Geofence for Domoticz
Appesteijn
Re: Geofence for Domoticz
Post by Appesteijn »
thecosmicgate wrote:Okay back again : domofence was working for a fews days (i think) but at the moment when we entered the zone , it doesn't send the "on" signal.
When we manually press the "test connection" it is working fine ;(
Then I'm afraid I'm out of options :( Maybe someone else has any ideas?
atlej
Domoticz version: Stable
Post by atlej »
I see the same behavior on my Sony xperia z1c with android 5.1.1
-test button works and trigger my switch, the app nicely reports leaving and entering the zone, but this does not trigger the switch....
Is there a way I can get an older build for testing?
-what is on google play store seems to be an attempt to fix something for android 7.
Atle
Appesteijn
The code is the same, I only didn't build the app for the latest android version (7.1). So it should use functionality of android 6.
When the app doesn't switch your virtual switch, could you try to disable and then enable your wifi? I would like to know if it switches the switch after this action.
atlej
Post by atlej »
Tested some more, the problem was that the app could not reach my server when on the mobile network. (worked only on wifi.)
Reinstalled when on mobile network ( turned wifi off), and now it connects fine..
Atle
sisaenkov
Domoticz version: 3.8
Post by sisaenkov »
Hello.
Device: Xiaomi Mi5
Android: 6.0.1
I got error "GoogleApiClient not yet connected" when I try to save a point.
Test connection is ok.
Solved after Android System WebView install.
Appesteijn
Thanks for posting your solutions, this might help other people!
Attie
Post by Attie »
Hello.
Device: Huawei P9 Lite
Android: 7.0
Same issues here. Switch will not turn Off.
When I push the test connection button on 3G the switch is updated by an On command. But by the second push I see a new On command.
So the connection is working fine. Should I see an Off command by the second push?
Appesteijn
Attie wrote:Hello.
Android: 7.0
The test button only sends a 'on' command. The second time you press it, it will also send an 'on' command.
sundberg84
Post by sundberg84 »
I have this issue as well - When I add the fence it updates the first time, but then not the off (even if i get a notification that i left the area). I will reinstall and see what happens.
Controller: Domoticz (Raspberry PI)
Gateways: MySensors (Ethernet W5100), RFLink
Appesteijn
sundberg84 wrote:I have this issue as well - When I add the fence it updates the first time, but then not the off (even if i get a notification that i left the area). I will reinstall and see what happens.
What is your android version?
EdwinK
Post by EdwinK »
Misterik wrote:
Appesteijn wrote:Has the IDX code of your virtual switch changed?
Nope...but i changed my switch to protected and this is what it was causing.
Thanks for sharing. I just had the same thing happening and couldn't figure out why.
Now it only shows me entering or entering the Geofence, even if I click the button and it says 'Geofences removed'. btw. Is it possible to make something in the app so we can see if the fences are on or off?
Duh... My phone was trying to connect to a wrong gateway.
sundberg84
6.0.1 on my phone (Samsung S6). Will check my wifes phone (S6 edge) which version.
My first feeling on my phone is that it works better but my wifes phone is buggy... but let me come back to you with results.
DomoFence has been working great for a long time and the issues began with a Samsung update my wife did to her phone.
Appesteijn
I just created a new beta that should fix the Android 7.+ problems and also fix the trouble with some switches that were missed:
You can sign up for it here:
https://play.google.com/apps/testing/co ... .domofence
If I don't hear of any bugs, I'll release it in a few days.
sundberg84
Appesteijn wrote:I just created a new beta that should fix the Android 7.+ problems and also fix the trouble with some switches that were missed:
Great! I was just about to say I upgraded now to 7.0 and it stopped working on my phone as well (checked wife phone and she got 7.0).
sundberg84
Sorry - its not working for me or my wife on our samsung S6 + S6 edge.
The application freezen and android terminate it as soon as i try to add a fence or when we enter/exit.
Appesteijn
Thank you for letting me know, I also saw some crashes and I (think) I fixed them in the new beta (2.8.5), but I want to test for a whole day to see if it is correct now. You can help by installing the beta.
sundberg84
Appesteijn wrote:Thank you for letting me know, I also saw some crashes and I (think) I fixed them in the new beta (2.8.5), but I want to test for a whole day to see if it is correct now. You can help by installing the beta.
I got two updates over the past day I think. Now it works much better.
The program is sending off sometimes when im home which it didnt do before but i guess thats something changed in Samsung geo service.
Appesteijn
Thx for letting me know. Getting the release stable was a bit messy as I didn't have enough test-devices and I had to beta-release to see if it worked correctly. Unfortunately I got some 2 star ratings because of that, so my average has dropped :(
I'm going to see if I can add the functionality to have more that 1 geofence in the app in a next release.
EdwinK
Post by EdwinK »
The app is notifying me that I left or entered the location, but it's not updating the switch.
Appesteijn
EdKo66 wrote:The app is notifying me that I left or entered the location, but it's not updating the switch.
Make sure you have the latest version 2.8.8 (or use the beta link a little bit up in this thread)
What happens if you use the 'test' button?
