robgeerts
Domoticz version: 3.7067
Post by robgeerts »
I'll add a function to make it mich more clear if there are any errors in the code because of a faulty config.js in upcoming days ;)
Meanwhile, please post your whole config.js
godinperson
Post by godinperson »
var _LANGUAGE                   = 'en_US'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ              = 'http://10.XX.XX.XX:8080';
var _DOMOTICZ_REFRESH           = 5; //in seconds
var _DASHTICZ_REFRESH           = 30; //in minutes
var _HOST_ZIGGO_HORIZON         = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND        = '25c928fxxxxx';
var _WEATHER_CITY               = 'Saint-X, Quebec';
var _WEATHER_CITYNAME           = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY            = 'CA';
var _USE_AUTO_POSITIONING       = true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES              = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = false; //do not show the seconds in the clock
var _NEWS_RSSFEED               = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT             = false;
var _USE_BEAUFORT               = true; //Bft instead of m/s
var _TRANSLATE_SPEED            = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES      = 10; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER          = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE            = true;
var _LASTUPDATE_FORMAT          = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT        = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _APIKEY_MAPS                = '';
var _MAPS_LATITUDE              = '4X.XXXXX';
var _MAPS_LONGITUDE             = '-7X.XXXX';
var _AUTO_SWIPEBACK_TO          = 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME        = 10; //seconds
// Online Radio Stream Plugin, Note: you must enable  plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS        = [
        {"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3"},
        {"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3"},
        {"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3"},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var _ICALENDAR_URL              = 'https://testurl.com/ical.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT       = 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE           = 'en'; //en,hu, etc.
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
//blocks[1] = {}
//blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
//blocks[1]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks[1]['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
//blocks[204] = {} //dimmer
//blocks[204]['width'] = 12;
//blocks[204]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks['blocktitle_1'] = {}
//blocks['blocktitle_1']['type'] = 'blocktitle';
//blocks['blocktitle_1']['title'] = 'Schakelaars';
//var columns = {}
//columns[1] = {}
//columns[1]['blocks'] = ['blocktitle_1',1,2,62,'144_2',204,248,295] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
//columns[1]['width'] = 5;
//columns[2] = {}
//columns[2]['blocks'] = ['currentweather_big','weather',5,'144_1']
//columns[2]['width'] = 5;
//columns[3] = {}
//columns[3]['blocks'] = ['clock','sunrise','horizon','streamplayer',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
//columns[3]['width'] = 2;
//var columns_standby = {}
//columns_standby[1] = {}
//columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//columns_standby[1]['width'] = 12;
//if you want to use multiple screens, use the code below:
//var screens = {}
//screens[1] = {}
//screens[1]['background'] = 'bg1.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
//screens[1]['columns'] = [1,2,3]
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['background_morning'] = 'bg_morning.jpg';
//screens[2]['background_noon'] = 'bg_noon.jpg';
//screens[2]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[2]['background_night'] = 'bg_night.jpg';
//screens[2]['columns'] = [4,5,6]
EdwinK
Post by EdwinK »
Are you sure that your internal ip address to domoticz or port are correct?
Btw. Next time, please use [c o d e] and [/ c o d e] tags when posting codes. (Remove the spaces).
godinperson
Yep, pretty sure the IP because if I remove the /dashboard/, I get my Domoticz.
Even installed dashboardbeta but getting the same thing
michaldobrotka
Post by michaldobrotka »
Hi, for those who is adding weather map to your Dashticz and looking for one try http://en.sat24.com/en/freeimages ;)
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
robgeerts
Re: Server notifications?
Post by robgeerts »
Latest version should update the statuses..
Do you get any console errors?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
bsmeding wrote:and the variable _SHOW_LASTUPDATE = true in CONFIG.js?
So i set variable _SHOW_LASTUPDATE = true and it works with the lines lastupdate in custom.js.
Now i have to set in all blocks that i dont want lastupdate to false.
I had it set variable _SHOW_LASTUPDATE = false and in some blocks i set show last update = true and that works.
But for some reason that doesn't work when you use custom.js to modify some text for switch.
Thanks for the help
tontze
Domoticz version: Beta Ch
Post by tontze »
HI !
My dashboard are starting to shape :P But i have one thing i would like to do. In picture below, i have calendar in left upper corner, what i would like, is its size to be half, and add another calendar besides it. I just dont get it how to do it .. Now its is just added to columns :
columns[10] = {}
columns[10]['blocks'] = ['clock',calendars.hobbydeed,118,119,120,121,122,123,2,134,135,144]
columns[10]['width'] = 5;
Also, i see that in beta there is some sort off pre selection for rgb bulbs, can they be used and if so, how ?
Thnx -T
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
axelbaas
Post by axelbaas »
For the third day in a row, i got this email from WU.
Your wunderground API key (XXXXX) exceeded its allotted usage today by making 502 calls in a day but the limit is 500.
Is it possible to reduce the amount of API calls to WU?
robgeerts
Post by robgeerts »
You could try setting this variable in config.js to a higher number...
var _DASHTICZ_REFRESH		= 480;
robgeerts
Post by robgeerts »
tontze wrote:HI !
columns[10] = {}
Thnx -T
Both, not yet possible.
tontze
Post by tontze »
Ok, thnx :) With the updated calendar plugin, it looks better now, more events to be seen :) Thnx rogbeerts
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
Post by robgeerts »
Well, that will be a setting in upcoming version...
godinperson
var buttons = {}
//blocks[1] = {}
//var columns = {}
//columns[1] = {}
//columns[2] = {}
//columns[3] = {}
//var screens = {}
//screens[1] = {}
//screens[2] = {}
Please don't forget my post. I would really like this dashboard to work!!!
Thanks guys!
robgeerts
Post by robgeerts »
If you try latest beta, do you get an error alert?
repoman
Post by repoman »
repoman wrote:Hi folks,
I've downloaded the latest beta and i like the moving weather icons. I'm also happy to see that the news items are scrolling again. Thnx!
The problem I have is with the dual output blocks. I'm using a youless device to monitor energy usage.
When I use 'idx_1' I get te total power usage of today and when I use 'idx_2' I get the total power usage.
I would like to see the current power usage. ('ídx_3' gives me an emty block...)
Related to this is are the temperature sensors. I suspect it should be possible to use i.e. 'idx_1'for temperature and 'idx_2' for humidity but it doesn't.
I still get two blocks while I only need the temperature reading..
Probably something stupid but I can't find it in the wiki..
A little help is much appreciated.
Thnx,
Pascal
Any suggestions?
poudenes
Domoticz version: 3.8993
Post by poudenes »
In latest beta the calendar looks better. i See repeated items now. Only it shows now old items from past. :) but the repeated items are visible now haha
godinperson
Pretty much the same background only image.
robgeerts
Post by robgeerts »
Have you checked console (f12) for any errors? And checked the network tab in console for any red lines?
godinperson
The only console error I have is: [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Network tab seems fine.
Locked
