Page 12 of 15
Re: Domoticz to Google Assistant integration
Posted: Thursday 30 January 2020 18:12
by DewGew
pvklink wrote: Thursday 30 January 2020 17:59
OK, good to hear that the sdk isnt used!
is there hope that the python issue will be solved?
Python 3.7 is supported in buster...
Just try it out. Only one user had issues. I have tryed in a rpi 3b with buster and python 3.7, that worked fine.
Posted: Friday 31 January 2020 0:08
by Xavier82
DewGew wrote: Thursday 30 January 2020 8:32
Xavier82 wrote: Wednesday 29 January 2020 22:47
Please help.
How can I fix this?
Is there anyway to run the script in the background?
I changed the bash script and now I revert it. Back up your config.yaml and smart-home-key.json then delete Domoticz-Google-Assistant folder.
Run the script, now it should update you service.
Thanks for the quick reply.
I removed the folder and reinstalled it.
Now seems to work except on 1 strange thing..
When I set ngrok tunnel to "true" and I enter my ngrok_auth_token I then Save and I do a "restart server" the server dies/stops.
dzga services seems to be running ok only the Domoticz Google Assistant dies/stops.
When rechanging it back to default, and press F5 the server is back online.
Looks like an issue with ngrok but it is installed:
pi@raspberrypi:~/Domoticz-Google-Assistant $ pip install ngrok
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: ngrok in /home/pi/.local/lib/python3.7/site-packages (0.0.1)
Oh and also the logging remains empty.
"Logs Loglevel: Debug"
"Problem opening this file"
When pressing "Sync devices" I get this error:
"Page not found!: 500 Server Error: Internal Server Error for url:
https://homegraph.googleapis.com/v1/devices:requestSync"
The "Smart-home-key.json" exists in the config folder.
btw: Running this on a PI3b, with Raspbian Buster and Python3.7 and 2.7 installed.
Posted: Friday 31 January 2020 15:07
by Xavier82
Got it working after recreating API and service account.
Posted: Friday 31 January 2020 16:35
by pvklink
It works great. I have only one problem. Each time i change something to my node-red flows, and i do that a lot! the nora connection is corrupt!
I have to disable the nora connection on my home app on my mobile and connect it again.
IS there a solution for this behavior?
Posted: Friday 31 January 2020 18:02
by DewGew
pvklink wrote: Friday 31 January 2020 16:35
Dzga has nothing todo with nora and node-red. Only connects to domoticz
Posted: Friday 31 January 2020 22:25
by pvklink
sorry post on the wrong place..
was ment for node-red !
multitasking went wrong...
Posted: Tuesday 04 February 2020 18:03
by emichiels
hi there,
I installed DZGA and it has been working perfectly for a period.
But now when i try to sync the devices I get an error.
also when I give a command to google it says sorry, but it looks like domoticz is not available at the moment, although both domoticz and dzga are running well. Has anyone have an idea what's causing this and how to solve this?
Posted: Tuesday 04 February 2020 20:47
by DewGew
Sometimes the test disables in actions on google. Try goto actions on google console and click test.like you did when you set up first time
Posted: Tuesday 04 February 2020 20:54
by emichiels
Thanks for your reply dewgew. I tried this earlier or. Tried it again now, but problem remains. Any other idea's?
Posted: Wednesday 05 February 2020 8:43
by DewGew
emichiels wrote: Tuesday 04 February 2020 20:54
Error 500 is usally something with the auth server. Check:
- public urls is correct in actions on google
- reverse proxy server is running correct
- if auth pass and user is changed you might reconnect with google home app
- generate a new smart-home-key.json file
Posted: Sunday 09 February 2020 12:42
by GeCoLi
tage wrote: Saturday 16 November 2019 11:54
i also have some trouble to get this to work.
domoticz -> raspberry
Domoticz-Google-Assistant -> linux pc
and reverse proxy (pound) same linux pc
router portforward port 443 to linux pc
reverse proxy listen port 443 send that to port 3030 (Domoticz-Google-Assistant)
double check and have make new projects on google console just to make sure that is okey.
when try add "test" project in google home i come to login page and when type username and password i got this in domoticz-google-assistant log :
192.168.0.10 - - [16/Nov/2019 11:36:10] "POST /login HTTP/1.1" 301 -
192.168.0.10 - - [16/Nov/2019 11:36:11] "GET /login?client_id=574522741018-46vmha139e9vi049mlucupdiq49dp3gt.apps.googleusercontent.com&redirect_uri=https%253A%252F%252Foauth-redirect.googleusercontent.com%252Fr%252Fmitt-projekt-259118&redirect=/oauth&state=AB8b_TOhbrqakbQy04zp9D8Xt-5pgNQmUuVDQiDdFNP4rthBSz9OXZ5Fw1Y8mDAV7Sv7KzgBurXetyTqwrb8T-kRuQ2TdTblyVdUTR_zhffPz5tipNx0EpzUvZzgGe6r3yhtl7ciO5gC5agRvoENE9pYGOEl6tCaW754HqjxM6g8FdjAaXlKWvZpYhqi_19eIKk-tnEeww0QjmXB-OuMDdBJWgi7GGu-C4vu2agewbPHQtBvxGl14rdAAk6WgcOj-U7Jjn2CUHUy8OcP8rKflBm17e7XgYQfQ_GNhz62wL7SC_WBKsWW7ueHlcTheEUc2yIH_2LUsohOaXf1k5zL3ZouS3GmzjyvUDWuproy4NTssaSy0OLniMwJsT5q2r2BUJxqVHIDdWAUVjkPma8scgF1VbwupfDy0UYARNbkm2EP-Ad1aMpoYqLhKN9ibuCEKIbpfpg80rAWg2dbzCtZbRiApVj6S5QiDAjsLe6LVsfo2NSM0YH_mXqmpJ6FgetML4Ae3VaN8uniwe9BhaoylEwfaK2bX1fIyxqE56CsUwQ3G-G48KHi4t8ldnsuQo2qhg89ysNH9OcrrxFczUNxUnhNoYbOpBo-7ayvwJmwlL_35_aeQUcbteA HTTP/1.1" 200 -
and got back to add new device app.
when try again and select my test app this shows up on phone/tablet :
Page not found!: '/https%3A%2F%2Foauth-redirect.googleusercontent.com%2Fr%2Fmitt-projekt-259118'
then i have to kill python3 pid and start it again to come to login page when trying again .
/tage
I have the exact same problem as tage.
He replied later he resolved it by replacing the certificate with a new one made with certbot.
I use a certificate from Comodo and created a .crt and .key from a .pfx file and pointed to them in the configuration. When I browse externally to my revers proxy server, it correctyle shows that my website is secure and shows the right certificate.
I tried a self signed certificate, but no luck.
still receiving the 'page not found' error when trying to test with app.
I hope someone can help.
EDIT: I used the manual from Github. So I created a smart-home-key.json and used sampleClientId and sampleClientSecret for authentication.
Posted: Monday 10 February 2020 11:27
by inzuno
Hello and thanks a lot for this amazing work!
I can control every switch and every shutter with voice without any error.
But in the home app the status is not updated and shows 'no response'
When I ask if the status it says something went wrong and in the dzga log i can see : ERROR - 'Low_battery_limit' every time I ask the status.
Hardware: PI3B+
Domoticz Version: 4.10717
DZGA Version: V1.5.9
Python 3.5.3
Reverse proxy configured on Synology NAS
I have another issue but with my old voice commands with IFTTT as they continue to run, even if they are "disconnected" does anyone have a solution?
Thanks again a lot!
Posted: Monday 10 February 2020 17:45
by DewGew
Is ”Low_battery_limit” set in config? Or try set it to 0.
Posted: Monday 10 February 2020 17:51
by DewGew
GeCoLi wrote: Sunday 09 February 2020 12:42
/tage
Do you reach ui with your public url?
Posted: Monday 10 February 2020 18:09
by GeCoLi
Yes I can reach the UI.
Will tell the steps I perform:
In google Home app select [test] App name
need to fist authenticate reverse proxy
then need to authenticate DZGA (UI)
after login, it redirects me back to the screen where I can select a new account
then I select again [test] App name
need to authenticate again with reverse proxy
then it tells me: Page not found!: '/
https://oauth-redirect.googleuserconten ... tion-d8ee4'
I would like to add a screenshot from the log, but don't know how actually. sorry
Posted: Monday 10 February 2020 18:14
by DewGew
Check your settings in actions on google dont forget to press test button after saving. Next check if certificate is valid. You can try if it works with ngrok.
Posted: Tuesday 11 February 2020 14:34
by GeCoLi
DewGew wrote: Monday 10 February 2020 18:14
Excuse me.. I am just an idiot...
Still had my /path/to/.pem commented out
Still not working, but now I know how to look further. Need to convert my certificate to .pem the right way.
Posted: Thursday 20 February 2020 18:29
by Ierlandfan
Am I correct that everytime I restart dzga (Or actually ngrok) a new ngrok dns is created? So I have to update that in Google console?
Posted: Friday 21 February 2020 13:59
by DewGew
Ierlandfan wrote: Thursday 20 February 2020 18:29
That is correct, It explained in wiki
https://github.com/DewGew/Domoticz-Goog ... nfiguraton
Posted: Saturday 22 February 2020 0:28
by jawadde
I'm having some trouble to get dzga working.
I'm using nginx as a reverse proxy, which seems to work OK.
However when I try to link my [test] smarthome services, I get the dzga login page, where I can succesfully login. Then you would expect that Google Home would add the devices, which is NOT happening. I just being returned to the list of services.
When I select my [test] service again I get the following error on my smartphone:
Page not found!: '/https%3A%2F%2Foauth-redirect.googleusercontent.com%2Fr%2Fnumber-17-4679c
This looks to me as I'm receiving a wrong redirect_uri. Note the / before the https
Anybody any idea what the problem could be, I've been looking into this for a couple of days now, without any succes.
Thanks for any hints.
