Dashticz - Feature Requests
Locked
Derik
Re: Dashticz - Feature Requests
Post by Derik »
naitsirhc wrote: Tuesday 13 February 2018 18:50 this worked for me :D
https://api.buienradar.nl/image/1.0/Rad ... =0&forc=48
Please how do you do this?
naitsirhc
Post by naitsirhc »
ehm googled a bit and hit (by accident) the right search criteria.
Put it in Dashticz custom.js. Adapted the number behind hist and presto there you go
Last edited by naitsirhc on Tuesday 13 February 2018 22:43, edited 1 time in total.
Und Tschjuß
Derik
Post by Derik »
naitsirhc wrote: Tuesday 13 February 2018 22:38 ehm googled a bit and hit (by accident) the right search criteria.
Put it in Dashticz custom.js. Adapted the unit behind hist and presto
Where do you place it??
Pleace a screendump..xxx
naitsirhc
Post by naitsirhc »
you mean:
in config.js?
Und Tschjuß
Derik
Post by Derik »
mm yepp
please share the link in the code option i still get errors..
naitsirhc
Post by naitsirhc »
@Derik
Send PM
Und Tschjuß
norrland
Post by norrland »
Looks like support for the type "Door Lock" is missing.
States are Locked and Unlocked.
Now it is handled the same way as "Door Contact" which is a completely different thing (a sensor rather than a lock).
This is how the device info looks like.
   "ActTime" : 1519415468,
   "AstrTwilightEnd" : "19:26",
   "AstrTwilightStart" : "04:43",
   "CivTwilightEnd" : "17:41",
   "CivTwilightStart" : "06:27",
   "DayLength" : "09:42",
   "NautTwilightEnd" : "18:33",
   "NautTwilightStart" : "05:35",
   "ServerTime" : "2018-02-23 20:51:08",
   "SunAtSouth" : "12:05",
   "Sunrise" : "07:13",
   "Sunset" : "16:55",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Locked",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 1,
         "HardwareName" : "ZStick",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00002801",
         "Image" : "Light",
         "InternalState" : "Locked",
         "IsSubDevice" : false,
         "LastUpdate" : "2018-02-23 20:49:57",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Garagedörren",
         "Notifications" : "true",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Locked",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Door Lock",
         "SwitchTypeVal" : 19,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "door",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "260"
   "status" : "OK",
   "title" : "Devices"
nosehook
Post by nosehook »
Hoi Rob,
First of all, I love Dashticz so far!
What I was wondering:
1) Is it possible to use google to calculate the (car based) commute time at present to work? I generally use Dashticz in the morning when I wake up and this would make me quite happy, since I work at irregular times.
2) traffic jams/accidents that have happened on the route to work.
3) check flight status (on time/delay) of a specific flight (pulled from google callendar)
Keep up the amazing work!
Regards,
Freek
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
Ingmar
Post by Ingmar »
nosehook wrote: Monday 05 March 2018 14:20 Hoi Rob,
Regards,
Freek
Hi Freek,
Maybe not exactly what you are looking for, but I am using the following code: It creates a button on your dashboard and when you click it it will show a popup with your route to work (or whatever you set it on) including the time required with traffic and alternative routes. Just like as if you planned your route with Google maps.
buttons.Route = {width:10, title: 'Route to work', url: 'https://www.google.com/maps/embed/v1/directions?key=INSERT_YOUR_GOOGLE_API&origin=STREETNAME+123,+1234+AB+CITYNAME,+COUNTRY&destination=STREETNAME+123,+1234+AB+CITYNAME'}
So for example:
buttons.Route = {width:10, title: 'Route to work', url: 'https://www.google.com/maps/embed/v1/directions?key=AIzaRyDPHISSPkc5g6Elcm4pWRTcGdDcfeGJtM&origin=Damrak+1,+1012+LG+Amsterdam&destination=Noordeinde+1,+2514+GA+Den+Haag'}
Obviously the API in the piece of code above is not my API, i changed bits to make sure it doesn't work ;)
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
Derik
Post by Derik »
Ingmar wrote: Monday 05 March 2018 23:00
Regards,
Freek
Hi Freek,
So for example:
mm very great feature....
Cannot script self...unfort.......
Only perhaps is it possible place it in to a smal window like te buienradar option?
And when you tick on the smal window there come a pop up in a new lager window..
That pop up stops after x second ?
Looks great to me.
when this could be possible.
Ingmar
Post by Ingmar »
I can't script either, it's a matter of searching, reading, trying, etc. Maybe you should put some time into researching things yourself instead of only asking other people to stuff for you ;-)
Derik
Post by Derik »
Ingmar wrote: Monday 05 March 2018 23:36 I can't script either, it's a matter of searching, reading, trying, etc. Maybe you should put some time into researching things yourself instead of only asking other people to stuff for you ;-)
Thanks love U2
Only this name of this topic is.....
nosehook
Post by nosehook »
Regards,
Freek
Hi Freek,
So for example:
Got it working! Many thanks.
clubeddie
Post by clubeddie »
Regards,
Freek
You can take a look at this thread.
http://www.domoticz.com/forum/viewtopic ... it=Traffic
I use this in combination of a google Maps of my area (which can be easily inserted in dashticz).
So i can see in two blocks my travel time, delay in percentage and an overview of the area.
I also combined ut with my xiaomi gateway, so i can see on the light (green, orange, red) how many delay there is and if i have to eat my breakfast fast :lol:
tlkg
Domoticz version: 2021.1
Post by tlkg »
A way to disable screen swiping/sliding for use with tablets.
For example, when you have sliders on the first or other screens, for dimming lights, it becomes difficult to actually grab the dimming slider to move rather than the whole screen. Would be nice to be able to disable the sliding function and just navigate screens using the bottom buttons or buttons created to direct links to other screens.
Beschuitje
Post by Beschuitje »
A find my iphone/friends feature.
Maybe with a map from GM lat. long.
Apple uses two way verification so thats going to be a problem
jake
Post by jake »
Please add the option to the blocks to control the amount of digits. At the moment I calculate the outputs from several micro inverters together, to show the total power generation. It is displayed in Dashticz as 1250,00 W. I know this is how the info comes from Domoticz, but it would be nice to be able to shorten this display (in my case) to 1250 W. This would help as well to keep the whole text on 1 line.
aiolos
Domoticz version: stable
Post by aiolos »
jake wrote: Friday 23 March 2018 19:44 Please add the option to the blocks to control the amount of digits. At the moment I calculate the outputs from several micro inverters together, to show the total power generation. It is displayed in Dashticz as 1250,00 W. I know this is how the info comes from Domoticz, but it would be nice to be able to shorten this display (in my case) to 1250 W. This would help as well to keep the whole text on 1 line.
You can try the (undocumented) 'units' configuration option:
config['units'] = {
    names: {
        kwh: 'kWh',
        watt: 'W',
    decimals: {
        kwh: 2,
        watt: 0,
    separators: {
        decimal: ',',
        thousands: '.'
Contributor to Dashticz
More on my Github profile
jake
Post by jake »
config['units'] = {
    names: {
        kwh: 'kWh',
        watt: 'W',
    decimals: {
        kwh: 2,
        watt: 0,
    separators: {
        decimal: ',',
        thousands: '.'
Thanks this works for most of the electrical sensors.
It would be good to put the opion in the Wiki.
The PV-output sensor, which publishes the daily energy harvest on the dashboard, doesn't comply with the setting, it keeps the 3 digits accuracy and uses a '.' instead of the intended ','
Is it possible to add m3 gas to it as well? I don't really care for the last dm3/liter on the dashboard. 1 digit would be plenty to display
aiolos
Post by aiolos »
jake wrote: Tuesday 27 March 2018 19:12
config['units'] = {
    names: {
        kwh: 'kWh',
        watt: 'W',
    decimals: {
        kwh: 2,
        watt: 0,
    separators: {
        decimal: ',',
        thousands: '.'
it could be added for other sensors too, they are handled a bit different, but it should be possible to work the same way. I'll have a look how this can be reached.
Locked
