Satel Integra (Security System) with ethernet module Topic is solved
fantom
Re: Satel Integra (Security System) with ethernet module
Post by fantom »
Do You have the newest firmware version o nIntegra and ETHM1 ?
Fantom
piokuc
Post by piokuc »
If i have connected to Satel Integra control switches light i also can use it in Domoticz ?
fantom
Post by fantom »
Yes
Fantom
xyntec
Post by xyntec »
sorry I'm kind of new to this, both domoticz and satel, I just installed an Integra64plus, installed Domoticz on my Synology NAS and added the Satel to devices (so far so good) but really have no idea what to do next, is there a guide somewhere how to go on from there? I'd like to read status of arm/disarm/sensors etc for now. I have used a homey for my domotica, but like to start using Domoticz because it seems more versatile, but it's kind of hard to start, if I have a few examples I'll figure it out from there (unfortunately don't have my Zwave USB yet, so can't really do much with the rest of my plugs and switches)
Thanks in advance
fantom
Post by fantom »
Please clikc button "Allow for 5 minutes" in Settings.
And nex add (or enable) Integra hardware
All devices will add.
If not - check logs.
Fantom
samboman
Post by samboman »
Does this integration module with RPI block the connectivity with ETHM? As far as I know ETHM module does accept maximum 1 connection at a time.
Doest it mean that while Domoticz is connected to Satel via ETHM I will have no possibility to connect to Satel through e.g. Satel Mobile app?
fantom
Post by fantom »
Yes, ETHM1 accepted only on connection on one port.
Satel ETHM1 and Satel Mobile App using different ports.
Fantom
xyntec
Post by xyntec »
Just managed to get connection and have all the inputs and outputs in domoticz now, is there a way to determine how to arm? (away or home/without internal) or is it only possible to arm all?
fantom
Post by fantom »
Each zone can be armored separately, but only in mode 0
0• Full (default)
1• Full + bypasses
2• Stay
3• Stay, delay = 0 (off)
Fantom
xyntec
Post by xyntec »
ok thanks, would be nice if also possible in 2 (Stay) but for now i'm happy :-)
xyntec
Post by xyntec »
I'm trying to set my nefit to manual mode and lower the temperature to 14 when the alarm is on (only when away) and back to automatic when alarm is off (or in home mode) but I can't get it to work, actually I can't do anything on the status of the alarm, even tried to just send an email when switching on. I only tried in blockly since I don't know how the scripts work. But the states are text variables (they do change correctly), not 0/1 variables, maybe that has something to do with it? I tried in various ways but no luck yet, anyone has some hints? :-)
alarm variables
alarm variables
switch clock mode and temp
only switch clock mode
fantom
Post by fantom »
Maybe try switch device (instead text).
All partitions have one switch for arm/disarm partition
Fantom
xyntec
Post by xyntec »
I can't change the device type of the armed status, they are by default "text", same is for all outputs, all inputs are alerts with a numeric value (1=ok, 3=violation), only arming is a switch, but I cannot use that because then I still do not know when it is in home or away mode.
fantom wrote: Friday 24 November 2017 22:58 Maybe try switch device (instead text).
Fantom
xyntec
Post by xyntec »
I do notice that in the actual values there is no state, only in sValues (whatever that is) so I guess it ain't going to work in blockly...
fantom
Post by fantom »
I send You private message.
Fantom
fantom
Post by fantom »
Info for Satel Users.
For Alert Devices (for example for Satel Integra) works this simple script:
huberthc
Post by huberthc »
Hi Fantom.
I love the idea of Satel/Domoticz integration - could you tell me what models are compatible with this?
Greetings from Lublin :D
fantom
Post by fantom »
I think that all ETHM-1 and ETHM-1 PLUS are working.
Fantom
vinyl
Post by vinyl »
Found strange issue. When trying to on/off any switch it works but I'll have to click 3 times. In log it looks like below. Please advise.
2017-12-02 02:05:37.760 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:37.761 Error: Satel Integra: bad data length received (-1)
2017-12-02 02:05:37.761 Error: Satel Integra: Switch output 28 failed
2017-12-02 02:05:40.644 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:40.645 Error: Satel Integra: Send command '89' failed
2017-12-02 02:05:40.645 Error: Satel Integra: Switch output 28 failed
2017-12-02 02:05:42.957 User: Admin initiated a switch command (109/L Salon Sufit B/Off)
2017-12-02 02:05:42.960 Satel Integra: connected to 10.30.60.2:7094
2017-12-02 02:05:43.346 Satel Integra: switched output 28 to off
2017-12-02 02:05:43.358 (integra) Light/Switch (L Salon Sufit B)
Best regards,
Pawel
Regards,
Pawel
fantom
Post by fantom »
Please check you connection between domoticz and ETHM1.
Do You have Wi-Fi ?
Many user have problem when domoticz connecting to ETHM1 using WiFi.
Fantom
