Aurora theme
blauwebuis
- Domoticz version: current
Re: Aurora theme
When you change these privacy settings this is actually noted in the log (to leave a trail when someone 'tampers' with the privacy settings).
And you can change these settings under the theme settings.
I could make it so that it is no longer a default, in order to limit confusion.
bdormael
Re: Aurora theme
Small issue, I’ve combined several battery sensors together, but somewhere in the middle the layout is not correct, see screenshot,
Verzonden vanaf mijn iPad met Tapatalk
blauwebuis
Re: Aurora theme
@bdormael: that's not a bug. You can merge at most 6 items. This is precisely because more won't fit in a highlighted item. In this case you could disable highlighted items.
A NEW VERSION HAS BEEN UPLOADED
FIXES
- Fixed bug with fluid display on pages other than the front page.
- Tried to put back a more optimal alignment of fluid items. Hopefully it won't break anything.
NEW FEATURES
- Change the value of text items on the utilities page simply by clicking on the text value.
FIXES
NEW FEATURES
jeanclic
Re: Aurora theme
Thanks for the new version ! I will test it asap
Send via Tapatalk
Send via Tapatalk
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
jeanclic
Re: Aurora theme
just tried it now !
looks better for empty room.
New feature doesn't seem to work... did I missed something or do I just have to click on a text item to change its text ?
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
bdormael
Re: Aurora theme
Thx, didn't think about that, I've added 3 highlighted items, then the battery sensors, all is fine now, thx again for the kind support, I love this theme@bdormael: that's not a bug. You can merge at most 6 items. This is precisely because more won't fit in a highlighted item. In this case you could disable highlighted items.
blauwebuis
Re: Aurora theme
@bdormael: glad to hear it!
@jeanclic: yes, just click on the text, and it will transform into an input field. Click outside it when you are done changing it, and the new value will be stored. This makes it a lot easier to, for example, set the text of a LED display via MySensors.
jeanclic
Re: Aurora theme
Yes it works ! Thanks for having explain it again !
Send via Tapatalk
Send via Tapatalk
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
Re: Aurora theme
for some strange reason I cant see any history in switch page, history is empty
jeanclic
Re: Aurora theme
please read the first post regarding privacy...
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
- emme
- Domoticz version: latest
Re: Aurora theme
uhm... it might be possible to replace the grouping character from "-" to "_" ?
(or at least have it selectable?)
I have a lot of devices with the same prefix and _ separated... and a lot of scripts using such syntax... and I was wondering if there would be a way to avoid changing all scripts
thanks
ciao
M
thanks
ciao
M
"We always done this way"
- Phantom
- Domoticz version: 4.11652
Re: Aurora theme
Great theme,
i have 1 issue with it, i am using the : https://www.domoticz.com/wiki/Plugins/BatteryLevel.html plugin to monitor the battery level of my pir.
But when i combine those it looks really weird:
My other question is, there is an option "Show three highlighted items" is it possible to make this adjustable with a slider or number because i would like to have more then 3.
Re: Aurora theme
Really great feature... this way could be posiblle to hack domoticz and make switch with input text field ? With little modified selector switch and editable text? (I have selector switch connected to python script that play custom song (i have to edit selector switch python command) ....jeanclic wrote: Tuesday 06 February 2018 7:18 just tried it now !
dagger38
- Domoticz version: 3.8153
Re: Aurora theme
BIGGG problems...
After installing the new design it was all white , so after reading , i cleared the app data cache in chrome.
Now i can bearly reatch the pi , sometimes , after a hard reset (unplug power
( ) the dashticz works , but the browser domoticz version gets :'browser cache refresh failed'...after that not even dashticz can reatch the pi?? 'deze site is niet bereikbaar' message...
After the hard reset i can also make contact whith the pi with my MOBAXTERM programm via ssl
What have i done wrong , and HOW TO FIX this...
HEELP
HEELP
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
kevinbiri
Re: Aurora theme
bonjour je viens d'installer le théme aurora aujourdhui mais j'ai un graphique qui ne va pas du tout j'ai éffacé le cache isntaller en ftp et en direct sur la raspberry mais rien n'y fair help me please
- Capture.PNG (69.04 KiB) Viewed 4707 times
CLEMENT99
- Domoticz version: BETA
Re: Aurora theme
Tu utilises quel navigateur ?kevinbiri wrote: Thursday 15 February 2018 9:44 bonjour je viens d'installer le théme aurora aujourdhui mais j'ai un graphique qui ne va pas du tout j'ai éffacé le cache isntaller en ftp et en direct sur la raspberry mais rien n'y fair help me please
Cletus
- Domoticz version: Latest
Re: Aurora theme
@kevinbiri Please note that this is an english speaking forum.
I have the same thing though, all white
This is our world now... the world of the electron and the switch, the beauty of the baud.
- EdwinK
Re: Aurora theme
Looks like the css isn't working properly. Maybe if you try installing the theme again
Cletus
Re: Aurora theme
Already tried that several times. No luck
olinek2
Re: Aurora theme
It seems to work properly only on beta release.
