Page 12 of 18
Re: Python Plugin: Zigbee2Mqtt
Posted: Wednesday 21 April 2021 7:48
by Nautilus
Hi, I am still running pre 3.0 version with zzh and zigbee2mqtt v.1.18. I have two locations, in both of them over 30 zigbee devices (most of them have 3-5 separate devices in Domoticz so the total is somewhere around 100 devices per location - and I have named them all
). Also a lot of automations, some of which have been tied to the idx, but most of them to the device name. On top of this I would like to keep my over 5 years of history of temperatures, but other log info is irrelevant. Everything works now, but I want to be future proof with new deivces coming and new features as well.
Do I understant that I could try to update without removing the hardware first? In this case I could expect duplicate devices and maybe some other harm, but still more or less everything should work and with a bit of effort (less effort than removing all devices in Domotics and creating them again?) all would be back to normal?
And the other option would be to remove the current zigbee2mqtt hardware, then add the hardware again and do the update? In this case all of my logs (temp history) would be lost, all devices would be created again (and I would have to name all of them again
) with new idx and I would have to go through all of my automations etc. to make sure they work again? But I would not need to link the devices again with zzh?
Of course, I would have a backup if I needed to go back...
Posted: Thursday 22 April 2021 17:42
by fac13
I was in a similar position but with even more devices; I decided I wasn't willing to trash everything and start again.
So I worked out a way to do it by manually updating the domoticz database in between the last run with old plugin code and the first run with the new plugin code.
I used a test domoticz instance to discover what new deviceid's the plugin would use when restarted at v3.0, and how those mapped to my existing pre-v3.0 deviceid's.
I then prepared a set of SQL update statements like this one: -
UPDATE devicestatus SET deviceid = '0x000b3cfffef4febd_state' WHERE deviceid = '0x000b3cfffef4febd_switch';
In my case I needed a total of 28 such statements. I tested these and rehearsed my upgrade plan several times on my test system until I was happy, and then applied it to my production system. It worked perfectly.
I did this almost three months ago and have had no problems. Absolutely no other changes were required, everything carried on working.
This method obviously requires some thought, planning and a bit of knowledge. If anybody else reading this likes the idea but has lots of basic questions then I'm afraid this isn't for you.
It does work though!
Posted: Saturday 24 April 2021 9:04
by ubee
Seems to be just one thread about this plugin, so it might be a long shot get through this way....
I'm new in the Zigbee world but not with Domoticz. Decided to try out some Zigbee stuff since I'm extremely tired of 433MHz devices. I have added a cc2652 dongle to my Rasp, installed zigbee2mqtt broker and this Domoticz plugin. I have also managed to set up a Agara temp&humidity sensor and it works fine as far as I can see. Next on my list is to integrate a wall-switch. I have added Sunricher ZG9100A-S switch which should be a supported by zigbee2mqtt. Pairing is OK. However, the only thing that shows up in the list in zigbee2mgtt tab is a router, no end device. I enclose two screendumps.
What am I missing?
Posted: Saturday 24 April 2021 11:08
by fac13
Most of the support for the plugin is via github. When I've needed help I've got it by raising an issue there, it's much more active than this thread.
https://github.com/stas-demydiuk/domoti ... gin/issues
Posted: Saturday 24 April 2021 12:40
by waltervl
It is also OK to create a new topic here in Zigbee subforum with your questions as long as you mention your plugin (Zigbee2mqtt, ZiGate, Deconz) in the title.
Posted: Wednesday 28 April 2021 17:19
by Nautilus
Well, I went ahead and updated my system where I have less zigbee devices. I was not able to add my newest due to compatibility and decided this is the only way to go.
Now, after the update some devices continue to work fine, but with some I have issues. E.g. WSDCGQ01LM Temp/hum sensor stopped reporting under the combined sensor (temp/hum). It still updates the individual temp and hum sensor. I’ve tried re-pairing, I removed the existing temp/hum device and hoped it would be recreated but nothing seems to work. What should I do to make it alive again (in this case to be created again)?
Same seems to trouble my IKEA Kadjril roller blinds. I have not tested any repair actions with them yet but the existing devices are not working anymore...
edit. The blinds control works - just that it is now inverted. By changing the type to "blinds percentage inverted" it is logical to use them again except that both 0% and 100% will fully drop them. I went ahead and removed the temp/hum sensor from domoticz (all that was created) and from zigbee network. Then added it to zigbee2mqtt again afer which all except the combined temp/hum sensor were created as new sensors. So I am still wondering how I could get that combined sensor back...
Posted: Sunday 02 May 2021 22:48
by Nautilus
There is now a PR for this missing temp/hum sensor issue in the github repository:
https://github.com/stas-demydiuk/domoti ... n/pull/629
Unfortunately it seems that StasDemydiuk has not been active on the forum nor in Github since March. I hope everything is ok. Does anyone here know him personally? I wonder if anyone else can merge PR's to this repository in case he is busy with other activities?
Posted: Sunday 02 May 2021 23:21
by heggink
Let's give it a bit. Worst case, someone else clones the repo and we work from that for a while.
Posted: Monday 03 May 2021 9:43
by sammyke007
Nautilus wrote: Sunday 02 May 2021 22:48
He replied on Github 13 minutes ago, everything's ok...
Posted: Monday 03 May 2021 13:27
by Nautilus
Yes, the PR is now merged - great news to see Stas is back with us...
Posted: Monday 10 May 2021 8:12
by Derik
Hi....
I read the best way for the upgrade is to remove the plugin and install a clean version.
Only all the IDX.....
What happend when i upgrade the plugin anyway?
Is this working?
I have 50 z2m device, so a upgrade and all new idx is a lot work..
Some one have a idea? or a solution?
Posted: Monday 10 May 2021 8:14
by eddieb
Hi @Derik,
I did upgrade and it all went ok here, just got some new idx ..
All existing kept working
Posted: Monday 10 May 2021 11:55
by Derik
eddieb wrote: Monday 10 May 2021 8:14
Hi @Derik,
Hi thanks forthe answer..
Only i did:
pi@odroidn2:~$ cd domoticz/plugins/zigbee2mqtt
pi@odroidn2:~/domoticz/plugins/zigbee2mqtt$ git pull
remote: Enumerating objects: 389, done.
remote: Counting objects: 100% (344/344), done.
remote: Compressing objects: 100% (110/110), done.
remote: Total 389 (delta 245), reused 315 (delta 222), pack-reused 45
Receiving objects: 100% (389/389), 57.82 KiB | 2.89 MiB/s, done.
Resolving deltas: 100% (251/251), completed with 57 local objects.
From https://github.com/stas-demydiuk/domoticz-zigbee2mqtt-plugin
47cc6f3..7537ad5 master -> origin/master
* [new tag] v.3.0.0 -> v.3.0.0
Updating 47cc6f3..7537ad5
error: Your local changes to the following files would be overwritten by merge:
adapters/__init__.py
Please commit your changes or stash them before you merge.
Aborting
something went wrong?
Posted: Monday 10 May 2021 13:17
by waaren
Derik wrote: Monday 10 May 2021 11:55
Do a
Posted: Monday 10 May 2021 18:57
by Derik
waaren wrote: Monday 10 May 2021 13:17
Do a
Thanks Did was the working oprion..
A few new features...
Thanks to all great work!!!!!
Posted: Saturday 15 May 2021 12:20
by fac13
Nautilus wrote: Wednesday 28 April 2021 17:19
The fact that the blind control goes wrong at 0% and 100% but works correctly on values in between appears to be a known problem - there is an issue for this on github but there has been no response as yet.
Posted: Monday 17 May 2021 20:35
by hoeby
I updated domoticz to the last version.
Also zigbee2mqtt and zigbee plugin are update.
In the domoticz log i see this row every 5 seconds.
Zigbee2MQTT: (Zigbee2MQTT) Received groups list from bridge
Need i to worry about it?
I don't use groups, don't know why i receives it.
Can i disable this information line?
Posted: Wednesday 21 July 2021 7:00
by fvdp80
I've been getting irregular errors from a Osram/Lightify A60 lightbulb. Does anybody know what this error means?
2021-07-21 00:09:51.486 Error: Zigbee2MQTT: (Zigbee2MQTT) A Zigbee publish error occured for device '0x7cb03eaa0a046794' with error message: Publish 'set' 'brightness' to '0x7cb03eaa0a046794' failed: 'Error: Command 0x7cb03eaa0a046794/3 genLevelCtrl.moveToLevelWithOnOff({"level":25,"transtime":0}, {"sendWhenActive":false,"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC no ack' (233))'
Posted: Wednesday 21 July 2021 8:58
by heggink
I have these sometimes with IKEA services as well. I was told these are because of an overflow bug in their firmware (see my issue logged on the z2m GitHub). Disconnecting them from power fixes it for a while until it happens again.
Posted: Wednesday 21 July 2021 11:03
by waltervl
This is looks like that the Zigbee Coordinator (USB Stick) did not get a acknowledgement from the bulb. So they are not talking to each other.
Indeed toggle the power on the bulb will trigger a zigbee reconnect.
With Zigate I get these too (on some devices). Sometimes sending the command already triggers the reconnect so no need to toggle power.
