Page 118 of 184
Posted: Sunday 14 May 2017 20:13
by HansieNL
Trigun wrote:Hi Guy's, i al looking to install the Calendar feature but i was wondering if it is possible to install the google calendar of a different account than setup on the specific device. Reason for this question is that I don't see a place where you put in you credentials of the desired account.
You can use the private ical link from a Google calender.
Re: Dashticz - Module - Calendar
Posted: Sunday 14 May 2017 22:00
by htilburgs
HansieNL wrote:htilburgs wrote:HansieNL wrote:Is it possible to change the height of the title block of the calendar?
Can you tell me how you add this calendar? I'm very interested!
1. The calendar is a .ics file from Formula 1 site
https://www.formula1.com/sp/static/f1/2 ... r/ical.ics
2. Created a new Google calendar Formule 1 Race
3. Choose import from local file and selected Formule 1 Race calender to import to
4. I used the Googles' Formule 1 Race calender private address in Dashticz calendar
calendars.f1 = { maxitems: 7, title: 'Formule 1 Kalender', icalurl: '
https://calendar.google.com/calendar/ic ... /basic.ics' }
Thnx... Working!
Posted: Sunday 14 May 2017 22:32
by HansieNL
Thnx... Working!
You're welcome. My problem with Homey and an ical is also solved now. Homey told me the race was gonna start over 60 minutes and a nice race sound was played. Only a shame Max didn't finish.
Posted: Sunday 14 May 2017 22:37
by Trigun
EdKo66 wrote:Samsung is Android
Haha ok, i guess i should have been more specific
i meant Wich version. @ jake, Are you on the latest? If not; perhaps an update of Your os is an option?
Also, try downloading another browser on the tab.
Posted: Monday 15 May 2017 8:52
by bsmeding
Does someone know how to enable an popup on a switch?
I want to create an popup on the status icon if someone is offline and the status icon i red, then when you clock on the user it will popup an google maps card with the location.
same window when clicking the buttons.webcam or buttons.news but than for a switch.
Feature maybe? When adding to config.js ? so every block can have an popup window?
buttons.block[xxx] { url:http://www.url.to'}
or
block[xxx]:url:http://www.url.to'}
Posted: Monday 15 May 2017 13:49
by jake
Trigun wrote:EdKo66 wrote:Samsung is Android
After I saw in the 'show your dashticz' topic that user Swordfish used this device, I googled it at XDA and found a broad community around it. I therefore bought a 2nd hand one on Marktplaats, put TWRP and 2 different flavors of Android 7.1.2 on it. Both firmwares behave the same way as I described.
So far I tried with a blank CM 14.1 version the 'Full Kiosk Browser' and 'Chrome'. On my current firmware (Xenon HD, for what's in a name) I only used 'Chrome' with equal issues.
Obviously the clock value is a GMT value (2hr behind Amsterdam), while the tablet itself is in the right time zone. I checked the RPI and also there both the time is accurate and the time zone is specified correctly.
I am on the latest beta and started to disable functions, like the buienradar and news feed, traffic and train info, but to no avail.
Posted: Monday 15 May 2017 14:07
by SwordFish
jake wrote:Trigun wrote:EdKo66 wrote:Samsung is Android
Is you're tablet rooted?
I use the original firmeware (4.4.2) and chrome browers (Shortcut to Dashticz on homescreen).
Have no problems with running Dashticz or time or graph.
Posted: Monday 15 May 2017 14:51
by Derik
Is there somebody that has a good advise for a cheap 12 or 13 inch tablet
Posted: Monday 15 May 2017 14:55
by NicoLP
What temp meters for 433mhz are good for domoticz or dashticz ???
or what do you guys use
Nico
Posted: Monday 15 May 2017 15:21
by blacksn0w
NicoLP wrote:What temp meters for 433mhz are good for domoticz or dashticz ???
Nico
I'm using some cheap Xiaomi Temperatur/Humidity Sensors in combination with the hub. Perfect interaction with Domoticz, extremely small and perfect build quality.
Posted: Monday 15 May 2017 15:26
by NicoLP
where did you buy it ??
Nico
Posted: Monday 15 May 2017 20:35
by jake
The tablet is rooted indeed. I installed System Monitor on the tablet. In the graph/log I can see that it is using 70+% when Dashticz is running, but only 5-10% when the home screen is visible (I used a widget to show CPU/mem usage) Memory consumption overall is only 34%, so plenty left.
I wonder why Dashticz uses so much CPU time (I changed CPU governor to 'Performance' to rule out a 'smart' governor which would concentrate on battery performance).
Based on logic and Swordfishes experience, I don't think this tablet is too slow/old to run a webpage like this (Duo core 1.5 GHz and 1.5Gb. RAM). I now also disabled animated weather icons, just to be sure.
After 3 days of showing the Dashticz interface nonetheless, I was surprised when I came home today and found the time had corrected itself to local time. No idea what triggered that, but so far so good.
Posted: Monday 15 May 2017 20:54
by SwordFish
I now that when I want to show the graphs from my nest thermostat the dashboard get slowly, I think because it's has dots every 5 minutes and take some time to load. But when I remove it it runs smoothly.
Posted: Monday 15 May 2017 21:03
by madrian
(Relatively) cheap 3D printed iPad holder:
- IMG_0542.jpg (87.73 KiB) Viewed 2745 times
- IMG_0541.jpg (159.33 KiB) Viewed 2745 times
Posted: Monday 15 May 2017 21:40
by philuxe
congratulation to Rob for the good work !
I read most of the previous 117 pages yesterday and found some users (two if I remember well) who reported high cpu issues and I believe I have the same behavior (OSX + chrome in my case), so I was wondering whether there was some fix/workaround or not ? I did not notice the same cpu usage on the iphone .
Second point, I use a couple of temp/humidity sensor, the same device report two values with one block definition :
blocks[40] = {} // TEMP ROOM_1
blocks[40]['width'] = 6;
then form the column definition I can make a reference to '40_1' for temperature or '40_2' for humidity only however the block is not clickable anymore and I dont get the graph.
On the other side when the same sensor produce two blocks both are clickable but each of them points to the temperature graph. Any idea ?
Last request
is there a way to translate 'grafiek' in the graph pop up (when you pass ur mouse over the line ) ?
bye and thanks again for all the efforts
Posted: Tuesday 16 May 2017 0:25
by cyberclwn
Hey,
Thanks for the great work.
But there are somethings i don't know how to get working on dashticz:
1. I have a radiator-valve from Smartwares. it uses 2 devices. One is day/night (on/off) and one to use to set temperature/setpoint with. But if i add both to dashticz/CONFIG.js they both are shown as on/off devices. I can't find a way to show the 2nd device as a thermostat-option.
2. Can't get a google calendar displayed on my dahsticz, but i read you are working on changing a lot on that topic, so i wait for that. (there is a %-sign in my address, maybe that is messing things up tho)
There is a lot of posts to search thru, i apologize if i missed the solution somewhere.
Posted: Tuesday 16 May 2017 8:39
by philuxe
Nico
I recommand Oregon Scientific THGR 810 for inside and Oregon Scientific THGR 122 NX.
Oregon Scientific THGR 122 NX is normally for inside but you can put it outisde under a shelter
they are very accurate and good quality product , you will need the Rfxcom
Posted: Tuesday 16 May 2017 9:51
by EdwinK
cyberclwn wrote:Hey,
If you mean ' %40', that5 is the HTML-code for the '@' symbol.
Posted: Tuesday 16 May 2017 13:15
by Derik
mm i set multiple screens..on dashticz swiping automaticly..
only swipe everytime to the last screen instat to the first
can i set somewhere the swipe stop by the first?
Or a random swipe to all screens, and wait x minute on the first?
Posted: Tuesday 16 May 2017 14:06
by Ierlandfan
Offtopic: If you want to play around with 433 mhz sensors like temp/humidity/doorbell/(insert-sensor here) or already have a weather station, you can use rxcom or use the (much cheaper) Arduino+433mhz+rflink firmware way.
