Page 14 of 35
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Posted: Monday 14 October 2019 16:54
by Thorgal789
In path I have F:\Application\Python3\
2019-10-14 16:52:58.387 Status: PluginSystem: Started, Python version '3.7.4'.
I have win 7, have you checked same checkbox than in the tutorial ?
Posted: Monday 14 October 2019 17:01
by Plantje
In the default install settings the box for install for all users was already ticked. So I didn't see a need to do the custom install to check that box. Currently I am doing another install with doing the custom settings. See if that works
Posted: Monday 14 October 2019 17:40
by Plantje
O, if people (like me) would only read the manual....
Got it installed...
Now I do see this in the logging:
2019-10-14 17:38:49.427 Error: (deConz) Your pyton version miss requests library
2019-10-14 17:38:49.427 Error: (deConz) To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
Which is nice Linux code, but still...yet one step further
Posted: Monday 14 October 2019 17:50
by Thorgal789
Lol.
If you have pip installed
If you haven't it installed, I think it's a realy good thing to install it.
Posted: Monday 14 October 2019 19:08
by Plantje
Getting there... getting there...
So, that was the Windows variant of the command. Ran that in cmd prompt started as administrator...
And of course... to have a bridge you need two shores, so I had to start the deCONZ app as well (still need to start that with the computer)
One thing left now is this error message:
2019-10-14 19:07:08.492 Error: (deConz) Bad API KEY !
I believe I saw something on that one as well...
O yeah... and still no devices
Posted: Monday 14 October 2019 19:55
by Plantje
Yes, created API key and everything is running! Nice!
I've jotted everything down in a manual. If people are interested I'm willing to share
Posted: Monday 14 October 2019 20:51
by Thorgal789
Have fun ^^.
If it's a blog or a personal webpage I can put them on the first topic if you want.
Posted: Monday 14 October 2019 21:56
by Plantje
Thanks! Finally some ZigBee stuff! Less expensive, but still mesh network.
And no, I keep these notes in a manual in Word.
Posted: Thursday 17 October 2019 19:42
by Harald777
Hello there,
I am completely new to the Zigbee plugin.
Just installed the Raspbee board into my Raspberry PI with Domoticz running.
Installed all in according instructions on the
https://phoscon.de/en/raspbee website.
After installation and plugin activation I get the following errors:
2019-10-17 19:22:38.172 Error: (deCONZ) 'onHeartbeat' failed 'UnboundLocalError'.
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 841 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function onHeartbeat
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 337 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function onHeartbeat
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 394 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function ManageInit
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 737 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function SendCommand
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 755 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function UpdateBuffer
2019-10-17 19:22:38.172 Error: (deCONZ) ----> Line 894 in '/home/pi/domoticz/plugins/Domoticz-deCONZ/plugin.py', function MakeRequest
If this issue is already addressed somewhere please point me to that thread.
Any help is much appreciated.
Greetings,
Harald
Posted: Friday 18 October 2019 15:50
by Thorgal789
It's a request problem, I think there is a problem in the url, perhaps bad config in plugin setting.
Pls enable debug level "debug info only", just before theses lines you will have something like "making request .........." , can you show me this line.
This url need to work in a browser, if you want to make test.
Posted: Friday 18 October 2019 18:05
by Harald777
Thorgal789 wrote: Friday 18 October 2019 15:50
Thanks for your reply, much appreciated.
Switched debug on with following result:
2019-10-18 17:33:39.039 (deCONZ) onHeartbeat called
2019-10-18 17:33:39.039 (deCONZ) ### Initialisation > config
2019-10-18 17:33:39.040 (deCONZ) ### Request config
2019-10-18 17:33:39.040 (deCONZ) Send Command /api/1234567890/config/ with None (0 in buffer)
2019-10-18 17:33:39.040 (deCONZ) Making Request :
http://127.0.0.1:80/api/1234567890/config/ with params None
2019-10-18 17:33:39.053 Error: (deCONZ) 'onHeartbeat' failed 'UnboundLocalError'.
Greetings,
Harald
Posted: Friday 18 October 2019 18:33
by Plantje
I think your API is wrong as it is still the default. You need to run something to create an API key and then insert the API key in the configuration of the deCONZ hardware.
Should be somewhere here:
https://github.com/Smanar/Domoticz-deCONZ
Posted: Friday 18 October 2019 19:03
by Thorgal789
Yep.
For theses ones who have problems with API Key, there is a file called API_KEY.py to help you to create/delete/get list with command line, informations and commands inside the file. It can too give somes informations like your used websocket port. To have all commands or parameters just use:
python3 API_KEY.py
And for theses ones who don't know where to find the API key and don't wana use the tool:
https://dresden-elektronik.github.io/de ... uireapikey
Posted: Friday 18 October 2019 19:08
by Harald777
Thanks for the response.
Will have to do more investigation.
python3 API_KEY.py
returns with: python3: can't open file 'API_KEY.py': [Errno 2] No such file or directory
And the instructions on Dresden Elektronik are ????????????? for me (now).
Posted: Friday 18 October 2019 19:25
by Thorgal789
Lol, np the tool is easy to use, you need same parameters than in the plugin.
Go in the plugin directory
cd /home/pi/domoticz/plugins/Domoticz-deCONZ
You can have a different folder.
Posted: Saturday 19 October 2019 9:01
by 00luke
Hiya, this looks a great plugin, thank you!! Unfortunately I'm struggling to get it working - I think I'm being really stupid, but I can't for the life of me get Python to run for Domoticz on Ubuntu 14.04 headless server.. I've installed python3, including the lib packages:
luke@Holly:~/dev-domoticz/plugins$ python3 -V
Python 3.4.3
luke@Holly:~/dev-domoticz/plugins$ dpkg --get-selections | grep libpython
libpython-dev:i386 install
libpython-stdlib:i386 install
libpython2.7:i386 install
libpython2.7-dev:i386 install
libpython2.7-minimal:i386 install
libpython2.7-stdlib:i386 install
libpython3-dev:i386 install
libpython3-stdlib:i386 install
libpython3.4:i386 install
libpython3.4-dev:i386 install
libpython3.4-minimal:i386 install
libpython3.4-stdlib:i386 install
I've restarted Domoticz, but the Domoticz About screen just shows:
Version: 4.10726
Build Hash: be79a17
Compile Date: 2019-05-10 10:37:55
dzVents Version: 2.4.19
Python Version: None
And the log after startup shows:
2019-10-19 07:53:52.062 Status: Domoticz V4.10726 (c)2012-2019 GizMoCuz
2019-10-19 07:53:52.063 Status: Build Hash: be79a17, Date: 2019-05-10 10:37:55
2019-10-19 07:53:52.063 Status: Startup Path: /home/luke/dev-domoticz/
2019-10-19 07:53:52.083 Status: Philips Hue: Using default poll interval of 10 secs.
2019-10-19 07:53:52.087 Status: WebServer(HTTP) started on address: :: with port 8082
2019-10-19 07:53:52.090 Status: WebServer(SSL) started on address: :: with port 443
2019-10-19 07:53:52.091 Status: RxQueue: queue worker started...
2019-10-19 07:53:52.091 Status: TCPServer: shared server started...
2019-10-19 07:53:54.095 Status: Hardware Monitor: Started
2019-10-19 07:53:54.139 Status: RFXCOM: Worker started...
2019-10-19 07:53:54.139 Status: Philips Hue: Worker started...
2019-10-19 07:53:54.140 Status: EventSystem: reset all events...
2019-10-19 07:53:54.141 Status: EventSystem: reset all device statuses...
2019-10-19 07:53:54.152 Status: EventSystem: Queue thread started...
2019-10-19 07:53:54.152 Status: EventSystem: Started
2019-10-19 07:53:55.169 Status: RFXCOM: Using serial port: /dev/ttyUSB0
What am I doing wrong?! I've also installed the development libraries, for what it's worth! And I've enabled EventSystem in Settings --> Other.
Any hints / tips?
Posted: Saturday 19 October 2019 12:26
by Plantje
I don't see the plugins being started... So most likely it is not doing anything with the deCONZ plugin
Posted: Saturday 19 October 2019 12:46
by 00luke
No I thought that might be it. I'll post it in Bugs / Problems forum, thanks Plantje.
Posted: Saturday 19 October 2019 13:21
by Plantje
I think Thorgal789 will have some answers. He generally does. Has been very helpful in my first steps in Zigbee!
Posted: Saturday 19 October 2019 15:14
by Thorgal789
I realy don't see problem, your install seem fine.
Have you tried a more recent python version ? ATM I m on 3.7.4.
But the problem can come from domoticz directly.
