Page 14 of 37
Re: ELV Max! Heating control system
Posted: Wednesday 19 October 2016 10:24
by hasan
Hi guys,
thanks for nice topic. I have 5 valves EQ-3 with Cube and RPi with Domoticz and I would like to use Domoticz to control valves. I read all topic but I'm little bit lost. I tried to install LUA5.2 into RPi but without success. Is there somebody who can send me some "How to install to RPi"? Thanks.
Posted: Saturday 22 October 2016 14:11
by blackdog65
@Hasan :D
Hi, some raspberry distros already have lua installed so 1st try
pi@xxxxxx:~ $ lua
and you will either get something like this
Lua 5.1.5  Copyright (C) 1994-2012 Lua.org, PUC-Rio
or this
Lua 5.2.3  Copyright (C) 1994-2013 Lua.org, PUC-Rio
or
The program 'lua' can be found in the following packages:
 * lua5.2
 * lua5.1
 * lua50
Try: sudo apt install <selected package>
if it isn't installed at all
If no lua
sudo apt-get update
sudo apt-get lua5.2
should do the trick
Once you have it "in" your RasPi you may have problems with where it was placed or conflict with 5.1 or 5.0. I seem to remember I had to completely flush my system of everything lua related and reinstall... or maybe that was another project :?
But try this 1st and see how you go from there.
Sean :D
Posted: Saturday 22 October 2016 14:27
by blackdog65
@mvzut :D
1st many thanks for the hard work so far!
I had problems getting this to run so I wandered off and played with another project for a while (The wonderful Amazon Doorstop :evil: ) and then came back to it this week. At 1st I only had partial success as I could only update one room with the script yet the "Westcott test script" ;) shows all rooms stats and valves. Then it hit me, 3 rooms were set to auto in the max app. set them to manual and BOOM all showing! :D
So temps all fine, set-points fine but my valve percentages are not correct. How should the be named? e.g. my kitchen is set up as
Room = Kitchen
Stat = Kitchen-Stat
TRV = Kitchen-Rad
My virtual devices are
Temp = Kitchen
Stat = Kitchen-Stat
% = Kitchen-Rad
The 1st 2 work but not the 3rd. Others are similar V-Room, V-Room-Stat, V-Room-Rad etc. All with the same issue.
I hope this sense (and is an easy solution ;) )
Many thanks
Sean :D
Posted: Tuesday 25 October 2016 17:40
by jmbjmbjmb
I am getting the following error message with the lua script (named script_time.lua) that was posted in this forum (not that I have uncommented all prints to get the messages shown, hoping that this helps figuring what the problem is).
lua scripts/lua/script_time_max.lua
H=JEQ0543318,03f77a,0113,00000000,7e71f81d,01,32,100a19,1124,03,0000
C=03f77a,7QP3egATAf9KRVEwNTQzMzE4AQsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly93d3cubWF4LXBvcnRhbC5lbHYuZGU6ODAvY3ViZQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
C=0b0442,0gsEQgICEABLRVEwNTcxNzk4JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d7,0gj21wIDEP9LRVEwNTcwOTAzJiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIUQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f616,0gj2FgIFEP9LRVEwNTY5OTA3JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d4,0gj21AIBEABLRVEwNTcwOTA2JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=09b650,zgm2UAMBEP9LRVEwODYzNzAwJiE9CURITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgBxgw
C=08f541,0gj1QQIBEP9LRVEwNTY5NjkzJiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f556,0gj1VgIEEABLRVEwNTY5NzE0KyE9CQcYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbETMVRRFIEUgRSBFIEUgRSBFIEUgRSBESFRsRMxVFEUgRSBFIEUgRSBFIEUgRSBFIERIVGxEzFUURSBFIEUgRSBFIEUgRSBFIEUgREhUbETMVRRFIEUgRSBFIEUgRSBFIEUgRSBESFRsRMxVFEUgRSBFIEUgRSBFIEUgRSBFIA==
lua: scripts/lua/script_time_max.lua:90: attempt to index global 'bit32' (a nil value)
stack traceback:
	scripts/lua/script_time_max.lua:90: in function 'maxCmd_L'
	scripts/lua/script_time_max.lua:202: in main chunk
	[C]: ?
Posted: Wednesday 26 October 2016 7:46
by mvzut
blackdog65 wrote:@mvzut :D
Room = Kitchen
Stat = Kitchen-Stat
TRV = Kitchen-Rad
Temp = Kitchen
Stat = Kitchen-Stat
% = Kitchen-Rad
Many thanks
Sean :D
Your naming scheme seems correct, but I took out the updates of the valve positions in the alternative version of the script (the one that has a "useWMT" setting to work with systems without a wall mounted thermostat in every room). I figured most people would probably not need that funtionality. You should be able to put it back in by adding this line
        table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..valve_pos})
directly above the line that reads "elseif dtype == "Thermostat" then".
Hope this helps.
Posted: Wednesday 26 October 2016 9:54
by blackdog65
Many thanks!
I'll try later when I get home.
My current script is based on the max buddy set up and activates the heating if 2 or more valves are open more than 50%. This works well for me so I plan to cannibalise it to work with your script (if my ability allows).
Thanks again
Sean
Posted: Thursday 27 October 2016 18:35
by blackdog65
blackdog65 wrote:My current script is based on the max buddy set up and activates the heating if 2 or more valves are open more than 50%. This works well for me so I plan to cannibalise it to work with your script (if my ability allows).
and it doesn't :oops:
I've been going round in circles with this and getting further confused. :?
I have 2 scripts
Script "A" based on the script written by l0gic viewtopic.php?f=34&t=841&start=60#p38160
-- script_time_Heating Valves.lua
-- Version 1.8 26/03/15
-- Script to read the % open of radiator valves
-- All radiator valves are labelled "RV <room name>"
-- search is made for  "RV " (Note space) to indicate a radiator valve
-- If found it will be interrogated for % open value
-- Thermostat are named "Stat <room name>" so a search is made for "Sta" to indicate thermostats
-- If found it will be interrogated for temperature value
-- If demand is greater than BoilerOnPercent value then fire up boiler
-- If demand is less than BoilerOnPercent minus HysterysisOffPercent then switch off boiler
-- Preset Values
BoilerOnPercent = 50               -- percentage valve open at which the boiler will be turned on
HysterysisOffPercent = 20             -- percentage below BoilerOnPercent to switch off the boiler
MinValves = 2                      -- Number of Valves that need to be open before boiler is turned on
ValvePercentOveride = 99            -- Percentage value of valve open required to override MinValves value (one room is very cold)
HolidayMinTemp = 10                -- Minimum room temperature before boiler is turned on during holiday period
HolidayHysterysisTemp = 2             -- Value to increase house temperature by while in holiday mode if boiler is turned on due to low temperatures
MissingDevicesTime = 3600            -- Value in seconds to allow before reporting a device has not been updated
email = "[email protected]"             -- email address for warnings
-- Script Variables
PercentMax = 0
TempMin = 100
ValveCount = 0
MissingDeviceCount = 0
SendAnEmail = false
-- Set printing to log options (true / false)
-- printData = false
printData = false
printDebug = false
-- printDebug = true
-- Get current date & time
t1 = os.time()
local currentDate = os.date("*t");  -- sets up currentDate.[table]
-- (currentDate.year [full], .month [1-12], .day [1-31], .hour [0-23], .min [0-59], .sec [0-59], .wday [0-6 {Sun-Sat}])
sCurrentTime = currentDate.year .. "-" .. currentDate.month .. "-" .. currentDate.day .. " " .. currentDate.hour .. ":" .. currentDate.min .. ":" .. currentDate.sec
function TimeElapsed(s) -- expects date & time in the form of 2010-01-23 12:34:56
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference -- in seconds
       -- print blank line in log
       if printData == true then
         print (" ")
         print (" *** Heating Script Output ***")
         print (" ")
       -- Get Data from Radiator Valves
      for i, v in pairs(otherdevices) do -- Get all devices in the database
         v = i:sub(1,3) -- Grab the first three characters of the device name
            if (v == 'RV ') then -- are the first three characters "RV "? If so we have a Radiator Valve
                RoomName = i:sub(4) -- Get the rest of the name, which will be the room name
                sSetTempValue, sValvePercentOpen = otherdevices_svalues[i]:match("([^;]+);([^;]+)") -- get the valve set Point and the  valve % open (Temp, Humidity)
                sLastUpdateTime = otherdevices_lastupdate[i]
                sElapsedTime = TimeElapsed(otherdevices_lastupdate[i])
                message = RoomName .. " valve is open " .. sValvePercentOpen .. " percent " .. " Setpoint temperature is " .. sSetTempValue .. "C"  -- for debug
                message2 = RoomName .. " last seen " .. sLastUpdateTime  ..  " Elapsed time " .. sElapsedTime
                  print (message)
                  print (message2)
                -- check for missing devices
                if sElapsedTime > MissingDevicesTime then
                SendAnEmail = false
                MissingDeviceCount = MissingDeviceCount + 1
                -- get the % value of the most open Radiator Valve
                if tonumber(sValvePercentOpen) > PercentMax then
                  PercentMax = tonumber(sValvePercentOpen)
                -- Count the number of valves that are open more than BoilerOnPercent
                if tonumber(sValvePercentOpen) >= BoilerOnPercent then
                  ValveCount = ValveCount + 1
         print (" ")
      -- Get Data from Thermostats
         v = i:sub(1,5) -- Grab the first three characters of the device name
            if (v == 'Stat ') then -- are the first five characters "Stat "? If so we have an EQ-3 Thermostat
                RoomName = i:sub(6) -- Get the rest of the name, which will be the room name
                  sTemp = otherdevices_svalues[i] -- get the temperature
                message = RoomName.." temperature is " .. sTemp .. " Centigrade "  -- for debug
                  print(message)
                  print(message2)
                -- get the lowest temperature of the thermostats
                if tonumber(sTemp) < TempMin then
                  TempMin = tonumber(sTemp)
                SendAnEmail = true                      -- change this to false if you do not require emails to be sent
         print (" ")
         print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves")
         print("Highest valve open value is " .. PercentMax .." percent ")
         print("Lowest thermostat reading is " .. TempMin .." Centigrade ")
         print (" ")
      if (otherdevices['CH_Switch'] == 'On')then
         print ("Current state - Boiler is ON ")
         print ("Current state - Boiler is OFF ")
   -- Check the elapsed time and email if overdue
      if (SendAnEmail == true) then
         print (" ")
         print("Heating Script: missing device email sent to " .. (email) );
         notifyString = os.date("Domoticz Alert # The current time is %X on %A Lost contact with " .. MissingDeviceCount .. " Heating script devices, check if Max!Buddy is running.  #") .. (email)
         commandArray['SendEmail'] = notifyString
      -- Perform logic
      if printDebug == true then
      -- view the settings to understand logic performance
         print ("PercentMax (" .. PercentMax .. "%) " .. "Boiler On value (" .. BoilerOnPercent .. "%) " .. "Boiler Off value (" .. (BoilerOnPercent - HysterysisOffPercent) .. ")% ")
         print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves. Minimum valves setting " .. MinValves )
         print ("Maximum open value " .. PercentMax .. "%" .. " Override value " .. ValvePercentOveride .."%")
      print (" ")
      if (otherdevices['Holiday'] == 'Off')then -- Not on holiday
	if (otherdevices['Heating'] == 'On')then -- It's time to heat the house
         	if (otherdevices['CH_Switch'] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
                     print ("Test passed - Boiler is OFF ")
            	if (PercentMax > BoilerOnPercent) then
                     print ("Test passed - Radiators are open beyond the threshold ")
               	if (ValveCount >= MinValves) or (BoilerOnPercent >= ValvePercentOveride) then
                     print ("Test passed - Either multiple valves are open or override count is reached ")
                  commandArray['CH_Switch']='On' -- turn on boiler
                        print ("Command sent - Turn ON Boiler ")
         if (PercentMax < (BoilerOnPercent - HysterysisOffPercent) or (ValveCount < MinValves)) and (otherdevices['CH_Switch'] == 'On')  then -- If the number of valves open more than BoilerOnPercent minus HysterysisOffPercent
            commandArray['CH_Switch']='Off' -- turn off boiler
                     print ("Command sent - Turn OFF Boiler ")
      else -- on holiday
         if (TempMin <= HolidayMinTemp) and (otherdevices['CH_Switch'] == 'Off') then  -- house is very cold
         if (TempMin >= (HolidayMinTemp + HolidayHysterysisTemp)) and (otherdevices['CH_Switch'] == 'On') then  -- house is warm enough
            commandArray['CH_Switch']='Off' -- turn on boiler
      print (" ")
This reads the cube, creates devices and controls my heating based on temperature, valve open% and holiday settings. All very clever but relies on maxbuddy and cannot change setpoints.
And the mvzut script viewtopic.php?f=34&t=841&start=220#p88647
--./script_time_max.lua
-- Script parameters
package.loadlib("core.so", "*")
local Socket = require "socket"
local Basexx = require "basexx"
local Rooms = {}
local Devices = {}
local Room_nums = {}
local MaxIP = "192.168.1.131"
local MaxPort = 62910
local useWMT = true             --# Set to true if there is a wall mounted thermostat in every room, then this one will be used for setpoint getting/setting
Debug = "YES"                       --# Turn debugging on ("YES") or off ("NO")
-- Script functions
function age(timestring)
    t = {}
    t.year = string.sub(timestring,1,4)
    t.month = string.sub(timestring,6,7)
    t.day = string.sub(timestring,9,10)
    t.hour = string.sub(timestring,12,13)
    t.min = string.sub(timestring,15,16)
    t.sec = string.sub(timestring,18,19)
    return os.difftime(os.time(),os.time(t))
function maxCmd_H(data)
   --if Debug=="YES" then print('H='..data) end
function maxCmd_M(data)
   i = 0
   j = 0
   while true do                --find next comma
      i = string.find(data, ",", i+1)
      if not i then break end
      j = i
   s   = data:sub(j+1)
   dec = Basexx.from_base64(s)
   num_rooms = string.byte(dec,3)
   pos=4
   for i=1, num_rooms do
      room_num = string.byte(dec, pos)
      name_len = string.byte(dec, pos+1)
      pos  = pos+2
      name = dec:sub(pos, pos+name_len-1)
      pos  = pos+name_len
      adr  = Basexx.to_hex(dec:sub(pos, pos+2))
      Rooms[room_num] = name
      pos = pos+3
   num_devs = string.byte(dec, pos)
   for i=1, num_devs do
      dtype = string.byte(dec, pos+1)
      adr   = Basexx.to_hex(dec:sub(pos+2, pos+4))
      snum  = dec:sub(pos+5, pos+14)
      name_len = string.byte(dec, pos+15)
      pos  = pos+16
      pos  = pos+name_len
      Room_nums[adr] = room_num
      Devices[adr] = name
function maxCmd_C(data)
   --if Debug=="YES" then print('C='..data) end
function maxCmd_L(data)
   pos = 1
   dec = Basexx.from_base64(data)
   L_hex = Basexx.to_hex(dec)
   L_len = string.len(L_hex)
   while (pos < L_len) do
      s = L_hex:sub(pos,(pos+1))
      data_len  = tonumber(s,16) + 1
      hex  = L_hex:sub(pos,pos+(data_len*2))
      adr  = hex:sub(3,8)
      room_num = string.format("%02X", Room_nums[adr])
      room = Rooms[Room_nums[adr]]
      name = Devices[adr]
      if not name then name=adr end
      valve_info = tonumber(hex:sub(13,14),16)
      batt = bit32.extract(valve_info,7,1)
      bst  = bit32.extract(valve_info,3,1)
      mode = bit32.extract(valve_info,0,2)
      if (batt==0) then sbat="OK" else sbat="Low"   end
      if (mode==0) then
         smode="Auto"
      elseif (mode==1) then
         smode="Manual"
      elseif (mode==2) then
         smode="Holiday"
      elseif (mode==3) then
         smode="Boost"
        if (data_len == 13) then -- WallMountedThermostat (dev_type 3)
            valve_pos = -1
            s = hex:sub(17,18)
            setpoint = tonumber(s,16) / 2
            s = hex:sub(23,26)
            temp = tonumber(s,16) / 10
            dtype = "Thermostat"
        elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
            s = hex:sub(15,16)
            valve_pos = tonumber(s,16)
            s = hex:sub(17,18)
            if (mode ~= 2) then
                s = hex:sub(19,22)
                temp = 0
            dtype = "Valve"
        --Temperaturdevices den Status aktualisieren
       if temp ~= 0 and dtype == "Valve" then
           table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
        elseif  temp ~= 0 and dtype == "Thermostat" then
            table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
        if smode=="Manual" then
         --Update virtual devices in Domoticz and update MAX! setpoints if necessary
         if Debug=="YES" then print(dtype.."  "..name.."  Setpoint="..setpoint.."  Temp="..temp.."  Valve pos="..valve_pos) end
         if dtype == "Valve" then
            --table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
            if not useWMT and tonumber(otherdevices_svalues[name])~=nil then        --Use valve to check setpoint mismatch
               setpoint_Domoticz = tonumber(otherdevices_svalues[name])
               ---if name ~= "EcoTaster" and name ~= "Switch-SZ" and name ~= "Switch-WZ" then
                  if setpoint_Domoticz ~= setpoint then
                       print(otherdevices_lastupdate[name])
                       print(age(otherdevices_lastupdate[name]))
                     if otherdevices_lastupdate[name]~=nil and age(otherdevices_lastupdate[name]) > 120 then       --Domoticz thermostat value must be updated
                        table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..setpoint})
                        if Debug=="YES" then print("Domoticz setpoint updated") end
                     else        --Max! setpoint must be updated
                        MaxCmdSend(adr, room_num, "manual", setpoint_Domoticz)
                        if Debug=="YES" then print("MAX!Valve setpoint updated") end
               ---end
            --table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
                   if Debug=="YES" then print("MAX!WMT setpoint updated") end
      dtype=""
      name=""
      setpoint=""
      temp=""
      valve_pos=""
      pos = pos + (data_len*2)
function MaxCmdSend(id, room, mode, setpoint)
   bits  = setpoint * 2
   smode = string.upper(mode)
   if smode == 'MANUAL' then
      bits = 64 + bits
   elseif smode == 'BOOST' then
      bits = 192 + bits
   elseif smode == 'VACATION' then
      bits = 128 + bits
   hex = "000440000000"..id..room..string.format("%x",bits)
   sendStr = Basexx.to_base64(Basexx.from_hex(hex))
   i, status = tcp:send("s:"..sendStr.."\r\n")
   if not i then
      print("MAX! TCP send failed - "..status)
      return
-- CommandArray
    local m = os.date('%M')
    if (m % 2 == 0) then
        --print("The 3 minute script interval reached")
       tcp = Socket.connect(MaxIP, MaxPort)
       if not tcp then
          print("MAX! Socket connect failed for "..MaxIP..':'..MaxPort)
          return
       tcp:settimeout(2)
       local time = os.date("*t")
       while (time.min ~= 0) do
          s, status, partial = tcp:receive()
          if (status) then
             print("MAX! TCP receive - "..status)
             break
          local line = (s or partial)
          local cmd  = line:sub(1,1)
          local data = line:sub(3)
          if (cmd == 'H') then
             maxCmd_H(data)
          elseif (cmd == 'M') then
             maxCmd_M(data)
          elseif (cmd == 'C') then
             maxCmd_C(data)
          elseif (cmd == 'L') then
             maxCmd_L(data)
             break
       tcp:close()
which reads direct without maxbuddy and can change setpoints but doesn't have the heating control.
I've been pulling my hair out trying to see a way to combine the two to create the perfect heating control script. Can any kind soul offer some pointers.
My 1st thought was to strip the "Find devices" part from l0gic's script and get the mvzut script to fill in the missing information... but as a non-coder I over-heated my brain and I'm lucky to still have functioning heating at all! :roll:
Please help me! :D
Sean
Posted: Thursday 27 October 2016 21:27
by Skippiemanz
Reading through the 2 scripts a combination would be indeed haven on earth... Im unfortunetly no coder also.. Fingers crossed
Posted: Thursday 27 October 2016 22:22
by mvzut
Do you mean that the % devices for the valves still don't update?
Can you maybe put a "print(valve_pos)" line below "valve_pos = tonumber(s,16)", does it print the valve positions in the log?
Posted: Thursday 27 October 2016 22:27
by blackdog65
mvzut wrote:Do you mean that the % devices for the valves still don't update?
No, my friend. Your script works fine. I have setpoints, temps and %, all fine. My problem is using the % to control my system as in the 1st (l0gic) script.
I really do struggle with code :roll:
Posted: Thursday 27 October 2016 22:57
by mvzut
The script written by l0gic requires your device names to start with "RV " for radiator valves, and "Stat " for thermostats. If I understand your previous post correct, you have named them:
Stat = Kitchen-Stat
% = Kitchen-Rad
Moreover, l0gic's script assumes that the setpoint temperatures & valve positions are stored together in temp/humidity devices. I have separated them: the setpoint temperature is stored in a thermostat device, and the valve position is a separate % device. I have modified the script so that it should work again for your situation:
-- Version 1.9 27/10/16
-- All radiator valves are labelled "<room name>-Rad"
-- search is made for "-Rad" to indicate a radiator valve
-- Thermostat are named <room name>-Stat so a search is made for "-Stat" to indicate thermostats
-- Preset Values
-- Script Variables
PercentMax = 0
TempMin = 100
ValveCount = 0
SendAnEmail = false
printData = false
printDebug = false
t1 = os.time()
   t1 = os.time()
         print (" ")
         print (" ")
         v = i:sub(-4,-1) -- Grab the last four characters of the device name
            if (v == '-Rad ') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
                RoomName = i:sub(1,-5) -- Get the rest of the name, which will be the room name
                sSetTempValue = otherdevices_svalues[RoomName..'-Stat']
                  print (message)
                  print (message2)
                SendAnEmail = false
         print (" ")
         v = i:sub(-5,-1) -- Grab the last five characters of the device name
            if (v == '-Stat ') then -- are the last five characters "-Stat "? If so we have an EQ-3 Thermostat
                RoomName = i:sub(1,-6) -- Get the rest of the name, which will be the room name
                  print(message)
                  print(message2)
         print (" ")
         print (" ")
         print (" ")
      -- Perform logic
      print (" ")
      else -- on holiday
      print (" ")
Please note however that I haven't tested it myself... Let me know your results!
UPDATE 27-10-2016 23:17
I have taken out a few errors in the adapted script after publishing it. Please use the latest version.
Posted: Thursday 27 October 2016 23:53
by blackdog65
WOW! @ mvzut!!! :shock: :o :shock:
Many thanks for such a fast AND comprehensive reply. I just saw this before going to bed so I shall try it tomorrow morning and get back to you.
Am I right in assuming that this eliminates the need to run maxbuddy? Also, I think I need to run your original script + this script together?
Fingers crossed and huge thanks :D :D :D
Sean
Posted: Friday 28 October 2016 7:17
by mvzut
blackdog65 wrote:WOW! @ mvzut!!! :shock: :o :shock:
Sean
You're welcome Image.
Yes, this eliminates the need for maxbuddy. You should indeed run both scripts as time scripts, I also have it set up that way.
Let me know if it works or not, including any error messages you may get.
Posted: Friday 28 October 2016 13:03
by blackdog65
Hi mvzut!
I have both scripts running now.
The max script is reporting
2016-10-28 11:50:01.930 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=19.6 Valve pos=-1
2016-10-28 11:50:01.931 LUA: Thermostat V-Bed-Stat Setpoint=17.5 Temp=20.4 Valve pos=-1
2016-10-28 11:50:01.931 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 11:50:01.931 LUA: Valve Z-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=0
2016-10-28 11:50:01.932 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_max2.lua: /home/linaro/domoticz/scripts/lua/script_time_max.lua:131: attempt to concatenate field '?' (a nil value)
2016-10-28 11:50:01.938 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua
so it only appears to get part way through the interrogation process.
And the heating script outputs
2016-10-28 11:50:49.279 LUA: *** Heating Script Output ***
2016-10-28 11:50:49.280 LUA:
2016-10-28 11:50:49.281 LUA:
2016-10-28 11:50:49.281 LUA: Number of valves open more than 50% is 0 valves
2016-10-28 11:50:49.281 LUA: Highest valve open value is 0 percent
2016-10-28 11:50:49.281 LUA: Lowest thermostat reading is 100 Centigrade
2016-10-28 11:50:49.281 LUA: Current state - Boiler is OFF
2016-10-28 11:50:49.281 LUA: PercentMax (0%) Boiler On value (50%) Boiler Off value (30)%
2016-10-28 11:50:49.281 LUA: Number of valves open more than 50% is 0 valves. Minimum valves setting 2
2016-10-28 11:50:49.281 LUA: Maximum open value 0% Override value 99%
2016-10-28 11:50:49.281 LUA: Test passed - Boiler is OFF
2016-10-28 11:50:49.282 LUA:
So no heat even though 2 valves are actually open 100%
I hope this makes sense to you
Thanks again
Sean
PS. I owe you a BIG beer :D
Posted: Friday 28 October 2016 13:28
by blackdog65
Ok,
now I have a full read
2016-10-28 12:24:00.878 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=19.6 Valve pos=-1
2016-10-28 12:24:00.878 LUA: Thermostat V-Bed-Stat Setpoint=17.5 Temp=20.4 Valve pos=-1
2016-10-28 12:24:00.878 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 12:24:00.879 LUA: Valve Z-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=0
2016-10-28 12:24:00.879 LUA: Valve V-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=35
2016-10-28 12:24:00.879 LUA: Valve Kitchen-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 12:24:00.879 LUA: Thermostat Kitchen-Stat Setpoint=20 Temp=19.1 Valve pos=-1
2016-10-28 12:24:00.880 LUA: Thermostat Z-Bed-Stat Setpoint=17.5 Temp=18.5 Valve pos=-1
2016-10-28 12:24:00.892 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua
2016-10-28 12:24:00.906 LUA:
2016-10-28 12:24:00.906 LUA: *** Heating Script Output ***
2016-10-28 12:24:00.907 LUA:
2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves
2016-10-28 12:24:00.907 LUA: Highest valve open value is 0 percent
2016-10-28 12:24:00.907 LUA: Lowest thermostat reading is 100 Centigrade
2016-10-28 12:24:00.907 LUA: Current state - Boiler is OFF
2016-10-28 12:24:00.907 LUA: PercentMax (0%) Boiler On value (50%) Boiler Off value (30)%
2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves. Minimum valves setting 2
2016-10-28 12:24:00.907 LUA: Maximum open value 0% Override value 99%
2016-10-28 12:24:00.907 LUA: Test passed - Boiler is OFF
the max script is seeing 2 valves open but the heating valve script isn't
Posted: Friday 28 October 2016 13:54
by mvzut
blackdog65 wrote:Ok,
Do you know why the MAX script gave an error at first, and then suddenly worked later?
I'll see if I can find why the heating valve script doesn't show the correct info, but that will probably be tonight (while enjoying a (your?) beer :))
Posted: Friday 28 October 2016 14:18
by blackdog65
mvzut wrote: Do you know why the MAX script gave an error at first, and then suddenly worked later?
It seems to be a "feature" :lol: as it will do it for 3 or 4 checks then run perfect for 24hrs. Would it happen if a device wasn't picked up? I have some very thick walls (800mm+) and massive chimney breasts that can be a nuisance at times, causing the EQ3 devices to skip a check occasionally.
However, many thanks so far! I'm sure there are more people watching this and hoping. Full heating automation is something of a "Holy Grail" for me as it will make the wife appreciate Domoticz more... and loosen the purse strings ;)
Sean :D
Posted: Friday 28 October 2016 15:04
by mvzut
Sean :D
Wow, do you live in a castle?
As you probably know, Domoticz doesn't directly communicate with the valves/thermostats but with the Cube, which in turn communicates with the valves. As far as I know, the Cube will always return a value, even if it briefly lost communication with the devices. It will then simply return the last known value. So I don't expect that this is the cause for the missed updates, although I could of course be wrong.
My wife also very much likes the fact that she now can turn on the heat in her study, even if the rest of the house is unheated. She didn't buy me a beer for it (yet), maybe I should show her your post Image.
Posted: Friday 28 October 2016 16:21
by blackdog65
not quite. It's a very big 400 year old farm house... they knew how to build them back then! :D
My wife has her desk in "The Library" which makes it sound more like the "Cluedo" house than a castle :lol:
But seriously, heating is a very wife friendly thing. Most of what I do looks like either magic or a waste of time to my wife... unless it keeps her warm or saves money... THEN she's interested :roll:
Posted: Friday 28 October 2016 19:51
by mvzut
blackdog65 wrote: the max script is seeing 2 valves open but the heating valve script isn't
I think I know what the problem is. There are two typos is the valve script. Please change
into
if (v == '-Rad') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
(i.e. remove the space after -Rad).
Similarly, change
into
if (v == '-Stat') then -- are the last five characters "-Stat"? If so we have an EQ-3 Thermostat
(i.e. remove the space after -Stat).
