Page 12 of 12
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
Posted: Saturday 10 October 2026 15:11
by AddieJanssen
imautohuttraeger wrote: Saturday 10 October 2026 1:01
EDIT: Next morning, when the battery is charged again, it is back to normal again (both status devices show "charge").
Maybe this is a standard behaviour, but I thought it might not be harmful to notify this:
Today is the first day since March (Heavy rain and dark clouds all over the day) ,where my Battery was sucked empty.
Battery1 - State of Energy:
"0"
And I recognized the following findings:
Battery1 - Status:
"Key not found in lookup table: 10"
(normally it is Idle, Charge or Discharge)
Battery1 - Internal Status:
"Fault"
According to the SolarEdge documentation that I have, there's no such status as "10".
However, I looked at a Home Assistant plugin, they list this: 10: "B_STATUS_POWER_SAVING"
They have a whole bunch more information where it is unclear where they got it from, but interesting to have a peek at in the future.
Posted: Sunday 11 October 2026 22:39
by hskip
I ran the scanner again (with the 15-second setting) on the SE3000, no battery.
python scanner.py 192.168.178.77 502
Connecting to server
Connected to server
Looking for SunSpec identifier at address [40000 (0x9c40)] for device [1]
The inverter is providing a SunSpec Map
Reading Block at address [40002 (0x9c42)] for device [1]
ERROR: request ask for transaction_id=2 but got id=1, Skipping.
Block id = [1]
Block length = [65]
=================================================================== DEVICE DETAILS ===================================================================
[id] [1]
[name] [common]
[label] [Common]
[description] [All SunSpec compliant devices must include this as the first model]
-------------------------------------------------------------------- MEASUREMENTS --------------------------------------------------------------------
[id] [Model identifier] [1]
[l] [Model length] [65]
[mn] [Well known value registered with SunSpec for compliance] [SolarEdge ]
[md] [Manufacturer specific value (32 chars)] [SE3000]
[opt] [Manufacturer specific value (16 chars)] []
[vr] [Manufacturer specific value (16 chars)] [0003.2537]
[sn] [Manufacturer specific value (32 chars)] [7F190BC7]
[da] [Modbus device address] [1]
Reading Block at address [40069 (0x9c85)] for device [1]
Block id = [101]
Block length = [50]
[id] [101]
[name] [inverter_single_phase]
[label] [Inverter (Single Phase)]
[description] [Include this model for single phase inverter monitoring]
[id] [Model identifier] [101]
[l] [Model length] [50]
[a] [AC Current] [0]
[apha] [Phase A Current] [0]
[aphb] [Phase B Current] [NOT_IMPLEMENTED]
[aphc] [Phase C Current] [NOT_IMPLEMENTED]
[a_sf] [] [0]
[ppvphab] [Phase Voltage AB] [230.70] = [2307 * (10**-1)] using scale factor [v_sf]
[ppvphbc] [Phase Voltage BC] [NOT_IMPLEMENTED]
[ppvphca] [Phase Voltage CA] [NOT_IMPLEMENTED]
[phvpha] [Phase Voltage AN] [NOT_IMPLEMENTED]
[phvphb] [Phase Voltage BN] [NOT_IMPLEMENTED]
[phvphc] [Phase Voltage CN] [NOT_IMPLEMENTED]
[v_sf] [] [-1]
[w] [AC Power] [0]
[w_sf] [] [0]
[hz] [Line Frequency] [50.01] = [50013 * (10**-3)] using scale factor [hz_sf]
[hz_sf] [] [-3]
[va] [AC Apparent Power] [0]
[va_sf] [] [0]
[var] [AC Reactive Power] [0]
[var_sf] [] [0]
[pf] [AC Power Factor] [100.00] = [10000 * (10**-2)] using scale factor [pf_sf]
[pf_sf] [] [-2]
[wh] [AC Energy] [41970476.00] = [41970476 * (10**0)] using scale factor [wh_sf]
[wh_sf] [] [0]
[dca] [DC Current] [0]
[dca_sf] [] [0]
[dcv] [DC Voltage] [1.20] = [12 * (10**-1)] using scale factor [dcv_sf]
[dcv_sf] [] [-1]
[dcw] [DC Power] [0]
[dcw_sf] [] [0]
[tmpcab] [Cabinet Temperature] [NOT_IMPLEMENTED]
[tmpsnk] [Heat Sink Temperature] [0]
[tmptrns] [Transformer Temperature] [NOT_IMPLEMENTED]
[tmpot] [Other Temperature] [NOT_IMPLEMENTED]
[tmp_sf] [] [-2]
[st] [Enumerated value. Operating state] [STARTING]
[stvnd] [Vendor specific operating state code] [0]
[evt1] [Bitmask value. Event fields] [NOT_IMPLEMENTED]
[evt2] [Reserved for future use] [NOT_IMPLEMENTED]
[evtvnd1] [Vendor defined events] [0]
[evtvnd2] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd3] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd4] [Vendor defined events] [0]
Reading Block at address [40121 (0x9cb9)] for device [1]
Block id = [65535]
Block length = [0]
Block type = [The End of the block list has been reached]
End of SunSpec MAP
Looking for Battery at address [57600 (0xe100)] for device [1]
No battery found at this address
Looking for Battery at address [57856 (0xe200)] for device [1]
Disconnected from server
Posted: Monday 12 October 2026 10:06
by imautohuttraeger
hskip wrote: Sunday 11 October 2026 22:39
[...] (with the 15-second setting) [...]
Seems I have missed something. What is the "15-second setting"? Shall we other testers run it with this option, too?
Posted: Monday 12 October 2026 11:19
by hskip
AddieJanssen wrote: Thursday 08 October 2026 10:24
Are these results from the scanner with the increased timeout?
Please check line 168 of the scanner. It should read:
line 168: client = ModbusTcpClient(host=args.host, port=args.port, timeout=15)
Posted: Monday 12 October 2026 11:26
by eddieb
The github version is correct ...
