Page 14 of 14
Re: Zigbee2MQTT
Posted: Wednesday 13 April 2022 13:04
by heggink
mastadook wrote:Hi,
I try to ask my Question here, not open an extra Thread.
Since 2022.04.02 I have Problems with some of my Devices, not all, just some.
I tried to restart mosquito, restart the Raspi, restart Domoticz also and the zigbee2mqtt.
All running on the same Raspi and working fine since Weeks now.
What can i try to get them running again?
Anyone idea welcome
Did you check these devices in the zigbee2mqtt web interface? Try to reinclude them close to the zigbee stick.
In zigbee2mqtt, you can also look at your zigbee network and see if you have a connection or range issue.
Sent from my SM-G980F using Tapatalk
Re: Zigbee2MQTT
Posted: Wednesday 13 April 2022 13:50
by mastadook
Ok, thank you.
I just see, that all the Devices that did not update has N/A in LQI (that means no Link?!)
They where connected and working before, so I wonder why they lost connection.
I enabled Pairing and paired one of the Devices again without removing or something before.
And that worked, so I will try this with the other ones later today.
Let you know if it working or not
Re: Zigbee2MQTT
Posted: Wednesday 13 April 2022 14:20
by heggink
mastadook wrote: Wednesday 13 April 2022 13:50
Ok, thank you.
When you have re-paired the device successfully, have a look at both the LQI (signal strength) as well as the network topology to see where the device is connected and how many connections it has. If this is related to a connection issue then you may need to include a repeater (which can be a dummy wall plug) in your network.
Re: Zigbee2MQTT
Posted: Wednesday 20 April 2022 15:20
by mastadook
I buyed 3 additional Ikea Tradfri Wallsockets now.
I now have the Coordinator, 4 Wallsockets and one Ikea Router with USB Loading.
Now every Device looks like good LQI, let´s wait what the time brings
Re: Zigbee2MQTT
Posted: Thursday 04 May 2023 8:12
by draghip
I am not sure if this is the right topic and I couldn't find the same request elsewhere...
I have a raspberry with Python plugin v.3.2.0-beta and zigbee2mqtt v.1.28.4 (zStack12 20211115).
I assume it should be the latest release.
When I select "Allow new zigbee devices to join", a message pops up:
"New devices are not allowed to join the network",
but in fact I can pair new devices.
When I remove the tick, the same message appears.
With previous versions the message was different.
It is not a major issue, only annoying a bit
and I am not sure if it is an issue in my setup or a bug in the software.
Many thanks
