,6144/443, with or without username and password) .
Every time I get the message 'No value for result'. Whatever I try, it won't work.
Does anybody has any idea ?? Is there a manual available how to setup ??
Thanks.
Posted: Monday 28 December 2015 20:37
by pepeEL
Give us screen from app...how you configure it.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Posted: Monday 28 December 2015 20:42
by Jango
rniekolaas wrote:Hi all,
Thanks.
Can you see the domoticz server in your browser and what is the address and portnumber? That's the address and portnumber to get things working for server connection settings together with username and password.
Verstuurd vanaf mijn E6853 met Tapatalk
Posted: Monday 28 December 2015 21:45
by rniekolaas
Jango wrote:rniekolaas wrote:Hi all,
Thanks.
Yes I can see it in the browser and used these settings already
Verstuurd vanaf mijn SM-T550 met Tapatalk
Posted: Monday 28 December 2015 21:49
by pepeEL
Is any chance to add to app Domoticz features for dimmer switch RGBW Led option to ser color leds ? And small size level % and big size slider because is too small.
Posted: Monday 28 December 2015 22:10
by rniekolaas
pepeEL wrote:Give us screen from app...how you configure it.
Hope it works and it's clear enough
Posted: Monday 28 December 2015 22:28
by RoadXY
It's able to read the Domoticz version but can't receive any devices.
What's the output of the Domoticz website with the following:
/json.htm?type=devices&filter=all&used=true&order=Name
So if your Domoticz site is:
http://192.168.1.11:8080
The URL to test would be:
http://192.168.1.11:8080/json.htm?type= ... order=Name
If had this issue once but I'm unable to reproduce ever since.
Posted: Monday 28 December 2015 22:47
by rniekolaas
RoadXY wrote:It's able to read the Domoticz version but can't receive any devices.
I used
http://192.168.0.126:8080/json.htm?type ... order=Name to test
The output is:
"ActTime" : 1451339066,
"ServerTime" : "2015-12-28 22:44:26",
"Sunrise" : "08:49",
"Sunset" : "16:29",
"status" : "OK",
"title" : "Devices"
Posted: Monday 28 December 2015 23:38
by jewlsoft
Nice app. Works OK. But..
I have a remark off course. There is an option "Sort Devices".
This is not really about sorting devices but selecting devices and what is actually displayed is allways sorted.
There should be an option not to select and not to sort at all.
In the dashboard view this is very confusing.
In the domoticz website there is already a selection done and the viewing order is already set.
Please update the app at this point and I will buy the premium version.
Posted: Monday 28 December 2015 23:39
by kurniawan77
You are using your local adres but you have to use your internet adres in there. Further below you can set an other server adres for local
Posted: Tuesday 29 December 2015 0:33
by Brutus
kurniawan77 wrote:You are using your local adres but you have to use your internet adres in there. Further below you can set an other server adres for local
When you have forwarded the ports in your router you can but I only use the internal IP adres.
When I am outside I make a VPN connection to my home and start the app.
I have seen a lot of false logins in my domotics log when opening ports to Domoticz. So I will not connect it directly to the internet anymore.
Posted: Tuesday 29 December 2015 9:16
by RoadXY
Really weird issue: the JSON call doesn't return any devices.
Since this has to be completed for everyone it works for everyone else.
You could try and reboot your Domoticz server, remove the Android app and reinstall.
Posted: Tuesday 29 December 2015 9:32
by rniekolaas
I found it. It's a stupid mistake by myself.
I setup a new installation of Domoticz and didn't add any hardware yet.
I added the temperaturesensor of the raspberry and it's working now.
Thanks for the help and pushing me in the good direction.
Posted: Tuesday 29 December 2015 9:48
by RoadXY
rniekolaas wrote:I found it. It's a stupid mistake by myself.
Lol, that's also possible.
We'll change the logic behind it so if you don't have any devices your able to continue.
Posted: Tuesday 29 December 2015 9:58
by pj-r
Only a small problem becouse of my environment. I'm using this on Jolla phone(alien dalvik for android support). Looks like there is no wlan ssid listing working yet on Jolla and thats why I cannot use separate settings for local connection. Could it be possible to manually write wlan ssid if the list is empty? Or can I "hack" that setting thru file system?
Posted: Tuesday 29 December 2015 10:34
by RoadXY
pj-r wrote:Only a small problem becouse of my environment. I'm using this on Jolla phone(alien dalvik for android support). Looks like there is no wlan ssid listing working yet on Jolla and thats why I cannot use separate settings for local connection. Could it be possible to manually write wlan ssid if the list is empty? Or can I "hack" that setting thru file system?
Hacking would not be easy as the shared preferences has to be exact or the app crashes.
Manual input is not possible yet.
I'll put it on the to-do list.
Posted: Tuesday 29 December 2015 11:02
by galadril
pepeEL wrote:
But still i can not set up color led on dimmer switch fibaro rgbw. Only can eneable switch and set dimm.
Should be fixed in the next version
Posted: Tuesday 29 December 2015 11:06
by pepeEL
Very very thanks
Posted: Tuesday 29 December 2015 11:13
by jayjay
Hi Guys,
Really thank you for this application and the work you do.
Just a small suggestion for the issue "Camera issues #128", you have a white screen of the cameras whern you are outside of the lan. May be you can use Picasso with basic authentication to get the camera snapshot.
You need also create a new fullUrl of the camera outside, for exemple in my case to access from outside to my RAspiCam the full Url is :
http://88.xx.xx.122:68953/cam snapshot.jpg?idx=1
http:// Public IP : NAT public port / Camera Url
I think you have all the informations in the app to create this fullUrl outside to pass it in Picasso with basic-auth
Maybe it's impossible to do I don't know, I'm not developper just Sys Administrator. But I think this camera screen interress a lot of person when you are not at home
Have a nice day.
