TOON died within Domoticz
EdwinK
Re: TOON died within Domoticz
Post by EdwinK »
astrapowerrr wrote: Sunday 07 January 2018 23:36 Does anyone here has the issue that in the log the toon is set to 6 degrees. At every Sunday morning about 00:02...
I see this constantly coming back only at that moment.
That is a known bug within Toon. Since not everyone is having that problem, it seems hard to fix. If you go to forum.toon.nl I believe it has been discussed there.
astrapowerrr
Post by astrapowerrr »
Correct!! Its a bug. Thanks for the tip!
rjblake
Post by rjblake »
astrapowerrr wrote: Thursday 18 January 2018 22:04 Correct!! Its a bug. Thanks for the tip!
Good luck getting this resolved. I filed a bug report with Eneco about this bug over 6 months ago and it has never been fixed to date.
michaelm86
Domoticz version: 3.8153
Post by michaelm86 »
Hi GUys,
hope that you can help me.
i added Toon to domoticz. but i cannot get the scenes working. when i select comfort it keeps flipping back to weg (away). But when i perform the json call bij hand in the browser it just works...does anybody know how to slove this?
i configured the following:
Setpoint:
Toon Scens:
see attachement and picture bellow:
error:
2018-02-27 13:40:40.147 Error: Error opening url: http://xx.xx.xx.xx:8080/json.htm?type=c ... =5&state=0
(i replaces the ip bi xx.xx.xx.xx)
lua script
-- script_time_toonselector.lua
-- Reads the Toon Thermostat Setpoint Temperature and updates the
-- selector in Domoticz to represent the current Active State.
-- Off scene is an option, leave it out if not needed.
-- Action commands will not be executed.
-- Settings: Configure as desired
-- Name of the switch with the temperature setpoint.
ThermostatSetPointName = 'Thermostaatinstelling' --Must match the name of you SetPoint device
-- Temperature SetPoints.
OffSetPoint = '6.00' --optional
AwaySetPoint = '16.50'
SleepSetPoint = '17.00'
HomeSetPoint = '19.00'
ComfortSetPoint = '20.00'
-- Name of the selector for Toon
ToonSelector = 'Thermostaat' --Must match (including case) the name of your Selector Switch
-- Name of the levels in the selector
OffLevel = 'Off' --optional
AwayLevel = 'Weg'
SleepLevel = 'Slapen'
HomeLevel = 'Thuis'
ComfortLevel = 'Comfort'
-- Values from each level name
OffLevelValue = '0' --optional
AwayLevelValue = '10'
SleepLevelValue = '20'
HomeLevelValue = '30'
ComfortLevelValue = '40'
-- End of settings
-- Toon Thermostat SetPoint:
ThermostatSetPoint = otherdevices_svalues[ThermostatSetPointName]
if (ThermostatSetPoint == HomeSetPoint) then
        --print("SetPoint equals to Home");
		if (otherdevices[ToonSelector] ~= HomeLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. HomeLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..HomeLevelValue
elseif (ThermostatSetPoint == ComfortSetPoint) then
        --print("SetPoint equals to Comfort");
		if (otherdevices[ToonSelector] ~= ComfortLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. ComfortLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..ComfortLevelValue
elseif (ThermostatSetPoint == SleepSetPoint) then
        --print("SetPoint equals to Sleep");
		if (otherdevices[ToonSelector] ~= SleepLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. SleepLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..SleepLevelValue
elseif (ThermostatSetPoint == AwaySetPoint) then
        --print("SetPoint equals to Away");
		if (otherdevices[ToonSelector] ~= AwayLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. AwayLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..AwayLevelValue
-- Optional
elseif (ThermostatSetPoint == OffSetPoint) then
        --print("SetPoint equals to Off");
		if (otherdevices[ToonSelector] ~= OffLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. OffLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..OffLevelValue
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
Plantje
Post by Plantje »
I didn't know it was possible to connect the programm settings of Toon to Domoticz. Can you also read and write the programm itself?
I will see if I can try this as well and if I can reproduce the issue.
michaelm86
does anybody have an idea?
HansieNL
Post by HansieNL »
I stopped sending state commands long ago and use temp commands. No problems at all:
http://192.168.x.xx.8080/json.htm?type= ... value=20.5
Blah blah blah
michaelm86
HansieNL wrote: Wednesday 28 February 2018 19:24 I stopped sending state commands long ago and use temp commands. No problems at all:
Can you explain what you did for configuration and setup? because ik i repaced the command in the toon scenes switch and i have the same issues.. :(
Error: Error opening url: http://192.168.116.98:8080/json.htm?par ... =5&state=2
when i push the button on the switch is does not work and when i open a new tab in the browser it works:
http://192.168.116.98:8080/json.htm?typ ... value=20.5
   "status" : "OK",
   "title" : "Update Device"
michaelm86
michaelm86 wrote: Wednesday 28 February 2018 22:39
   "status" : "OK",
I found the issue! now i have to find a solution...
i configured a username and password for domoticz for the portal. when i remove this the scens work..
when i activate the pw and username again an di change the url to:
http://username:[email protected] ... =5&state=2
it does not work... any ideas?
HansieNL
Post by HansieNL »
Have you included your local network in the Domoticz settings: Local Networks (no username/password)?
Blah blah blah
michaelm86
HansieNL wrote: Wednesday 28 February 2018 23:41 Have you included your local network in the Domoticz settings: Local Networks (no username/password)?
Yes. the localhost, ip of the machine itself and the subnet.
EdwinK
Post by EdwinK »
And since about a day now, Toon, and the smart plug's connected to it, are again not working with Domoticz :(
EdwinK
Post by EdwinK »
deleted
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
EdwinK wrote: Thursday 06 December 2018 10:08 It looks like the other forum (www.domoticaforum.eu) is having certificate problems :(
There is no link between Toon or Domoticz and the forum.
madpatrick
EdwinK wrote: Wednesday 06 June 2018 9:12 And since about a day now, Toon, and the smart plug's connected to it, are again not working with Domoticz :(
Have you checked the log ?
EdwinK
Post by EdwinK »
madpatrick wrote: Thursday 06 December 2018 19:44
This is from about 6 months ago.
Plantje
Post by Plantje »
EdwinK wrote: Thursday 06 December 2018 21:11
And did you check the log? :)
bierlaagh
Domoticz version: 4.9984
Post by bierlaagh »
Since 12th of February toon isn’t working anymore
Log says:
 Error: ToonThermostat: Invalid data received, or invalid username/password!
Already did a password reset, but still same line in my log
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
EdwinK
Post by EdwinK »
Eneco stopped there service https://toonopafstand.eneco.nl/.
It was a long time coming, and it seems they finally pulled the plug on the mentioned site. Eneco/Quby long time ago mentioned they didn't like the way Domoticz polled their service.
waspy
Domoticz version: 4.10430
Post by waspy »
Maybe you can give it a go:
https://www.domoticz.com/forum/viewtopi ... on#p207631
Regards,
John
