Page 117 of 184
Posted: Friday 12 May 2017 20:32
by HansieNL
Trigun wrote:EdKo66 wrote:Nope. It's correct. In this file you can add stuf you want. Such as rounded corners or in this case no bullets.
Hi Edko, thnx for your reply!
can you help me a bit out here?
the code states:
CUSTOM CSS FILE
this is going to sound dumb but where do I need to put the code?
after the /* ....*/ ?
Just under that text is good enough.
Posted: Friday 12 May 2017 20:37
by Trigun
Go it!! thnx a lot HansieNL !!
Posted: Friday 12 May 2017 21:10
by robgeerts
booster wrote:I'm also starting to play around with Dashticz, and I'm trying to get the most important switches on the dashboard now.
Just one issue I'm running into:
My curtains look like this in the standard domoticz page:
However, when adding them (standard way) in Dashticz, the curtains are not listed as dimmer/with a slider, so I can't set a percentage.
In domoticz, I configured them as "blinds percentage inverted"
Is there something I can do to make them listed with the slider from within Dashticz, without changing the switch type?
Could you test latest beta for this?
I tried fixing this with a dummy but cannot really test this...
Re: Dashticz - Module - Calendar
Posted: Friday 12 May 2017 22:57
by HansieNL
Is it possible to change the height of the title block of the calendar?
- Naamloos 1.jpg (7.18 KiB) Viewed 3172 times
Posted: Saturday 13 May 2017 6:39
by htilburgs
/* Height of the blocktitles and center text in new height */
div.mh.titlegroups {
height: 60px !important;
padding-top: 3px !important;
Posted: Saturday 13 May 2017 8:23
by HansieNL
- Spoiler: show
htilburgs wrote:Code: Select all
Thank you sir
Posted: Saturday 13 May 2017 8:50
by mAiden88
the code states:
CUSTOM CSS FILE
@Trigun:
*/ stand for comments, so the script knows it is a comment. You can use that to tell what that line do, or what script does.
Posted: Saturday 13 May 2017 10:12
by Derik
mmm,
Is it perhaps possible to change the height piece by piece or in a row?
Now i have the status not in the square..
- ScreenShot245.jpg (27 KiB) Viewed 3093 times
EDIT:
Sorry see now the topics before...
Only where can/must i place this code..
Please a example height an center...
Posted: Saturday 13 May 2017 10:18
by Trigun
mAiden88 wrote:Trigun wrote:EdKo66 wrote:Nope. It's correct. In this file you can add stuf you want. Such as rounded corners or in this case no bullets.
the code states:
CUSTOM CSS FILE
@Trigun:
Ah great! Thnx for Your reply mAiden88!
Still learning all the stuff but getting better every day
Posted: Saturday 13 May 2017 15:55
by rpwessels
I want to try to control my Onkyo receiver via the dashticz dashboard. If it is possible i want to use the zing horizon script. Can somebody show my how the control of the ziggo box looks in the dashboard and how can i activate this control.
Gr. Ricardo
Posted: Saturday 13 May 2017 20:46
by HansieNL
I want the word "Regenverwachting" removed and "Voorlopig blijft het droog" with the font size of the word "Regenverwachting".
Someone got the code for that already?
- Naamloos 1.jpg (3.43 KiB) Viewed 3024 times
Posted: Saturday 13 May 2017 21:06
by htilburgs
I've done this. Remove word:
blocks[178] = {} //Regen verwachting
blocks[178]['title'] = '';
blocks[178]['width'] = 12;
I didn't change the font. But if you need thus I can take a look at which css is needed.
EDIT: I looked into which code for the font. This is .tiltle {}
Problem is that if you change, then you change this for every title on the Dashboard.
What is possible, is that @robgeerts change the class for this, so we can overule it in the custom.css.
Good luck!
Posted: Saturday 13 May 2017 21:17
by htilburgs
HansieNL wrote:Is it possible to change the height of the title block of the calendar?
Can you tell me how you add this calendar? I'm very interested!
Posted: Saturday 13 May 2017 22:05
by HansieNL
htilburgs wrote:HansieNL wrote:Is it possible to change the height of the title block of the calendar?
1. The calendar is a .ics file from Formula 1 site
https://www.formula1.com/sp/static/f1/2 ... r/ical.ics
2. Created a new Google calendar Formule 1 Race
3. Choose import from local file and selected Formule 1 Race calender to import to
4. I used the Googles' Formule 1 Race calender private address in Dashticz calendar
calendars.f1 = { maxitems: 7, title: 'Formule 1 Kalender', icalurl: '
https://calendar.google.com/calendar/ic ... /basic.ics' }
Posted: Sunday 14 May 2017 8:07
by tontze
Hi ! I have recently had moon lua errors in my domoticz log :
2017-05-13 23:36:00.726 Error: EventSystem: in script_time_moon.lua: [string "-- Variables to customize -------------------..."]:135: attempt to concatenate global 'moonriseMinute' (a nil value)
As far as i know, i havent changed a thing ?
Posted: Sunday 14 May 2017 10:17
by poudenes
tontze wrote:Hi ! I have recently had moon lua errors in my domoticz log :
Sometimes happen this... had this in past, later the day its ok... something of wunderground
Posted: Sunday 14 May 2017 17:17
by jake
After running the dashboard on my Asus TF701 tablet, I bought a Samsung T310 (Tab 3 8.0) to use as a wall mounted device. Although I know that the TF701 is more powerfull than the T310, I don't understand why Dashticz (beta) behaves strange on that device:
- The clock in Dashticz is 2hrs (exactly) behind (the tablet clock itself is alright, the 'Dashticz clock' on the TF701 is alright too)
- The website becomes sluggish very soon after opening it for the first time. The seconds of the clock stutter, skip seconds here and there. Sliding to a 2nd page takes 4-5 seconds
All of those issues I can't reproduce from my main tablet, while pointing to the same website address. Any clues about the 2hr difference and sluggish response?
Posted: Sunday 14 May 2017 17:19
by Trigun
Hi Guy's, i al looking to install the Calendar feature but i was wondering if it is possible to install the google calendar of a different account than setup on the specific device. Reason for this question is that I don't see a place where you put in you credentials of the desired account.
Posted: Sunday 14 May 2017 17:27
by Trigun
jake wrote:After running the dashboard on my Asus TF701 tablet, I bought a Samsung T310 (Tab 3 8.0) to use as a wall mounted device. Although I know that the TF701 is more powerfull than the T310, I don't understand why Dashticz (beta) behaves strange on that device:
It seems like the tablet isn't powerful enough to run the graphics of the pages. What OS is tablet running on?
Posted: Sunday 14 May 2017 17:40
by EdwinK
Samsung is Android
