Page 12 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Wednesday 25 October 2017 12:31
by fantom
Do You have the newest firmware version o nIntegra and ETHM1 ?
Fantom
Posted: Friday 03 November 2017 7:17
by piokuc
If i have connected to Satel Integra control switches light i also can use it in Domoticz ?
Posted: Friday 03 November 2017 7:41
by fantom
Yes
Fantom
Posted: Sunday 05 November 2017 14:58
by xyntec
sorry I'm kind of new to this, both domoticz and satel, I just installed an Integra64plus, installed Domoticz on my Synology NAS and added the Satel to devices (so far so good) but really have no idea what to do next, is there a guide somewhere how to go on from there? I'd like to read status of arm/disarm/sensors etc for now. I have used a homey for my domotica, but like to start using Domoticz because it seems more versatile, but it's kind of hard to start, if I have a few examples I'll figure it out from there (unfortunately don't have my Zwave USB yet, so can't really do much with the rest of my plugs and switches)
Thanks in advance
Posted: Sunday 05 November 2017 16:11
by fantom
Please clikc button "Allow for 5 minutes" in Settings.
And nex add (or enable) Integra hardware
All devices will add.
If not - check logs.
Fantom
Posted: Monday 13 November 2017 14:24
by samboman
Does this integration module with RPI block the connectivity with ETHM? As far as I know ETHM module does accept maximum 1 connection at a time.
Doest it mean that while Domoticz is connected to Satel via ETHM I will have no possibility to connect to Satel through e.g. Satel Mobile app?
Posted: Monday 13 November 2017 17:52
by fantom
Yes, ETHM1 accepted only on connection on one port.
Satel ETHM1 and Satel Mobile App using different ports.
Fantom
Posted: Thursday 16 November 2017 23:39
by xyntec
Just managed to get connection and have all the inputs and outputs in domoticz now, is there a way to determine how to arm? (away or home/without internal) or is it only possible to arm all?
Posted: Friday 17 November 2017 8:12
by fantom
Each zone can be armored separately, but only in mode 0
0• Full (default)
1• Full + bypasses
2• Stay
3• Stay, delay = 0 (off)
Fantom
Posted: Friday 17 November 2017 21:09
by xyntec
ok thanks, would be nice if also possible in 2 (Stay) but for now i'm happy
Posted: Friday 24 November 2017 21:33
by xyntec
Posted: Friday 24 November 2017 22:58
by fantom
Maybe try switch device (instead text).
All partitions have one switch for arm/disarm partition
Fantom
Posted: Saturday 25 November 2017 9:08
by xyntec
I can't change the device type of the armed status, they are by default "text", same is for all outputs, all inputs are alerts with a numeric value (1=ok, 3=violation), only arming is a switch, but I cannot use that because then I still do not know when it is in home or away mode.
fantom wrote: Friday 24 November 2017 22:58
Fantom
Posted: Saturday 25 November 2017 9:39
by xyntec
I do notice that in the actual values there is no state, only in sValues (whatever that is) so I guess it ain't going to work in blockly...
- 2017-11-25_093832.jpg (37.64 KiB) Viewed 5925 times
Posted: Saturday 25 November 2017 9:43
by fantom
I send You private message.
Fantom
Posted: Saturday 25 November 2017 12:21
by fantom
Info for Satel Users.
For Alert Devices (for example for Satel Integra) works this simple script:
- Capture.PNG (7.19 KiB) Viewed 5913 times
Posted: Tuesday 28 November 2017 12:51
by huberthc
Hi Fantom.
I love the idea of Satel/Domoticz integration - could you tell me what models are compatible with this?
Greetings from Lublin
Posted: Tuesday 28 November 2017 13:12
by fantom
I think that all ETHM-1 and ETHM-1 PLUS are working.
Fantom
Posted: Sunday 03 December 2017 2:12
by vinyl
Found strange issue. When trying to on/off any switch it works but I'll have to click 3 times. In log it looks like below. Please advise.
2017-12-02 02:05:37.760 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:37.761 Error: Satel Integra: bad data length received (-1)
2017-12-02 02:05:37.761 Error: Satel Integra: Switch output 28 failed
2017-12-02 02:05:40.644 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:40.645 Error: Satel Integra: Send command '89' failed
2017-12-02 02:05:40.645 Error: Satel Integra: Switch output 28 failed
2017-12-02 02:05:42.957 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:42.960 Satel Integra: connected to 10.30.60.2:7094
2017-12-02 02:05:43.346 Satel Integra: switched output 28 to off
2017-12-02 02:05:43.358 (integra) Light/Switch (L Salon Sufit B)
Best regards,
Pawel
Posted: Sunday 03 December 2017 10:30
by fantom
Please check you connection between domoticz and ETHM1.
Do You have Wi-Fi ?
Many user have problem when domoticz connecting to ETHM1 using WiFi.
Fantom
