Page 12 of 114
Posted: Tuesday 05 December 2017 21:59
by waow29
Hi Madgeni,
I register on Controlicz, my email start marc.l
Could you add me?
Posted: Tuesday 05 December 2017 22:08
by gijsje
i did add 2 new switches for the Christmas tree and i did change the icon in domoticz to the Christmas tree.
If you change the icon it shows it like this in home
You can ask google to turn them on individual and that works but if you put them in a room in home they will not work
If you change the icon back the normal light bulb in domoticz they show up like this
Then you can put them in a room and they will work as a group
So i made a room called Christmas and that works.
Maybe have a look at this issue
Posted: Tuesday 05 December 2017 22:22
by maxtrash
I got it working now, thanks! But also have a problem with some thermostats in a particular room. I can get the status and temperature from other devices, but for these it wil say "Unable to reach TV room stat". How can I debug this message?
Posted: Tuesday 05 December 2017 22:33
by gijsje
Also a strange thing is if you ask for the outside temperature it will tell you it is 6.6°C and the garden is off
How can it be off??
Posted: Wednesday 06 December 2017 0:36
by markjgabb
i noticed this too..it always tells me that the temp sensor is off...i figured it was just reporting on the state as known by domoticz.....
+1 for an awesome product....absolutely love whats been done and cant believe how well it intergrates so easily...ill definatly be giving tangible support for this product
Posted: Wednesday 06 December 2017 8:46
by Madgeni
ebbspot wrote: Tuesday 05 December 2017 21:52
ebbspot wrote: Wednesday 29 November 2017 0:42
Hello Madgeni,
Have you read this request?
i would like to use (test) controlicz with my domoticz and google assistant. I am registred on controlicz with email eb*e*@xs4all.nl
Hi there -
Email addresses and domains must be associated with an active Google Account or Google Apps account
Posted: Wednesday 06 December 2017 8:47
by Madgeni
gijsje wrote: Tuesday 05 December 2017 22:33
How can it be off??
*sigh* it isn't. Honestly i've no idea how it's getting that state - i pass back 'on', but it has decided that it's 'off'. I'll add it to my list to look at.
Posted: Wednesday 06 December 2017 8:52
by Madgeni
gijsje wrote: Tuesday 05 December 2017 22:08
Yeah a common theme is that Domoticz allows for a large amount of customisation, but Alexa and Google don't, so I have to find ways of deciding what's a light, what's a switch, when they both have Type of Light and Subtype of light. I decided on the image - if it's a bulb, it's a light. if it isn't a bulb, well..you can work that out
I did put something in the FAQ
Posted: Thursday 07 December 2017 16:57
by FCJean
Hi Madgeni,
I have just registered on Controlicz, my email starts with fcjean7...
Could you please add me?
Thanks a lot
Posted: Thursday 07 December 2017 22:49
by quirk
Hi Madgeni,
I just registered on Controlicz, my email start david.leb*****@gmail.com
Can you add me?
Thanks a lot!
David
Posted: Thursday 07 December 2017 23:32
by Madgeni
All done
Posted: Friday 08 December 2017 1:56
by planetf1
Thanks for me setting up. I registered my google email on controlicz, setup port forwarding etc, have a new user, and have run through the google beta test setup.
When I go into add devices, I see [test] Home Controlicz. If I click I get prompted for user/pass , to accept, then user/pass. After doing this I just get 'something went wrong' . How do I debug?
Posted: Friday 08 December 2017 9:14
by Madgeni
can you double check your domoticz username/password?
weirdly, i can see controlicz is getting a http 503 error, which usually means the Domoticz service is not available - have you done any whitelisting/blacklisting on a firewall?
Posted: Friday 08 December 2017 10:04
by planetf1
I can do 'telnet A.B.C 10443' and connect
I can browse to
https://A.B.C.D:10443 and get into domoticz - though without userid/password... looking at that now....
(I'm using a non-standard port to not clash with other https stuff I may expose)
Posted: Friday 08 December 2017 11:47
by Madgeni
non-standard is fine
Posted: Friday 08 December 2017 12:56
by fergalom
Could I get added also?
fer****m at gmail
Posted: Friday 08 December 2017 16:36
by mikejclark
Hi Madgeni
If I query my lounge temperature it returns a different number to that shown in Domoticz. It seems no matter what the temperature is in Domoticz, Google home returns 17.5. Any idea what's happening?
Sent from my GT-I9505 using Tapatalk
Posted: Friday 08 December 2017 16:40
by Madgeni
ok, that's weird!
if you use this - https://yourhost:port/json.htm?type=devices&rid=IDXOFLOUNGETEMPERATURE - what does 'temp' say?
Posted: Friday 08 December 2017 16:52
by mikejclark
Madgeni wrote:ok, that's weird!
{ "ActTime" : 1512748152, "ServerTime" : "2017-12-08 15:49:12", "Sunrise" : "08:05", "Sunset" : "15:53", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "17.8 C, 56 %", "Description" : "", "DewPoint" : "8.90", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Virtual Switch", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveTimeout" : false, "Humidity" : 56, "HumidityStatus" : "Comfortable", "ID" : "140EA", "LastUpdate" : "2017-12-08 15:48:57", "Name" : "Lounge Temperature", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "THGN122/123, THGN132, THGR122/228/238/268", "Temp" : 17.800000000000001, "Timers" : "false", "Type" : "Temp + Humidity", "TypeImg" : "temperature", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "154" } ], "status" : "OK", "title" : "Devices" }
It's now changed to 18. Is it rounding up?
Posted: Friday 08 December 2017 17:38
by Lyrex
Hey Madgeni,
can you leave a message if your selector switch impelentation is finished? Im happy to try it out!
