Jos, hope this is oke.....
-- MijnAfvalWijzer huisvuil script: script_time_afvalwijzer.lua
ver="20191218-2100"
-- curl in os required!!
-- create dummy text device from dummy hardware with the name defined for: myAfvalDevice
-- Check the timing when to get a notification for each Afvaltype in the afvaltype_cfg table
-- Check forumtopic: https://www.domoticz.com/forum/viewtopic.php?f=61&t=17963
-- Check source updates: https://github.com/jvanderzande/mijnafvalwijzer
-- Link to WebSite: http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=6137LP&street=&huisnummer=15&toevoeging
myAfvalDevice = 'D.M.: Afval' -- The Text devicename in Domoticz
ShowNextEvents = 3 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode = '6668AW' -- Your postalcode
Huisnummer = '9' -- Your housnr
NotificationEmailAdress = "[email protected]" -- Specify your Email Address for the notifications. Leave empty to skip email notification
--NotificationEmailAdress = {"",""} -- Specify multiple Email Addresses for the notifications. Leave empty to skip email notification
Notificationsystem = "" -- Specify notification system eg "telegram/pushover/gcm/http/kodi/lms/nma/prowl/pushalot/pushbullet/pushsafer" leave empty to skip
-- Switch on Debugging in case of issues => set to true/false=======
debug = false
-- ### define format for text device
-- date options:
-- wd = weekday in 3 characters eg Zon;Maa;Din
-- dd = day in 2 digits eg 31
-- mm = month in 2 digits eg 01
-- mmm = month abbreviation in 3 characters eg : jan
-- yy = year in 2 digits eg 19
-- yyyy = year in 4 digits eg 2019
-- Afvaltype description options
-- sdesc = short afvaltype description from Website eg pmd
-- ldesc = Long afvaltype description from Website eg Plastic, Metalen en Drankkartons
textformat = "dd mmm sdesc"
-- ### define a line for each afvaltype_cfg retuned by the webrequest:
-- hour & min ==> the time the check needs to be performed and notification send when daysbefore is true
-- daysbefore ==> 0 means that the notification is send on the day of the planned garbage collection
-- daysbefore ==> X means that the notification is send X day(s) before the day of the planned garbage collection
-- reminder ==> Will send a second reminder after x hours. 0=no reminder (needs to be in the same day!)
-- text ==> define the text for the notification.
afvaltype_cfg = {
["restafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Grijze Container met Restafval"},
["gft"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Groene Container met Tuinafval"},
["pmd"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Oranje Container met Plastic en Metalen"},
["kca"] ={hour=19,min=01,daysbefore=1,reminder=0,text="kca"},
["kerstbomen"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Kerstbomen"},
["takken"] ={hour=19,min=01,daysbefore=1,reminder=0,text="snoeiafval"},
["papier"] ={hour=12,min=05,daysbefore=0,reminder=0,text="Blauwe Container met Oud papier"},
["plastic"] ={hour=19,min=01,daysbefore=1,reminder=0,text="plastic en drankenkartons"},
["grofvuil"] ={hour=19,min=01,daysbefore=1,reminder=0,text="grofvuil/oud ijzer"},
["tuinafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="tuinafval"},
-- Add any missing records above this line
["dummy1"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update for testing"},
["dummy2"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update of text sensor at night"}}
-- Define the Notification Title and body text. there are 3 variables you can include:
-- @DAG@ = Will be replaced by (vandaag/morgen/over x dagen)
-- @AFVALTYPE@ = Will be replaced by the AfvalType found on the internet
-- @AFVALTEXT@ = Will be replaced by the content of the text field for the specific AfvalType in afvaltype_cfg
-- @AFVALDATE@ = Will be replaced by the pickup date found on the internet
notificationtitle = '@AFW: @DAG@ de @AFVALTEXT@ aan de weg zetten!'
notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!'
--==== end of config ========================================================================================================================
-- General conversion tables
local nMON={"jan","feb","maa","apr","mei","jun","jul","aug","sep","okt","nov","dec"}
-- debug print
function dprint(text)
if debug then print("@AFW:"..text) end
-- try to load JSON default library
function loaddefaultjson()
if unexpected_condition then error() end
JSON = require "JSON" -- use generic JSON.lua
-- try to load JSON.lua from the domoticz setup
function loaddomoticzjson()
JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- Use default Domoticz JSON.lua
-- Load JSON.lua
if pcall(loaddefaultjson) then
dprint('Loaded default JSON.lua.' )
dprint('Failed loading default JSON.lua... trying /home/pi/domoticz/scripts/lua/JSON.lua' )
if pcall(loaddomoticzjson) then
dprint('Loaded JSON.lua.' )
print('@AFW Error: failed loading default JSON.lua and /home/pi/domoticz/scripts/lua/JSON.lua.')
print('@AFW Error: Please check your setup and try again.' )
return
-- round function
function Round(num, idp)
return tonumber(string.format("%." ..(idp or 0).. "f", num))
-- run program and return captured output
function os.capture(cmd, rep) -- execute command to get site
-- rep is nr of repeats if result is empty
local r = rep or 1
local s = ""
while ( s == "" and r > 0) do
r = r-1
local f = assert(io.popen(cmd, 'r'))
s = assert(f:read('*a'))
f:close()
if ( rep - r > 1 ) then
print("os.capture needed more than 1 call: " .. rep-r)
return s
-- get days between today and provided date
function getdaysdiff(i_afvaltype_date, stextformat)
local curTime = os.time{day=timenow.day,month=timenow.month,year=timenow.year}
-- check if date in variable i_afvaltype_date contains "vandaag" in stead of a valid date -> use today's date
afvalyear,afvalmonth,afvalday=i_afvaltype_date:match("(%d-)-(%d-)-(%d-)$")
if (afvalday == nil or afvalmonth == nil or afvalyear == nil) then
print ('@AFW Error: No valid date found in i_afvaltype_date: ' .. i_afvaltype_date)
return
local afvalTime = os.time{day=afvalday,month=afvalmonth,year=afvalyear}
local daysoftheweek={"Zon","Maa","Din","Woe","Don","Vri","Zat"}
local wday=daysoftheweek[os.date("*t", afvalTime).wday]
stextformat = stextformat:gsub('wd',wday)
stextformat = stextformat:gsub('dd',afvalday)
stextformat = stextformat:gsub('mmm',nMON[tonumber(afvalmonth)])
stextformat = stextformat:gsub('mm',afvalmonth)
stextformat = stextformat:gsub('yyyy',afvalyear)
stextformat = stextformat:gsub('yy',afvalyear:sub(3,4))
dprint("...gerd-> diff:"..Round(os.difftime(afvalTime, curTime)/86400,0).. " afvalyear:"..tostring(afvalyear).." afvalmonth:"..tostring(afvalmonth).." afvalday:"..tostring(afvalday)) --
-- return number of days diff
return stextformat, Round(os.difftime(afvalTime, curTime)/86400,0) -- 1 day = 86400 seconds
function notification(s_afvaltype,s_afvaltype_date,i_daysdifference)
dprint("...Noti-> i_daysdifference:"..tostring(i_daysdifference).." afvaltype_cfg[s_afvaltype].daysbefore:"..tostring(afvaltype_cfg[s_afvaltype].daysbefore).." hour:"..tostring(afvaltype_cfg[s_afvaltype].hour).." min:"..tostring(afvaltype_cfg[s_afvaltype].min))
if afvaltype_cfg[s_afvaltype] ~= nil
and (timenow.hour==afvaltype_cfg[s_afvaltype].hour or timenow.hour==afvaltype_cfg[s_afvaltype].hour+afvaltype_cfg[s_afvaltype].reminder)
and timenow.min==afvaltype_cfg[s_afvaltype].min
and i_daysdifference == afvaltype_cfg[s_afvaltype].daysbefore then
local dag = ""
if afvaltype_cfg[s_afvaltype].daysbefore == 0 then
dag = "vandaag"
elseif afvaltype_cfg[s_afvaltype].daysbefore == 1 then
dag = "morgen"
dag = "over " .. tostring(afvaltype_cfg[s_afvaltype].daysbefore) .. " dagen"
notificationtitle = notificationtitle:gsub('@DAG@',dag)
notificationtitle = notificationtitle:gsub('@AFVALTYPE@',s_afvaltype)
notificationtitle = notificationtitle:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtitle = notificationtitle:gsub('@AFVALDATE@',s_afvaltype_date)
notificationtext = notificationtext:gsub('@DAG@',dag)
notificationtext = notificationtext:gsub('@AFVALTYPE@',s_afvaltype)
notificationtext = notificationtext:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtext = notificationtext:gsub('@AFVALDATE@',s_afvaltype_date)
if type(NotificationEmailAdress) == 'table' then
for x,emailaddress in pairs(NotificationEmailAdress) do
if emailaddress ~= "" then
commandArray[x] = {['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. emailaddress}
dprint ('Notification Email send for ' .. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '#' .. emailaddress.."|")
if NotificationEmailAdress ~= "" then
commandArray['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress
dprint ('Notification Email send for ' .. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress.."|")
if Notificationsystem ~= "" then
commandArray['SendNotification']=notificationtitle .. '#' .. notificationtext .. '####'..Notificationsystem
dprint ('Notification send for '.. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '####'..Notificationsystem)
-- Do the actual update retrieving data from the website and processing it
function Perform_Update()
print('AfvalWijzer module start update (v'..ver..')')
dprint('=== web update ================================')
local sQuery = 'curl "https://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode='..Postcode..'&street=&huisnummer='..Huisnummer..'&toevoeging" 2>nul'
local handle=assert(io.popen(sQuery))
local jresponse = handle:read('*all')
handle:close()
if ( jresponse == "" ) then
print("@AFW Error: Empty result from curl command. Please check whether curl.exe is installed.")
return
if ( jresponse:sub(1,3) == "NOK" ) then
print("@AFW Error: Check your Postcode and Huisnummer as we get an NOK response.")
return
-- strip bulk data from "ophaaldagenNext" till the end, because this is causing some errors for some gemeentes
if ( jresponse:find('ophaaldagenNext') == nil ) then
print("@AFW Error: returned information does not contain the ophaaldagenNext section. stopping process.")
return
jresponse=jresponse:match('(.-),\"ophaaldagenNext\":')
jresponse=jresponse.."}}"
-- Decode JSON table
decoded_response = JSON:decode(jresponse)
rdata = decoded_response["data"]
if type(rdata) ~= "table" then
print("@AFW: Empty data table in JSON data... stopping execution.")
return
-- get the description records into rdesc to retrieve the long description
rdesc = rdata["langs"]
rdesc = rdesc["data"]
-- get the ophaaldagen tabel for the coming scheduled pickups
rdata = rdata["ophaaldagen"]
print("@AFW: Empty data.ophaaldagen table in JSON data... stopping execution.")
return
rdata = rdata["data"]
print("@AFW: Empty data.ophaaldagen.data table in JSON data... stopping execution.")
return
-- get the next number of ShowNextEvents
dprint("- start looping through received data -----------------------------------------------------------")
--~ for i = 1, ShowNextEvents do
local missingrecords=""
local txt=""
local txtcnt = 0
for i = 1, #rdata-1 do
record = rdata[i]
if type(record) == "table" then
wnameType = record["nameType"]
web_afvaltype = record["type"]
web_afvaldate = record["date"]
-- first match for each Type we save the date to capture the first next dates
if afvaltype_cfg[web_afvaltype] == nil then
print ('@AFW Error: Afvalsoort not defined in the "afvaltype_cfg" table for found Afvalsoort : ' .. web_afvaltype.." desc:"..wnameType)
missingrecords = missingrecords .. ' ["' .. web_afvaltype..'"] ={hour=19,min=22,daysbefore=1,reminder=0,text="'..wnameType..'"},\n'
afvaltype_cfg[web_afvaltype] = {hour=0,min=0,daysbefore=0,reminder=0,text="dummy"}
-- check whether the first nextdate for this afvaltype is already found to get only one next date per AfvalType
if afvaltype_cfg[web_afvaltype].nextdate == nil and txtcnt < ShowNextEvents then
-- get the long description from the JSON data
dprint("web_afvaltype:"..tostring(web_afvaltype).." web_afvaldate:"..tostring (web_afvaldate))
local stextformat = textformat
-- Get days diff
stextformat, daysdiffdev = getdaysdiff(web_afvaldate, stextformat)
-- When days is 0 or greater the date is today or in the future. Ignore any date in the past
if daysdiffdev == nil then
dprint ('Invalid date from web for : ' .. web_afvaltype..' date:'..web_afvaldate)
elseif daysdiffdev >= 0 then
-- Set the nextdate for this afvaltype
afvaltype_cfg[web_afvaltype].nextdate = web_afvaldate
-- fill the text with the next defined number of events
if txtcnt < ShowNextEvents then
stextformat = stextformat:gsub('ldesc',rdesc[web_afvaltype:upper().."_L"])
stextformat = stextformat:gsub('sdesc',web_afvaltype)
txt = txt..stextformat.."\r\n"
txtcnt = txtcnt + 1
notification(web_afvaltype,web_afvaldate,daysdiffdev) -- check notification for new found info
dprint("-End --------------------------------------------------------------------------------------------")
if missingrecords ~= "" then
print('#### -- start -- Add these records to local afvaltype_cfg = {')
print(missingrecords)
print('#### -- end ----------------------------')
if (cnt==0) then
print ('@AFW Error: No valid data found in returned webdata. skipping the rest of the logic.')
return
-- always update the domoticz device so one can see it is updating and when it was ran last.
print ('@AFW: Found:'..txt:gsub('\r\n', ' ; '))
if otherdevices_idx == nil or otherdevices_idx[myAfvalDevice] == nil then
print ("@AFW Error: Couldn't get the current data from Domoticz text device "..myAfvalDevice )
commandArray['UpdateDevice'] = otherdevices_idx[myAfvalDevice] .. '|0|' .. txt
if (otherdevices[myAfvalDevice] ~= txt) then
print ('@AFW: Update device from: \n'.. otherdevices[myAfvalDevice] .. '\n replace with:\n' .. txt)
print ('@AFW: No updated text for TxtDevice.')
-- End Functions =========================================================================
-- Start of logic ========================================================================
timenow = os.date("*t")
-- check for notification times and run update only when we are at one of these defined times
dprint('AfvalWijzer module start check')
local needupdate = false
for avtype,get in pairs(afvaltype_cfg) do
dprint("afvaltype_cfg :"..tostring(avtype)..";"..tostring(afvaltype_cfg[avtype].hour)..";"..tostring(afvaltype_cfg[avtype].min))
if (timenow.hour==afvaltype_cfg[avtype].hour
or timenow.hour==afvaltype_cfg[avtype].hour+afvaltype_cfg[avtype].reminder)
and timenow.min==afvaltype_cfg[avtype].min then
needupdate = true
-- Always update when debugging
if debug then needupdate = true end
-- get information from website, update device and send notification when required
if needupdate then
Perform_Update()
dprint("Scheduled time(s) not reached yet, so nothing to do!")
So where do i wrong..
