Page 13 of 15
Re: Low cost window/door sensor
Posted: Thursday 22 December 2016 20:20
by b_weijenberg
If you can use Ext2 firmware enable Lighting4 and X10 and the Kerui sensor will be decoded by the RFXtrx433E as a X10 security sensor.
Posted: Friday 23 December 2016 16:35
by Melissen
Hi, my sensor came in today. Tried to learn it AUTOMATIC, but no succes. (clone of a Kerui D026, but also a KR-D026)
Sensor lights when door is closed, opens or the switch on the back goes to 'unmounted' (protection if someone removes the switch)
In RFXmngr with Undec ON and only Lighting 4 ON, I get these messages:
How should I install this sensor? I already installed version 1012 on my RFXcom433E.
Posted: Friday 23 December 2016 17:13
by Melissen
Here another pic of the manual of the door-sensor.
Posted: Friday 23 December 2016 18:04
by Melissen
Already got it to work in Domoticz. Was maybe a problem with too may protocols on. Turned almost every protocol off and now it works...
Now finding out what the statusses are for programming the switch in LUA
Posted: Thursday 12 January 2017 18:15
by Melissen
Problem with the Kerui sensors is: the look the same, but they have different protocols.
Also if you have Rubicson enabled, the most sensors won't respond.
They are working on a fix (new firmware), but it's not perfect yet.
At least, I've got mine working with a lot of support. (thx Bert)
Posted: Friday 17 February 2017 13:54
by ArieKanarie
Hi Melissen,
Do they send andON signal only, or ON & OFF?
I am looking now for new sensors, but i want them to report ON/OFF
Posted: Saturday 18 February 2017 22:38
by sincze
ArieKanarie wrote:Hi Melissen,
+1 for this question indeed. :D
Posted: Friday 24 February 2017 9:07
by bernardstef
Hi, I can confirm, they send 3 different signals : On, off, and tamper (when dismounted from the door/wall)
Link : https://fr.aliexpress.com/item/High-gra ... 21054.html
Posted: Friday 24 February 2017 9:17
by ArieKanarie
"Désolé, cet article n'est plus disponible !" :-(
Posted: Friday 24 February 2017 12:46
by bernardstef
Oh I just see that .... I bought this set 2 weeks ago and received them this week ... from this listing.
Sorry ... But I can confirm they are the same as pictured by Melissen (same insides)
Posted: Thursday 02 March 2017 17:56
by ArieKanarie
Posted: Friday 03 March 2017 12:00
by jackderuiter
Just ordered these.. now hope they send different open close tamper signal that rflink van decode. They don't have the brand name on it..
@ariekanarie: did You manage to get the other two up and running? You reported that two sensors could not be paired with your system.
Posted: Friday 03 March 2017 14:15
by ArieKanarie
Yes, finally I succeeded, with help. (disabeling all other protocols was the trick)
But that was not with the sensors from my last post, that was with other doorsensors, which I wanna replace because they only send ON signal.
The ones from my last post should be the same as the ones from Bernardstef.
Posted: Friday 10 March 2017 8:00
by jackderuiter
Received them very fast. Using IT with rflink but receive continuous other id and unit. Not useable this way. Maybe i should contact rflink team...
Posted: Tuesday 14 March 2017 10:03
by ArieKanarie
That is a shame :-(
Posted: Tuesday 14 March 2017 12:16
by tontze
jackderuiter wrote:Received them very fast. Using IT with rflink but receive continuous other id and unit. Not useable this way. Maybe i should contact rflink team...
Sooo .. they are not working with rflink ?
Posted: Tuesday 14 March 2017 15:31
by jackderuiter
Not yet. Had a reply from rflink guys but it is not yet working. Should use learning mode but debug log shows IT is not showing correct responses.
Posted: Tuesday 02 May 2017 9:48
by ArieKanarie
Any luck yet?
Still looking for some nice door/window sensors with on/off signal..
Posted: Tuesday 02 May 2017 9:59
by scottydj2
I also also ordered these.
They worked out of the box with RFLink R46 firmware for me:
Unit 0 off for close
Unit 1 on for open
Unit 2 on for tamper alarm.
Commands seem to be sent 3 times each.
Cheers
Scott
Posted: Tuesday 02 May 2017 21:14
by jackderuiter
I did not get it up and running with these or at least similar looking sensors. Still gave me different main and unit ids. Rflink progamming command feature did not work for me.
Verstuurd vanaf mijn XT1562 met Tapatalk
