Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by Madgeni »
Did you resubscribe? If so, msg me from Controlicz and I’ll get you working again :)
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
disable/enable skill
working now
frenchyyii
Post by frenchyyii »
Hi Madgeni, just a quick feeback as I'm back home.
After re suscribe with new user and reactivate skills everything is ok !!
And really... thanx for keeping it running, that's a very good news 8-)
Account: french.......hotmail
nahoj
Post by nahoj »
Madgeni wrote: Monday 28 August 2023 11:12 Hi all - for those that weren't aware, i've decided to keep Controlicz running. I've made changes to it to allow for the newer Domoticz versions (aligned changes to auth and API calls).
If you've lost access, it's highly likely it's due to an annual subscription expiring. I stopped them this year, so that people didn't pay for a service which was going to no longer be running. It's likely you had some free usage of Controlicz before i enforce expiration.
You will need to create a new account and subscribe monthly for now.
Pliease help me with my Controlicz subscription: I reregistered, but the subcription fee is reservedd on my creditcard account, but my Contolicz account remains free and I cannot use voice control via Domoticz
JimmyH1969
Post by JimmyH1969 »
Yes, same here...
Also when testing the connection i get this in the Domoticz log:
2023-10-17 12:10:54.553 Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.178.116.149)
It all used to work fine until i had to re-register again.... any ideas?
Madgeni
Post by Madgeni »
nahoj wrote: Monday 09 October 2023 14:09
As per support mail, this is a 3d secure issue with your card provider. If you use PayPal you should be fine
Madgeni
Post by Madgeni »
JimmyH1969 wrote: Tuesday 17 October 2023 12:14 Yes, same here...
Failed auth attempts on Domoticz side, check basic-auth is set, and/or restart Domoticz (which refreshes security model afaik).
JimmyH1969
Madgeni wrote: Tuesday 17 October 2023 12:18
Sometimes it's so simple... all working fine now. Thank you!
JanJaap
Domoticz version: Dev
Post by JanJaap »
Since some time (guess around 1-2 weeks) Google is not connecting to Controlicz anymore. Controlicz connection to Domotucz is fine (test connection says all is ok and device status is nicely updated in controlicz when I make a change from domoticz). Anything that I can check? Known issue? Google updating their API's?
Madgeni
Post by Madgeni »
hi - sorry, only just seen this. all is fine with Controlicz - hopefully you resolved this (maybe subscription?) , but if not, drop me a support email from Controlicz, and i'll see what's happening
JanJaap
Post by JanJaap »
Indeed it still is an issue. Dropped a note via controlicz as requested.
Varazir
Post by Varazir »
Anyone ells having issue with Controlicz? It's not working. Webpage say ok on test but google say my devices are offline and trying to re-authenticate I get a error saying it can't contact Controlicz
mark.sellwood
Post by mark.sellwood »
Working for me
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Varazir
Post by Varazir »
mark.sellwood wrote: Wednesday 24 July 2024 20:19 Working for me
Hmm strange.
Varazir
Post by Varazir »
Tried to remove and add it again and got the same error :(
Madgeni
Post by Madgeni »
Late to this, but best thing is to msg me via Controlicz profile. Also, check your test works ok, and you can see your devices in your profile
Varazir
Post by Varazir »
Madgeni wrote: Monday 05 August 2024 18:16 Late to this, but best thing is to msg me via Controlicz profile. Also, check your test works ok, and you can see your devices in your profile
I sent a msg on the Controlicz webpage but I haven't heard anything back.
Madgeni
Post by Madgeni »
Hi - I don’t seem to have received one. What’s the issue?
Are you able to access Domoticz remotely? Does the test work?
