FlatZ Frontpage
rebelo
Domoticz version: 3.5877
Re: FlatZ Frontpage
Post by rebelo »
@ stavroshamster
When You say:
Then there is some JavaScript code to read the SetPoint and pass it to the 'insert' div, noting that the '11' here is the position of the thermostat in the resulting JSON information:
what is the meaning of this?
Is it different from the idx?
What number shall i consider from the following json info:
        "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "16.0",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "NETATMO",
         "HardwareType" : "Netatmo",
         "HardwareTypeVal" : 54,
         "HaveTimeout" : false,
         "ID" : "000004C",
         "LastUpdate" : "2017-02-09 10:46:11",
         "Name" : "NETATMO_SETPOINT",
         "Notifications" : "false",
         "PlanID" : "3",
         "PlanIDs" : [ 3, 4 ],
         "Protected" : false,
         "SetPoint" : "16.0",
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "5"
Tks
Rebelo
rebelo
Re: FlatZ Frontpage
Post by rebelo »
rebelo wrote:@ stavroshamster
When You say:
        "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "16.0",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "ID" : "000004C",
         "PlanID" : "3",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "5"
Tks
Rebelo
Will answer myself.
It was not easy to find the position of the thermostat in the resulting JSON information.
Assumed that it was the 'data' field from the set poit counting from the begining of the list but it wasn't.
Have so used a test page like bellow and changed the numbers in [ ]till the correct set point value was shown.
Enjoy it.
<!DOCTYPE html>
<html>
 <head>
  <title>Title</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <script src="http://code.jquery.com/jquery.js"></script>
 </head>
 <body>
 <script>
  $(document).ready(function(){
   //We request a list of all sensor data
   $.getJSON("http://domoticz ip:port/json.htm?type=devices&filter=all&used=true&order=Name", function(result){
 document.getElementById("sensor-container").innerHTML += '<div>'+
     '<h4>' + result.result[5].Name + '</h4>'+
     '<h5>Status: ' + result.result[5].Data + '</h5>'+
     '<p>Updated: ' + result.result[5].LastUpdate +'</p>'+
    '</div>';
 </script>
<div id="sensor-container">
</div>
rebelo
Re: Redraw
Post by rebelo »
Btje wrote:What I see is that pies redraw al the time. Is this configurable?
Hi Btje, try to replace the highcharts.js in the js folder by the most recent one from http://www.highcharts.com/.
In my case it solved the issue.
levynger
Re: FlatZ Frontpage
Post by levynger »
Really liked the UI, i;ve been trying now to make it work.
I have the page loaded sucessfully, and connected to domoticz.
however for some strange behaviour, the same Switch works under Graph tab and not in Lights/Dashboard page
the switch is 'button' (type On/Off) -
in the Dashboard setting.js:
.PageDashboardArray = [
    //switches
    ['37', 'Data', 'cell1', 'Room Lights', 'button'],//onbutton = only push on
the same switch appears in PageSwitchArray in the settings, and in Graph/Traffic it seems to work fine.
$.PageSwitchArray = [
    //switches (left sidebar)
    ['37', 'Data', 'cell1', 'Room Lights1', 'button'],//onbutton = only push on
I've been sniffing the json GET commands, at leats for the sucessfull, i have found:
http://*******:********@192.168.*.***:8*8*/json.htm?type=command&param=switchlight&idx=37&switchcmd=On&level=0&passcode=&jsoncallback=jQuery214048847436707621905_1487621397244&_=1487621397254
which is missing 'level' and 'passcode; params in it.
                url: $.domoticzurl + "/json.htm?type=command&param=switchlight" + "&idx=" + idx + "&switchcmd=" + switchcmd + "&level=0",
i couldnt find the code for the graph/weather pages that construct the GET command to compare.
or perhaps im doing something wrong in the cofigration..
EDIT: found the culprit, had to change the json command to:
url: $.domoticzurl + "/json.htm?type=command&param=switchlight" + "&idx=" + idx + "&switchcmd=" + switchcmd + "&passcode=&jsoncallback=?",
stingone
Re: FlatZ Frontpage
Post by stingone »
Is it possible to run it from a sub folder in the www folder? Just tried to test but all devices stay Black.
rebelo
Re: FlatZ Frontpage
Post by rebelo »
stingone wrote:Is it possible to run it from a sub folder in the www folder? Just tried to test but all devices stay Black.
It is, that's the way we have it.
What is Your $.domoticzurl in settings.js?
stingone
Re: FlatZ Frontpage
Post by stingone »
Strange i had to login in domoticz itself before it was working, however i had al login information included in the config file.
one issue i ran into now is that the "button" is not working as a switch. i can only use it for turning on a device but switching off does not work.
rebelo
Re: FlatZ Frontpage
Post by rebelo »
stingone wrote:Strange i had to login in domoticz itself before it was working, however i had al login information included in the config file.
I believe user and pass in url do not work, now, in most of the browsers.
Try to white list your Local Network (no username/password) in the Domoticz settings page.
Or use the remember user/pass feature of the browser.
stingone
Re: FlatZ Frontpage
Post by stingone »
Ok wil do :) last one... how can i change the camera page to 1 cam and full size over the page instead of 6 small cams.
rebelo
Re: FlatZ Frontpage
Post by rebelo »
stingone wrote:Ok wil do :) last one... how can i change the camera page to 1 cam and full size over the page instead of 6 small cams.
You have to play with the css and html files.
Try to use the one from weather that is a full page...
Enjoy ;-)
stingone
Re: FlatZ Frontpage
Post by stingone »
Enjoy ;-)
Great works like a charm,
Still having the button issue only works as a on button... and is it possible to access the flatz frontpage from outside LAN? i use a dns name to access domoticz via 443 ssl. however the page stays empty after login
rebelo
Re: FlatZ Frontpage
Post by rebelo »
stingone wrote:Great works like a charm,
Good.
Abt the button not quite sure what might be the issue.
What do You see in the logs?
From outside the lan i get only the weather page working.
Reason might be having it in a folder inside the www folder...
Do You want to access it via android? Domoticz app 2.0 from https://www.domoticz.com/forum/viewtopi ... =37&t=8884 is really good for that.
Maartenkr
Domoticz version: 3.7196
Re: FlatZ Frontpage
Post by Maartenkr »
i have a question
I have ad a extra trend only I get the size not the same who can help me?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head>
    <meta charset="utf-8">
    <title>Fat-Huis</title>
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <meta name="viewport" content="width=device-width, initial-scale=1,maximum-scale=1,user-scalable=no" />
    <meta name="apple-mobile-web-app-capable" content="yes" />
    <meta name="mobile-web-app-capable" content="yes" />
    <meta name="apple-mobile-web-app-status-bar-style" content="black-translucent" />
    <link rel="stylesheet" type="text/css" href="bootstrap/css/bootstrap.min.css" />
    <link rel="stylesheet" href="css/main.css" />
    <link href="css/icons.css" rel="stylesheet">
    <script type="text/javascript" src="js/jquery-2.1.4.js"></script>
    <script type="text/javascript" src="js/highcharts.js"></script>
    <script type="text/javascript" src="js/jquery.noty.packaged.js"></script>
    <script type="text/javascript" src="settings/settings.js"></script>
    <script type="text/javascript" src="js/noty.js"></script>
    <script type="text/javascript" src="js/methods.js"></script>
    <script type="text/javascript" src="js/jquery.stayInWebApp.min.js"></script>
    <script type="text/javascript" src="bootstrap/js/bootstrap.js"></script>
    <style type="text/css">
        body {
            padding-top: 60px;
    </style>
    <!-- Le HTML5 shim, for IE6-8 support of HTML5 elements -->
    <!--[if lt IE 9]>
      <script src="https://html5shim.googlecode.com/svn/trunk/html5.js"></script>
      <![endif]-->
    <!-- Google Fonts call. Font Used Open Sans & Raleway -->
    <link href="https://fonts.googleapis.com/css?family=Raleway:400,300" rel="stylesheet" type="text/css">
    <link href="https://fonts.googleapis.com/css?family=Open+Sans" rel="stylesheet" type="text/css">
</head>
<body>
    <div class="navbar-nav navbar-inverse navbar-fixed-top">
        <div class="container">
            <div class="navbar-header">
                <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
                    <span class="icon-bar"></span>
                </button>
                <a class="navbar-brand" href="index.html">Fat-Huis</a>
            </div>
            <div class="navbar-collapse collapse">
                <ul class="nav navbar-nav">
                    <li><a class="stay" href="index.html"><i class="icon-home icon-white"></i> Home</a></li>
                    <script>
                        if ($.Lights) {
                            document.write('<li ><a class="stay" href="lights.html"><i class="icon-th icon-white"></i> Verlichting</a></li>');
                    </script>
                    <script>
                        if ($.Graph) {
                            document.write('<li class="active"><a class="stay" href="graph.html"><i class="icon-th icon-white"></i> Trend</a></li>');
                    </script>
                    <script>
                        if ($.Camera) {
                            document.write('<li><a class="stay" href="camera.html"><i class="icon-th icon-white"></i> Camera</a></li>');
                    </script>
                    <script>
                        if ($.Weather) {
                            document.write('<li ><a class="stay" href="weather.html"><i class="icon-th icon-white"></i> Weer</a></li>');
                    </script>
                    <script>
                        if ($.News) {
                            document.write('<li ><a class="stay" href="news.html"><i class="icon-th icon-white"></i> Nieuws</a></li>');
                    </script>
                    <script>
                        if ($.Traffic) {
                            document.write('<li ><a class="stay" href="traffic.html"><i class="icon-th icon-white"></i> Verkeer</a></li>');
                    </script>
                    <script>
                        if ($.Log) {
                            document.write('<li><a class="stay" href="logs.html"><i class="icon-th icon-white"></i> Log</a></li>');
                    </script>
                </ul>
            </div>
            <!--/.nav-collapse -->
        </div>
    </div>
        <!-- FIRST ROW OF Domoticz -->
        <div class="row">
            <!-- SWITCHES Domoticz -->
            <div class="col-sm-3 col-x-3">
                <div class="dash-unit" style="height: 610px;">
                    <dtitle>Schakelaar</dtitle>
                    <hr>
                    <!-- ICON -->
                    <div class="info-user">
                        <span aria-hidden="true" class="li_params fs2"></span>
                    </div>
                    <br>
                    <center>
                        <dtitle id="desc_cell1"></dtitle>
                    </center>
                    <center>
                        <div id="cell1" style="margin-top:5px;width:60px;"></div>
                    </center>
                    <center>
                        <dtitle id="desc_cell2"></dtitle>
                    </center>
                    <center>
                        <div id="cell2" style="margin-top:5px;width:60px;"></div>
                    </center>
                    <center>
                        <dtitle id="desc_cell3"></dtitle>
                    </center>
                    <center>
                        <div id="cell3" style="margin-top:5px;width:60px;"></div>
                    </center>
                    <center>
                        <dtitle id="desc_cell4"></dtitle>
                    </center>
                    <center>
                        <div id="cell4" style="margin-top:5px;width:60px;"></div>
                    </center>
                    <center>
                        <dtitle id="desc_cell5"></dtitle>
                    </center>
                    <center>
                        <div id="cell5" style="margin-top:5px;width:60px;"></div>
                    </center>
                    <center>
                        <dtitle id="desc_cell6"></dtitle>
                    </center>
                    <center>
                        <div id="cell6" style="margin-top:5px;width:60px;"></div>
						<center>
                        <dtitle id="desc_cell12"></dtitle>
                    </center>
                    <center>
                        <div id="cell12" style="margin-top:5px;width:60px;"></div>
                    </center>
                    </center>
                </div>
            </div>
            <!-- DONUT CHART -->
            <div class="col-sm-3 col-lg-3 largemobilefix" >
                <div class="dash-unit" style="height:190px;">
                    <dtitle id="desc_cell7"></dtitle>
                    <hr>
                    <div id="graph100" style="height: 13em;margin: auto;margin-top: -17px"></div>
                    <h4 id="cell7" style="margin-top:-35px;"></h4>
                  <span class=" text" id="cell70" style="margin-top:-5px;float:right;padding-right:10px;font-size: 10px;color: #9E9E9E; "/>
               </div>
            </div>
         </div>
         <!-- /row -->
         <div >
            <div class="col-sm-3 col-lg-3 largegraphmobilefix">
               <div class="dash-unit" style="height:190px; ">
                  <dtitle id="desc_cell8" ></dtitle>
                  <hr>
                  <div id="graph200" style="height: 13em;margin: auto;margin-top: -17px "></div>
                  <h4 id="cell8" style="margin-top:-35px; "></h4>
                  <span class="text" id="cell80" style="margin-top:-5px;float:right;padding-right:10px;font-size: 10px;color: #9E9E9E; "/>
               </div>
            </div>
         </div>
         <!-- /row -->
         <div>
            <div class="col-sm-3 col-lg-3 largegraphmobilefix2" >
                  <dtitle id="desc_cell10" ></dtitle>
                  <hr>
                  <div id="graph300" style="height: 13em;margin: auto;margin-top: -17px "></div>
                  <h4 id="cell10" style="margin-top:-35px;"></h4>
                    <p><span class="text" id="cell100" style="margin-top:-5px;float:right;padding-right:10px;font-size: 10px;color: #9E9E9E;" /></p>
                    <p>&nbsp;</p>
                    <div class="col-sm-3 largegraphmobilefix3 col-lg-12" >
                        <dtitle id="desc_cell11" ></dtitle>
                        <hr />
                        <div id="graph400" style="height: 13em;margin: auto;margin-top: -17px "></div>
                        <h4 id="cell11" style="margin-top:-35px;"></h4>
                        <span class="text" id="cell110" style="margin-top:-5px;float:right;padding-right:10px;font-size: 10px;color: #9E9E9E;" /></span> </div>
                    </div>
                    <p>&nbsp;</p>
                </div>
            </div>
        </div>
        <!-- /row -->
		         <div>
        <!-- DONUT CHART --></div>
        <!-- /row -->
		<!-- /row -->
    </div>
    <!-- /container -->
    <script type="text/javascript" charset="utf-8">
        $(document).ready(function() {
            $(function() {
                $.stayInWebApp('a.stay');
            loadCSS("css/" + $.theme);
            RefreshSwitchData();
            RefreshGraphData();
    </script>
</body>
</html>
JeanChristophe
Re: FlatZ Frontpage
Post by JeanChristophe »
sorampage wrote:
sorampage wrote:Hi all,
It's possible to add Blinds ??
I have some switches in my Domoticz for my blinds, I have 1 ID per Blinds, but 3 switches for one blind ... (Open,Stop,Close) PJ
If anyone has an idea .. :)
Someone can help me ?
I can't. Sorry.
But I'm interested too :)
Martijn85
Domoticz version: Stable
Re: FlatZ Frontpage
Post by Martijn85 »
My Philips Hue lights don`t work correctly. FlatZ sees when the are off or on but i can't switch them on or off. I also can't set any color.
Can someone tell me what's wrong here?
// Light screen User settings >>>
$.LightArray = [
    //format: idx, 'Hue' (color lamp) or 'Dimmer' (for normal dimmer), replace label, description, maxdimlevel
    ['348', 'Hue', 'cell7', 'Lamp TV'],
    ['349', 'Hue', 'cell8', 'Lamp Bank (Klein)'],
    ['350', 'Hue', 'cell10', 'Lamp Bank (Groot)'],
    ['109', 'Hue', 'cell11', 'Tafel 4'], //demo
    ['111', 'Hue', 'cell12', 'Spot 1 (TV)'], //demo
    ['112', 'Hue', 'cell13', 'Spot 1 (Bank)'], //demo
sander
Domoticz version: latest..
Re: FlatZ Frontpage
Post by sander »
Hi, I am having the same issue getting it to work on my pi. How did you get it going? did you unzip it with the pi command ...?
Raspberry Pi 2B+
connected: klik aan klik uit switches, dimmers, weather station, water meter (pulse)
Automation use: Blocky
johnwulp
Domoticz version: 3.4834
Re: FlatZ Frontpage
Post by johnwulp »
I'm trying to get my power consumption in one graph. Problem is that around 23.00 we switch over to a lower rate. In JSON this is returned as V and V2. See screenshot below.
Currently, i can only specify the day or night counter (V or V2) with:
['19', 'counter', 'day', 'cell7', 'Stroom (Watt)', 'graph100', '#b2c831', 'v2']
Result in the graph:
Is there a way to use the V value and V2 together?
if it ain't broke don't fix it!
Jochem
Domoticz version: 4.10181
Re: FlatZ Frontpage
Post by Jochem »
When I do: http://192.168.1.9:8080/json.htm?type=d ... ncallback=?
I recieve the message: -bash: http://192.168.1.9:8080/json.htm?type=devices: No such file or directory
whats going wrong???
For now I have a huge list of devices and their code, but when I add the IDX numbers for the side bar, only the switch disappear on the screen and I cannot change the setting of it. why can I not choose IDX 2 for switching off to switch off everything at the house.
I speciale setup some scenes to switch off a group of lamps (see picture)
Test 001.png (160.92 KiB) Viewed 4504 times
Raspberry P3, RF-Link FW version 48, lots of KAKU switches, Sonos connected, LG TV switching, a lot of weather switches.
