Posted: Tuesday 29 August 2023 17:59
Did you resubscribe? If so, msg me from Controlicz and I’ll get you working again
Open source Home Automation System
https://forum.domoticz.com/
Pliease help me with my Controlicz subscription: I reregistered, but the subcription fee is reservedd on my creditcard account, but my Contolicz account remains free and I cannot use voice control via DomoticzMadgeni wrote: Monday 28 August 2023 11:12 Hi all - for those that weren't aware, i've decided to keep Controlicz running. I've made changes to it to allow for the newer Domoticz versions (aligned changes to auth and API calls).
If you've lost access, it's highly likely it's due to an annual subscription expiring. I stopped them this year, so that people didn't pay for a service which was going to no longer be running. It's likely you had some free usage of Controlicz before i enforce expiration.
You will need to create a new account and subscribe monthly for now.
2023-10-17 12:10:54.553 Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.178.116.149)As per support mail, this is a 3d secure issue with your card provider. If you use PayPal you should be finenahoj wrote: Monday 09 October 2023 14:09Pliease help me with my Controlicz subscription: I reregistered, but the subcription fee is reservedd on my creditcard account, but my Contolicz account remains free and I cannot use voice control via DomoticzMadgeni wrote: Monday 28 August 2023 11:12 Hi all - for those that weren't aware, i've decided to keep Controlicz running. I've made changes to it to allow for the newer Domoticz versions (aligned changes to auth and API calls).
Failed auth attempts on Domoticz side, check basic-auth is set, and/or restart Domoticz (which refreshes security model afaik).JimmyH1969 wrote: Tuesday 17 October 2023 12:14 Yes, same here...
Also when testing the connection i get this in the Domoticz log:It all used to work fine until i had to re-register again.... any ideas?Code: Select all
Sometimes it's so simple... all working fine now. Thank you!Madgeni wrote: Tuesday 17 October 2023 12:18Failed auth attempts on Domoticz side, check basic-auth is set, and/or restart Domoticz (which refreshes security model afaik).JimmyH1969 wrote: Tuesday 17 October 2023 12:14 Yes, same here...
Hmm strange.
I sent a msg on the Controlicz webpage but I haven't heard anything back.Madgeni wrote: Monday 05 August 2024 18:16 Late to this, but best thing is to msg me via Controlicz profile. Also, check your test works ok, and you can see your devices in your profile
