Page 13 of 14
Re: Find My iPhone implementation in LUA script
Posted: Friday 03 August 2018 19:54
by Irmin
I tried it with a script with just the curl and the output just gives a nil. 1 thing I noticed that I dont even get a error if I use wrong username or password.
If you can make a script whenever you have time please do so.
Posted: Friday 03 August 2018 21:28
by Egregius
Apple changed something in their ssl. I had to add a option to disable the ssl check to get it working again in my php script.
Posted: Friday 03 August 2018 23:43
by landaisbenj
I try tomorrow or in 1 week
Posted: Saturday 04 August 2018 21:03
by JohnBoy32
Egregius wrote: Friday 03 August 2018 21:28
Hi Egregius,
Can you give me a clue how to disable the SSL-check in the PHP script?
And on me search for a solution I walked into this solution for java:
https://community.openhab.org/t/icloud- ... blem/48314
Maybe it's an option to add the certificate instead of disabling the SSL-check? What is your opinion on this? And do you foresee this is possible for our application?
Thanks in advance for your help!
Posted: Saturday 04 August 2018 21:55
by Egregius
This is the php script I use, the solution is mentioned in this issue
https://github.com/albeebe/PHP-FindMyiPhone/issues/16
Posted: Sunday 05 August 2018 0:11
by Nautilus
I changed to pyicloud (
https://github.com/picklepete/pyicloud), a lot of additional functionalities implemented in this library...
Posted: Friday 10 August 2018 0:37
by Irmin
I still do not have it working, can some help?
Posted: Friday 10 August 2018 8:34
by MarceldeJongNL
I just added -k to every curl statement in the lua, and it works again
Posted: Friday 10 August 2018 9:07
by Irmin
MarceldeJongNL wrote: Friday 10 August 2018 8:34
That did the trick, thanks!
Posted: Tuesday 04 September 2018 21:27
by Hempie
Were in the line(s) will i add this -k
Posted: Thursday 06 September 2018 13:15
by landaisbenj
Hempie wrote: Tuesday 04 September 2018 21:27
stage1command = "curl -sk -X POST
stage2command = "curl -sk -X POST
Posted: Saturday 08 September 2018 9:12
by Hempie
Thank You...
Posted: Saturday 22 September 2018 22:16
by niwreg
Anyway in this thread
https://community.openhab.org/t/icloud- ... m/48314/28
they extract the key and signed the certificate with the apple root CA
So if we use that as trusted CA (maybe trick Curl into to that) the ssl should work again
Posted: Thursday 01 November 2018 17:40
by ropske
is this still working for you guys?
Mine is not updated anymore for a month
Posted: Saturday 22 December 2018 16:35
by Hempie
Mine also not working, any other script that will do the job?
Posted: Sunday 23 December 2018 11:24
by Superpjeter
Mine works like a charm
Posted: Tuesday 25 December 2018 16:24
by Hempie
Superpjeter wrote: Sunday 23 December 2018 11:24
Do u mind sharing your script? (without your credentials ofcourse)
Posted: Tuesday 25 December 2018 21:24
by krizzz
Hempie wrote: Tuesday 25 December 2018 16:24
I am curious also
Posted: Wednesday 26 December 2018 17:26
by Superpjeter
I only skipped the google maps position name because that is not working anymore
Still interested in the script, just let me know
Posted: Thursday 27 December 2018 10:52
by Marcvdp
I’m also interested in your script! Thank you in advance for sharing!
