TP-Link smart plug HS100/HS110
nosehook
Re: TP-Link smart plug HS100/HS110
Post by nosehook »
Hi Richard,
Please have a look here:
https://github.com/J0hnMatrix/domoticz- ... 0-hs110-v2
This should do the trick.
Regards,
Freek
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
ricvee
Domoticz version: Stable
Post by ricvee »
Hi Freek,
Unfortunately the same result.
So right after I installed the HS110 in setup-hardware, domoticz crashes, and I can only bring it back to life when I delete the plugins,
and delete the database restart and restore the database.
Thanks for the effort,
Richard
joew
Report button for energy cost etc?
Post by joew »
First post on this thread.
I'm using the plugin on domoticz on pi.
Is ther any way to add the Report button to get energy cost as with other power devices?
ajay100
Domoticz version: 4.10717
Post by ajay100 »
Hi @joew, sorry I haven't seen the Report button functionality and so I don't know the answer to your question, hopefully someone else will chime in.
Cheers - Andrew
The report function is only available for some device types.
For electricity it is for example available on the General (243), Subtype Kwh (29) device.
https://www.domoticz.com/wiki/Developin ... vice_Types
I did not read through all this topic but the plugin https://github.com/J0hnMatrix/domoticz- ... 0-hs110-v2 does not make use of this device subtype.
woempiej
Domoticz version: 2021.1
Post by woempiej »
I'm using the same steps as ricvee do and having the same problems.
- No plugin showed up in pp-manager list
- If a copy the plugin in the /home/pi/domoticz/plugin folder and install it from the hardware list, domoticz crashes until I'll remove the plugin
woempiej
Post by woempiej »
HS110 isn't connecting anymore because TP-Link closed port 9999 in the new firmware.
ccounotte
Post by ccounotte »
Hello everyone.
I'm trying to get new HS110 plugs but can't find any. Instead I found a new TP-Link KP115 which are actually a lot cheaper.
Wondering if the plugin will also work with those?
Thanks.
Alain
Domoticz version: 2022.1
Post by Alain »
ccounotte wrote: Sunday 28 November 2021 21:48 Hello everyone.
Thanks.
I don't think they are available with an EU plug right now.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
ccounotte
Post by ccounotte »
Alain wrote: Tuesday 30 November 2021 6:04 I don't think they are available with an EU plug right now.
Purchased 2 from Amazon yesterday, should get them in 1 to 3 months as per delivery information lol. I can post a link if it's allowed? Plug is for France by the way.
Alain
Post by Alain »
ccounotte wrote: Tuesday 30 November 2021 14:13
Please do.
ccounotte
Post by ccounotte »
Alain wrote: Wednesday 01 December 2021 0:31 Please do.
https://www.amazon.fr/dp/B09JKHZS2F/ref ... 8BN2ZTGZE1
Alain
Post by Alain »
Thanks.
ajay100
Post by ajay100 »
I purchased a KP115 in Australia (AU$29) and can confirm it is operating perfectly and exactly as per the HS110. It's quite a bit smaller, about the size of a typical USB charger.
KP115 image.jpg (4.6 KiB) Viewed 3690 times
In this case I'm using the plugin. I have it on long term test measuring my fridge power usage.
KP115 fridge power.jpg (30.57 KiB) Viewed 3690 times
reddo
Post by reddo »
Anyone who can give me a step by step install ? I did this years ago for the HS100 and 110 the simple way (sending commands to the switches), updated over a year ago to the plugin so I could ready the power etc from the 110 but ... now did a fresh install and cannot get it to work :(
Running a RPI3 with Raspberry OS with the latest Domoticz.
Thanks !!
Reddo
-Domoticz-RFLink-PVoutput-Solarmeter-SBFSpot-ESPEasy-Volumio with spotify connect-
ajay100
Post by ajay100 »
Hi @reddo, I see you were part of this thread early on. I have information about getting the plugin working on page 7 of this thread and ongoing. The stand-alone script is described on page 5. Logs are helpful for trouble-shooting, as we don't know which part you can't get to work.
Cheers - Andrew
reddo
Post by reddo »
ajay100 wrote: Thursday 17 November 2022 3:37 Hi @reddo, I see you were part of this thread early on. I have information about getting the plugin working on page 7 of this thread and ongoing. The stand-alone script is described on page 5. Logs are helpful for trouble-shooting, as we don't know which part you can't get to work.
Cheers - Andrew
Thanks ! After grinding through all the stuff I did use this one which works well !! Thanks for the reply Ajay100 !
viewtopic.php?p=219864#p219864
I do however still get these errors while all seems to be working well...
2022-12-03 00:19:19.281 Error: tplink: Traceback (most recent call last):
2022-12-03 00:19:19.281 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 290, in onHeartbeat
2022-12-03 00:19:19.281 Error: tplink: _plugin.onHeartbeat()
2022-12-03 00:19:19.281 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 137, in onHeartbeat
2022-12-03 00:19:19.281 Error: tplink: self.update_emeter_values()
2022-12-03 00:19:19.282 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 205, in update_emeter_values
2022-12-03 00:19:19.282 Error: tplink: Devices[2].Update(nValue=0, sValue=str(round(realtime_result['current'],2)))
2022-12-03 00:19:19.282 Error: tplink: KeyError: 2
