Page 14 of 14
Re: [RELEASED] Python plugin to control Onkyo receivers
Posted: Tuesday 27 February 2018 17:10
by JimmyH1969
I know, but that's a domotic thingy. The max is 100%, but for a selector switch there should be no limit i think.
Posted: Monday 12 March 2018 15:52
by dwmw2
Posted: Monday 30 April 2018 22:03
by biggles
JimmyH1969 wrote: Sunday 18 February 2018 15:06
You can move the inputs up and down when you modify the selectorswitch. Moving the desired input up at a level below 100 should do the trick.
Hi Jimmy,
I found something else that is weird and i am unable to find a solution.
If i edit the ONKY Selector switch and i delete the value at the Selector Actions / Action (let say there is a value of 05) then i am unable to put in a new value as it is expecting to start with script of http and i am unable to put in any action value like a number.
Is there a workaround for this ?
Regards,
Biggles.
Posted: Wednesday 04 July 2018 11:29
by Varazir
Any update on this script ?
Posted: Wednesday 04 July 2018 15:57
by dwmw2
The 4.9700 stable release was made a week or two ago, containing built-in support for Onkyo amps.
Posted: Monday 09 July 2018 21:09
by Varazir
dwmw2 wrote: Wednesday 04 July 2018 15:57
yes I know, it was in the beta for some time and it works fine but I hate that I can't force connect.
It's hard set to 30 sec.
Posted: Monday 09 July 2018 21:33
by dwmw2
Varazir wrote: Monday 09 July 2018 21:09
Hm, that's the first time I've spotted that complaint. Why's it a problem? You can connect to the amp even if it's "off"... do you use a hard power switch with it?
It probably isn't hard to fix; I think it sends a multicast when it starts up (and periodically thereafter). But I didn't see this "complaint" until after the stable release happened so it'll be a while before it gets fixed in the next stable release...
Patches welcome
Posted: Thursday 12 July 2018 14:56
by Varazir
dwmw2 wrote: Monday 09 July 2018 21:33
Patches welcome
I turn off and on the power to my amp using my greewave switch. So the build in tries to connect every 30 sec.
So when I turn it on I have to wait up to 30 sec until I can turn it on. I wish I could use a script to force connect when the amp responds to ping.
Turn it on and unmute.
Posted: Thursday 12 July 2018 23:17
by ronald1977
Hi i have now update Domoticz to 4.9700 and I can see more of my Onkyo 609.
But I wish to switch with selector or button from radio broadcast, but I see in the log that he sees it, but there is nothing created in the hardware list.
Must I make a script or is there a way around?
Posted: Monday 16 July 2018 10:00
by jake
ronald1977 wrote:Hi i have now update Domoticz to 4.9700 and I can see more of my Onkyo 609.
I assume you use the built in version for the Onkyo? That is not the same (topic) as this Python version.
Posted: Monday 05 November 2018 12:10
by silver323
Does somebody know why i get the following in my log:
2018-11-05 12:07:15.562 (Onkyo) Pushing 'onHeartbeatCallback' on to queue
2018-11-05 12:07:15.608 (Onkyo) Processing 'onHeartbeatCallback' message
2018-11-05 12:07:15.608 (Onkyo) Calling message handler 'onHeartbeat'.
2018-11-05 12:07:15.608 (Onkyo) onHeartbeat called
2018-11-05 12:07:15.609 (Onkyo) Checking if discovery data has been received
2018-11-05 12:07:15.709 (Onkyo) Sending UDP discovery packet
2018-11-05 12:07:15.710 (Onkyo) UDP Discovery packet send succesfully
Its repeats over and over. Can't get any devices..
My Onkyo is online.
Posted: Wednesday 07 November 2018 12:51
by jake
@jorgh, is there still a benefit for using this plugin versus the built in hardware within domoticz?
I use the NR535 receive.
Posted: Thursday 14 February 2019 10:39
by silver323
silver323 wrote: Monday 05 November 2018 12:10
My Onkyo is online.
Nobody?
Posted: Friday 15 February 2019 17:56
by jake
Is your Onkyo device supported by the plugin?
Posted: Friday 15 February 2019 22:37
by silver323
jake wrote: Friday 15 February 2019 17:56
Is there a way to check if my device is compatible with this script?
I didn't see any list which are supported
Posted: Saturday 16 February 2019 23:33
by jake
silver323 wrote:jake wrote: Friday 15 February 2019 17:56
I believe that all models after 2012? are supported. Back in this thread I read about accepting XML or not, defining how well the plugin works.
Posted: Sunday 17 February 2019 14:45
by silver323
jake wrote: Saturday 16 February 2019 23:33
I've got the TXNR609
For now i use the "Onkyo AV Receiver (LAN)" as default implemented in the domoticz.
Then I get the normal switches with on/off and volume but that's not working correct.
Most of the time the switch stays at Off. Doesn't see when it's on.
When the onkyo is really off Iget a lot of logs.
2019-02-21 07:08:45.824 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:09:18.944 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:09:52.064 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:10:25.184 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:10:58.304 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:11:31.424 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:12:04.544 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:12:37.664 Error: OnkyoAVTCP: Can not connect to: IP
2019-02-21 07:13:07.666 Error: OnkyoAVTCP: Can not connect to: IP
Does somebody know that?
Posted: Saturday 09 December 2023 13:45
by mvveelen
silver323 wrote: Sunday 17 February 2019 14:45
Same here.
I used to have a package installed on Buster, but now I moved to Bookworm, I can't install it and use the built-in Onkyo support. The volume switch works, the on-off switch doesn't recognise the right status. And I received several messages about the IP as mentioned above and that's just "ugly". If the IP isn't available, the status of the Power switch should be changed to "Off" and no error message should be in the log, right?
