Page 14 of 20
Re: [120] opentherm gateway
Posted: Friday 20 February 2015 10:18
by roblom
pwhooftman wrote:Deshke wrote:Note that the OTGW only supports full-speed serial interfacing via the USb interface. If the Raspberry has a high speed USB interface, this will likely cause issues similar to your findings (it seems to work, but only for a limited time (minutes to hours). Same happens when using an TP-Link WR703N router to make the OTGW LAN/Wireless accisble. Solution is to put an inexpensive USB hub in between the OTGW and WR703N. Dont know is the same problem applies to a Raspberry. (reference:
http://www.domoticz.com/forum/viewtopic ... &start=180 )
I used the cheapest USB I could find at home and it seems that it is working now. Domoticz hasn't crashed yet and the data from the OTGW keeps updating.
According to the
RPi website.
GENERAL LIMITATIONS
The OTG hardware on Raspberry Pi has a simpler level of support for certain devices, which may present a higher software processing overhead. The Raspberry Pi also has only one root USB port: all traffic from all connected devices is funnelled down this bus, which operates at a maximum speed of 480mbps.
The USB specification defines three device speeds - Low, Full and High. Most mice and keyboards are Low-speed, most USB sound devices are Full-speed and most video devices (webcams or video capture) are High-speed.
Generally, there are no issues with connecting multiple High-speed USB devices to a Pi.
The software overhead incurred when talking to Low- and Full-speed devices means that there are soft limitations on the number of simultaneously active Low- and Full-speed devices. Small numbers of these types of devices connected to a Pi will cause no issues.
The Pi is full speed only splitted. That explains why I have trouble using the OTGW and the serial cable to my Inverter at the same time.
I only do not completely understand why the cheap hub solution works....
Posted: Wednesday 11 March 2015 19:13
by JeroenK
I've Domoticz installed on my nas. For the connection to the Opentherm Gateway I use a Raspberry Pi.
In Domoticz I see a lot of devices. Including my room setpoint. I add this one. It appears under utility. I checked the favorite icon, so now it's visible under dashboard. When I click on the flame-icon I see the history not the menu where I can change the temp.
Does anyone know the solution?
Posted: Thursday 12 March 2015 17:31
by trie
OTGW (fw: 4.2.3) with Domoticz (2.2313) does not work for me. It does not create any devices.
Log says (snippet):
2015-03-12 17:23:03.377 OTGW: Using serial port: /dev/ttyUSB1
2015-03-12 17:23:04.456 OTGW: SC: 17:23/4
2015-03-12 17:23:30.460 OTGW: SC: 17:23/4
2015-03-12 17:24:00.464 OTGW: SC: 17:24/4
2015-03-12 17:24:30.469 OTGW: SC: 17:24/4
2015-03-12 17:25:00.473 OTGW: SC: 17:25/4
2015-03-12 17:25:30.478 OTGW: SC: 17:25/4
Any ideas? My self written software works fine with this OTGW but I can't get it to work with Domoticz...
-- FIXED: "Allow new hardware devices" in Settings was disabled. After enabling the devices appeared immediately!
Re: [120] opentherm gateway [SOLVED]
Posted: Wednesday 18 March 2015 18:00
by jvandenbroek
Somehow I only get these kind of lines in the Domoticz log (continuously at the rate as shown here) and it won't update any OTGW devices:
2015-03-18 17:57:35.942 OTGW: T80000200
2015-03-18 17:57:35.942 OTGW: B40000200
2015-03-18 17:57:36.943 OTGW: T10010600
2015-03-18 17:57:36.943 OTGW: BD0010600
2015-03-18 17:57:37.944 OTGW: T00110000
2015-03-18 17:57:37.944 OTGW: BC0110000
2015-03-18 17:57:38.945 OTGW: T80190000
2015-03-18 17:57:38.945 OTGW: BC01926DE
2015-03-18 17:57:39.946 OTGW: T001B0000
2015-03-18 17:57:39.946 OTGW: B601B0000
2015-03-18 17:57:40.947 OTGW: T80000200
2015-03-18 17:57:40.949 OTGW: B40000200
2015-03-18 17:57:41.950 OTGW: T10010600
2015-03-18 17:57:41.950 OTGW: BD0010600
2015-03-18 17:57:42.951 OTGW: T00110000
2015-03-18 17:57:42.951 OTGW: BC0110000
2015-03-18 17:57:43.952 OTGW: T80190000
2015-03-18 17:57:43.952 OTGW: BC01926DE
This has worked before, I've only changed the serial connection with an ESP8266 directly connected to it. However, otmonitor works fine and does get valid values from the boiler over TCP, so there must be something wrong in Domoticz. Restarted/rebooted the system, no luck. Any ideas? Running the latest beta of Domoticz and OTGW 4.2.3. Thanks!
- SOLVED -
I figured out that I couldn't send any data to OTGW, only retrieve. Some reference voltage wasn't correct, after fixing this, all is fine!
Posted: Thursday 04 June 2015 10:15
by Rodio
How did you do this?
I've got the same problem, see a lot in onfo in de log, but no data in Domoticz.
I use a NAS with USB-OTGW.
Posted: Thursday 04 June 2015 10:49
by jvandenbroek
First you should try disabling OTGW in Domoticz and connect to it with a serial program (e.g. minicom). If you see the same output, try sending 'PS=1' , which should give a summary of values on one line. If that works, than all is fine with and somehow Domoticz isn't communication well. Maybe removing and re-adding it will help. Also make sure no other app is using the serial at the same time.
I don't think you should have to change the voltage reference, I had to because I'm using the same power supply of OTGW for the ESP8266 (which unfortunately doesn't work stable yet, because of some excessive current bursts this device generates).
Posted: Thursday 04 June 2015 11:19
by Rodio
Ok, thanks.
I know the OTGW is working, because the OTmonitor is giving the info.
I'm gonna try it and keep you posted.
Posted: Saturday 20 June 2015 11:27
by Rodio
It took sometime, busybusybusy
I tried your suggestions, with PS=1 I get useful info: tapwater temp etc.
If I connect the OTGW to my laptop and start OTmonitor I get all the info I want, so the OTGW is working.
Uninstalled Domoticz, install, old version, older version, same problem every time.
I tried the onboard USB2 and USB3 of my NAS, same problem.
I'm gonna borrow a powered USB2 hub tomorrow.
Posted: Friday 10 July 2015 20:09
by hneel
I have setup a slave RPi connected with opentherm. (My master device is a RPi too). I see the devices on the slave and I can share them on the master.
However, when I change the setpoint on the master, a new thermostat device with the same ID will be created on the slave. They have different Idx numbers, though. This way I can't controll the setpoint from my master device, but only from the slave.
Posted: Saturday 11 July 2015 19:35
by franzelare
I have the same issue, I have the opentherm gateway to a slave Pi and when I set a temperature from the slave, all works fine
when I set a tempetature on the master I see in the log file: "Sending SetPoint to device...."
on my slave I see the setpoint coming in: "(OpenTherm) Thermostat (Unknown)"
but my slave creates a new device with a new idx and doesn't change my thermostat setpoint
I think it can be solved with a lua script using otherdevices_lastupdate when you add the new idx that is generated when sending a new temperature from the master and monitoring a status change of the second thermostat. use the new value to update the thermostat setpoint of the open therm gateway on the slave....
I will give it a try later and let you know!
Posted: Saturday 11 July 2015 21:40
by hneel
I have changed my configuration. Instead of working with master/slave, I have the 2nd rpi set up as a LAN interface for the OTGW. I have installed ser2net and it works fine.
I only have trouble accessing the own webserver of the OTGW but that's an unrelated issue.
All devices are now directly visible in Domoticz.
Posted: Wednesday 15 July 2015 21:08
by franzelare
I solved the issue to add the setpoint sent by the slave and named it WoonkamerSetpoint
than I run a lua script named script_device_WoonTempNew
the setpoint of my opentherm gateway is at Idx 22 so I need to transfer the new setpoint 'WoonkamerSetpoint' to Idx 22 with there is an update:
if devicechanged['WoonTempNew'] then
current = otherdevices_svalues['WoonkamerSetpoint']
new = otherdevices_svalues['WoonTempNew']
-- print ('huidig:' .. current)
-- print ('new:' .. new)
set = "22|0|" .. new
-- print ('set:' .. set)
commandArray['UpdateDevice'] = '22|0|' .. new
-- commandArray['Tempchange'] = 'on'
Posted: Thursday 06 August 2015 21:38
by Rodio
Finally found some time.
Re-attached the USB and guess what? now he's working, got feedback
Just shoot me, I've tried this many times, and now ......
Mixed feelings, glad its working, but for how long......
Anyway, just enjoy the moment, and see what we can do now with it
Posted: Wednesday 12 August 2015 12:52
by jvandenbroek
I've also struggled with it in the beginning, especially when switching between otgw monitor and domoticz things were not working as expected. Good to hear it works for you now
Posted: Friday 14 August 2015 14:41
by Rodio
Thanks,
When the temperatuur drops a bit I'll start playing with the OTGW
GrR
Posted: Sunday 11 October 2015 18:17
by sincze
I have the following setup
- OT compatible CV
- TPLINK 703 (ser2net)
- OTGW.
This setup has been working for over a year untill recently.
The display of my room was completely blank.
So I installed OTMonitor on my windows machine directly attaching the OTGW to the USB port.
This system runs without a problem for over a week.
Now back to setup: OTGW -> USB-HUB -> TP-LINK 703.
As soon as I open a minicom session it will start to run
However the display of the thermostat in the livingroom
shows an error.
I did not change anything on the TP-LINK
Ser2net.conf:
10001:raw:0:/dev/ttyUSB0:9600,NONE,1STOPBIT,8DATABITS
Minicom_conf
# Machine-generated file - use "minicom -s" to change parameters.
pu port /dev/ttyUSB0
pu baudrate 9600
pu bits 8
pu parity N
pu stopbits 1
First I thought Domoticz was at fault however as Domoticz is not using the serial connection & minicom also creates problems something else must be wrong.
As soon as I unplug the USB cord from the TPLINK (via the USB HUB) the display in the livingroom functions normally again.
Beats me
Suggestions??
Posted: Thursday 15 October 2015 22:53
by sincze
And suddenly it was working..
And after 4 days.... we have the same issue as described above.
Well beats me
Re: opentherm gateway
Posted: Monday 26 October 2015 16:31
by stingone
macaidwin wrote:I ordered an usb hub, so that I can connect the gateway to my raspberry.
I have already P1 meter and rfxcom connected to usb.
Then I can share the rpi with you. (later this week,I hope)
I have a Remeha Tzerra and a (buggy) iSense thermostat.
Running beta firmware 4.0a11.hex in the gateway.
I modified my gateway with 4 status LEDs (and a power LED) on the outside, using an 8 display.
P.s. My OTgateway is on the second floor, next to the boiler. My Pi is on ground level, next to the energie meters. I used an UTP connection (3wires) between the OTgateway and the USB connector. That is working fine.
I noticed that I had to connect the USB to the raspberry and then restart the OTgateway.
How can i connect the leds / display to the 5 pins on the board???
Posted: Monday 26 October 2015 16:38
by sincze
Nice.
For our soldering heroes maybe have a look ath
http://otgw.tclcode.com/peripherals.html
Posted: Saturday 31 October 2015 19:48
by hneel
jvandenbroek wrote:Somehow I only get these kind of lines in the Domoticz log (continuously at the rate as shown here) and it won't update any OTGW devices:
I got the same today after restarting the device. My solution was to just recycle the device.
But I have another problem. I have linked my OTGW to my network with a raspberry pi running ser2net and including a usb wifi module. This has run fine for months, but recently it is getting instable. Now after just a couple of days, it will stop sending data. In those cases I can still log in to the device.
I've tried the command "sudo service ser2net restart", but this has no effect. Rebooting helps, but like I said, only for a couple of days.
This is the (relevant) contents of my ser2net.conf file
BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
1001:raw:0:/dev/ttyUSB0:9600 8DATABITS NONE 1STOPBIT banner
What could be the problem here?
