Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Re: Easy Domoticz to Alexa Integration
Hi Madgeni,
I am moving my production domoticz setup from Synology to RPI and one of the steps is to connect Controlicz.
I changed portforwarding target on port 443 to new system, added user and updated profile in Controlicz and started to rediscover devices.
message in logfile: Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)
If I manual login from a non local network with a username/password, domoticz ask me for a username / password and if I enter them the same username / password screen pops up again and again. I am pretty sure the username / Password I used are correct because I used copy/paste.
I managed to get one step further by adding 35.176.67.167 to the trusted network in the domoticz settings. With that setting Controlicz can enter the system to discover my devices.
Any clue what I am dong wrong ?
freijn
Domoticz version: Stable
Post by freijn »
What happens if you do a local https to your domotics ?
Madgeni
Post by Madgeni »
it doesn't seem like a Controlicz issue - does anyone have any experience with the Domoticz security model?
You did the right thing whitelisting the Controlicz source IP :)
freijn wrote: Tuesday 10 October 2017 9:14 What happens if you do a local https to your domotics ?
If I remove the trusted networks in domoticz and connect using port 443, browser complaints about untrusted certificate but when I continue domoticsz wants a user/password. The user/password for Controlicz (User rights) does not work but my user/password (Admin rights) does ???
Madgeni
Post by Madgeni »
Can you double check the password for the account? Controlicz doesn't demand any superior rights, I have an account on my Domoticz which is a user, with enough access to see the room plans, share devices and control devices
IDANIT
Post by IDANIT »
Is Controlicz down? In a morning everything works fine, but after I came back from work all my devices are offline. I did not change anything, no upgrades, nothing. Rediscovery not helping. Restarts Alexa and Domoticz too.
Madgeni
Post by Madgeni »
apologies - it's back. I did some green/blue testing which failed - lesson learned!
IDANIT
Post by IDANIT »
NP, THX.
Madgeni wrote: Tuesday 10 October 2017 12:26 Can you double check the password for the account? Controlicz doesn't demand any superior rights, I have an account on my Domoticz which is a user, with enough access to see the room plans, share devices and control devices
Double checked but only way Controlicz can access my domoticz is to have it on my whitelist. When I have all my other migration stuff done and stable I will revisit. Until then I'll live with the workaround :D
Thanks for your time !
hayman
Domoticz version: 3.8153
Post by hayman »
Know it's works very nice .and it's handle me light rgbcct V6 bridge very nice ....keep the good work.you deserve a beer
Madgeni
Post by Madgeni »
Thanks hayman - just glad to get there in the end! Feel free to leave a review on Amazon :)
hayman
Post by hayman »
I've done already ....is there some things change ,sinds today can't change color on milight ...but brightness level work and on/off work but changing color not????
Any idea???
Madgeni
Post by Madgeni »
weird - can you try again?
Alcloud
Post by Alcloud »
same in Germany, can't change color on milight
hayman
Post by hayman »
Know it's working with some times device not responding???
Madgeni
Post by Madgeni »
how about now?
Alcloud
Post by Alcloud »
now, when i say "set bedroom light to "color", alexa turns light off
Madgeni
Post by Madgeni »
that's not ideal! I'm on it
hayman
Post by hayman »
Here is working okey
Madgeni
Post by Madgeni »
ok wait. Hayman - are you using amazon.com?
AlCloud - are you using amazon.co.uk?
