HansieNL
Post by HansieNL »
remb0 wrote:When I use google maps the map is visible and after a few seconds i got: Oops something got wrong.
press F12 for ....
The message is that my api key isn't activated.
can somebody tell me how to create? I had it worked a few years before but I got the message: not activated now.
Have you checked here... https://developers.google.com/maps/docu ... avascript/
Blah blah blah
qwerk
Post by qwerk »
HansieNL wrote:
qwerk wrote:
robgeerts wrote:Impossible ;)
At least, if you are sure nothing gets cached and you have the latest beta ;)
I can make the impossible, possible
I tried everything, I removed the ":ss" from main.js where the variable is checked.
same result.
Sure the stationclock is getting his info from clock???
Ahhhh... You are using the nice stationclock. No, the variable is not for the stationclock.
As a workaround you can edit your main.js and change clock.secondHand = StationClock.HoleShapedSecondHand; to clock.secondHand = StationClock.NoSecondHand; and ask Rob to add a variable for it.
ok, we were talking beside each other ( lekker hollands)
I get it, I used the wrong clock for this.
I like the stationclock better, for now I will take the stottering second hand.
And I will ask Rob to add a variable.
thanks HansieNL
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
same result.
In latest beta the variable is ALSO for the stationclock :)
lukev
Post by lukev »
In latest beta, may scrolling is disabled? I have 3 pages, but cannout scroll. I do see three small dots in the bottom (smaller than before), but cannot reach page 2 and 3. I do see a small bit of the second page at the right border of the first page.
Someone else with this problem?
Edit: only seems to be broken in firefox...
wizjos
Post by wizjos »
lukev wrote:In latest beta, may scrolling is disabled? I have 3 pages, but cannout scroll. I do see three small dots in the bottom (smaller than before), but cannot reach page 2 and 3. I do see a small bit of the second page at the right border of the first page.
I can confirm that... In FF you see a small 'preview' of the next page. Edge doesn't show this. And indeed in both browsers the navigational dots are fairly small compared to before and blue instead of white (before)...
Wizjos
wizjos
Post by wizjos »
I can confirm that... In FF you see a small 'preview' of the next page at the far right. Edge doesn't show this. And indeed in both browsers the navigational dots are fairly small compared to before and blue in stead of white (before)...
Wizjos
robgeerts
Post by robgeerts »
Hmm its working fine at my laptop in firefox...
The dots where gone before but are back sinds last update... wil remove them again ;)
Try latest beta!
godinperson
Post by godinperson »
godinperson wrote:Can't place my rss. Would that link work: http://www.rds.ca/cmlink/le-fil-de-pres ... ttes-1.831 (French sports). I would also have another link which is in XML http://www.lapresse.ca/rss/225.xml
For the media player, which one is it? It would be nice to have a widget where it shows currently playing and basic control. I can help gather the information is you want.
For the RSS, I was able to make the XML work with crossorigin.me but, it displays the whole article. It would be nice to only have the Title, that way, we can display more news in less space
mkscity
Domoticz version: 3.5877
Post by mkscity »
in calendar i see for whole day entrys "hele dag" in front of entry, is there any way to change this to my language?
For sure i can do it in calendar.js but after every update it will change back. Using last beta.
Trigun
Domoticz version: 4.10717
Post by Trigun »
mvveelen wrote:I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
Hi mvveelen,
Did you manage to set this up? I am looking for a similar thing.
Grtz
Sent from my iPad using Tapatalk
HansieNL
Post by HansieNL »
robgeerts wrote:In latest beta the variable is ALSO for the stationclock :)
Nooooooo... I'm using the normal clock without seconds in 1st screen and StationClock with seconhand in 2nd screen.
Now my lovely secondhand of the StationClock is gone :cry:
Can you create for the StationClock secondhand an other variable?
Blah blah blah
robgeerts
Post by robgeerts »
Done in latest beta :)
New var voor stationclock is:
var _HIDE_SECONDS_IN_STATIONCLOCK = false;
EdwinK
Post by EdwinK »
Evil... Latest git pull wanted to overwrite my custom.js. ;) Luckily I always have backup :)
robgeerts
Post by robgeerts »
Yes I accidentially overwrote this file :( :( :(
PLEASE BACKUP PEOPLE!!
EdwinK
Post by EdwinK »
Good thing GIT warns you about it before you really do any damage
robgeerts
Post by robgeerts »
Trying to ingnore this file but because it is commited before this is not so easy ;)
EdwinK
Post by EdwinK »
No harm done. It was exact what I already had (minus the IDX)
robgeerts
Post by robgeerts »
Ok, fixed now but you can get the overwrite warning once more...
From then it wont happen again...
BACKUP CUSTOM.JS!
EdwinK
Post by EdwinK »
:) Thanks.
poudenes
Domoticz version: 3.8993
Post by poudenes »
robgeerts wrote:Trying to ingnore this file but because it is commited before this is not so easy ;)
Always responsibility of the user to make backups :) .. They cannot blame you .. You doing great work !! :)
Locked
