Events system thread (questions and feedback)
Tom23
Re: Events system feedback thread
Post by Tom23 »
First, sorry for my english, but i'm french.
I'm trying to make a lua time script to do twitter notification with the line command client TTytter.
When i launch manually a script like this:
t1 = os.date("%M")
t2 = t1
if t2 <= "57" then os.execute('/home/pi/ttytter/ttytter -status="test"')
--os.execute('sudo killall TTYtter')
print("Tweet envoye "..t1)
It's works fine and the message is post. But when domoticz launch the same script automatically, the ttytter's process run on 100%, dont post and dont stop. I must kill the process.
In the process list in htop i see two process:
-ttytter
-/home/pi/ttytter/ttytter -status="test"
I don't if it's normal.
Can you help me ?
Yihaaa
Post by Yihaaa »
I am trying to set up an event for automatic switching on some lights in my living room. I want when I enter the room between 06:00 and upto sunrise three lamps to go on. They have to switch on and stay on until it is sunrise.
But somehow it doesn't work, does somebody know what is wrong and how to correct this?
CopyCatz
Developer
Post by CopyCatz »
You can only do on for x minutes. How on earth is the system going to make sense of "sunrise minutes"?
Yihaaa
Post by Yihaaa »
Well I thought so actually, and hoped the system was kind of smart to know this.
Some other ideas to make sure that the lights are only switched on in the described time frame? And go off when sun rises?
CodeItAway
Post by CodeItAway »
I am trying to set the setpoint temperature on a OTGW using a blockly script but i keep getting a: Malformed action sequence! in the logs.
What am I doing wrong?
I also tried setting the value in a LUA script, but that isn't working either (with no errors).
ace2
Blocky problem
Post by ace2 »
I have a problem i have a switch that i always will have on,
Lets say the power go off then it shud turn this switch on even if i accidently turnd it off shall it turn it self on.
How do i do that whit blocky ?
SweetPants
Re: Blocky problem
Post by SweetPants »
Hmm, don't know if this is possible with Blockly
You can use 2 LUA scripts to do this.
script_time_always_on.lua (called every 60 sec) will turn on your light after start of domoticz
if (otherdevices['Lamp_2_Woonkamer'] == 'Off') then
commandArray['Lamp_2_Woonkamer'] = 'On'
script_device_always_on.lua (after device change) will turn your light on again if you turn if off
if (devicechanged['Lamp_2_Woonkamer'] == 'Off') then
Harry
mbliek
Re: Blocky problem
Post by mbliek »
It's not a problem. Just a question about how to do. Merged with the events feedback thread.
ace2
Re: Events system thread (questions and feedback)
Post by ace2 »
That was a nice one SweetPants. Thanks for that
But if i whil send a "on" comand every 10 min ?
gabou14
Post by gabou14 »
Hi !
I'd like to use external text to speech notification in the events using the blockly interface, but everytime I add a space in the url of the openURL action, it doesn't work.
I also tried with the characters encoded (%20), it does not seem to work either.
Am I doing something wrong ?
Thank ou very much !
simonrg
Domoticz version: 3.8807
Post by simonrg »
I think you need commandArray['UpdateDevice'] = ..... you can find an example of its usage for energy logging in the Wiki here - http://www.domoticz.com/wiki/Capturing_ ... ua_Scripts - commandArray['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy, not sure about exact format for humidity and temperature, but knowing the humidity and temperature ids I guess it should be a matter of just writting the values back to them.
simonrg
Post by simonrg »
Using commandArray['UpdateDevice'] to update the value, updates the device, so yes this modifies the otherdevices_lastupdate to the time / date at which the update occurs.
simonrg
Post by simonrg »
Strange, as you say for humidity this does not seem to work correctly as it does for energy meters.
I created a dummy humidity device 'DummyHumidity', then wrote a simple time test script - checking the web humidity display all seems to work fine, the humidity is change to 32% as set with 1 being it is comfortable, the last updated is always less than 1 minute ago as the time script is executed every minute and the devices pages shows the updated time.
However in the script I have 3 issues:
1. otherdevices_humidity['DummyHumidity'] returns nil, not the humidity value, what am I doing wrong?
2. otherdevices_svalues['DummyHumidity'] returns 50% always
3. otherdevices_lastupdate['DummyHumidity'] does not change and so is a time unrelated to that displayed on the web page.
-- ~/domoticz/scripts/lua/device_time_humidity.lua
print('Humidity Script')
hum4 = otherdevices_svalues['DummyHumidity']
-- hum4 = otherdevices_humidity['DummyHumidity']
print('Humidity '..hum4)
print(otherdevices_lastupdate['DummyHumidity'])
commandArray[1] = {['UpdateDevice'] = 417 .. "|32|" .. 1}
simonrg
Post by simonrg »
Without devicechanged_lastupdate ['devicename'], you can use a dummy switch which you switch on at the end of the script each time the script is called. Then before setting the switch you can use otherdevices_lastupdate ['dummy switch'] and so work out the time since the last switching. Have a look at http://www.domoticz.com/wiki/Capturing_ ... ua_Scripts where this concept is used to calculate energy used from power measurements.
panosnl
Post by panosnl »
Hi I just discovered the event interface and it is great.
I seem to have discovered a bug though:
When a block is disbled it gets nicely greyed out. However this block is still executed.
So the only way to diable a block is to completerly remov it.
Running v 1.1811 on raspberry
epierre
Post by epierre »
I have a virtual sensor for Pressure (Pressure type, not the composite Weatherunderground).
Using either otherdevices_barometer[Barometer] or otherdevices[Barometer] does not brings anything, any idea ? data are in the nvalue column...
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
leby
Post by leby »
Not sure if I should post in this or in the variable part but the challenge is a mix..
To avoid duplicate messages being sent in a PIR scenario I tried to set up a variable instead of a switch to block new event from triggering for x minutes. I realise that it will work with a switch but the variable would be e neater solution.
I have done a simplified scenario to show my question:
Now I would expect when triggered by the test switch that the variable would first be set to "1" and after 2 minutes be set to "0". unfortunately the second do never happens, if it would work this would be a very handy tool.
Should this work or have I used the blocks incorrect?
/lennart
CopyCatz
Developer
Post by CopyCatz »
that doesn't work.
leby
Post by leby »
To bad, guess that I can't use a string variable either with On and Off as alternative, I'll use a dummy switch instead or a script
thx for the info anyhow
/lennart
epierre
Post by epierre »
Is there a way to read the CO2 value ? otherdevices and _svalues does not report anything...
And more globally is it possible to have an otherdevices_nvalues[] in LUA so we could get all devices values with one or the other ?
thanks !
