Xavier82 wrote: Saturday 06 January 2018 20:28
I also use the Domoticz V3.8153 (on Synology).
I use the "Onkyo AV Receiver (LAN)" as default implemented in this version.
After entering correct settings (IP-adres of my Onkyo TX-NR414 (PRE-NRI) and port (60128) ).
I get the same:
2018-01-05 20:22:45.261 OnkyoAVTCP: Send PWRQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send MVLQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send ZPWQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send ZVLQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send SLIQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-05 20:22:46.262 OnkyoAVTCP: Packet received: 8 PWR01
2018-01-05 20:22:46.263 OnkyoAVTCP: Packet received: 8 MVL37
2018-01-05 20:22:46.264 OnkyoAVTCP: Packet received: 8 SLI23
2018-01-05 20:22:46.264 OnkyoAVTCP: Packet received: 8 ZPW00
2018-01-05 20:22:46.265 OnkyoAVTCP: Packet received: 9 ZVLN/A
2018-01-05 20:22:46.279 (Onkyo Receiver) Light/Switch (Onkyo Power)
2018-01-05 20:22:46.283 (Onkyo Receiver) Light/Switch (Zone 2 power)
What I did to get the switches in Domitcz is simply:
1. In Domoticz go to setup and make sure Domoticz is accepting new hardware/sensors.
2. Go to your Onkyo amplifier and put it on.
3. Now simply press 1 by 1 (one after each other) all the functions like Cab/sat/ Dvd/FM/USB/NET/whatever.
4. Turn the volume up/down for a bit.
5. Go back to Domoticz and now check your logg, you can now see that Domoticz received data.
6. Go in Domoticz to the Devices and Add the new devices to the switches.
7. Done
I hope I can help some people with this information.
Regards,
Xavier
Till step 5 it goes good
, I can see in the log that he receives the other inputs.
But then by Devices I don't see the devices? Is there another solution?
This is the log.
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 8 SLI10
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:08.478 OnkyoAVTCP: Packet received: 8 LMD84
2018-01-08 18:11:08.478 OnkyoAVTCP: Packet received: 8 SLI00
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 8 SLI01
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 8 LMD89
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 8 SLI02
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:15.480 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:15.480 OnkyoAVTCP: Packet received: 8 SLI05
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:17.481 OnkyoAVTCP: Packet received: 8 SLI03
2018-01-08 18:11:18.481 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 8 SLI24
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 11 TUN09470
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 8 LMD84
2018-01-08 18:11:21.483 OnkyoAVTCP: Packet received: 8 SLI23
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 31 NLTF300000000070000FFFF00NET
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 30 NLSU0-vTuner Internet Radio
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 31 NLSU1-Last.fm Internet Radio
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 16 NLSU2-Napster
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 16 NLSU3-Spotify
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 30 NLSU4-AUPEO! PERSONAL RADIO
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 21 NLSU5-My Favorites
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 13 NLSU6-DLNA
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 8 LMD13
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 8 SLI2B
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:27.484 OnkyoAVTCP: Packet received: 8 SLI40
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 8 SLI29
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 8 SLI24
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 11 TUN09470
2018-01-08 18:11:37.487 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:37.488 OnkyoAVTCP: Packet received: 8 MVL2D
2018-01-08 18:11:37.492 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:37.496 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:38.488 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:38.489 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:38.494 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:38.498 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:39.490 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:39.491 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:39.496 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:39.500 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:40.492 OnkyoAVTCP: Packet received: 8 MVL2D
2018-01-08 18:11:40.493 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:40.498 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:41.096 (rf) Temp (Tempratuur Buiten)
2018-01-08 18:11:41.494 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:41.495 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:41.500 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:41.503 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:42.496 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:42.501 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:43.497 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:43.502 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:44.498 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:44.503 (Onkyo) Light/Switch (Master volume)
