EdwinK
Re: Dashticz doesn't work anymore
Post by EdwinK »
Duh... Maybe I should have installed the webstation first...
*feels stupid*
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Nice :)
htilburgs
Post by htilburgs »
Nice... Waiting for this... :D
Thanx!
Hardware:
htilburgs
Post by htilburgs »
Schermafbeelding 2017-07-12 om 23.30.45.png (129.53 KiB) Viewed 3068 times
Rob, the text is under the icon, instead of behind the icon like all the other blocks.
One other thing is the font, it's different from the default. Is this on purpose, or do I need to add custom.css information?
Can I also change the font-color (green is very dark with my blue background) through custom.css?
Hardware:
Derik
Post by Derik »
Dear All get my weather not working....
Is there someone that will test my api key:
 91950e7f510e4615
And a working WU station...
See no weather on my screen.
And it looks the key is running:
My config:
var _APIKEY_WUNDERGROUND  		= '91950e7f510e4615';
var _WEATHER_CITY 			= 'IGELDERL237';
var _WEATHER_CITYNAME 		= 'Nijmegen'; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
And:
columns[3] = {}
columns[3]['blocks'] = ['sunrise','currentweather_big','weather'];
columns[3]['width'] = 6;
The only thing see on my screen:
@ ROB, all the screens show a setting part....?
robgeerts
Post by robgeerts »
This will work:
var _WEATHER_CITY          = 'Nijmegen';
Settings is coming soon!
Derik
Post by Derik »
Fu**ck finally....
It works after 4 weeks... searching...
Thanks!!!!!
robgeerts
Post by robgeerts »
htilburgs wrote:Schermafbeelding 2017-07-12 om 23.30.45.png
Could you test latest beta?
You can override this css in custom.css:
.containslog .items .level0{ color:#c70626; }
.containslog .items .level1{ color:#067676; }
.containslog .items .level2{ color:#ffffff; }
.containslog .items .level0.popup{ color:#c70626; }
.containslog .items .level1.popup{ color:#067676; }
.containslog .items .level2.popup{ color:#727272; }
Derik
Post by Derik »
Is working:
Perhaps a option to enlarge the tile ?
robgeerts
Post by robgeerts »
Changed!
Before you could assign a background to a screen like:
screens[1]['background'] = 'bg9.jpg';
If you wanted to use your own images, you had to place them in the img-folder.
From now on (in BETA), you can place them in the custom-folder and use it like:
screens[1]['background'] = 'custom/bg9.jpg';
Derik
Post by Derik »
robgeerts wrote:Changed!
Perhaps possible to place the images in a separate map..
Think i get more images there. custom/images/ possible?
robgeerts
Post by robgeerts »
Thats already possible, create that folder and use:
screens[1]['background'] = 'custom/images/bg9.jpg';
Derik
Post by Derik »
Rob...
Did the trick wioth a images folder:
screens[1] = {}
screens[1]['background'] 		= 'bg1.jpg';
screens[1]['background_morning'] 	= 'custom/images/bg_morning_1.jpg';
screens[1]['background_noon'] 	= 'custom/images/bg_noon_1.jpg';
screens[1]['background_afternoon'] 	= 'custom/images/bg_afternoon_1.jpg';
screens[1]['background_night'] 	= 'custom/images/bg_night_1.jpg';
screens[1]['columns'] 		= [1]
screens[2] = {}
screens[2]['background'] 		= 'bg2.jpg';
screens[2]['background_morning'] 	= 'bg_morning.jpg';
screens[2]['background_noon'] 	= 'bg_noon.jpg';
screens[2]['background_afternoon'] 	= 'bg_afternoon.jpg';
screens[2]['background_night']	= 'bg_night.jpg';
screens[2]['columns'] 		= [4]
screens[3] = {}
screens[3]['background'] 		= 'bg3.jpg';
screens[3]['background_morning']	= 'custom/images/bg_morning_1.jpg';
screens[3]['background_noon']		= 'custom/images/bg_noon_1.jpg';
screens[3]['background_afternoon']	= 'custom/images/bg_afternoon_1.jpg';
screens[3]['background_night']	= 'custom/images/bg_night_1.jpg';
screens[3]['columns'] 		= [2,3]
screens[4] = {}
screens[4]['background'] 		= 'bg4.jpg';
screens[4]['background_morning']	= 'custom/images/bg_morning_1.jpg';
screens[4]['background_noon']		= 'custom/images/bg_noon_1.jpg';
screens[4]['background_afternoon']	= 'custom/images/bg_afternoon_1.jpg';
screens[4]['background_night']	= 'custom/images/bg_night_1.jpg';
screens[4]['columns'] 		= [5]
and here a re the images:
Did CTRL F5...
Only still see a black wallpaper:
robgeerts
Post by robgeerts »
AH, it wont work for the changing background based on time ;)
edit: Could you test latest beta?
Derik
Post by Derik »
Rob,
You are a Hero...
Works great.. [ for this part of the day ]
THANKS
Onrust
Domoticz version: 4.10717
Post by Onrust »
I'm getting following error when doing a git pull:
pi@raspberrypi:~/domoticz/www/dash $ git pull
Updating ade0b8c..c87ae9d
error: Your local changes to the following files would be overwritten by merge:
        js/main.js
Please, commit your changes or stash them before you can merge.
Aborting
@robgeerts, could this be due to the changes you made through Teamviewer? What should I do to fix this? Git noob here so not sure stashing or merging is what I want.
blacksn0w
Post by blacksn0w »
Onrust wrote:I'm getting following error when doing a git pull:
        js/main.js
Aborting
When the change was done in the repo too just delete js/main.js and do a git pull again.
Onrust
Post by Onrust »
Thnx, that worked!
stlaha2007
Specific sensor data P1 Smartmeter missing?
Post by stlaha2007 »
Hi there....
First @RobGeerts thumbs up for the exellent work on Dashticz v.2
Running Domoticz beta v3.7680 and Dashticz v2 beta (updated friday evening).
I'm not sure if it's a bug or a feature request...
The P1 SmartMeter is 'loaded' with several stats (totalling 6, power, usage today, usage total, return power, return today, return total). P1 Gas also has used today and total....
However i can't find the specific return values with 'IDX#_3', 'IDX#_4' etcetera.... Also P1 Gas only happens to have IDX# not 'IDX#_1' and 'IDX#_2'
It works for almost every sensor with multiple values, like Water or Solar system which are based on the RFXmeter or General (kWh).
Any suggestions, where to look, or does it need to be moved to Bug or Feature Request??
See my dump from main Domo attached....Image
Sent from my K00C using Tapatalk
robgeerts
Re: Specific sensor data P1 Smartmeter missing?
Post by robgeerts »
Could you send me your output of:
http://DOMOTICZ URL/json.htm?type=devices&filter=all&used=true&order=Name
Locked
