Page 14 of 32
Re: Domoboard a New Dashboard using Domoticz as backend
Posted: Thursday 12 January 2017 14:59
by Awst6000
dutchdevil83 wrote:
1) Do you have true spelled with a capital T in your config? If you look into my config above you see a config which should work
Yes, but still no date without a click on the time.
Posted: Thursday 12 January 2017 15:05
by dutchdevil83
Routernl wrote:Looking good !
Did you manage to get the traffic working with Google maps ?I'm still struggling with that.
Have got it to work. You have to generate a API key and fill this in your configuration file :
[[domoboard]]
google_maps_api_key = yourkeyhere # Google Maps Embed API key
You also must activate your API key here :
https://console.developers.google.com/a ... w?project=
Posted: Thursday 12 January 2017 15:19
by Awst6000
dutchdevil83 wrote:Have got it to work. You have to generate a API key and fill this in your configuration file :
google_maps_api_key = yourkeyhere # Google Maps Embed API key[/code]
Yesterday I created an API key and filled it in, but nothing seems to happen in Domoboard.
Is there perhaps a screenshot of what I should get?
Txs
Posted: Thursday 12 January 2017 16:00
by SwordFish
I've been following this topic from the start and its looks great. When I have time i give it a try.
Is it also possible to add Google calendar to Domoboard?
Posted: Thursday 12 January 2017 16:12
by jossie67
I like the Domo dashboard a lot.
I try to make a new tab with deuren
[deur]
[[display_components]]
components = Deuren
[[Deuren]]
Voordeur = 1149, info
Achterdeur = 1156, info
I can see the tab Deuren, but there is no information in the tab.
What do i do wrong
Posted: Thursday 12 January 2017 16:35
by jhenrikb
Could you also zip your "templates" folder? I fixed some of my issues after seeing how your config file is, but my page looks really messed up. Huge spaces between Switches and Weather etc.
John
Posted: Thursday 12 January 2017 16:49
by dutchdevil83
jossie67 wrote:Hi,
[deur]
components = Deuren
[[Deuren]]
What do i do wrong
You have to charge the line components = Deuren to components = top_tiles[Deuren]
Posted: Thursday 12 January 2017 16:50
by dutchdevil83
jhenrikb wrote:Thanks
John
Can you post a screenshot? Don't charge anything in the templates folder. This isn't needed.
Posted: Thursday 12 January 2017 17:19
by blackdog65
Hi guys,
I'm trying to get Wunderground working but I get
Error occured during loading imports for the plugin wunderground: No module named geocoder
when I try to start it... any ideas?
Posted: Thursday 12 January 2017 17:24
by jhenrikb
Ah ok. I have only changed header texts to norwegian and Weather-country etc. Small things.
Thought you might had organized something in HTML design wise. I can post later after work.
I also get answp(don't remember exact name, but it's the file that comes with traffic plugin) error in putty when running Traffic. So I had to delete it in order to start it. That's why I thought maybe u changed something in the traffic.html
Last point is that is shows update available under time and date, but it doesn't update even I run in debug.
Thanks for your great help so far, kind of you.
Posted: Thursday 12 January 2017 17:45
by felix63
blackdog65 wrote:Hi guys,
by felix63
Posted: Thursday 12 January 2017 17:50
by dutchdevil83
jhenrikb wrote:Ah ok. I have only changed header texts to norwegian and Weather-country etc. Small things.
Had that problem too. Just open putty and do
in domoboard directory
Posted: Thursday 12 January 2017 18:35
by blackdog65
@felix63
many thanks... obvious when you see it
I doesn't show up on my dashboard though
Posted: Thursday 12 January 2017 19:21
by dutchdevil83
blackdog65 wrote:
@felix63
Check your config file and compare with the config i posted. Probaly you figure it out why it isn't showing...
Posted: Thursday 12 January 2017 20:24
by blackdog65
dutchdevil83 wrote:blackdog65 wrote:
@felix63
and
@dutchdevil83 as it was your config I was copying!
I have
[general_settings]
[[wunderground]]
api = xxxxxxxxxxxxxxxx
language = EN
Then further down
[dashboard]
components = top_tiles, switches[Switches], news, wunderground[forecast]
[[top_tiles]]
Sitting Room = 361, television
Kitchen = 372, cutlery
Z-Bedroom = 374, bed
V-Bedroom = 363, bed
S-Bedroom = 369, bed
Outside = 77, thermometer-full
[[switches]]
[[[Switches]]]
D-Gong = 56, pushon
SR_Main = 389, dimmer
[[wunderground]]
[[[forecast]]]
location = "Wisbech, GB"
[[news]]
rssfeed = http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/uk/rss.xml
but no forecast in my dashboard. I've removed
for now
by wez3
dutchdevil83 wrote:felix63 wrote:dutchdevil83 wrote:Looking at my pages i see that i don`t have the icons displayed in the top_tiles. Anyone knows why this isn`t loading? The icons on the right navbar is loading properly so i think the font file is correct.
I think my icons have disappeared from the top tiles. are you running development or master? It might be a bug?
i`m on develop. Trying to debug in chrome inspector but can`t get it to fix.
This one should be fixed:
https://github.com/wez3/domoboard/issues/71
Posted: Thursday 12 January 2017 20:47
by Sateetje
dutchdevil83 wrote:Sateetje wrote:My "afvalwijzer" on the left looks different. How do I get the nice icons?
Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?
No, no adblocker installed and on different browsers almost the same result (on IOS i've an icon at Plastic verpakkingen).
Posted: Thursday 12 January 2017 21:03
by dutchdevil83
@blackdog65
Can you try following link in your browser if jou get Json result back? (Fill in your API key)
http://api.wunderground.com/api/api_key ... sbech.json
Posted: Thursday 12 January 2017 21:07
by dutchdevil83
Sateetje wrote:dutchdevil83 wrote:Sateetje wrote:My "afvalwijzer" on the left looks different. How do I get the nice icons?
Mmm strange... you can check with Chrome Inspector tool for errors when loading the page. In Chrome press (CTRL+SHIFT+J) and check preserve log to follow loading trail. Also could be that you are missing some files in the afvalwijzer plug-in folder. You can try to copy the folder from github...
