Alexicz - FREE Domoticz to Alexa Integration
Re: Alexicz - FREE Domoticz to Alexa Integration
For the appliance, I found this terme in the pdf §9.1 : https://github.com/rimram31/dz_smarthom ... zskill.pdf
You're saying that "SwitchLight, TemperatureSensor, etc" are a compound of the v3 smart home from amazon, is there list somewhere?
Thanks for the log's link but it's empty. From the lambda function I can clic "show the logs in cloudwatch", it brings me to your page with an error saying the log group "/aws/lambda/alexicz" doesn't exist. I created this group but still empty.
Beside this, I got all the "metrics" with the number of error, duration etc, but no details on the errors.
Do I need to create a "stream log" or something else? (some binding missing?)
I still don't know how to print the logs, but I think I've found why it works randomly : firewall
Domoticz is installed on a synology nas. I configured the firewall on it to block all the traffic towards domoticz except from "france" (me) and "irlande" (aws).
If I remove irlande, it's 100% failure. It must be one of the IP aws is using from irlande which is not in the synology list of 'irlande'.
And of course, synology don't log what is rejected by the firewall
I canno't find the IP behind the countries in synology, but I've found all the ip ranges on aws : https://ip-ranges.amazonaws.com/ip-ranges.json
Irlande is on eu-west-1, so I filtered the json with : prefixes[?region=='eu-west-1']|[?service=='S3'].ip_prefix and tried the 3 ranges without success.
Here is the list of the "services", do you know which one is used by aws for the lambda functions? There is to much range for AMAZON and EC2 to try :/
"AMAZON",
"ROUTE53_HEALTHCHECKS",
"S3",
"DYNAMODB",
"EC2",
"CODEBUILD",
"GLOBALACCELERATOR",
"ROUTE53_HEALTHCHECKS_PUBLISHING",
"CLOUDFRONT",
"API_GATEWAY",
"CLOUD9",
"EC2_INSTANCE_CONNECT",
"WORKSPACES_GATEWAYS",
"AMAZON",
"S3",
"DYNAMODB",
"EC2",
"CODEBUILD",
"CLOUDFRONT",
"API_GATEWAY",
"CLOUD9",
- philchillbill
Ah, now I see where you got appliance from. applicandeId used to be the old name for endpointId which is what confused me, but in the PDF it's just a placeholder. Alexicz endpointIds are formed by adding the idx of the device in Domoticz to the class name of the category assigned during discovery. So e.g. a lamp with idx of 301 would be called SwitchLight-301 in Alexicz. To test that device in the console, you would use that specific endpointId instead of the Appliance-001 placeholder.Skwi wrote: Tuesday 12 May 2020 20:28 For the appliance, I found this terme in the pdf §9.1 : https://github.com/rimram31/dz_smarthom ... zskill.pdf
You really need to look at the JSON response from Domoticz in my post above and ask yourself how each device would walk through the discovery code in DomoticzHandler.py. I completely re-wrote the discovery code based on how I wanted things handled. That's the advantage of having the source code - it's no longer a black box so you can figure out its exact workings, plus you can tailor it to your needs.
Last edited by philchillbill on Wednesday 13 May 2020 9:39, edited 1 time in total.
- philchillbill
You would normally see that list in Cloudwatch logs in the Discovery response which would show the JSON returned to Alexa upon finishing discovery. They will be the "endpointId" parameters in the JSON.Skwi wrote: Tuesday 12 May 2020 10:29 Hi, I can now test from the lambda function. Si I could try from the aws to get the logs when the problem occurs.
Reading this thread I found that for a switch I must declare endpointID = "SwitchLight-idx"
In the pdf it's written we have to change the 'appliance-001' into "SwitchLight-Domoticz IDX", and I read it as "the idx of my switch light"
Is there a list of all the "appliances" (except in the DomoticzHandler.py)?
- philchillbill
Regarding the Cloudwatch logs, you need to have set up am IAM role giving permission for logging. See https://docs.aws.amazon.com/lambda/late ... -role.htmlSkwi wrote: Tuesday 12 May 2020 20:28 Thanks for the log's link but it's empty. From the lambda function I can clic "show the logs in cloudwatch", it brings me to your page with an error saying the log group "/aws/lambda/alexicz" doesn't exist. I created this group but still empty.
I am not the one with the discovery issues, it was a previous post.philchillbill wrote: Wednesday 13 May 2020 9:35You would normally see that list in Cloudwatch logs in the Discovery response which would show the JSON returned to Alexa upon finishing discovery. They will be the "endpointId" parameters in the JSON.Skwi wrote: Tuesday 12 May 2020 10:29 Hi, I can now test from the lambda function. Si I could try from the aws to get the logs when the problem occurs.
And big thank you for the logs, I followed the instructions you linked : https://docs.aws.amazon.com/lambda/late ... -role.html
I already had a role so I created added the permissions policies with no success. Then I created a new role (following Creating an execution role in the IAM console), then in the lambda function permission selected this new role (then save). And now I do have the logs <3
CloudWatch> CloudWatch Logs> Log groups>/aws/lambda/alexicz>2020/05/13/[$LATEST]01df8165006d4695ac3eb5e85e1314b5
But now that I know it is a firewall issue, I must find a way to know what ip range is missing in my rule (no logs on synology, and no ip in the aws logs :p)
- philchillbill
Take a look at https://ip-ranges.amazonaws.com/ip-ranges.json for a list of all the Amazon IPs in use at any time (it's in JSON format). And remember it updates daily. And then forget you ever thought about trying to whitelist AWS for your firewall
I've already found this json, and yes it's hard (impossible?) to whitelist all that is needed. Until now it worked at 99%, but now it's more like 70%.
Viewing this map : https://aws.amazon.com/about-aws/global-infrastructure/
I added "Great-Britain" in the firewall, maybe if aws irlande is not available it's scaled to try the closest datastore?
Wait & see..
Edit:
On this site it's written Regional Edge Caches Frankfurt, Germany; London, England for europe
Don't know exactly what that means but maybe it's what I'm searching for : if Irelande is not available, it's executed on england or germany (?)
Wait & see..
Edit:
Romel
Hi, is here someone who can discover zigbee devices ?
I am running zigbee2mqtt, I added description of light :"Alexa_Name:computer", but Alexicz cant discover it. Other items was discovered fine.
- philchillbill
Look at http://192.168.x.y:8080/json.htm?type=devices&rid=aaa (where aaa is the idx of your zigbee light) in your browser. Now ask yourself how that json will be interpreted within DomoticzHandler. What class of endpoint will it fall under?Romel wrote:Hi, is here someone who can discover zigbee devices ?
Romel
Hi plilchillbill and thank you for helping!philchillbill wrote: Wednesday 27 May 2020 22:15Look at http://192.168.x.y:8080/json.htm?type=devices&rid=aaa (where aaa is the idx of your zigbee light) in your browser. Now ask yourself how that json will be interpreted within DomoticzHandler. What class of endpoint will it fall under?Romel wrote:Hi, is here someone who can discover zigbee devices ?
IDx of zigbee light is 38 and here is json output:
"ActTime" : 1590649772,
"AstrTwilightEnd" : "23:51",
"AstrTwilightStart" : "01:45",
"CivTwilightEnd" : "21:25",
"CivTwilightStart" : "04:11",
"DayLength" : "15:52",
"NautTwilightEnd" : "22:21",
"NautTwilightStart" : "03:14",
"ServerTime" : "2020-05-28 09:09:32",
"SunAtSouth" : "12:48",
"Sunrise" : "04:52",
"Sunset" : "20:44",
"app_version" : "2020.2",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Color" : "{\"b\":0,\"cw\":0,\"g\":0,\"m\":2,\"r\":0,\"t\":127,\"ww\":0}",
"CustomImage" : 0,
"Data" : "Off",
"Description" : "Alexa_Name:computer",
"DimmerType" : "abs",
"Favorite" : 0,
"HardwareID" : 9,
"HardwareName" : "Zigbee2mqttRaspberryPi",
"HardwareType" : "Zigbee2MQTT",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "0x680ae2fffe160741_light",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2020-05-27 23:07:04",
"Level" : 1,
"LevelInt" : 1,
"MaxDimLevel" : 100,
"Name" : "sw-pc-desk",
"Notifications" : "false",
"PlanID" : "7",
"PlanIDs" :
7
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "WW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Color Switch",
"TypeImg" : "dimmer",
"Unit" : 11,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "279",
"YOffset" : "214",
"idx" : "38"
"status" : "OK",
"title" : "Devices"
}Here is another device working well:
"ActTime" : 1590650020,
"ServerTime" : "2020-05-28 09:13:40",
"Sunset" : "20:44",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "Alexa_Name: dining light",
"DimmerType" : "none",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveGroupCmd" : true,
"ID" : "00014056",
"Image" : "Light",
"LastUpdate" : "2020-05-27 23:07:02",
"Level" : 99,
"LevelInt" : 99,
"Name" : "sw-jidedlni-stul",
"PlanID" : "7",
"PlanIDs" :
7
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"XOffset" : "212",
"YOffset" : "172",
"idx" : "6"
"status" : "OK",
"title" : "Devices"
}- philchillbill
It should be caught by and the will be false so
meaning it is discoverable with the code in DomoticzHandler. Did you assign it a room ID?
if (devType.startswith('Lighting') or devType.startswith('Color Switch'))Code: Select all
if switchType == 'On/Off'Code: Select all
# Usual switch case
endpoint = SwitchLightAlexaEndpoint("SwitchLight-"+endpointId, friendlyName, description, manufacturerName)
endpoint.addDisplayCategories("LIGHT")
hasDimmer = deviceHasDimmer(device)
if (hasDimmer):
endpoint.addCapability(AlexaPercentageController(self, 'Alexa.PercentageController',[{'name': 'percentage'}]))
endpoint.addCapability(AlexaBrightnessController(self, 'Alexa.BrightnessController',[{'name': 'brightness'}]))
subType = device['SubType']
if (subType.startswith("RGB")):
endpoint.addCapability(AlexaColorController(self, 'Alexa.ColorController'))
endpoint.addCapability(AlexaColorTemperatureController(self, 'Alexa.ColorTemperatureController'))
Romel
Yes I assigned it to room - it should be:philchillbill wrote: Thursday 28 May 2020 10:05 meaning it is discoverable with the code in DomoticzHandler. Did you assign it a room ID?
"PlanID" : "7",Code: Select all
"ActTime" : 1590654864,
"ServerTime" : "2020-05-28 10:34:24",
"Sunset" : "20:44",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Color" : "{\"b\":255,\"cw\":0,\"g\":255,\"m\":3,\"r\":255,\"t\":0,\"ww\":0}",
"CustomImage" : 0,
"Data" : "Off",
"Description" : "Alexa_Name: kitchen",
"Favorite" : 1,
"HardwareID" : 3,
"ID" : "00082009",
"Image" : "Light",
"LastUpdate" : "2020-05-27 23:07:23",
"Level" : 51,
"LevelInt" : 51,
"Name" : "ledky kuchyn\u011b",
"PlanID" : "3",
"PlanIDs" :
3
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGBW",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "121",
"YOffset" : "237",
"idx" : "9"
"status" : "OK",
"title" : "Devices"
Romel
new scene can be discovered. But no new light discovered... I dont know why
Output of Configure test events - discovery in console.aws.amazon.com dont show new light. Light assigned to room same as other light woking.
- philchillbill
Take a look on Cloudwatch Logs at the Discovery response to see if it’s in the JSON being returned to Amazon. Sometimes devices are there but your account does not “accept” them. Amazon bug.Romel wrote:new scene can be discovered. But no new light discovered... I dont know why
Output of Configure test events - discovery in console.aws.amason.com dont show new light. Light assigned to room same as other light woking.
DrMacabre
- Domoticz version: 4.11590
Does anyone have an unresponsive skill since this morning ? Last night everything was fine and today, none of my devices are responding.
- philchillbill
No problems here. Did you check the cloud watch logs? Is your external Domoticz URL still valid?DrMacabre wrote:Hello,
DrMacabre
When using test on the function it says task timed out after 3 seconds. The domain is accessible and domoticz as well. When trying to look at the log group, it says log group doesn’t exist.philchillbill wrote: Saturday 06 June 2020 14:08No problems here. Did you check the cloud watch logs? Is your external Domoticz URL still valid?DrMacabre wrote:Hello,
DrMacabre
Nevermind, my domain is down for some unknown reason.
Romel
Hi, problem SOLVED by setting devices under Domoticz user defined in configdz.json in lambda ... ufffphilchillbill wrote: Wednesday 03 June 2020 20:16Take a look on Cloudwatch Logs at the Discovery response to see if it’s in the JSON being returned to Amazon. Sometimes devices are there but your account does not “accept” them. Amazon bug.Romel wrote:new scene can be discovered. But no new light discovered... I dont know why
