Siri / HomeKit support for Domoticz
ivom74
Re: Siri / HomeKit support for Domoticz
Post by ivom74 »
I overwrite /home/pi/homebridge/platforms/Domoticz.js with the file from the forum.
Now I get the following error: Error: Cannot find module '../lib/HAP-NodeJS/accessories/types.js
How can I install this?
> [email protected] start /home/pi/homebridge
> node app.js
Starting HomeBridge server...
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Loading 1 platforms...
module.js:338
    throw err;
Error: Cannot find module '../lib/HAP-NodeJS/accessories/types.js'
    at Function.Module._resolveFilename (module.js:336:15)
    at Function.Module._load (module.js:278:25)
    at Module.require (module.js:365:17)
    at require (module.js:384:17)
    at Object.<anonymous> (/home/pi/homebridge/platforms/Domoticz.js:32:13)
    at Module._compile (module.js:460:26)
    at Object.Module._extensions..js (module.js:478:10)
    at Module.load (module.js:355:32)
    at Function.Module._load (module.js:310:12)
npm ERR! Linux 4.1.4-v7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.6
npm ERR! npm  v2.11.2
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR!     node app.js
npm ERR! You can get their info via:
npm ERR!     npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR!     /home/pi/homebridge/npm-debug.log
G3rard
Domoticz version: No
Post by G3rard »
Follow the wiki procedure and NodeJS will be installed.
Not using Domoticz anymore
ivom74
Post by ivom74 »
G3rard wrote:Follow the wiki procedure and NodeJS will be installed.
I did that, and it looks like it's installed. The directory node.js contains 1 file: node_latest_armhf.deb
pi@raspberrypi ~/node.js $ node -v
v0.12.6
[code]pi@raspberrypi ~/node.js $ sudo dpkg -i node_latest_armhf.deb
(Reading database ... 96771 files and directories currently installed.)
Preparing to replace node 0.12.6-1 (using node_latest_armhf.deb) ...
Unpacking replacement node ...
Setting up node (0.12.6-1) ...
Processing triggers for man-db ...
What did I miss? by the way, thank you for your fast reply. Really nice the help I get on this forum !
G3rard
Post by G3rard »
I would suggest you do a new full install following the wiki. In the log there is also an error regarding homebridge.
ivom74
Post by ivom74 »
G3rard wrote:I would suggest you do a new full install following the wiki. In the log there is also an error regarding homebridge.
I think i have to wait for a complete image for raspberry pi 2. I did a fresh install on the pi 1 and didn't get it to work. On the pi 2 it worked a little bit, just warnings but now i got errors. After copy of the Domoticz module file it doesn't work anymore.
I really like this application, works nice to control by voice.
ivom74
Post by ivom74 »
I wonder what command installs the /home/pi/homebridge/lib directory? I tried a clean install before but didn't find this directory??
Is it a link or something?
G3rard
Post by G3rard »
I don't have that lib folder.
Maybe you can check this link for install on a Pi https://github.com/nfarina/homebridge/w ... spberry-Pi
G3rard
Post by G3rard »
A new bridged mode is implemented lately https://github.com/nfarina/homebridge/w ... tion-Guide
Anyone tried this already? And does that mean changes to Domoticz.js have to be made?
Eduard
Post by Eduard »
G3rard wrote:A new bridged mode is implemented lately https://github.com/nfarina/homebridge/w ... tion-Guide
Works great! In iOS HomeKit you only have to pair HomeBridge once! Every change (add or rename a switch for example) is updated after a restart of the HomeBridge service. You don't have to add all your switches one by one.
If you have for example 3 switches in a room, only adding HomeBridge in HomeKit wil actually add all 3 switches!!
G3rard
Post by G3rard »
Great, that's indeed a lot easier! Thanks for the feedback, will update to that new version as well.
Eduard
Post by Eduard »
G3rard wrote:Great, that's indeed a lot easier! Thanks for the feedback, will update to that new version as well.
BTW, how do you upgrade to a new version? I did an new wget clone, npm install but that takes a long (compile-)time. Is there a faster way?
G3rard
Post by G3rard »
No idea yet how to upgrade, so I certainly don't know if there is a faster way...
Which steps did you follow?
Eduard
Post by Eduard »
G3rard wrote:No idea yet how to upgrade, so I certainly don't know if there is a faster way...
I just renamed the HomeBridge folder to HomeBridge old and started to follow the Wiki to install from scratch
[EDIT] Also no problems anymore with the perstist-folder :D
G3rard
Post by G3rard »
I did the same, but got an error...
/home/pi/homebridge/node_modules/HAP-NodeJS/lib/Accessory.js:159
      throw new Error("Cannot add a bridged Accessory with the same UUID as an
Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 89330305-7111-49e4-96e7-fc81521a1b39
Same issue as http://www.domoticz.com/forum/viewtopic ... 285#p52285.
Even if I only add one device to the room the issue is there...
This is my config.json
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for Domoticz platform.",
    "platforms": [
            "platform": "Domoticz",
            "name": "Domoticz",
            "server": "192.168.1.102",
            "port": "8084",
	         "roomid": "11"
    "accessories": [
Eduard
Post by Eduard »
Should be fixed in the latest version, i did not test this yet.
My solution what to disable the get-scene code in Domoticz.js :D
G3rard
Post by G3rard »
I used the latest version, so the issue seems to be still there.
I will disable the scene part in Domoticz.js.
Eduard
Post by Eduard »
G3rard wrote:I used the latest version, so the issue seems to be still there.
Sorry, it was in a test-branch. It is now merged into the master-branche. Please try again
G3rard
Post by G3rard »
Great, I just saw that on GitHub. Will try it this evening.
[Edit] New install worked. First still a issue in Eve (homekit app) when I had added scenes to the room. But when removing the scenes from the room it worked. The scenes are standard added to homekit.
wokkelp
Post by wokkelp »
Okay, I think I got it running now.
This is my output:
> DEBUG=* node app.js || true
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdn ... ceRegister>
_____________________________________________________________________
IMPORTANT: Homebridge is in the middle of some big changes.
Read more about it here:
[Domoticz] Initializing Domoticz platform...
[Domoticz] Fetching Domoticz lights and switches...
Loading 0 accessories...
[Domoticz] Initializing platform accessory 'Eetkamer 1'...
[Domoticz] Loaded services for Eetkamer 1
[Domoticz] Initializing platform accessory 'Keuken 1'...
[Domoticz] Loaded services for Keuken 1
[Domoticz] Initializing platform accessory 'Woonkamer 1'...
[Domoticz] Loaded services for Woonkamer 1
[Domoticz] Initializing platform accessory 'Woonkamer 2'...
[Domoticz] Loaded services for Woonkamer 2
[Domoticz] Initializing platform accessory 'Woonkamer 3'...
[Domoticz] Loaded services for Woonkamer 3
[Domoticz] Initializing platform accessory 'Alles AAN'...
[Domoticz] Loaded services for Alles AAN
[Domoticz] Initializing platform accessory 'Alles UIT'...
[Domoticz] Loaded services for Alles UIT
EventedHTTPServer Server listening on port 51826 +0ms
I think it is working..?
But somehow I can't see anything popping up in Insteon or in Eve....
The devices are both in the same subnet.
G3rard
Post by G3rard »
wokkelp wrote:Okay, I think I got it running now.
This is my output:
Have you put scenes in the room in Domoticz? I had that and then it doesn't seem to work. Just remove the scenes from the room as they are imported anyway.
Then restart Homebridge and clear the Homekit on your iOS. Then it should work.
