Python Plugin: Volvo EV
mvveelen
Re: Python Plugin: Volvo EV
Post by mvveelen »
Sorry, haven't done anything with Github. At least not for the last years.
diff --git a/plugin.py b/plugin.py
index ead9b6d..ff2300d 100644
--- a/plugin.py
+++ b/plugin.py
@@ -314,52 +314,52 @@ def CheckRefreshToken():
         else:
             Debug("Not logged in, retrying in "+str(MINTIMEBETWEENLOGINATTEMPTS-(time.time()-lastloginattempttimestamp))+" seconds")
-def VolvoAPI(url,mediatype):
+def VolvoAPI(url, mediatype):
     global vin
-    Debug("VolvoAPI("+url+","+mediatype+") called")
+    Debug("VolvoAPI(" + url + "," + mediatype + ") called")
     try:
-        starttime=datetime.datetime.now()
+        starttime = datetime.datetime.now()
         status = requests.get(
             url,
-            headers= {
+            headers={
                 "accept": mediatype,
                 "vcc-api-key": vccapikey,
                 "Authorization": "Bearer " + access_token
             timeout=TIMEOUT
-        endtime=datetime.datetime.now()
+        endtime = datetime.datetime.now()
         Debug("\nResult:")
         Debug(status)
-        Debug("Result took "+str(endtime-starttime))
+        Debug("Result took " + str(endtime - starttime))
         try:
             resp_json = status.json()
         except Exception as json_error:
-            Error("Response from "+url+" is not valid JSON: "+str(json_error))
-            output=status.text
-            Error("Raw response: "+output)
-            UpdateTextSensor(Parameters["Name"],APISTATUS,APISTATUSNAME,f"API Error: {output}")
+            Error("Response from " + url + " is not valid JSON: " + str(json_error))
+            output = status.text if status is not None else ""
+            Error("Raw response: " + output)
+            UpdateTextSensor(Parameters["Name"], APISTATUS, APISTATUSNAME, f"API Error: {output}")
             return None
         if status.status_code != 200:
-            Error("VolvoAPI failed calling "+url+", HTTP Statuscode "+str(status.status_code))
-            Error("Response: "+json.dumps(resp_json, indent=4))
+            Error("VolvoAPI failed calling " + url + ", HTTP Statuscode " + str(status.status_code))
+            Error("Response: " + json.dumps(resp_json, indent=4))
akamming
Post by akamming »
mvveelen wrote: Friday 07 November 2025 21:31 Sorry, haven't done anything with Github. At least not for the last years.
--- a/plugin.py
+++ b/plugin.py
         else:
     global vin
     try:
             url,
-            headers= {
+            headers={
             timeout=TIMEOUT
         Debug("\nResult:")
         Debug(status)
         try:
             return None
I see what you did, i made a similar change now in the repository (but gives a bit more info tot the API Error field). I cannot test, since i never have this issue, so please update your plugin to the latest code and let me know the results...
mvveelen
Post by mvveelen »
Done, but after a while:
2025-11-08 10:54:32.875 Error: Volvo: Call to function 'onHeartbeat' failed, exception details:
2025-11-08 10:54:32.878 Error: Volvo: Traceback (most recent call last):
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1712, in onHeartbeat
2025-11-08 10:54:32.878 Error: Volvo: _plugin.onHeartbeat()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1677, in onHeartbeat
2025-11-08 10:54:32.878 Error: Volvo: Heartbeat()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1426, in Heartbeat
2025-11-08 10:54:32.878 Error: Volvo: UpdateDevices()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1388, in UpdateDevices
2025-11-08 10:54:32.878 Error: Volvo: UpdateLastKnownLocation()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1332, in UpdateLastKnownLocation
2025-11-08 10:54:32.878 Error: Volvo: TripSpeed=int(((Triplength*1000.0)/TripDuration.total_seconds())*3.6)
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2025-11-08 10:54:32.878 Error: Volvo: ZeroDivisionError: float division by zero
akamming
Post by akamming »
mvveelen wrote: Saturday 08 November 2025 11:48 Done, but after a while:
Could you switch on debugging and post the full plug-in logging?
Btw: this is all just attacking the symptoms. Your real issue is that you have connectivity issues. Are you still working on that?
EDIT:
Just to be safe, i made some handling around this division... so pls upgrade to latest version.
My remark on the connection issue still stands, now in some connection error cases it will now report some sensors to 0 instead of the real value, cause due to the connection issue which prevents it from getting data. So you get less errors in the log, but your issue is not solved
mvveelen
Post by mvveelen »
I've updated just now, but I don't know why there are connectivity issues like you say. The NUC is connected by wire and I have a fast internet connection via KPN (glass). Could it be that I poll the server too often? I've got the interval set to every 60 seconds.
akamming
Post by akamming »
mvveelen wrote: Sunday 26 October 2025 10:58 I've migrated my Domoticz installation from a Raspberry Pi 3B+ to a NUC. Everything is working fine now, also the Volvo plugin.
But.
Once in a while I see a bunch of errors although the plugin is working fine.
What can be the cause of it and....what could be the solution to prevent these errors (which I didn't have on my RPi)? I could, of course, switch off error logging, but that's not a solution.
Update interval is (unchanged): 60
The errors:
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~~~~^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/ssl.py", line 1304, in recv_into
2025-10-26 10:30:01.490 Error: Volvo: return self.read(nbytes, buffer)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/ssl.py", line 1138, in read
2025-10-26 10:30:01.490 Error: Volvo: return self._sslobj.read(len, buffer)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: ConnectionResetError: [Errno 104] Connection reset by peer
2025-10-26 10:30:01.490 Error: Volvo: During handling of the above exception, another exception occurred:
2025-10-26 10:30:01.490 Error: Volvo: Traceback (most recent call last):
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 667, in send
2025-10-26 10:30:01.490 Error: Volvo: resp = conn.urlopen(
2025-10-26 10:30:01.490 Error: Volvo: method=request.method,
2025-10-26 10:30:01.490 Error: Volvo: ...<9 lines>...
2025-10-26 10:30:01.490 Error: Volvo: chunked=chunked,
2025-10-26 10:30:01.490 Error: Volvo: )
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in urlopen
2025-10-26 10:30:01.490 Error: Volvo: retries = retries.increment(
2025-10-26 10:30:01.490 Error: Volvo: method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 474, in increment
2025-10-26 10:30:01.490 Error: Volvo: raise reraise(type(error), error, _stacktrace)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/util/util.py", line 38, in reraise
2025-10-26 10:30:01.490 Error: Volvo: raise value.with_traceback(tb)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
2025-10-26 10:30:01.490 Error: Volvo: response = self._make_request(
2025-10-26 10:30:01.490 Error: Volvo: conn,
2025-10-26 10:30:01.490 Error: Volvo: ...<10 lines>...
2025-10-26 10:30:01.490 Error: Volvo: **response_kw,
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 534, in _make_request
2025-10-26 10:30:01.490 Error: Volvo: response = conn.getresponse()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 516, in getresponse
2025-10-26 10:30:01.490 Error: Volvo: httplib_response = super().getresponse()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 1430, in getresponse
2025-10-26 10:30:01.490 Error: Volvo: response.begin()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 331, in begin
2025-10-26 10:30:01.490 Error: Volvo: version, status, reason = self._read_status()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 292, in _read_status
2025-10-26 10:30:01.490 Error: Volvo: line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/socket.py", line 719, in readinto
2025-10-26 10:30:01.490 Error: Volvo: return self._sock.recv_into(b)
2025-10-26 10:30:01.490 Error: Volvo: urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 323, in VolvoAPI
2025-10-26 10:30:01.490 Error: Volvo: status = requests.get(
2025-10-26 10:30:01.490 Error: Volvo: url,
2025-10-26 10:30:01.490 Error: Volvo: ...<5 lines>...
2025-10-26 10:30:01.490 Error: Volvo: timeout=TIMEOUT
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/api.py", line 73, in get
2025-10-26 10:30:01.490 Error: Volvo: return request("get", url, params=params, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
2025-10-26 10:30:01.490 Error: Volvo: return session.request(method=method, url=url, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 589, in request
2025-10-26 10:30:01.490 Error: Volvo: resp = self.send(prep, **send_kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 703, in send
2025-10-26 10:30:01.490 Error: Volvo: r = adapter.send(request, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 682, in send
2025-10-26 10:30:01.490 Error: Volvo: raise ConnectionError(err, request=request)
2025-10-26 10:30:01.490 Error: Volvo: requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1712, in onHeartbeat
2025-10-26 10:30:01.490 Error: Volvo: _plugin.onHeartbeat()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1677, in onHeartbeat
2025-10-26 10:30:01.490 Error: Volvo: Heartbeat()
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1426, in Heartbeat
2025-10-26 10:30:01.490 Error: Volvo: UpdateDevices()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1372, in UpdateDevices
2025-10-26 10:30:01.490 Error: Volvo: GetLocation() #Location must be known before GetRechargeStatus te detect local charging and to detect if carhasmoved
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1104, in GetLocation
2025-10-26 10:30:01.490 Error: Volvo: Location = VolvoAPI("https://api.volvocars.com/location/v1/vehicles/" + vin + "/location", "application/json")
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 359, in VolvoAPI
2025-10-26 10:30:01.490 Error: Volvo: output=status.text
2025-10-26 10:30:01.490 Error: Volvo: ^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: UnboundLocalError: cannot access local variable 'status' where it is not associated with a value
It's this logging what start this, The "ConnectionResetError: [Errno 104] Connection reset by peer" is the actual error which happens on your system.
This means that something (the “peer”) abruptly closes the TCP connection while your the plugin was trying to read or write data.
The domoticz Python plugin is making an HTTPS request to the Volvo API, The Volvo server (or something in between) sent a TCP RST packet, forcefully ending the connection. So the reset does not happens in Domoticz or Python.
I've asked chatgpt, and 2 possible causes:
- TLS/SSL issues (Some APIs require modern TLS versions or SNI support. Outdated Python versions or requests libraries can fail to negotiate properly.)
- or a router, proxy, or firewall might reset idle or long-running connections.
mvveelen
Post by mvveelen »
No errors since the latest update. Yet.
mvveelen
Post by mvveelen »
Using the latest Beta 2026.1 (build 17932) and I noticed the Volvo plugin hasn't updated any devices for a while now. There are no error messages, so what might be wrong? Anyone else with the same issue?
Edit: just run the python3 authorize.py again in the Plugins directory, enter the data and let it generate a new ini file. Restart Domoticz: done.
microkid
Domoticz version: 2024.7
Post by microkid »
mvveelen wrote: Thursday 07 May 2026 16:42 Using the latest Beta 2026.1 (build 17932) and I noticed the Volvo plugin hasn't updated any devices for a while now. There are no error messages, so what might be wrong? Anyone else with the same issue?
same issue here. I notice my Volvo stats has not been updated since 17/7. I tried to run authorize.py, it says "OTP sent to PINGFEDERATE.SMTP (<my mail address>)" but the OTP never arrives. Any ideas?
akamming
Post by akamming »
microkid wrote: Monday 20 July 2026 17:09
If it says OTP sent to PINGFEDERATE.SMTP, this means it got back a succesful API response, so the code seems to be working.
And i Just tested for myself, it still works i get a OTP in my email.
Did you check your spamfolder?
What happens if you login in the normal Volvo URL : https://www.volvocars.com/nl/support/to ... 117dbb3ba/ ?
microkid
Post by microkid »
akamming wrote: Monday 20 July 2026 21:04
Logon to the Volvo site works fine. Mail is not received however. I even checked the logs at my provider, there is no OTP mail received. Strange.
akamming
Post by akamming »
microkid wrote: Tuesday 21 July 2026 6:54
That should not be possible did you really grunten logon to your Volvo id on the page i sent you ( https://volvoid.eu.volvocars.com/Account/? And did you get the otp when logging in using that link?
microkid
Post by microkid »
Yes I received the 6 digit code in my mail when loggin in to the Volvo site.
update: after several attempts today, I finally received the OTP via the mail and the plugin started working right away :) Case closed.
BramDW
Post by BramDW »
The latest Volvo Android app update introduces the ability to adjust the charging amp limit (at least for Belgian users).
Are there any plans to expose this feature through the integration/API so that automations can be created to dynamically change the charging limit?
FireWizard
Post by FireWizard »
Hello @ BramDW
As you might have read in this thread, I do not use this Python plugin (nor any other Python plugin), so to add things and to test new things, the original creater (akamming) and maintainer should become active again.
However:
I am in The Netherlands and my latest version of the Volvo app is 7.2.0. As I own a XC40 PHEV I do not have that function.
However, I see:
You can now set a maximum amperage directly from the app, providing added control and convenience. Applies to XC40 Recharge Pure Electric, C40, EC40, and EX40 cars.
So I understand that I do not see it in my app.
You wrote also:
If it can be integrated in an application depends in the first place on the fact: "is it available in de Energy API v2 (or the Connected vehicle API).
The short answer is: "No, there is no command to set the Charging Limit
A longer answer is: Currently the API is under review again and I see some changes, but also additions.
So who knows, it will come available in the future.
But for now, it is simply not possible.
For people interested in the new data, see the list of modified Connected Vehicle API Endpoints below.
Endpoint:
https://api.volvocars.com/connected-vehicle/v2/vehicles/"Volvo_VIN"/statistics
New:
averageEnergyConsumption
averageEnergyConsumptionAutomatic
averageEnergyConsumptionSinceCharge
averageFuelConsumptionAutomatic
averageSpeedAutomatic
All these new sensors currently give null as value.
Endpoint:
https://api.volvocars.com/connected-vehicle/v2/vehicles/"Volvo_VIN"/fuel
Returned sensor (previously: hvbatteryChargeLevel): batteryChargeLevel Value: null
Endpoint:
https://api.volvocars.com/connected-vehicle/v2/vehicles/"Volvo_VIN"/command-accessibility
Changed value for sensor unavailableReason:previously "undefined", changed to null
Best regards
akamming
Post by akamming »
FireWizard wrote: Wednesday 02 September 2026 19:45 Hello @ BramDW
However:
However, I see:
You wrote also:
Endpoint:
New:
Endpoint:
Endpoint:
Best regards
this is the correct answer indeed: The plugin is a wrapper on the API, so if it's not available in the API it cannot be made available in the plugin...
FireWizard
Has anyone noted, that this plugin has stopped functioning approx 14:30 - 14:35, yesterday October 26?
akamming
Post by akamming »
FireWizard wrote: Tuesday 27 October 2026 17:01 Hi,
for myself it's still working. But do have an issue when i try to run authorize.py. I was using a backdoor.
Since i switched to hass myself, it is very difficult for me to maintain this plugin (already asked if someone would take over earlier on this forum). I will take a look sometime, but i might take a while
but if someone wants to investigate and finds a solution: Feel free to make a PR. It is easy for me to merge (if you can show me that the solution works)
FireWizard
Hello @akamming,
You know probably I use Node-RED, which has worked for me without any issue for many months.
Yesterday it stopped at around 14:30-14:35.
It gave the following error directly after the first HTTP Request
(So the first poll of https://volvoid.eu.volvocars.com/as/aut ... ion.oauth2?)
Validation Error.png (31.15 KiB) Viewed 341 times
Based on the error message, my first thoughts were, that Volvo has closed the hole and made the used Client-ID invalid.
However I'm not sure, as it also has been reported at Linus Dietz' application. See: https://github.com/Dielee/volvo2mqtt/issues/337 [Edit] I'm sure now.
A PR is also available, which I have to read more carefully. See: https://github.com/Dielee/volvo2mqtt/pull/338
[Edit] See also: https://github.com/soothill/volvo-mcp/c ... d5106870f5
As I'm not a Python specialist, you can maybe have a look and try to get authorisation with your authorize.py.
akamming
Post by akamming »
FireWizard wrote: Tuesday 27 October 2026 19:47 Hello @akamming,
i noticed the same PR. I didn't have time to dig into it myself, but asked Claude to create a fix for my authorize.py script based on the same PR. Good news is that i can use the script again to generate tokens. But since i didn't have the issue myself, my test is not full proof that the fix works. I did upload the the change (old version wasn't working anymore anyway, so cannot break anything by uploading untested code)
So please for anyone with this issue on this plugin, pls
- do a "git pull",
- then rerun "python authorize.py" in the plugin directory,
- restart the plugin
and report here if it works..
