mvveelen
Post by mvveelen »
Since the latest beta (I missed a few beta's so I don't know which one is the guilty one :) ) I don't see the 'buttons' to switch from screen 1 to screen 2 (and back). They are still there, but probably very tiny, because when I click on the place where they used to be I can switch between te screens. Didn't change anything in the .css myself.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
I removed the buttons.
This was already removed 10 to 20 versions ago but due to changes they were back.
Blueone
Post by Blueone »
Is there a possibilty somewhere in the code to set the refresh time for the weather and trash seperate of the dasticz refresh? I scheduled the full refresh each 12 hours (otherwise it is distractive with a tablet on the wall next to the tv :oops: ). But I would to refresh the weather and trash (otherwise i have the old date of the trash in the morning) a bit more often without a full load.
poudenes
Domoticz version: 3.8993
Post by poudenes »
In latest beta the buttons to change screens are gone. Update before the buttons become small and are blue in color ...
tontze
Domoticz version: Beta Ch
Post by tontze »
Quick guestion, blocks in wiki :
var blocks = {}
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[1]['title'] = 'Living room' //if you want change the name of switch different then domoticz
blocks[1]['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[1]['switch'] = true; //if you want to switch the title and data
blocks[1]['hide_data'] = true; //if you want to hide the data of this block
blocks[1]['show_lastupdate'] = true; //if you want to show the last update specific for this block
Should "blocks[1]['title'] = 'Living room' //if you want change the name of switch different then domoticz" have ; after the 'Living room' like icon row has ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
robgeerts
Post by robgeerts »
It's not required..
repoman
Post by repoman »
robgeerts wrote:I removed the buttons.
Is it possible to make something like "var _swipe buttons = true/false" ?
(i'm using Dashtic on a laptop and a pc/server with a monitor)
Pascal
josimd
Post by josimd »
My dashboard is up and running, can be openend via http://192.168.0.15:8084 but how can I access the domoticz configuration screens which I had before my dashboard was running?
robgeerts
Post by robgeerts »
You had to install it in a subfolder... now yoi have overwritten some domoticz files..
josimd
Post by josimd »
aha...so I have to wait for the next domoticz update..
HansieNL
Post by HansieNL »
josimd wrote:aha...so I have to wait for the next domoticz update..
Maybe you can download Domoticz .tgz file and overwrite www folder. Don't forget to backup your Dashticz cusom folder first.
Then reinstall Dashticz in other folder.
Blah blah blah
robgeerts
Post by robgeerts »
The bullets to swipe to other pages are back again.
You can hide them in custom.css if you dont want them:
.swiper-pagination-bullet {
    width: 0px !important;
    height: 0px !important;
Or make them bigger:
    width: 30px !important;
    height: 30px !important;
booster
Post by booster »
I'm also starting to play around with Dashticz, and I'm trying to get the most important switches on the dashboard now.
Just one issue I'm running into:
My curtains look like this in the standard domoticz page:
However, when adding them (standard way) in Dashticz, the curtains are not listed as dimmer/with a slider, so I can't set a percentage.
In domoticz, I configured them as "blinds percentage inverted"
Is there something I can do to make them listed with the slider from within Dashticz, without changing the switch type?
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
Swifty
Post by Swifty »
Anyone know of a good source for animated weather radar covering UK ?
I checked out Weather underground which works, but their images look very bad (very rough and blocky).
I also looked at OpenWeatherMap API, as their maps look really nice, but I can't work out how to get more than a single tiny tile...
robgeerts
Post by robgeerts »
booster wrote:I'm also starting to play around with Dashticz, and I'm trying to get the most important switches on the dashboard now.
I've added this type of device (dummy) to my domoticz so I can fix this.
Will be fixed asap!
repoman
Post by repoman »
robgeerts wrote:The bullets to swipe to other pages are back again.
Thnx!
booster
Post by booster »
robgeerts wrote: I've added this type of device (dummy) to my domoticz so I can fix this.
Will be fixed asap!
Great!!!! Thanks Rob!!
Connected to:
Trigun
Domoticz version: 4.10717
Post by Trigun »
Thnx!
Hi Guys,
I was also looking for this option but when I open custom.css the file seems empty. is this right or am I forgetting something:)
thanks i advance guys!
Grtz
EdwinK
Post by EdwinK »
Nope. It's correct. In this file you can add stuf you want. Such as rounded corners or in this case no bullets.
Trigun
Post by Trigun »
EdKo66 wrote:Nope. It's correct. In this file you can add stuf you want. Such as rounded corners or in this case no bullets.
Hi Edko, thnx for your reply!
can you help me a bit out here?
the code states:
CUSTOM CSS FILE
this is going to sound dumb but where do I need to put the code?
after the /* ....*/ ?
Locked
