HansieNL
Post by HansieNL »
Trigun wrote:
EdKo66 wrote:Nope. It's correct. In this file you can add stuf you want. Such as rounded corners or in this case no bullets.
Hi Edko, thnx for your reply!
can you help me a bit out here?
the code states:
CUSTOM CSS FILE
this is going to sound dumb but where do I need to put the code?
after the /* ....*/ ?
Just under that text is good enough.
Blah blah blah
Trigun
Domoticz version: 4.10717
Post by Trigun »
Go it!! thnx a lot HansieNL !!
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
booster wrote:I'm also starting to play around with Dashticz, and I'm trying to get the most important switches on the dashboard now.
Just one issue I'm running into:
My curtains look like this in the standard domoticz page:
However, when adding them (standard way) in Dashticz, the curtains are not listed as dimmer/with a slider, so I can't set a percentage.
In domoticz, I configured them as "blinds percentage inverted"
Is there something I can do to make them listed with the slider from within Dashticz, without changing the switch type?
Could you test latest beta for this?
I tried fixing this with a dummy but cannot really test this...
HansieNL
Re: Dashticz - Module - Calendar
Post by HansieNL »
Is it possible to change the height of the title block of the calendar?
Naamloos 1.jpg (7.18 KiB) Viewed 2598 times
Blah blah blah
htilburgs
Post by htilburgs »
/* Height of the blocktitles and center text in new height */
div.mh.titlegroups {
    height: 60px !important;
    padding-top: 3px !important;
Hardware:
HansieNL
Post by HansieNL »
Thank you sir ;)
Blah blah blah
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
the code states:
CUSTOM CSS FILE
@Trigun:
*/ stand for comments, so the script knows it is a comment. You can use that to tell what that line do, or what script does. ;)
Anyone can build a fast processor. The trick is to build a fast system.
Derik
Post by Derik »
mmm,
Is it perhaps possible to change the height piece by piece or in a row?
Now i have the status not in the square..
EDIT: :-)
Sorry see now the topics before...
Only where can/must i place this code..
Please a example height an center...
Trigun
Post by Trigun »
the code states:
CUSTOM CSS FILE
@Trigun:
Ah great! Thnx for Your reply mAiden88!
Still learning all the stuff but getting better every day ;)
rpwessels
Domoticz version: V3.5641
Post by rpwessels »
I want to try to control my Onkyo receiver via the dashticz dashboard. If it is possible i want to use the zing horizon script. Can somebody show my how the control of the ziggo box looks in the dashboard and how can i activate this control.
Gr. Ricardo
Ubuntu16.04 LTS | Z-wave | Opentherm | P1 Smartmeter
HansieNL
Post by HansieNL »
I want the word "Regenverwachting" removed and "Voorlopig blijft het droog" with the font size of the word "Regenverwachting".
Someone got the code for that already?
Naamloos 1.jpg (3.43 KiB) Viewed 2450 times
Blah blah blah
htilburgs
Post by htilburgs »
I've done this. Remove word:
blocks[178] = {} //Regen verwachting
blocks[178]['title'] = '';
blocks[178]['width'] = 12;
I didn't change the font. But if you need thus I can take a look at which css is needed.
EDIT: I looked into which code for the font. This is .tiltle {}
Problem is that if you change, then you change this for every title on the Dashboard.
What is possible, is that @robgeerts change the class for this, so we can overule it in the custom.css.
Good luck!
Hardware:
htilburgs
Post by htilburgs »
HansieNL wrote:Is it possible to change the height of the title block of the calendar?
Can you tell me how you add this calendar? I'm very interested!
Hardware:
HansieNL
Post by HansieNL »
1. The calendar is a .ics file from Formula 1 site https://www.formula1.com/sp/static/f1/2 ... r/ical.ics
2. Created a new Google calendar Formule 1 Race
3. Choose import from local file and selected Formule 1 Race calender to import to
4. I used the Googles' Formule 1 Race calender private address in Dashticz calendar
calendars.f1 = { maxitems: 7, title: 'Formule 1 Kalender', icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics' }
Blah blah blah
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi ! I have recently had moon lua errors in my domoticz log :
2017-05-13 23:36:00.726 Error: EventSystem: in script_time_moon.lua: [string "-- Variables to customize -------------------..."]:135: attempt to concatenate global 'moonriseMinute' (a nil value)
As far as i know, i havent changed a thing ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
poudenes
Domoticz version: 3.8993
Post by poudenes »
tontze wrote:Hi ! I have recently had moon lua errors in my domoticz log :
Sometimes happen this... had this in past, later the day its ok... something of wunderground
jake
Post by jake »
After running the dashboard on my Asus TF701 tablet, I bought a Samsung T310 (Tab 3 8.0) to use as a wall mounted device. Although I know that the TF701 is more powerfull than the T310, I don't understand why Dashticz (beta) behaves strange on that device:
- The clock in Dashticz is 2hrs (exactly) behind (the tablet clock itself is alright, the 'Dashticz clock' on the TF701 is alright too)
- The website becomes sluggish very soon after opening it for the first time. The seconds of the clock stutter, skip seconds here and there. Sliding to a 2nd page takes 4-5 seconds
All of those issues I can't reproduce from my main tablet, while pointing to the same website address. Any clues about the 2hr difference and sluggish response?
Trigun
Post by Trigun »
Hi Guy's, i al looking to install the Calendar feature but i was wondering if it is possible to install the google calendar of a different account than setup on the specific device. Reason for this question is that I don't see a place where you put in you credentials of the desired account.
Trigun
Post by Trigun »
jake wrote:After running the dashboard on my Asus TF701 tablet, I bought a Samsung T310 (Tab 3 8.0) to use as a wall mounted device. Although I know that the TF701 is more powerfull than the T310, I don't understand why Dashticz (beta) behaves strange on that device:
It seems like the tablet isn't powerful enough to run the graphics of the pages. What OS is tablet running on?
EdwinK
Post by EdwinK »
Samsung is Android ;)
Locked
