Zigbee2MQTT
Varazir
Re: Zigbee2MQTT
Post by Varazir »
Zigbee2MQTT just stopped working for me.
When I klicka on the button for the controlpanel I get this in the log
and the page just shows
2020-07-27 19:17:32.796 (zigbee2mqtt) MqttClient::ping
2020-07-27 19:17:32.797 (zigbee2mqtt) Sending 2 bytes of data
2020-07-27 19:17:32.797 (zigbee2mqtt) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-07-27 19:17:32.847 (zigbee2mqtt) Received 2 bytes of data
2020-07-27 19:17:32.847 (zigbee2mqtt) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-07-27 19:17:39.671 (zigbee2mqtt) New request: [4] bridge_getstatus({})
2020-07-27 19:17:39.671 (zigbee2mqtt) MqttClient::publish zigbee2mqtt/bridge/config/permit_join ()
2020-07-27 19:17:39.672 (zigbee2mqtt) Sending 41 bytes of data
2020-07-27 19:17:39.672 (zigbee2mqtt) 30 27 00 25 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 64 0'.%zigbee2mqtt/brid
2020-07-27 19:17:39.672 (zigbee2mqtt) 67 65 2f 63 6f 6e 66 69 67 2f 70 65 72 6d 69 74 5f 6a 6f 69 ge/config/permit_joi
2020-07-27 19:17:39.672 (zigbee2mqtt) 6e .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. n
2020-07-27 19:17:39.673 (zigbee2mqtt) Received 41 bytes of data
2020-07-27 19:17:39.673 (zigbee2mqtt) 30 27 00 25 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 64 0'.%zigbee2mqtt/brid
2020-07-27 19:17:39.673 (zigbee2mqtt) 67 65 2f 63 6f 6e 66 69 67 2f 70 65 72 6d 69 74 5f 6a 6f 69 ge/config/permit_joi
2020-07-27 19:17:39.673 (zigbee2mqtt) 6e .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. n
2020-07-27 19:17:39.674 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/config/permit_join
2020-07-27 19:17:42.782 (zigbee2mqtt) MqttClient::ping
2020-07-27 19:17:42.782 (zigbee2mqtt) Sending 2 bytes of data
2020-07-27 19:17:42.782 (zigbee2mqtt) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-07-27 19:17:42.833 (zigbee2mqtt) Received 2 bytes of data
2020-07-27 19:17:42.833 (zigbee2mqtt) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-07-27 19:17:52.758 (zigbee2mqtt) MqttClient::ping
2020-07-27 19:17:52.758 (zigbee2mqtt) Sending 2 bytes of data
2020-07-27 19:17:52.758 (zigbee2mqtt) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-07-27 19:17:52.809 (zigbee2mqtt) Received 2 bytes of data
2020-07-27 19:17:52.809 (zigbee2mqtt) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
When I press on a switch I get
2020-07-27 19:19:12.797 (zigbee2mqtt) MqttClient::ping
2020-07-27 19:19:12.797 (zigbee2mqtt) Sending 2 bytes of data
2020-07-27 19:19:12.797 (zigbee2mqtt) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2020-07-27 19:19:12.848 (zigbee2mqtt) Received 2 bytes of data
2020-07-27 19:19:12.848 (zigbee2mqtt) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2020-07-27 19:19:12.899 (zigbee2mqtt) onCommand: On, level (54) Color:
2020-07-27 19:19:12.899 (zigbee2mqtt) Can't process command from device "IKEA - Taklampa Datorrum"
2020-07-27 19:19:12.872 Status: User: zedde initiated a switch command (198/IKEA - Taklampa Datorrum/On)
I have updated to the latest github release
I have restarted the pie
I have shut it down and made it powerless 20 sec
Still same.
Varazir
Re: Zigbee2MQTT
Post by Varazir »
I noticed the led on the usb adapter just turns on 20 sec when I reconnect it in the pie
Varazir
Re: Zigbee2MQTT
Post by Varazir »
found the problem in the /var/log/syslog file
Jul 27 00:00:05 zwave2 rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="283" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
Jul 27 00:00:09 zwave2 npm[20401]: > [email protected] start /opt/zigbee2mqtt
Jul 27 00:00:09 zwave2 npm[20401]: > node index.js
Jul 27 00:00:12 zwave2 npm[20401]: #033[32mzigbee2mqtt:info #033[39m 2020-07-27 00:00:12: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2020-07-27.00-00-12' filename
Jul 27 00:00:13 zwave2 npm[20401]: (node:20422) UnhandledPromiseRejectionWarning: Error: Duplicate friendly_name 'IKEA - Taklampa Datorrum' found
Jul 27 00:00:13 zwave2 npm[20401]:     at check (/opt/zigbee2mqtt/lib/util/settings.js:348:41)
Jul 27 00:00:13 zwave2 npm[20401]:     at Object.values.forEach (/opt/zigbee2mqtt/lib/util/settings.js:358:64)
Jul 27 00:00:13 zwave2 npm[20401]:     at Array.forEach (<anonymous>)
Jul 27 00:00:13 zwave2 npm[20401]:     at Object.validate (/opt/zigbee2mqtt/lib/util/settings.js:358:49)
Jul 27 00:00:13 zwave2 npm[20401]:     at Controller.start (/opt/zigbee2mqtt/lib/controller.js:94:41)
Jul 27 00:00:13 zwave2 npm[20401]:     at Object.<anonymous> (/opt/zigbee2mqtt/index.js:11:12)
Jul 27 00:00:13 zwave2 npm[20401]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
Jul 27 00:00:13 zwave2 npm[20401]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
Jul 27 00:00:13 zwave2 npm[20401]:     at Module.load (internal/modules/cjs/loader.js:653:32)
Duplicate friendly_name didn't show up anywhere else.
hoeby
Domoticz version: V2022.1
Re: Zigbee2MQTT
Post by hoeby »
I don't know if it is normal, then put the question here i thoughed.
I have a osram switch, which is a remote with 3 buttons.
My zigbee network has the coördinator and 1 router.
The remote is in between and when i look in the zigbee connection plan i can seen the remote is connected to both. When in push the remote button, than i get 2 commands in domoticz (seen in log). When i unplug the router and push the button, then i get 1 command.
Is it normal that all receiving components are giving the command to domoticz?
I had a script that with 1 push it does something and with 2 pushes it does something else. This isn't going to work by the multi commands on 1 push
fabstar81
Re: Zigbee2MQTT
Post by fabstar81 »
peerkersezuuker wrote: Sunday 19 July 2020 11:35 Hi,
I have a strange problem.
After pairing an Gledopto Smart 4W E14 RGB / CCT LED bulb (GL-B-001ZS) :
info  2020-07-19 11:15:08: Device '0x00124b001f69f7c3' joined
info  2020-07-19 11:15:08: Starting interview of '0x00124b001f69f7c3'
info  2020-07-19 11:15:08: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_connected","message":{"friendly_name":"0x00124b001f69f7c3"}}'
info  2020-07-19 11:15:08: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_started","meta":{"friendly_name":"0x00124b001f69f7c3"}}'
debug 2020-07-19 11:15:08: Device '0x00124b001f69f7c3' announced itself
info  2020-07-19 11:15:08: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_announced","message":"announce","meta":{"friendly_name":"0x00124b001f69f7c3"}}'
debug 2020-07-19 11:15:08: Received MQTT message on 'zigbee2mqtt/bridge/config/devices' with data ''
info  2020-07-19 11:15:08: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"devices","message":[{"ieeeAddr":"0x00124b0018e2efdf","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack12","dateCode":"20190619","lastSeen":1595150108250},{"ieeeAddr":"0x000b3cfffef2b365","type":"Router","networkAddress":19115,"model":"LED1623G12","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, opal white","friendly_name":"Toilet Lamp","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 W opal 1000lm","hardwareVersion":1,"softwareBuildID":"1.2.214","dateCode":"20170302","lastSeen":1595146150306},{"ieeeAddr":"0xccccccfffe331b29","type":"Router","networkAddress":17783,"model":"LED1837R5","vendor":"IKEA","description":"TRADFRI LED bulb GU10 400 lumen, dimmable","friendly_name":"Kamer achter 01","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb GU10 WW 400lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595150068748},{"ieeeAddr":"0x14b457fffe548b92","type":"Router","networkAddress":38729,"model":"LED1837R5","vendor":"IKEA","description":"TRADFRI LED bulb GU10 400 lumen, dimmable","friendly_name":"Kamer achter 02","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb GU10 WW 400lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595150068843},{"ieeeAddr":"0xccccccfffe4c88b2","type":"Router","networkAddress":2000,"model":"LED1837R5","vendor":"IKEA","description":"TRADFRI LED bulb GU10 400 lumen, dimmable","friendly_name":"Kamer voor 01","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb GU10 WW 400lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595137596735},{"ieeeAddr":"0xccccccfffe3eef6c","type":"Router","networkAddress":2299,"model":"LED1837R5","vendor":"IKEA","description":"TRADFRI LED bulb GU10 400 lumen, dimmable","friendly_name":"Kamer voor 02","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb GU10 WW 400lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595137597241},{"ieeeAddr":"0xccccccfffe3eeccf","type":"Router","networkAddress":16212,"model":"LED1837R5","vendor":"IKEA","description":"TRADFRI LED bulb GU10 400 lumen, dimmable","friendly_name":"Kamer voor 03","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb GU10 WW 400lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595137597768},{"ieeeAddr":"0x00124b001d43e264","type":"Router","networkAddress":15752,"model":"GL-C-008-1ID","vendor":"Gledopto","description":"Zigbee LED controller RGB + CCT (1 ID)","friendly_name":"Gledopto No 1","manufacturerID":0,"manufacturerName":"GLEDOPTO","powerSource":"Mains (single phase)","modelID":"GL-C-008","hardwareVersion":1,"softwareBuildID":"2.0.0","dateCode":"20131206","lastSeen":1588690387212},{"ieeeAddr":"0x000b3cfffef2aedc","type":"Router","networkAddress":18459,"model":"LED1623G12","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, opal white","friendly_name":"Poort Lamp","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 W opal 1000lm","hardwareVersion":1,"softwareBuildID":"1.2.214","dateCode":"20170302","lastSeen":1595130251790},{"ieeeAddr":"0x00124b001ee8d574","type":"Router","networkAddress":24124,"model":"GL-C-006","vendor":"Gledopto","description":"Zigbee LED controller WW/CW","friendly_name":"Keuken Blok","manufacturerID":0,"manufacturerName":"GLEDOPTO","powerSource":"Mains (single phase)","modelID":"GL-C-006","hardwareVersion":1,"softwareBuildID":"1.0.7","dateCode":"20131206","lastSeen":1582296135958},{"ieeeAddr":"0xd0cf5efffeffa80b","type":"EndDevice","networkAddress":47778,"model":"E1525/E1745","vendor":"IKEA","description":"TRADFRI motion sensor","friendly_name":"Kamer PIR 01","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Battery","modelID":"TRADFRI motion sensor","hardwareVersion":1,"softwareBuildID":"1.2.214","dateCode":"20170302","lastSeen":1595150094939},{"ieeeAddr":"0x04cf8cdf3c772525","type":"EndDevice","networkAddress":42869,"model":"GZCGQ01LM","vendor":"Xiaomi","description":"MiJia light intensity sensor","friendly_name":"Lux Sensor 01","manufacturerID":4718,"manufacturerName":"LUMI","powerSource":"Battery","modelID":"lumi.sen_ill.mgl01","hardwareVersion":1,"softwareBuildID":"2019\u0000www.","dateCode":"20191118","lastSeen":1595149964069},{"ieeeAddr":"0x00158d0004210781","type":"EndDevice","networkAddress":24774,"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","friendly_name":"Kamer Temperatuur","manufacturerID":4151,"manufacturerName":"LUMI","modelID":"lumi.weather","hardwareVersion":30,"softwareBuildID":"3000-0001","dateCode":"20161129","lastSeen":1595149191542},{"ieeeAddr":"0x680ae2fffe3f15f2","type":"EndDevice","networkAddress":15298,"model":"E1926","vendor":"IKEA","description":"KADRILJ roller blind","friendly_name":"Rol Gordijn 01 Overkapping","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Battery","modelID":"KADRILJ roller blind","hardwareVersion":1,"softwareBuildID":"2.2.009","dateCode":"20190311","lastSeen":1595106327589},{"ieeeAddr":"0x680ae2fffe785feb","type":"EndDevice","networkAddress":24574,"model":"E1766","vendor":"IKEA","description":"TRADFRI open/close remote","friendly_name":"Rol Gordijn Bediening","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Battery","modelID":"TRADFRI open/close remote","hardwareVersion":1,"softwareBuildID":"2.2.010","dateCode":"20190311","lastSeen":1595122922636},{"ieeeAddr":"0xd0cf5efffef579af","type":"EndDevice","networkAddress":49760,"model":"E1757","vendor":"IKEA","description":"FYRTUR roller blind","friendly_name":"Rol Gordijn 02 Overkapping","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Battery","modelID":"FYRTUR block-out roller blind","hardwareVersion":1,"softwareBuildID":"2.2.007","dateCode":"20190311","lastSeen":1595143136450},{"ieeeAddr":"0x14b457fffe45984c","type":"Router","networkAddress":58575,"model":"LED1842G3","vendor":"IKEA","description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","friendly_name":"Tuin Lamp 1-1","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 WW clear 250lm","hardwareVersion":2,"softwareBuildID":"2.3.050","dateCode":"20181203","lastSeen":1595130244439},{"ieeeAddr":"0x14b457fffe3ef61a","type":"Router","networkAddress":63677,"model":"LED1842G3","vendor":"IKEA","description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","friendly_name":"Tuin Lamp 2-2","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 WW clear 250lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595130244849},{"ieeeAddr":"0x14b457fffe6d5485","type":"Router","networkAddress":21259,"model":"LED1842G3","vendor":"IKEA","description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","friendly_name":"Tuin Lamp 2-1","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 WW clear 250lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595130244506},{"ieeeAddr":"0x14b457fffe6c483e","type":"Router","networkAddress":33425,"model":"LED1842G3","vendor":"IKEA","description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","friendly_name":"Tuin Lamp 2-3","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 WW clear 250lm","hardwareVersion":2,"softwareBuildID":"2.3.050","dateCode":"20181203","lastSeen":1595130244899},{"ieeeAddr":"0x14b457fffe537ac0","type":"Router","networkAddress":17058,"model":"LED1842G3","vendor":"IKEA","description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","friendly_name":"Tuin Lamp 3-1","manufacturerID":4476,"manufacturerName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelID":"TRADFRI bulb E27 WW clear 250lm","hardwareVersion":2,"softwareBuildID":"2.1.022","dateCode":"20181203","lastSeen":1595130244971},{"ieeeAddr":"0x00124b001f69f7c3","networkAddress":7224,"model":"XBee","vendor":"Digi","description":"Router","friendly_name":"0x00124b001f69f7c3","lastSeen":1595150108226}]}'
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"modelId":"GL-B-001ZS"}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"GLEDOPTO"}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"powerSource":1}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"appVersion":1}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:09: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"stackVersion":2}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:10: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:10: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20131206"}' from endpoint 11 with groupID 0
debug 2020-07-19 11:15:10: Received Zigbee message from '0x00124b001f69f7c3', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"1.0.9"}' from endpoint 11 with groupID 0
info  2020-07-19 11:15:10: Successfully interviewed '0x00124b001f69f7c3', device has successfully been paired
info  2020-07-19 11:15:10: Device '0x00124b001f69f7c3' is supported, identified as: Gledopto Smart 4W E14 RGB / CCT LED bulb (GL-B-001ZS)
info  2020-07-19 11:15:10: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_successful","meta":{"friendly_name":"0x00124b001f69f7c3","model":"GL-B-001ZS","vendor":"Gledopto","description":"Smart 4W E14 RGB / CCT LED bulb","supported":true}}'
it is visible in the Zigbee2MQTT plugin :
https://i.imgur.com/lCDm8nL.png
But is not creating any devices in Domoticz. (set accept new hardware device on !)
https://i.imgur.com/eF1M1Wz.png
Any suggestions ?
Regards Peer
i have exactly the same problem. i paired a Gledopto GL-B-001Z E14 RGB light bulb which is perfectly recognized by zigbee2mqtt but i don't get Domoticz to make a new device for it. Have tried practically everything. Checked the box "Accept new hardware devices" AND also clicked on the "Allow for 5 minutes" button. I restarted domoticz, restarted NPM, enabled and disable the zigbee2mqtt plugin in domoticz hardware, all to no prevail.
anyone any ideas left?
thanks!
hoeby
Re: Zigbee2MQTT
Post by hoeby »
fabstar81 wrote: Wednesday 16 September 2020 20:31
thanks!
I haven't looked for it, but is that device support by domoticz?
It could be that the zigbee2mqtt supports it, but domoticz also have to support it, to get it working
fabstar81
Re: Zigbee2MQTT
Post by fabstar81 »
hoeby wrote: Wednesday 16 September 2020 21:17
thanks!
where can i check that it is supported by domoticz or not?
hmm, i do see here that it is supposed to be updated in the plugin. now find a way to update the plugin. never did that actually :roll:
Jan Jansen
Domoticz version: Stable
Re: Zigbee2MQTT
Post by Jan Jansen »
@fabstar81
The Domomitcz WIKI (Zigbee2MQTT) refers to https://github.com/stas-demydiuk/domoti ... qtt-plugin. There it is indicated how the update should be performed.
Derik
Re: Zigbee2MQTT
Post by Derik »
Does anyone have roller blinds working? Or maybe horizontal jealousies too?
I see a hack with Somfy io
https://www.hackster.io/beejayf/somfyduino-io-3d8283
And:
https://gathering.tweakers.net/forum/li ... 6#63825436
and then a python script, only the forum is not alive.
Are there any other brands or options for blinds and blinds?
Zigbee2mqqt contains:
https://www.zigbee2mqtt.io/devices/mcdj3aq.html
Only not working in Domoticz ...
JuanUil
Domoticz version: 4.11083
Re: Zigbee2MQTT
Post by JuanUil »
Hi There,
I am new with zigbee2mqtt and have a problem. probably a noob question but I am really stuck.
I flashed a cc2231 installed all the software as discribed but when I start zigbee2mqtt i get this:
pi@Raspi4Jan:/opt/zigbee2mqtt $ npm start
node index.js
Zigbee2MQTT:info 2020-10-16 15:57:44: Logging to console and directory: ‘/opt/zigbee2mqtt/data/log/2020-10-16.15-57-44’ filename: log.txt
Zigbee2MQTT:info 2020-10-16 15:57:45: Starting Zigbee2MQTT version 1.15.0 (commit #1bccc5d)
Zigbee2MQTT:info 2020-10-16 15:57:45: Starting zigbee-herdsman…
Zigbee2MQTT:error 2020-10-16 15:57:45: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-16 15:57:45: Failed to start zigbee
Zigbee2MQTT:error 2020-10-16 15:57:45: Exiting…
Zigbee2MQTT:error 2020-10-16 15:57:45: Error: Error while opening serialport ‘Error: Error Resource temporarily unavailable Cannot lock port’
at Znp. (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
at Generator.next ()
at /opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
at new Promise ()
at __awaiter (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
at SerialPort. (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
at SerialPort._error (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2020-10-16T13_57_45_835Z-debug.log
anybody any idea to help me?
Jan
heggink
Domoticz version: 12451
Re: Zigbee2MQTT
Post by heggink »
The error eens to indicate that Z2M cannot open your zigbee usb stick. Have you checked your config as well as what port your stick is on (unplug and plug back in, run dmesg)? Sometimes there are conflicts with other usb services (there is another thread on that). Have you looked at the syslog?
Based on just this error, it's difficult to say where the exact problem is.
P1 meter & solar panel
JuanUil
Re: Zigbee2MQTT
Post by JuanUil »
Hi Heggink,
thnx for your reply.
I have only 1 usb sstick on my pi 4.
dmseg gives port ttyACM0
this is in my configuration.yaml
homeassistant: false
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.2.16:8080'
serial:
  port: /dev/ttyACM0
advanced:
  network_key:
    - 45
    - 102
    - 120
    - 132
    - 7
    - 230
    - 82
    - 195
    - 243
    - 187
    - 18
    - 202
    - 56
    - 6
    - 237
    - 183
salopette
Re: Zigbee2MQTT
Post by salopette »
are you sure it is de port for mqtt?
Standard port is 1883
JuanUil
Re: Zigbee2MQTT
Post by JuanUil »
You are right, thnx but the problem persists
JuanUil
Re: Zigbee2MQTT
Post by JuanUil »
This is the complete logfile:
0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using [email protected]
3 info using [email protected]
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle [email protected]~prestart: [email protected]
6 info lifecycle [email protected]~start: [email protected]
7 verbose lifecycle [email protected]~start: unsafe-perm in lifecycle true
8 verbose lifecycle [email protected]~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/zigbee2mqtt/node_modules/.bin:/u$
9 verbose lifecycle [email protected]~start: CWD: /opt/zigbee2mqtt
10 silly lifecycle [email protected]~start: Args: [ '-c', 'node index.js' ]
11 silly lifecycle [email protected]~start: Returned: code: 1  signal: null
12 info lifecycle [email protected]~start: Failed to exec start script
13 verbose stack Error: [email protected] start: `node index.js`
13 verbose stack Exit status 1
13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack     at EventEmitter.emit (events.js:314:20)
13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack     at ChildProcess.emit (events.js:314:20)
13 verbose stack     at maybeClose (internal/child_process.js:1021:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
14 verbose pkgid [email protected]
15 verbose cwd /opt/zigbee2mqtt
16 verbose Linux 5.4.51-v7l+
17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
18 verbose node v12.19.0
19 verbose npm  v6.14.8
20 error code ELIFECYCLE
21 error errno 1
22 error [email protected] start: `node index.js`
22 error Exit status 1
23 error Failed at the [email protected] start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
JuanUil
Re: Zigbee2MQTT
Post by JuanUil »
there was not so much support but what I want you to know is that after a fresh install of Buster evrything is working allright.
Hope I have helped somebody with the same problems.
Also hope that more people give help on this forum to make Domoticz even better as it is!!!
One thing to reach this goal is to give help when asked
gulem333
Re: Zigbee2MQTT
Post by gulem333 »
Smiggel wrote: Saturday 09 February 2019 20:06 Hi guys,
I have a CC2531 USB stick running using the https://github.com/Koenkk/zigbee2mqtt guide. I have also installed the Domoticz plugin (https://github.com/stas-demydiuk/domoti ... qtt-plugin) installed. I have a total of 2 Xaomi doorsensor connected and 5 Xiaomi temp/hum/bar sensors connected. They all work just fine after having paired them.
However, I notice sometimes one of the temp/hum/bar sensors suddenly stops with updating. I have no errors in my logs and the other sensors continue without problems. It's also not always the same sensor. One time it was the sensor on the attic and then it suddenly it's the sensor in the bedroom. It's not just for one hour, but for over 12 hours or so. When I push the rest button of the sensor, it starts to work again. I did not have this issue with the Xaomi hub (v2) installed.
Can someone tell me what could be causing this problem? Does anyone else experience these kind of issues?
Hello Smiggel,
I have exactly the same issue.
Did you manage to solve the problem with Sensor and CC2531 Stick.
If yes - I will be glad to know the solution :)
THX
daroot
Domoticz version: 2023.2
Re: Zigbee2MQTT
Post by daroot »
S10NL wrote: Saturday 25 July 2020 10:39 Fixed it myself :-)
The answer was adding the following line to [your directory]/domoticz/plugins/zigbee2mqtt/adapters__init__.py
    #ECO.DIM (S10)
    'Dimmer-Switch-ZB3.0': DimmableBulbAdapter        # ECO.DIM dimmer
For anyone struggling with this, a simple explanation.
The file adapters__init__.py defines how to interpret the devices. In my case, the dimmer wasnt recognised and so i had to define how the plugin should see the new device.
Steps:
1. Search for the model (not modelid) of the new device in the zigbee2mqtt log file. In my case 'Dimmer-Switch-ZB3.0'.
2. Define the type of device it should act as. In my case 'DimmableBulbAdapter'
3. Restart domoticz.
4. The plugin should now see the new devices.
I registered to this forum just to thank you for this post!
I recently bought the same dimmer, and couldn't get the dimming part to work.. after making some changes to __init__.py I finally have it working.
I also have the EcoDim.07 (which today is sold as 07.Pro (there's a 07.Basic also)), mine showed as model "Eco-Dim.07".
A former colleague of mine is thinking of ordering the Basic version, curious to see if that one works as well also
MikeF
Domoticz version: V2022.2
Re: Zigbee2MQTT
Post by MikeF »
For info, Koenkk has just released v1.17.1 of zigbee2mqtt - see changelog here: https://github.com/Koenkk/zigbee2mqtt/releases
(fixes / improvements / new supported devices)
jeroenkl
Re: Zigbee2MQTT
Post by jeroenkl »
MikeF wrote: Tuesday 02 February 2021 16:18 For info, Koenkk has just released v1.17.1 of zigbee2mqtt - see changelog here: https://github.com/Koenkk/zigbee2mqtt/releases
Thanks to let us know, update went fine.
