Page 12 of 15
Re: Error ToonThermostat
Posted: Friday 12 April 2019 15:56
by MJVR
I have the same problems since a couple of days. What works for me is a restart of Domoticz (SSH)
sudo service domoticz.sh stop
sudo service domoticz.sh start
After a reboot the errors return. So it works as long you don't reboot or update.
Posted: Friday 12 April 2019 17:10
by dressie
MJVR wrote: Friday 12 April 2019 15:56 I have the same problems since a couple of days. What works for me is a restart of Domoticz (SSH)
It works for a few minutes. If you don't do anything, this happens:
2019-04-12 17:03:50.747 (Toon) An error occurred updating power usage
2019-04-12 17:03:50.748 (Toon) An error occurred updating gas usage
2019-04-12 17:03:50.748 (Toon) An error occurred updating temperature
2019-04-12 17:03:50.749 (Toon) An error occurred updating thermostat set point
2019-04-12 17:03:50.749 (Toon) An error occurred updating burner state
2019-04-12 17:03:50.749 (Toon) An error occurred updating thermostat state
2019-04-12 17:03:50.749 (Toon) An error occurred updating program state
2019-04-12 17:03:50.750 (Toon) An error occurred updating modulation level
2019-04-12 17:04:52.769 (Toon) Update power/solar usage: 12736690;10458504;0;0;402;0
2019-04-12 17:04:52.772 (Toon) Update gas usage: 2292
2019-04-12 17:04:52.775 (Toon) Update temperature: 20.0
2019-04-12 17:04:52.778 (Toon) Update state: off
Out of nowhere it work again. Something is up with the API, I hope we can find out what.
Posted: Friday 12 April 2019 20:03
by astrapowerrr
hi
still getting this getting to work(day 4).. hahaha
im getting this in the domoticz log.
2019-04-12 19:49:52.229 Error: (ToonApiLib) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/toonapilib4domoticz/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload:/usr/local/lib/python3.4/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.4/dist-packages:/usr/lib/dist-python'.
2019-04-12 19:49:52.229 Error: (Toon ) Module Import failed, exception: 'ImportError'
2019-04-12 19:49:52.229 Error: (Toon ) Module Import failed: ' Name: toonapilib'
2019-04-12 19:49:52.229 Error: (Toon ) Error Line details not available
but i had this before and i was told i was not on beta version.
but now i am on latest version of beta and im getting this error?
now im kinda lost :?
btw: i am very much further in installation:
got some help and i did this steps from a earlier backup:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get autoremove
sudo apt-get autoclean
"then reboot system"
cd domoticz
./updatebeta
pip3 install --upgrade setuptools
pip3 install -U pip
pip3 install --user toonapilib -U
cd /home/pi/domoticz/plugins
git clone https://github.com/JohnvandeVrugt/toonapilib4domoticz
sudo service domoticz restart
that did well with "almost" no errors.. except when installing the toonapilib
i had in the end this 3 orange lines:
Installing collected packages: toonapilib, cachetools, coloredlogs, dateparser, requests, humanfriendly, regex, pytz, python-dateutil, tzlocal, urllib3, chardet, idna, certifi, six
Running setup.py install for toonapilib
warning: no previously-included files matching '__pycache__' found under directory '*'
Could not find .egg-info directory in install record for toonapilib
Running setup.py install for regex
BASE_DIR is /tmp/pip-build-i6rmfj2c/regex
building 'regex._regex' extension
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.4m -c regex_3/_regex.c -o build/temp.linux-armv7l-3.4/regex_3/_regex.o
regex_3/_regex.c: In function ?fuzzy_match_group_fld?:
regex_3/_regex.c:11327:10: warning: ?data.new_text_pos? may be used uninitialized in this function [-Wmaybe-uninitialized]
if (!record_fuzzy(state, data.fuzzy_type, data.new_text_pos - data.step))
regex_3/_regex.c: In function ?fuzzy_match_string_fld?:
regex_3/_regex.c:11102:10: warning: ?data.new_text_pos? may be used uninitialized in this function [-Wmaybe-uninitialized]
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.4m -c regex_3/_regex_unicode.c -o build/temp.linux-armv7l-3.4/regex_3/_regex_unicode.o
arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.4/regex_3/_regex.o build/temp.linux-armv7l-3.4/regex_3/_regex_unicode.o -o build/lib.linux-armv7l-3.4/regex/_regex.cpython-34m.so
/usr/local/lib/python3.4/dist-packages/setuptools/dist.py:472: UserWarning: Normalizing '2019.04.10' to '2019.4.10'
normalized_version,
Could not find .egg-info directory in install record for regex (from dateparser~=0.7.1->toonapilib)
Running setup.py install for tzlocal
Could not find .egg-info directory in install record for tzlocal (from dateparser~=0.7.1->toonapilib)
Successfully installed toonapilib cachetools coloredlogs dateparser requests humanfriendly regex pytz python-dateutil tzlocal urllib3 chardet idna certifi six
Cleaning up...
if someone can tell me this is my problem???
greets marco
Posted: Friday 12 April 2019 20:41
by dressie
I'm missing the "sudo" commands during installation. If you copy/paste the instructions from https://github.com/JohnvandeVrugt/toona ... TALL_PI.md it should go without any issues.
Make sure you also have this one: sudo apt-get install python3-pip.
You really shouldn't get any error during installation.
I found out that I had two API's running from Toon, one on Domoticz and one on a test HomeAssist. I remover the HA one and have only one API @Toon. So far it's all fine again.
Posted: Friday 12 April 2019 20:44
by astrapowerrr
dressie wrote:I'm missing the "sudo" commands during installation. If you copy/paste the instructions from https://github.com/JohnvandeVrugt/toona ... TALL_PI.md it should go without any issues.
Hmmm im also habing some email contact with Costas from toonapilib and he explicitly told me NOT to use sudo??? This gets confusing...
But i will try with sudo...
Posted: Friday 12 April 2019 20:45
by dressie
astrapowerrr wrote: Friday 12 April 2019 20:44
Yes, on Raspberry Pi you should use the SUDO command actually.
Posted: Friday 12 April 2019 21:12
by waspy
I also commented on your thread on github.
You will have to install it as root (sudo) because you need to have it installed in one of the folders that is processed by domoticz.
sudo pip3 install toonapilib -U
Another thing: I did not experience any of the errors that were reported in this thread.
I just upgraded to the last version of domoticz, toonapilib and stable version of my plugin.
This combination seems to run just fine. (Tested on a virtual machine with raspbian)
2019-04-12 20:58:27.425 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-12 20:58:27.426 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-12 20:58:27.426 Status: Startup Path: /home/pi/dev-domoticz/
2019-04-12 20:58:27.713 Status: PluginSystem: Started, Python version '3.5.3'.
2019-04-12 20:58:30.044 Status: PluginSystem: Entering work loop.
2019-04-12 20:58:32.536 (TestApilib) Using toonapilib version 3.2.3 by Costas Tyfoxylos <[email protected]>
2019-04-12 20:58:32.536 (TestApilib) Debug logging is active
2019-04-12 20:58:32.536 (TestApilib) Creating toonapilib object
2019-04-12 20:58:32.533 Status: (TestApilib) Initialized version 1.0.14, author 'John van de Vrugt'
2019-04-12 20:58:32.534 Status: (TestApilib) Entering work loop.
2019-04-12 20:58:53.700 (TestApilib) Check and create Toon devices
Posted: Friday 12 April 2019 21:45
by astrapowerrr
well gave the sudo command and now i get this errors again.
pi@raspberrypi:~ $ sudo pip3 install --upgrade setuptools
DEPRECATION: Python 3.4 support has been deprecated. pip 19.1 will be the last one supporting it. Please upgrade your Python as Python 3.4 won't be maintained after March 2019 (cf PEP 429).
The directory '/root/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/root/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already up-to-date: setuptools in /usr/local/lib/python3.4/dist-packages (41.0.0)
pi@raspberrypi:~ $ sudo pip3 install -U pip
Requirement already up-to-date: pip in /usr/local/lib/python3.4/dist-packages (19.0.3)
pi@raspberrypi:~ $ sudo pip3 install --user toonapilib -U
Collecting toonapilib
Downloading https://files.pythonhosted.org/packages ... 2.3.tar.gz (68kB)
100% |????????????????????????????????| 71kB 3.0MB/s
Collecting requests~=2.21.0 (from toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (57kB)
100% |????????????????????????????????| 61kB 4.3MB/s
Collecting dateparser~=0.7.1 (from toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (351kB)
100% |????????????????????????????????| 358kB 3.5MB/s
Collecting cachetools~=3.1.0 (from toonapilib)
Collecting coloredlogs~=10.0 (from toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (47kB)
100% |????????????????????????????????| 51kB 4.3MB/s
Collecting idna<2.9,>=2.5 (from requests~=2.21.0->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (58kB)
100% |????????????????????????????????| 61kB 4.6MB/s
Collecting chardet<3.1.0,>=3.0.2 (from requests~=2.21.0->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (133kB)
100% |????????????????????????????????| 143kB 4.7MB/s
Collecting urllib3<1.25,>=1.21.1 (from requests~=2.21.0->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (118kB)
100% |????????????????????????????????| 122kB 4.7MB/s
Collecting certifi>=2017.4.17 (from requests~=2.21.0->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (158kB)
100% |????????????????????????????????| 163kB 4.6MB/s
Collecting pytz (from dateparser~=0.7.1->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (510kB)
100% |????????????????????????????????| 512kB 3.5MB/s
Collecting python-dateutil (from dateparser~=0.7.1->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (226kB)
100% |????????????????????????????????| 235kB 4.4MB/s
Collecting tzlocal (from dateparser~=0.7.1->toonapilib)
Downloading https://files.pythonhosted.org/packages ... 5.1.tar.gz
Collecting regex (from dateparser~=0.7.1->toonapilib)
Downloading https://files.pythonhosted.org/packages ... .12.tar.gz (644kB)
100% |????????????????????????????????| 645kB 3.3MB/s
Collecting humanfriendly>=4.7 (from coloredlogs~=10.0->toonapilib)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (73kB)
100% |????????????????????????????????| 81kB 4.9MB/s
Requirement already satisfied, skipping upgrade: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil->dateparser~=0.7.1->toonapilib) (1.8.0)
Installing collected packages: idna, chardet, urllib3, certifi, requests, pytz, python-dateutil, tzlocal, regex, dateparser, cachetools, humanfriendly, coloredlogs, toonapilib
The script chardetect is installed in '/root/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Running setup.py install for tzlocal ... done
Running setup.py install for regex ... done
The script humanfriendly is installed in '/root/.local/bin' which is not on PATH.
The script coloredlogs is installed in '/root/.local/bin' which is not on PATH.
Running setup.py install for toonapilib ... done
Successfully installed cachetools-3.1.0 certifi-2019.3.9 chardet-3.0.4 coloredlogs-10.0 dateparser-0.7.1 humanfriendly-4.18 idna-2.8 python-dateutil-2.8.0 pytz-2019.1 regex-2019.4.12 requests-2.21.0 toonapilib-3.2.3 tzlocal-1.5.1 urllib3-1.24.1
pi@raspberrypi:~ $
strange… where does these come from?
Posted: Friday 12 April 2019 21:51
by astrapowerrr
in the log from domoticz i see this
2019-04-12 21:46:13.754 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-12 21:46:13.762 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-12 21:46:13.763 Status: Startup Path: /home/pi/domoticz/
2019-04-12 21:46:13.842 Status: EventSystem: reset all events...
2019-04-12 21:46:13.940 Status: PluginSystem: Started, Python version '3.4.2'.
2019-04-12 21:46:13.960 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-12 21:46:13.970 Status: WebServer(SSL) started on address: :: with port 443
2019-04-12 21:46:13.973 Status: Proxymanager started.
2019-04-12 21:46:14.015 Status: TCPServer: shared server started...
2019-04-12 21:46:14.016 Status: RxQueue: queue worker started...
2019-04-12 21:46:15.024 Status: PROXY: Authenticate result: success.
2019-04-12 21:46:16.016 Status: RFXCOM: Worker started...
2019-04-12 21:46:16.025 Status: ToonThermostat: Worker started...
2019-04-12 21:46:16.026 Status: Kodi: Started
2019-04-12 21:46:16.027 Status: (Toon ) Started.
2019-04-12 21:46:16.027 Status: Darksky: Started...
2019-04-12 21:46:16.027 Status: EventSystem: reset all events...
2019-04-12 21:46:16.032 Status: EventSystem: reset all device statuses...
2019-04-12 21:46:16.351 Status: PluginSystem: Entering work loop.
2019-04-12 21:46:16.408 Status: Python EventSystem: Initalizing event module.
2019-04-12 21:46:16.425 Status: EventSystem: Queue thread started...
2019-04-12 21:46:16.425 Status: EventSystem: Started
i only see (toon) started. but thats realy all...
Posted: Friday 12 April 2019 22:11
by waspy
I see, but don't understand :shock:
The previous error that the toonapilib could not be found seems to be fixed, so that's good news.
My plugin first logs the apilib version. But this line seems to be missing in your log at all...
So if this line is missing, I'm sure all the rest will fail as well.
Domoticz.Log("Using toonapilib version " + toonapilib.__version__ + " by " + toonapilib.__author__)
Not sure where to go from here. I'm no python or domoticz expert.
Maybe a good time to update the O/S on the pi?
I am using a pi3. Don't know what hardware you are using.
I have never tested it on a pi 1 or 2.
But maybe somebody else on the forum did...
Posted: Friday 12 April 2019 23:01
by astrapowerrr
well i used
sudo chown root:root /root
that fixed the errors from not owning the folder und use sudo -H flag etc.
but still nothing in the log of domoticz…
who else can i ask?
im running out of ideas…
ps hardware is a pi3 and reinstalling etc is a no go... my whole house is running on domoticz… my wife will kill me!
Posted: Friday 12 April 2019 23:04
by waspy
Always good to have a spare ;)
Verstuurd vanaf mijn SM-G935F met Tapatalk
Posted: Friday 12 April 2019 23:27
by astrapowerrr
i will try this weekend with a new run..
get my backup again.
sudo chown -R root:root /root
sudo apt-get update
cd domoticz
./updatebeta
sudo easy_install -U setuptools
then see what happens...
Posted: Saturday 13 April 2019 21:12
by Hiu80
I am still stuck at:
2019-04-13 21:04:34.240 Status: (toon) Started.
2019-04-13 21:04:41.770 (toon) Using toonapilib version 3.2.3 by Costas Tyfoxylos <[email protected]>
2019-04-13 21:04:41.765 Status: (toon) Entering work loop.
2019-04-13 21:04:41.766 Status: (toon) Initialized version 1.0.14, author 'John van de Vrugt'
2019-04-13 21:04:42.399 (toon) Could not create a toonapilib object
2019-04-13 21:04:42.401 (toon) Possible solution:
2019-04-13 21:04:42.401 (toon) * Check your credentials
2019-04-13 21:04:42.401 (toon) * Restart Domoticz
2019-04-13 21:04:42.401 (toon) Check and create Toon devices
2019-04-13 21:04:42.401 (toon) Creating Power usage device
2019-04-13 21:04:42.405 (toon) Creating Gas usage device
2019-04-13 21:04:42.408 (toon) Creating Room temperature device
2019-04-13 21:04:42.410 (toon) Creating Set point device
2019-04-13 21:04:42.411 (toon) Creating Heating active device
2019-04-13 21:04:42.414 (toon) Creating Hot water active device
2019-04-13 21:04:42.416 (toon) Creating Preheat active device
2019-04-13 21:04:42.418 (toon) Creating Scene device
2019-04-13 21:04:42.421 (toon) Creating Program state device
2019-04-13 21:04:42.423 (toon) Creating Modulation level device
The credentials i use are correct. Not shure how to proceed right now :)
Posted: Saturday 13 April 2019 21:17
by waspy
Are you using domoticz beta version? Think this happens with the stable one....
Posted: Saturday 13 April 2019 21:37
by Hiu80
waspy wrote: Saturday 13 April 2019 21:17 Are you using domoticz beta version? Think this happens with the stable one....
Iam using V4.10602, thats correct right?
Posted: Saturday 13 April 2019 23:02
by waspy
Yes, that is just fine. Tested with that version last night.
I have added testtoonapilib.py to the repository for testing purposes.
If you run python3.* testtoonapilib.py in the terminal you can test whether a toon object can be created.
That is, if toonapilib is installed correctly and your credentials are correct :)
Good luck!
Posted: Sunday 14 April 2019 16:03
by Hiu80
waspy wrote: Saturday 13 April 2019 23:02 Yes, that is just fine. Tested with that version last night.
Good luck!
Hey waspy,
Thanks for helping me!
When i run your testscript i get:
Starting toonapilib test
On success the room temperature will be presented
Trying to create a toon object
An error occurred creating the Toon object
I have removed domoticz, removed the toonapilib library and reinstalled everyting again. Installing gives no errors. I have an toon subscription and can use the toonAP on my smartphone with the same credentials i use to configure your plugin.
Maybe i have to completely reinstall my rasp?
Posted: Sunday 14 April 2019 16:05
by waspy
Apart from the credentials, you also need the API key and secret. Did you created those from the developer eneco site?
Posted: Sunday 14 April 2019 16:29
by Hiu80
waspy wrote: Sunday 14 April 2019 16:05 Apart from the credentials, you also need the API key and secret. Did you created those from the developer eneco site?
I did something wrong the last time. Now the script works and gives me:
Room temperature: 18.5
So, i does work. Why it is not working in domoticz i don't know. Installing a VM with stretch to build a test environment.
