As far as I can see, in the second part, you should have AND instead of OR between the phones. As it is now, just one phone fulfils the condition and swithc is set to OFF. Next, it detects one phone and sets it to ON again.Martijn85 wrote:Hello everybody,
Maybe someone can help me out with this small issue. These are my blocks:
This works but when one phone is off and one phone is on the switch Iemand Thuis (Someone Home) is switching every second from on to off. When the second phone is coming online the switch keeps on like ik should. Why, when one phone is off, the switch is switching from on to off?
Blockly examples
mKotek
Re: Blockly examples
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
Martijn85
- Domoticz version: Stable
Thanks for the fast reply mKotek, it seems that did the trick! Thank you
Evelen
- Domoticz version: 2.4538
Re: SCRIPS - EVENT MANAGEMENT SAMPLE
how to set a if-do inside a if-do?Jochen wrote:Turn on a Light when open a door
This example will turn on a light when
1. A door is opening
2. It is between 22:00 and 07:00
A notification will be send everytime the is opening (00:00 - 24:00)
PS: The device Garagentor is the door (Garagentor = Garagedoor), the light is light is Licht Garage (Light Garage)
Yoshiii
Does the script work now? I cannot get my blinds to work...rtulp wrote:Thanks! That makes sense!elmortero wrote:I don't know about curtains but with blinds you use Off for open and On for closed
brianprak
Whats wrong with the following blockly i get an error 'then' expected near 'comparevariable'
- StanHD
Hi, I think the problem is in the Else if section where the "On & "Or" are incorrectly arranged. Try right clicking all of the "And" "Or" blocks and setting them as "External Inputs" It might be easier to see the logic then.
Python:- Broadlink RM2, Sonos
djgodlike
Re: RE: Re: Blockly examples
Compare with this picture very precisely!brianprak wrote:Whats wrong with the following blockly i get an error 'then' expected near 'comparevariable'
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
I have made my first blocky event.
Is it possible to test this, without waiting till the sunn is under? (simultion of a day)
The script is sending nog from 23:00 till 00:00 email, a lot of emails!! I just want one email that i am not at home. How to do this? Thanks for reading,
Mark
Mark
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
sweup
I have build a Blockly with a manual switch to toggle alarm on/off.
Unfortunately my alarm not working, when I set my alarm "on", the alarm goes off - I want to set blockly to "when alarm is on and sensor 1 register motion, I will be notified and siren should beep". What I have done wrong?
Im using Aeon labs sensor+Razberry
JayKudo
So I am trying to create a group dimmer and want to use blocky for it.
How can I detect a change in a (virtual) dimmer switch. So if the virtual switch changes value, than I want to set two real dimmers to that value.
Do I need to create a user var and save the current value and than compare the value with the virtual dimmer, or is there an easier method (or should I use blocky at all for this)?
assenzuid
I have created below blockly, but unfortunately it's not working.
assenzuid
Solved by using.assenzuid wrote:I have created below blockly, but unfortunately it's not working.
micbou
so what am I doing wrong here? this feels so straight forward but it doesn't work
hjvingen
Please try again with setting the group to "on" instead of "active",micbou wrote:so what am I doing wrong here? this feels so straight forward but it doesn't work
this works for me.
- Schermafbeelding 2016-06-05 om 20.51.35.png (13.36 KiB) Viewed 4894 times
micbou
Unfortunatly not working neither. Time doesn't seem to work in any scenario and Domoticz does show the correct time.
hjvingen
Do you get something in the log, like this?micbou wrote:Unfortunatly not working neither. Time doesn't seem to work in any scenario and Domoticz does show the correct time.
Do other events (not time related) work?
micbou
No, the log shows no activity from the event.
Only events that seem to work are those activating a device after a device has been activated (for example 'turn on left light when the right light is on)
hjvingen
That's strange, because the event system is working but somehow the time related triggers don't work.
in the editor there is also a selector which can be set to time or device, did you already try these?
micbou
Yup, tried that too...
micbou
and its weird because below does work
