Page 13 of 17
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Posted: Thursday 04 August 2016 10:58
by ddahya
Here is the table from the Guest Room thermostat in device.lua
["AddjMulti"]= 1.0,
["AddjMulti2"]= 1.0,
["AddjValue"]= 0.0,
["AddjValue2"]= 0.0,
["BatteryLevel"]= 255,
["CustomImage"]= 102,
["Data"]= "Off",
["Description"]= "",
["Favorite"]= 0,
["HardwareID"]= 5,
["HardwareName"]= "HM: Heating",
["HardwareType"]= "Dummy (Does nothing, use for virtual switches only)",
["HardwareTypeVal"]= 15,
["HaveDimmer"]= true,
["HaveGroupCmd"]= true,
["HaveTimeout"]= false,
["ID"]= "000140C0",
["Image"]= "Underfloor",
["IsSubDevice"]= false,
["LastUpdate"]= "2016-08-04 20:26:05",
["Level"]= 0,
["LevelInt"]= 0,
["MaxDimLevel"]= 100,
["Name"]= "Guest Room",
["Notifications"]= "false",
["PlanID"]= "0",
["PlanIDs"]= { 0 },
["Protected"]= false,
["ShowNotifications"]= true,
["SignalLevel"]= "-",
["Status"]= "Off",
["StrParam1"]= "",
["StrParam2"]= "",
["SubType"]= "Switch",
["SwitchType"]= "On/Off",
["SwitchTypeVal"]= 0,
["Timers"]= "false",
["Type"]= "Light/Switch",
["TypeImg"]= "lightbulb",
["Unit"]= 1,
["UsedByCamera"]= false,
["XOffset"]= "0",
["YOffset"]= "0",
["idx"]= "113"
Posted: Thursday 04 August 2016 11:44
by dannybloe
You'll have to create the device as a Thermostat dummy instead of a switch. I think that would solve your problem.
Posted: Thursday 04 August 2016 14:04
by dannybloe
G3rard wrote:@dannybloe, just installed dzVents and it looks great! Thanks for all the effort you have put into this.
I have a question regarding the LUA script below which I am currently using. I store a timestamp in a user variable to determine if a switch is pressed 2 times within 3 seconds.
I want to change this script to dzVents, but I am not sure how to change the lastUpdate correctly as described on GitHub.
Old LUA script:
package.path = package.path .. ';' .. '/volume1/@appstore/domoticz/var/scripts/lua/functions/functions.lua'  -- dir functions lua script
local fs = require("functions");    --load functions lua script
TimeBetweenPresses = 3              --max time between presses (in seconds)
if (devicechanged['Lamp keukenkastjes'] == 'Off') then
    if (fs.timedifference(uservariables_lastupdate['Dubbelklikschakelaar']) < TimeBetweenPresses ) then
        --print('Twee keer gedrukt binnen de tijd')
        if (otherdevices['Lux Kamer gang'] == 'Off') then
            --print('Lampen zijn al uit...')
            commandArray['Group:Lampen kamer'] = 'Off'
		commandArray['Variable:Dubbelklikschakelaar']=tostring(os.time())
		--print('Te lang er tussen')
dzVents script:
        active = true,
		data = {
			--counter = { initial = 1 },
			previousClick = { initial = nil }
        execute = function(domoticz, switch)
			--calculate the difference in seconds between previous and current click
			print('Vorige tijdstip: ' .. domoticz.data.previousClick)
			local hoursAgo, minsAgo, secsAgo = string.match(domoticz.data.previousClick, "(%d+):(%d+):(%d+)")
			local timestamp = hoursAgo*3600 + minsAgo*60 + secsAgo
			domoticz.data.previousClick = switch.lastUpdate.raw
			local hoursAgo2, minsAgo2, secsAgo2 = string.match(domoticz.data.previousClick, "(%d+):(%d+):(%d+)")
			local timestamp2 = hoursAgo2*3600 + minsAgo2*60 + secsAgo2
			print('Huidige tijdstip: ' .. domoticz.data.previousClick)
			local difference = timestamp2 - timestamp
			print('Verschil: ' .. difference)
			if (difference < 3) then
				print('The switch was pressed 2 times in < 3 seconds!')
				--if (domoticz.data.counter == 2) then
					--domoticz.data.counter = 1 -- reset the counter
				--else
					--domoticz.data.counter = domoticz.data.counter + 1
				--end
				print('Niet binnen de tijd')
I tried to use lastUpdate.secondsAgo but that always returns 0 seconds. So I used lastUpdate.raw and calculate the difference, but I think this can be done easier. What am I doing wrong here :?
First of all, I'd make the script a bit shorter by using historical storage because that already stores the time for each sample (see help):
	active = true,
	on = {'Lamp keukenkastjes'},
	data = { previousClick = { history = true, maxItems = 1 } },
		domoticz.data.previousClick.add('click');
		local previous = domoticz.data.previousClick.getLatest()
		if (previous.time.secondsAgo < 3) then
			domoticz.log('The switch was pressed 2 times in < 3 seconds!', domoticz.LOG_INFO)
I'm not sure though if Domoticz is fast enough to detect 3 short clicks right after each other.And maybe you should set it to <4. Not sure.
Posted: Thursday 04 August 2016 14:14
by G3rard
dannybloe wrote: First of all, I'd make the script a bit shorter by using historical storage because that already stores the time for each sample (see help):
	active = true,
Thanks for the response.
Running this code (only changed the name of the switch to Kaku schakelaar) gives the following error:
2016-08-04 14:10:50.165 LUA: >>> Handler: Dubbelklik
2016-08-04 14:10:50.165 LUA: >>> Device: "Kaku schakelaar" Index: 338
2016-08-04 14:10:50.166 Error: EventSystem: in /home/gerard/domoticz/scripts/lua/script_device_main.lua: ...erard/domoticz/scripts/lua/dzVents/HistoricalStorage.lua:89: bad argument #1 to 'ipairs' (table expected, got string)
Any ideas how to fix this?
I currently use a LUA script to detect double click, which needs to be done within 3 seconds. That works, but indeed you can't double click to soon after the first click because that second click then won't be noticed.
Posted: Thursday 04 August 2016 14:24
by dannybloe
	active = true,
Ah, I guess that's becuase the name of the variable is the same but of a different type. Try to remove the side-car file in scripts/storage (__data_yourscript1.lua) or rename the variable in you script.
Posted: Thursday 04 August 2016 14:37
by G3rard
Yeah, renamed the variable, that works :)
But now it doesn't detect a doubleclick between 3 seconds. If I print previous.time.secondsAgo to the log it's always 0.
And the second press is detected and between 3 seconds :?
2016-08-04 14:37:27.906 LUA: -----------------------------------------------------
2016-08-04 14:37:27.906 LUA: <<< Done
2016-08-04 14:37:27.905 LUA: 0
2016-08-04 14:37:27.905 LUA: >>> Device: "Kaku schakelaar" Index: 338
2016-08-04 14:37:27.905 LUA: >>> Handler: Dubbelklik
2016-08-04 14:37:27.905 LUA: =====================================================
2016-08-04 14:37:26.257 RFXCOM: Lighting 2 | Kaku schakelaar
2016-08-04 14:37:26.282 LUA: -----------------------------------------------------
2016-08-04 14:37:26.282 LUA: <<< Done
2016-08-04 14:37:26.282 LUA: 0
2016-08-04 14:37:26.281 LUA: >>> Device: "Kaku schakelaar" Index: 338
2016-08-04 14:37:26.281 LUA: >>> Handler: Dubbelklik
2016-08-04 14:37:26.281 LUA: =====================================================
Posted: Thursday 04 August 2016 14:51
by dannybloe
Ah, my bad. Of course it is always 0 because at the beginning of the script I overwrite the only value in the historical queue ;-)
Of course you need to do the add afterwards:
	active = true,
		if (previous and previous.time.secondsAgo < 3) then
Posted: Thursday 04 August 2016 15:05
by G3rard
Ah, of course, that did the trick. Thanks!
Posted: Thursday 04 August 2016 15:07
by dannybloe
Ain't that a nice short script? Almost reads like nice poem :lol:
Posted: Thursday 04 August 2016 15:35
by G3rard
Yep and I don't need an user variable anymore as in the old LUA script 8-)
Posted: Friday 05 August 2016 0:36
by ddahya
Thanks, I now have it working but when the thermostat is updated it triggers two events, one with the device name and another with device name _Utility
Is there any way I get dzVents to ignore device name_Utility event?
2016-08-05 10:21:49.046 LUA: Handling events for: "Master Room_Utility", value: "20"
2016-08-05 10:21:49.046 LUA: =====================================================
2016-08-05 10:21:49.046 LUA: >>> Handler: Neo
2016-08-05 10:21:49.046 LUA: >>> Device: "Master Room" Index: 96
2016-08-05 10:21:49.046 LUA: .....................................................
2016-08-05 10:21:49.047 LUA: Master Room
2016-08-05 10:21:49.047 LUA: Thermostat
2016-08-05 10:21:49.047 LUA: 20
2016-08-05 10:21:49.047 LUA: python /home/pi/domoticz/scripts/python/NeoHub.py -s -x 20 --StatName 'Master Room'
2016-08-05 10:21:49.048 LUA: .....................................................
2016-08-05 10:21:49.048 LUA: <<< Done
2016-08-05 10:21:49.048 LUA: -----------------------------------------------------
2016-08-05 10:21:48.982 (NeoHub) Thermostat (Master Room)
And
2016-08-05 10:21:47.830 LUA: Handling events for: "Master Room", value: "20.00"
2016-08-05 10:21:47.830 LUA: =====================================================
2016-08-05 10:21:47.830 LUA: >>> Handler: Neo
2016-08-05 10:21:47.830 LUA: >>> Device: "Master Room" Index: 96
2016-08-05 10:21:47.830 LUA: .....................................................
2016-08-05 10:21:47.830 LUA: Master Room
2016-08-05 10:21:47.830 LUA: Thermostat
2016-08-05 10:21:47.831 LUA: 20
2016-08-05 10:21:47.831 LUA: python /home/pi/domoticz/scripts/python/NeoHub.py -s -x 20 --StatName 'Master Room'
2016-08-05 10:21:47.831 LUA: .....................................................
2016-08-05 10:21:47.832 LUA: <<< Done
2016-08-05 10:21:47.832 LUA: -----------------------------------------------------
2016-08-05 10:21:47.770 (NeoHub) Thermostat (Master Room)
Posted: Friday 05 August 2016 8:11
by dannybloe
ddahya wrote:Thanks, I now have it working but when the thermostat is updated it triggers two events, one with the device name and another with device name _Utility
And
That's weird. This should not happen as there is a check that the same device isn't triggered twice in this case. Just to make sure, are you on the latest version of dzVents? Could you try the dev branch (download)?
Posted: Friday 05 August 2016 11:34
by ddahya
Thanks that done the trick, i was running dzVents 1.1.1.
Just wanted to know if you are about to assist with my script. What i want it to do is if the targettemp is different to the previousTemp then run the os.execute command. if the targettemp and previousTemp are the same then do nothing, end
Thanks again for all your help.
   active = true,
      'Dining'  -- Thermostat Device Names as seen in App
   data = {
      previousTemp = { initial = 20 },
      local previousTemp = domoticz.data['previousTemp']
      local TargetTemp = device.setPoint;
      if (TargetTemp and previousTemp ~= TargetTemp) then
         -- send the TargetTemp to NeoHub
	os.execute('python /home/pi/domoticz/scripts/python/NeoHub.py -s -x '..TargetTemp..' --StatName '.."'"..device.name.."'")
	domoticz.log(device.name, domoticz_LOG_INFO)
	domoticz.log(device.deviceType, domoticz_LOG_INFO)
	domoticz.log(TargetTemp, domoticz_LOG_INFO)
	domoticz.log(previousTemp, domoticz_LOG_INFO)
	domoticz.log('python /home/pi/domoticz/scripts/python/NeoHub.py -s -x  '..tonumber(TargetTemp)..' --StatName '..  "'"..device.name.."'")
        domoticz.data['prevousTemp'] = TargetTemp
This is whats its currently doing, the new TargetTemp is 23 and the previousTemp is 24
 2016-08-05 21:26:08.859 LUA: Handling events for: "Dining", value: "23.00"
2016-08-05 21:26:08.859 LUA: =====================================================
2016-08-05 21:26:08.859 LUA: >>> Handler: neo
2016-08-05 21:26:08.859 LUA: >>> Device: "Dining" Index: 111
2016-08-05 21:26:08.859 LUA: .....................................................
2016-08-05 21:26:14.202 LUA: Dining
2016-08-05 21:26:14.202 LUA: Thermostat
2016-08-05 21:26:14.202 LUA: 24
2016-08-05 21:26:14.202 LUA: 20
2016-08-05 21:26:14.202 LUA: python /home/pi/domoticz/scripts/python/NeoHubInterface.py -s -x 24 --StatName 'Dining'
2016-08-05 21:26:14.203 LUA: .....................................................
2016-08-05 21:26:14.203 LUA: <<< Done
2016-08-05 21:26:14.203 LUA: -----------------------------------------------------
2016-08-05 21:26:08.758 (HM: Heating) Thermostat (Dining)
Posted: Friday 05 August 2016 13:24
by dannybloe
ddahya wrote:Thanks that done the trick, i was running dzVents 1.1.1.
   active = true,
   data = {
I suspect it has something to do with the typo you made in the last line:
Guess that should be:
domoticz.data['previousTemp'] = TargetTemp
If that isn't the case, could you add this line in your script:
domoticz.logDevice(device)
I'm curious what all the device attributes are.
Posted: Saturday 06 August 2016 1:24
by ddahya
Here is the device attributes for my Dining thermostat in my prod machine.
 2016-08-06 11:02:13.443 LUA: Handling events for: "Dining_Utility", value: "22"
2016-08-06 11:02:13.443 LUA: =====================================================
2016-08-06 11:02:13.443 LUA: >>> Handler: neohub
2016-08-06 11:02:13.443 LUA: >>> Device: "Dining" Index: 111
2016-08-06 11:02:13.443 LUA: .....................................................
2016-08-06 11:02:13.444 LUA: Dining
2016-08-06 11:02:13.444 LUA: Thermostat
2016-08-06 11:02:13.444 LUA: 23
2016-08-06 11:02:13.444 LUA: python /home/pi/domoticz/scripts/python/NeoHub.py -s -x 23 --StatName 'Dining'
2016-08-06 11:02:13.444 LUA: > hardwareId: 5
2016-08-06 11:02:13.444 LUA: > setPoint: 23
2016-08-06 11:02:13.444 LUA: > counterTotal:
2016-08-06 11:02:13.444 LUA: > counterToday:
2016-08-06 11:02:13.444 LUA: > timedOut: false
2016-08-06 11:02:13.444 LUA: > batteryLevel: 255
2016-08-06 11:02:13.444 LUA: > hardwareTypeVal: 15
2016-08-06 11:02:13.445 LUA: > id: 111
2016-08-06 11:02:13.445 LUA: > hardwareTypeValue: 15
2016-08-06 11:02:13.445 LUA: > hardwareType: Dummy (Does nothing, use for virtual switches only)
2016-08-06 11:02:13.445 LUA: > deviceType: Thermostat
2016-08-06 11:02:13.445 LUA: > deviceSubType: SetPoint
2016-08-06 11:02:13.445 LUA: > description:
2016-08-06 11:02:13.445 LUA: > signalLevel: -
2016-08-06 11:02:13.445 LUA: > name: Dining
2016-08-06 11:02:13.445 LUA: > changed: false
2016-08-06 11:02:13.445 LUA: > rawData:
2016-08-06 11:02:13.445 LUA: > 1: 23.0
2016-08-06 11:02:13.445 LUA: > lastUpdate:
2016-08-06 11:02:13.445 LUA: > month: 8
2016-08-06 11:02:13.445 LUA: > year: 2016
2016-08-06 11:02:13.445 LUA: > day: 6
2016-08-06 11:02:13.446 LUA: > raw: 2016-08-06 10:59:04
2016-08-06 11:02:13.446 LUA: > hoursAgo: 0
2016-08-06 11:02:13.446 LUA: > rawTime: 10:59:4
2016-08-06 11:02:13.446 LUA: > minutesAgo: 3
2016-08-06 11:02:13.446 LUA: > rawDate: 2016-8-6
2016-08-06 11:02:13.446 LUA: > isdst: false
2016-08-06 11:02:13.446 LUA: > yday: 219
2016-08-06 11:02:13.446 LUA: > current:
2016-08-06 11:02:13.446 LUA: > sec: 13
2016-08-06 11:02:13.446 LUA: > year: 2016
2016-08-06 11:02:13.446 LUA: > day: 6
2016-08-06 11:02:13.446 LUA: > wday: 7
2016-08-06 11:02:13.446 LUA: > month: 8
2016-08-06 11:02:13.447 LUA: > hour: 11
2016-08-06 11:02:13.447 LUA: > min: 2
2016-08-06 11:02:13.447 LUA: > sec: 4
2016-08-06 11:02:13.447 LUA: > secondsAgo: 189
2016-08-06 11:02:13.447 LUA: > isToday: true
2016-08-06 11:02:13.447 LUA: > wday: 7
2016-08-06 11:02:13.447 LUA: > hour: 10
2016-08-06 11:02:13.447 LUA: > min: 59
2016-08-06 11:02:13.447 LUA: > hardwareName: HM: Heating
2016-08-06 11:02:13.448 LUA: .....................................................
2016-08-06 11:02:13.448 LUA: <<< Done
2016-08-06 11:02:13.448 LUA: -----------------------------------------------------
Here is the device attributes for the same device "Dining" thermostat in my POC machine.
 2016-08-06 10:40:15.335 LUA: Handling events for: "Dining_Utility", value: "23"
2016-08-06 10:40:15.335 LUA: =====================================================
2016-08-06 10:40:15.335 LUA: >>> Handler: Neo
2016-08-06 10:40:15.335 LUA: >>> Device: "Dining" Index: 94
2016-08-06 10:40:15.335 LUA: .....................................................
2016-08-06 10:40:20.638 LUA: python /home/pi/domoticz/scripts/python/NeoHubInterface.py -s -x 23 --StatName 'Dining'
2016-08-06 10:40:20.638 LUA: > counterTotal:
2016-08-06 10:40:20.638 LUA: > hardwareTypeValue: 15
2016-08-06 10:40:20.638 LUA: > lastUpdate:
2016-08-06 10:40:20.638 LUA: > minutesAgo: 0
2016-08-06 10:40:20.639 LUA: > month: 8
2016-08-06 10:40:20.639 LUA: > rawTime: 10:40:15
2016-08-06 10:40:20.639 LUA: > isToday: true
2016-08-06 10:40:20.639 LUA: > secondsAgo: 0
2016-08-06 10:40:20.639 LUA: > current:
2016-08-06 10:40:20.639 LUA: > min: 40
2016-08-06 10:40:20.639 LUA: > yday: 219
2016-08-06 10:40:20.639 LUA: > year: 2016
2016-08-06 10:40:20.639 LUA: > hour: 10
2016-08-06 10:40:20.639 LUA: > isdst: false
2016-08-06 10:40:20.640 LUA: > wday: 7
2016-08-06 10:40:20.640 LUA: > day: 6
2016-08-06 10:40:20.640 LUA: > sec: 15
2016-08-06 10:40:20.640 LUA: > isdst: false
2016-08-06 10:40:20.640 LUA: > hoursAgo: 0
2016-08-06 10:40:20.640 LUA: > yday: 219
2016-08-06 10:40:20.640 LUA: > year: 2016
2016-08-06 10:40:20.640 LUA: > rawDate: 2016-8-6
2016-08-06 10:40:20.640 LUA: > min: 40
2016-08-06 10:40:20.641 LUA: > raw: 2016-08-06 10:40:15
2016-08-06 10:40:20.641 LUA: > hour: 10
2016-08-06 10:40:20.641 LUA: > day: 6
2016-08-06 10:40:20.641 LUA: > deviceSubType: SetPoint
2016-08-06 10:40:20.641 LUA: > hardwareType: Dummy (Does nothing, use for virtual switches only)
2016-08-06 10:40:20.641 LUA: > hardwareName: NeoHub
2016-08-06 10:40:20.641 LUA: > changed: true
2016-08-06 10:40:20.641 LUA: > utility: 23
2016-08-06 10:40:20.641 LUA: > bState: false
2016-08-06 10:40:20.641 LUA: > timedOut: true
2016-08-06 10:40:20.641 LUA: > rawData:
2016-08-06 10:40:20.641 LUA: > 1: 23.00
2016-08-06 10:40:20.642 LUA: > description:
2016-08-06 10:40:20.642 LUA: > signalLevel: -
2016-08-06 10:40:20.642 LUA: > setPoint: 23
2016-08-06 10:40:20.642 LUA: > state: 23.00
2016-08-06 10:40:20.642 LUA: > hardwareId: 10
2016-08-06 10:40:20.642 LUA: > counterToday:
2016-08-06 10:40:20.642 LUA: > hardwareTypeVal: 15
2016-08-06 10:40:20.642 LUA: > name: Dining
2016-08-06 10:40:20.642 LUA: > batteryLevel: 255
2016-08-06 10:40:20.643 LUA: > deviceType: Thermostat
2016-08-06 10:40:20.643 LUA: > _sValues: 23.00
2016-08-06 10:40:20.643 LUA: > id: 94
2016-08-06 10:40:20.644 LUA: .....................................................
2016-08-06 10:40:20.644 LUA: <<< Done
They are both running the same version of dzVents, the new dev branch supplied in an earlier post.
Looks like the POC machine as a few more attributes then my prod machine.
Version of Domoticz running on pi
POC machine is running an older version 3.5231
Prod machine is running 3.5406
Posted: Saturday 06 August 2016 8:16
by dannybloe
Could be because Domoticz sometimes swallows log messages when they come too fast or too many. Might be differen each time you run the script. But does it work now?
Posted: Sunday 07 August 2016 0:25
by ddahya
dannybloe wrote:Could be because Domoticz sometimes swallows log messages when they come too fast or too many. Might be differen each time you run the script. But does it work now?
Its working on my PoC machine but not my Prod box.
If you look at the device attributes from my prod machine it's missing,
these are in the PoC box.
Posted: Sunday 07 August 2016 1:02
by Abbell
First let me state that I do not write LUAs. This is simply because I have never written one. I think it is about time. I have been teaching myself Arduino sketches over the last four weeks. Now it is time to work on these.
I have created several Blocky scripts that all work without issue. This time I need to create a script that can take into account pauses. I have a simple meter that reads my washing machine wattage. The problem I encounter is that when I try to account for the moments in the script when the wattage drops for sort periods it fails to ignore the time period of these drops. I installed dzVents to help with the timing, but the implementation escapes me.
The Blocky script turns on the washer switch once the wattage goes above 50w.
If the switch is on and the wattage drops below 50w it turns on a washer timer after 300sec
If the switch is on and the wattage drops below 50w and the washer timer is on then it turns off the switch
The issue arises that the timer is an absolute. Can I use dzVents to check when the last time the wattage dropped below 50w more than a set time to turn the washer switch off?
In advance, I greatly appreciate the insights offered.
Posted: Sunday 07 August 2016 10:08
by dannybloe
That's really strange. Can you try to give the device the same name in production as it has on your poc machine? There must be some discrepancy between the two machines. I suspect the naming may be the culprit as Domoticz doesn't use ids but names in the Lua tables it provides to the scripts. I have to do some juggling to match all those tables to the same devices but it's all done by name.
Posted: Sunday 07 August 2016 11:22
by dannybloe
Abbell wrote:First let me state that I do not write LUAs. This is simply because I have never written one. I think it is about time. I have been teaching myself Arduino sketches over the last four weeks. Now it is time to work on these.
Ah, I love this one. There are several ways to do it and I think this one is the simplest. It uses one historical data point previous that holds only one value (high or low). Advantage of using historical data variables is that it stores a time-stamp each time you add a value to the history. In our case we only store one value though as we are only interested in when we go from high to low. So we only set a new value when we go from high usage to low or vice versa. Each cycle the script is run we check the current usage and if the previous value is 'low' then we inspect when that 'low' value was written (previousState.time.secondsAgo):
local THRESHOLD_USAGE = 50 -- watt
local THRESHOLD_TIME = 300 -- seconds
	active = true,
	on = { 'MachineUsage' },
	data = {
		previous = { history = true, maxItems = 1 } -- holds 'high' or 'low'
	execute = function(domoticz, usage)
		if (domoticz.data.previous.size == 0) then
			-- initialize to 'low'
			domoticz.data.previous.add('low')
		local previousState = domoticz.data.previous.getLatest()
		local machineBusy = domoticz.devices['MachineBusySwitch']
		local current = usage.WActual  -- may need usage.utility here instead
		if (current > THRESHOLD_USAGE and (previousState.data == 'low')) then
			-- going from low to high
			domoticz.data.previous.add('high')
			if (machineBusy.state == 'Off') then
				machineBusy.switchOn()
		if (current <= THRESHOLD_USAGE) then
			-- check if we dropped from high to low
			if (previousState.data == 'high') then
				-- we go from high to low, store this moment
				-- we were already low
				if (previousState.time.secondsAgo > THRESHOLD_TIME and machineBusy.state == 'On') then
					-- program is finished
					machineBusy.switchOff()
					domoticz.notify('Washing machine', 'Washing machine is ready', domoticz.PRIORITY_NORMAL)
Oh, and this is untested code ;-)
