[Plugin now available in Beta] Help with Yeelight Bulb
Westcott
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by Westcott »
Hi Deennoo,
No, my code is not 'better' than yours!
It is to demonstrate that the Yee light's API can be controlled directly by Lua.
My Yee is not used as a room light, so I don't need dimmers and colour pickers.
It is instead controlled directly by the security sensors.
deennoo
Re: RE: Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by deennoo »
Westcott wrote:Hi Deennoo,
This can be a great trainning for the futur new domoticz feature : Python Plugin.
Not to replace yeelight add made by corbin, but enhance it with python plugin
http://domo-attitude.fr
somiarun
Domoticz version: 3.5877
Post by somiarun »
Denoo
I reset the whole thing and again tried from step 1 and while no i dont get any error but the LUA script dont seem to work at all
I created 2 LAU scripts
first one named YeeLight Dimmer and second one named YeeLightLounge and scripts as below
DomDevice = 'Yeelight Dimmer';
TempDevice = 'YeeLounge'
IP = '192.168.1.111';
PORT = '55443'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
DomValue = 0;
runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";;
os.execute(runcommandoff);
TempValue = otherdevices_svalues[TempDevice];
CalcValue = ((TempValue-1) * 48)+1700;
DomValue = otherdevices_svalues[DomDevice];
if CalcValue==nil then CalcValue=0 end
runcommand = "sudo echo -ne '{\"id\":1, \"method\":\"set_scene\", \"params\":[\"ct\", " .. CalcValue .. ", " .. DomValue .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand);
print(runcommand)
print("bright value= "..DomValue);
script for YeeLightLounge
DomDevice = 'YeeLounge';
PORT = '55443'
DomValue = 0;
CalcValue = ((DomValue-1) * 48)+1700;
runcommand = " sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\"," .. CalcValue .. ", 75]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
print(runcommand)
print("Color Temp= "..CalcValue);
When i look in the log there is no error but when i use the virtual switches nothing happens - see log below
2016-12-21 12:35:58.870 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 6068, 33]}\r\n' | nc -w1 192.168.1.110 55443
2016-12-21 12:35:58.872 LUA: bright value= 33
2016-12-21 12:35:58.442 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:35:59.822 User: Admin initiated a switch command (43/YeeLounge/Set Level)
2016-12-21 12:36:00.160 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",3332, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:00.162 LUA: Color Temp= 3332
2016-12-21 12:35:59.824 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:36:32.912 EventSystem: reset all events...
2016-12-21 12:36:46.726 User: Admin initiated a switch command (44/Yeelight Dimmer/Off)
2016-12-21 12:36:46.976 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 0, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:46.977 LUA: bright value= 0
2016-12-21 12:36:46.728 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:36:49.246 User: Admin initiated a switch command (43/YeeLounge/Off)
2016-12-21 12:36:49.546 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",0, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:49.548 LUA: Color Temp= 0
2016-12-21 12:36:49.247 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:36:55.634 User: Admin initiated a switch command (43/YeeLounge/On)
2016-12-21 12:36:55.886 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",1652, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:55.888 LUA: Color Temp= 1652
2016-12-21 12:36:55.635 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:36:57.927 User: Admin initiated a switch command (43/YeeLounge/Set Level)
2016-12-21 12:36:58.314 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",5780, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:58.316 LUA: Color Temp= 5780
2016-12-21 12:36:57.930 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:36:59.122 User: Admin initiated a switch command (44/Yeelight Dimmer/On)
2016-12-21 12:36:59.389 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 5780, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:36:59.390 LUA: bright value= 0
2016-12-21 12:36:59.124 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:37:01.578 User: Admin initiated a switch command (44/Yeelight Dimmer/Set Level)
2016-12-21 12:37:01.983 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 5780, 84]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:37:01.985 LUA: bright value= 84
2016-12-21 12:37:01.579 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:38:34.240 User: Admin initiated a switch command (43/YeeLounge/Off)
2016-12-21 12:38:34.514 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",0, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:38:34.516 LUA: Color Temp= 0
2016-12-21 12:38:34.241 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:38:39.093 User: Admin initiated a switch command (44/Yeelight Dimmer/Off)
2016-12-21 12:38:39.390 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 0, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:38:39.392 LUA: bright value= 0
2016-12-21 12:38:39.094 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:38:56.121 User: Admin initiated a switch command (43/YeeLounge/On)
2016-12-21 12:38:56.440 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",1652, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:38:56.442 LUA: Color Temp= 1652
2016-12-21 12:38:56.123 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:38:58.588 User: Admin initiated a switch command (44/Yeelight Dimmer/On)
2016-12-21 12:38:58.902 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 1652, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:38:58.903 LUA: bright value= 0
2016-12-21 12:38:58.590 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:39:02.747 User: Admin initiated a switch command (44/Yeelight Dimmer/Set Level)
2016-12-21 12:39:03.179 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 1652, 93]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:39:03.180 LUA: bright value= 93
2016-12-21 12:39:02.749 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:39:03.979 User: Admin initiated a switch command (43/YeeLounge/Set Level)
2016-12-21 12:39:04.366 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",6116, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:39:04.368 LUA: Color Temp= 6116
2016-12-21 12:39:03.981 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:39:54.255 (Openweather) Temp + Humidity + Baro (Openweather THB)
2016-12-21 12:39:54.548 (Openweather) Wind (Wind)
2016-12-21 12:39:54.744 (Openweather) General/Visibility (Visibility)
2016-12-21 12:40:49.862 User: Admin initiated a switch command (43/YeeLounge/Off)
2016-12-21 12:40:50.561 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",0, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:40:50.562 LUA: Color Temp= 0
2016-12-21 12:40:49.863 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:40:52.577 User: Admin initiated a switch command (44/Yeelight Dimmer/Off)
2016-12-21 12:40:52.826 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 0, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:40:52.827 LUA: bright value= 0
2016-12-21 12:40:52.579 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:41:32.531 User: Admin initiated a switch command (44/Yeelight Dimmer/On)
2016-12-21 12:41:32.840 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 1652, 0]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:41:32.841 LUA: bright value= 0
2016-12-21 12:41:32.533 (virtual) Light/Switch (Yeelight Dimmer)
2016-12-21 12:41:39.150 User: Admin initiated a switch command (43/YeeLounge/On)
2016-12-21 12:41:39.440 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",1652, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:41:39.441 LUA: Color Temp= 1652
2016-12-21 12:41:39.151 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:41:43.028 User: Admin initiated a switch command (43/YeeLounge/Set Level)
2016-12-21 12:41:43.431 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",5060, 75]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:41:43.432 LUA: Color Temp= 5060
2016-12-21 12:41:43.030 (virtual) Light/Switch (YeeLounge)
2016-12-21 12:41:44.551 User: Admin initiated a switch command (44/Yeelight Dimmer/Set Level)
2016-12-21 12:41:44.954 LUA: sudo echo -ne '{"id":1, "method":"set_scene", "params":["ct", 5060, 78]}\r\n' | nc -w1 192.168.1.111 55443
2016-12-21 12:41:44.956 LUA: bright value= 78
2016-12-21 12:41:44.552 (virtual) Light/Switch (Yeelight Dimmer)
deennoo
Post by deennoo »
DEENNOO (2 E / 2 N / 2 O) not so hard, please.
Please use "code" to put your lua script this 'll be more readable
Does your yeelight works with domoticz ? have you put them on developper mode ? inclusion is ok ? domoticz can drive them ? is this a white or a color one ? (white one can't change is white temp...thoses script can't work with them)
sach
Post by sach »
Thank you for this great plug in.
I recently purchased 2 strip lights from gearbest for £28 each for the kitchen and they work great. Have a third on the way!
BTW they are still reduced if anyone is looking for one.
Derik
Post by Derik »
mmm
Perhaps start a new topic for yeelight scripts...
My sunrise script is working................Are there more scripts for this light?
Sunset perhaps?
deennoo
Post by deennoo »
Derik wrote:mmm
Sunset perhaps?
Got sunset, and other ones, just need some time to update wiki
Derik
Post by Derik »
Great place in the wiki...
when you share yours GREAT thanks...
deennoo
Post by deennoo »
About yeelight bulb is this possible to get brightness value on svalues column for event ?
I plan to made a rotative knob using xiaomi cube.
Clock wise turn on to 5% bulb if off and if already on increase dimmer of +10% vs actual value each time clock wise is trigger
turn anti clock wise decrease brightness of 10% vs actual value to turn it off.
Got a way to made it but need parsing json of device...not really fast answer.
Derik
Post by Derik »
make a seperate group for al your yeellight wishes.
You can make any color Bright you like
Then make a blockley, cube size 1 = group 1
cube size 2 = etc
[ i hope every xiaomi cube size is a different idx in domoticz..]
Ordered gateway etc only the post from china grrrr
deennoo
Post by deennoo »
Derik wrote:make a seperate group for al your yeellight wishes.
cube size 2 = etc
Your wrong i'm talking about the spinning fonction, spin the cube on his self clock_wise or anti_clock_wise.
Like a rotative knob
psedma
Post by psedma »
is there any way to enable developer mode through MiHome app? I want to keep it paired with MiHome app (not yeelight app), but I can't see developer mode in MiHome app.
deennoo
Post by deennoo »
Install yeelight app enable and remove app
psedma
Post by psedma »
thx, I thought it will not be able work in MiHome in developer mode... But it works well
LouiS22
Post by LouiS22 »
Guys, a quick help needed.
Does anyone know the default color temperature of the RGBW bulb (I mean the one when I first switch it on)? I'd like to compare it with the white only one (which is 4000k). If it's the same, then I could use the white only (cheaper one :D) bulbs in certain places.
Thanks in advance!
psedma
Post by psedma »
I am waiting for White Yeelight Bulb... Then I will compare it side by side with RGBW and we will see :-) But I expect it will be quite same as default mode of RGBW.
deennoo
Post by deennoo »
LouiS22 wrote:Guys, a quick help needed.
Thanks in advance!
Easy !
Just reset your rgbw bulb by turn it on/off 5 times quickly, if ok bulb will flash to say ok i'm reset !
LouiS22
Post by LouiS22 »
Thanks in advance!
Easy !
Did you understand my question? I have a feeling that the answer is no. :)
deennoo
Post by deennoo »
Thanks in advance!
Easy !
yeap i clearly understand your question, by reseting your bulb you will get it as brand new, and get the first white...
LouiS22
Post by LouiS22 »
deennoo wrote:
LouiS22 wrote:
deennoo wrote: Easy !
Actually you don't :D
What I'd like to know is that the default white color temperature of the RGBW version and the "plain" White version of Yeelight is the same? Let's say it's 4000K. (I only have RGBW, so cannot test/compare). Makes sense now? :)
