Page 14 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Friday 25 January 2019 17:16
by Irek
Problem solved - wrong password.
Irek
Posted: Friday 25 January 2019 19:09
by fantom
Did You pass correct password in domoticz to Satel ?
What do You see in domoticz logs ?
Fantom
Posted: Friday 25 January 2019 19:10
by fantom
Irek wrote: Friday 25 January 2019 17:16
Irek
Posted: Friday 01 February 2019 20:12
by Irek
I've a question regarding my strange hardware configuration. There is one light (LED) to illuminate the steps of stairs in my house. There is no physical button to switch it on or off. The light is triggered by the PIR for 30 seconds and it's done by the Satel (not domoticz). I do not have a device of this light on my domoticz list. I only have a PIR which controls this light.
The PIR is mounted midway through the stairs, because it has to detect movement from above and below. Unfortunately, it detects movement from the lower floor too late.
I thought I could solve this problem by adding another wireless PIR, pointing down, but I do not have this light on my devices list, so I'll be not able to controll it.
Is there any way to trigger a PIR programmatically from domoticz (change the data from 1 to 3)?
I mean: can one PIR triggered by movement, trigger another PIR by some command?
Irek
Posted: Sunday 03 February 2019 11:07
by vinyl
Hello Everyone,
I have strange issue with Domoticz and Satel. Some time ago I've configured my Domoticz with Integra via ETHM1-Plus with 8 INT-IORS modules. Now added another 3 IORSs and found that all outputs are presented as Text. I can only change name from Setup->Devices tab. How to fix this?
Regards,
Pawel
Posted: Sunday 03 February 2019 12:08
by xury
Only outputs marked as "controllable" are added as switches.
Posted: Sunday 03 February 2019 16:14
by vinyl
Thanks. Can you help me find this setting? It's on Integra or Domoticz side?
Edit: "Fixed" by removing HW and adding again. Question: is there a possibility to force rereading outputs without deleting HW? I don't want to loose all my customizations.
Regards,
Pawel
Posted: Tuesday 05 February 2019 14:21
by fantom
Irek wrote: Friday 01 February 2019 20:12
Irek
You must add new switch in Satel Integra. Not in domoticz.
Fantom
Posted: Tuesday 05 February 2019 14:23
by fantom
vinyl wrote: Sunday 03 February 2019 11:07
Hello Everyone,
Regards,
Pawel
https://www.domoticz.com/forum/viewtopi ... =60#p56646
Fantom
by fantom
vinyl wrote: Sunday 03 February 2019 16:14
Regards,
Pawel
Disable/Enable HW
Fantom
Posted: Friday 22 February 2019 20:26
by Irek
Will domoticz cooperate with Satel Integra with ETHM-2 module?
Irek
Posted: Sunday 24 February 2019 11:54
by fantom
Posted: Monday 25 March 2019 18:31
by sidcom
Hello, I have a problem with the Integra 256 and Domoticz control panels, there are no control of outputs from 129 to 256. Domoticz correctly reads the version as Integra 256 Plus, but you can not control the outputs above 128. Do you know any way that it works properly?
Posted: Monday 25 March 2019 20:04
by fantom
Please paste info from logs, when integra started.
Fantom
Posted: Monday 25 March 2019 21:25
by sidcom
Here you are....
019-03-25 21:24:00.604 Status: Satel Integra: worker stopped
2019-03-25 21:24:00.605 Status: Satel Integra: Destroy instance
2019-03-25 21:24:00.605 Status: Satel Integra: Create instance
2019-03-25 21:24:00.606 Status: Satel Integra: connected to 192.168.1.200:7200
2019-03-25 21:24:00.608 Status: Satel Integra: Model Integra 256 Plus
2019-03-25 21:24:00.609 Status: Satel Integra: RTC 2019-03-25 21:24:01
2019-03-25 21:24:00.610 Status: Satel Integra: ETHM-1 ver. 2.05 2018-09-07
2019-03-25 21:24:00.610 Status: Satel Integra: worker started
Posted: Monday 25 March 2019 21:33
by fantom
I limit number of zones to 128, when "32 bit mode" is disabled (by ETHM ? by Integra ?)
Info form documentation:
0x7C INT-RS/ETHM-1 module version 0x7C + 12 bytes, e.g. for version 1.23 2012-05-27 (****):
11 bytes - '12320120527'
1 byte - .0 - 1 = module can serve 32 data bytes for zones/outputs
When module use 16 bit mode, only 128 zones is accesible.
I try add this info to domoticz (maybe in nearest weekend), and we will see what say your logs.
Fantom
Posted: Sunday 31 March 2019 16:21
by fantom
I pushed a commit with changes:
- fix for Integra 256 Plus
- possibility to change name for arm zones and arm info
Fantom
Posted: Monday 01 April 2019 15:56
by sidcom
Hi, thanks for the quick response, after the update it looks like this:
2019-04-01 15:50:26.507 Status: Satel Integra: Create instance
2019-04-01 15:50:26.508 Status: Satel Integra: connected to 192.168.1.200:7200
2019-04-01 15:50:26.511 Status: Satel Integra: Model Integra 256 Plus
2019-04-01 15:50:26.512 Status: Satel Integra: RTC 2019-04-01 15:50:26
2019-04-01 15:50:26.513 Status: Satel Integra: ETHM-1 ver. 2.05 2018-09-07 (32 bytes mode = false)
2019-04-01 15:50:26.513 Status: Satel Integra: worker started
it looks like it does not work in 32 bit mode, how can I change it?
Posted: Monday 01 April 2019 16:21
by fantom
I'm not sure
Maybe only ETHM-1 PLUS is supporting 32 bit mode ?
Pls write to Satel with question (
https://info.satel.pl/index.php?a=add).
I have Integra 64 + ETHM-1 PLUS and I have set this bit (but of corse i don't have 256 zones)
Fantom
Posted: Wednesday 03 April 2019 10:39
by sidcom
I received the following answer from Satel:
This byte is read from the module and informs whether the module can send 32 bytes of information in addition to 16.
A module that has this ability by default sends 16 bytes. To send 32 bytes the command should be completed with an additional byte, eg:
FE FE 00 D7 E2 FE 0D - will show violation of the first 128 zones of the control panel, even if the module supports 32 bytes of response
FE FE 00 01 50 8B FE 0D - will show violation of all 256 inputs.
