Ouate
Re: Domoticz app 2.0
Personally, it's still bugged , same thing.
I can not open the blinds, the open button is working as a close button.
If I push up, it goes down if I push down, it goes down.
Some other blinds are not working at all, nothing is happening.
That worked perfectly before the last update!!
What's happening?,!
What's happening?,!
- Ragdag
Also issues with Blinds for me, will only close
Other issue that changing the dim level of dimmer results in commands being sent to the back end for every 1% change in the app instead of sending it once after the selection has been made.
Here is a log snippet of just sliding a dimmer from 100 to halfway
This overloads Domoticz and Zwave with queued commands
2023-04-21 11:28:49.409 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.419 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.425 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.431 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.437 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.445 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.454 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.462 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.470 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.479 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.486 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.494 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.500 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.510 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.519 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.526 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.534 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.542 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.551 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.559 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.566 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.576 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.584 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.593 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.602 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.611 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.624 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.633 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.642 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.650 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.658 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.667 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.675 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.687 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.695 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level)
2023-04-21 11:28:49.704 Status: User: USER (IP: 192.168.2.16) initiated a switch command (2045/Kantoor - Verlichting/Set Level) -
Ouate
Still bugged.
Ouate
I want to get back to the old working version, where can I find it?
Ouate
Fuck
- user4563
- Domoticz version: 2026.4
If someone wants to add Domoticz to apkmirror it would be a good idea so users can rollback to specific versions.
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
clmntpllr
Re: Domoticz app 2. 0
<double post>
clmntpllr
Blinds still messed up on the Android app (premium), even with the last update that happened two days ago (0°2°358 (9328)) .
I can only close them, same issue as the others.
Do you know when it will be fixed up ?
( 2022°2 Domoticz - hw : RPi)
Also does anyone uses "user variables" ? I liked when they were accessible from the main menu. At least could it be possible to have that choice for those who were using it.
Ouate
This app is still bugged for me too and the developer doesn't care.clmntpllr wrote:Hi,
Only possible to close blinds.
I will leave for Home Assistant, the android app is so wonderful.
Domoticz is now the past.
tulips
Still no update regarding the blinds?
Maybe bring the old app back? Or maybe someone can make a virtual button's + a script? Can that be done? Old version of app works but.
Ouate
Yes, please someone give us APK of old app
- user4563
I do have the APK from approx mid last year. I'm not sure what the version is so it's a couple of versions back. I can share that if you want.
Typing on my mobile so I can't post it right this second though.
- jacobsentertainment
- Domoticz version: 2021-1
Still have a couple of issues with the app.
- The widgets still don't work (still beta) Not getting updates/new data after installing a widget.
- most of the time you need to go all the way back up (extensive list of switches) to refresh the page. but tilting the mobile device will refresh and goes directly back to the dashboard. (somehow very annoying)
- Also when there is a poor wifi connection (in the back of the garden) the app can't connect and say's "check server settings" the only way to get refreshed is close the app fully down and start back up. I would like to use the same as for the other pages, swipe the screen down for refresh.
tomes
Switch logs are unavailable. (there are no events) Newest Domoticz 0.2.358 (premium).
Ouate
Who want to pay for that?
pikapt
android auto - has anyone tested this feature? I've tried to enable it on the app but nothing shows up on the screen of the car.
Ouate
Because this app is uselesspikapt wrote: Tuesday 06 June 2023 11:11 android auto - has anyone tested this feature? I've tried to enable it on the app but nothing shows up on the screen of the car.
- jvdz
- Domoticz version: 4.107
@Ouate,
You have made pretty clear you don't like the app by now and I honestly do not understand what point you are trying to make other than some sort of vendetta? I am pretty happy with the APP for years now, so what about you either post constructive information about what your issues are so they can be looked at or simply refrain from making these uncalled-for comments?
Jos
Jos
HansF
Totally agree. I have been using the app happily for years.
Hans
Hans
Ouate
When you buy an app and a few months after this app is updated, now bugged and not usable.jvdz wrote:@Ouate,
Jos
, that makes an useless app.
I'm not the only one in this case and the developer don't care.
Ok it takes his money and don't want to make something to repair,
But I will not shut up my mouth.
Honestly it looks like this app has been coded with foots.
