Page 12 of 26
Re: Domoticz App
Posted: Saturday 02 September 2017 10:15
by galadril
hekm77 wrote: Saturday 02 September 2017 9:52 In the Russian translation contains inaccuracies
Can you add the choice of application language?
Ill add it to the list!
Re: Domoticz App
Posted: Saturday 02 September 2017 11:07
by fkok
App works great. Keep up the good work!
Re: Domoticz App
Posted: Saturday 02 September 2017 11:20
by Clemen
galadril wrote: Saturday 02 September 2017 10:13 Meet our new Domoticz app for iPad and iPhone!
I'm extremely h'APP'y right now, that we finally released the first verion of my iOS app!!
Apple Store:
https://itunes.apple.com/us/app/domotic ... ?ls=1&mt=8
More information:
http://www.hnogames.nl/domoticz.html
How to get to next page in configuration?
And what’s with the small weird ugly buttons?
Re: Domoticz App
Posted: Saturday 02 September 2017 11:23
by solidum90
I can't find app on App Store :/
I've an iPhone 7, from italy.
Re: Domoticz App
Posted: Saturday 02 September 2017 11:24
by fkok
solidum90 wrote:I can't find app on App Store :/
Follow the link in the previous post!!! READ!!!
Re: Domoticz App
Posted: Saturday 02 September 2017 11:28
by galadril
Clemen wrote: Saturday 02 September 2017 11:20 How to get to next page in configuration?
Can i get a view account to debug your system?
Looks like there is an issue with one of your devices
Re: Domoticz App
Posted: Saturday 02 September 2017 11:49
by galadril
solidum90 wrote: Saturday 02 September 2017 11:23 I can't find app on App Store :/
Re: Domoticz App
Posted: Saturday 02 September 2017 12:01
by bing69
Ok app installed and purchased directly. Looks good. On some switches, I can not put a timer on a switch.
I can not find anywhere I can turn on a switch notification and i see no widgets.
Re: Domoticz App
Posted: Saturday 02 September 2017 12:56
by Jem101
OK this is a bit odd, just like 'Clemen' who posted above, my installation just seems to hang up at the verifying connection stage, no indication what's wrong or if it's doing anything.
But if I go back to the initial splash screen and opt to connect to the demo setup that seems to work OK. From that point I can go to the settings tab, hit the server connection settings and edit the details there to point to my Domoticz installation and press the Verifying your connection settings at the bottom, I get a brief 'Loading' message and Ok appears. If I then go back to the Switches tab, there are all my devices listed and they all seem to work. Similarly the Scenes, Temperature and Utilities tabs are all populated and working, the Weather tab is completely blank but the Dashboard tab still show the devices from the initial demo and I can't get that to change.
If I force close the app and relaunch it, I get a brief 'Error not connected to any network' message at the bottom but then it goes away, the Dashboard tab still show the demo devices but the others (except for the weather) pick up all my devices.
So it would look as if there is something it doesn't like about picking up dashboard settings - weird or what?
Re: Domoticz App
Posted: Saturday 02 September 2017 13:20
by galadril
Jem101 wrote: Saturday 02 September 2017 12:56 OK this is a bit odd, just like 'Clemen' who posted above, my installation just seems to hang up at the verifying connection stage, no indication what's wrong or if it's doing anything.
I found an issue for another user with the Barometer device (do you have one in your system)?
I already uploaded a hotfix request to Apple for a fix for this matter.
If you want i can debug the app with your devices, please send me the FULL json data from the next url on your system:
http://domoticz:port/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0
Re: Domoticz App
Posted: Saturday 02 September 2017 13:52
by Jem101
Why yes I do have a (virtual) barometer device.
I've just dumped the entire son output to a text file which I'll PM across to you if that's OK? I've emboldened the section for the barometer device (it's ID 198) if it makes it easier for you to find and debug.
Best wishes
John
Re: Domoticz App
Posted: Saturday 02 September 2017 13:54
by galadril
Jem101 wrote: Saturday 02 September 2017 13:52 Why yes I do have a (virtual) barometer device.
Best wishes
John
maybe you can remove the barometer device for now.. then test if it's working without..
the next beta will have a fix for that
Re: Domoticz App
Posted: Saturday 02 September 2017 14:16
by G3rard
Thanks @galadril for bringing this app to the store!
I have enabled the log of the app and there is an error that the pressure value of my barometer is not a valid integer.
That is right because in my example it is a string (containing 1021.2). That prevents the connection to Domoticz.
So if this is changed it should work.
Re: Domoticz App
Posted: Saturday 02 September 2017 14:44
by i000
Downloaded and purchased! We start the test all the devices!!
Re: Domoticz App
Posted: Saturday 02 September 2017 18:10
by andi216
Hello
Cool app ... I bought.
I have a question.
I have Fibaro motion sensors. In the application there is also a push button next to the status. Should not I just see the status of the sensor without a button? By mistake, if you press the button, you can trigger the alarm.
Re: Domoticz App
Posted: Saturday 02 September 2017 18:29
by poudenes
External try to connect. When i use https://<hostname> and using my username and password o can access it.
When i want use it with the app i get a error:
2017-09-02 13:11:39.525 Error: [web:8081] Failed authentication attempt, ignoring client request (remote address: 84.x.x.x)
someone know how to solve this?
Internal connection is working good!
BUT The best keep for last: Great design, paid for the full version !!!! Support this app and pay for it !! :D
Re: Domoticz App
Posted: Saturday 02 September 2017 18:56
by galadril
andi216 wrote: Saturday 02 September 2017 18:10 I have Fibaro motion sensors. In the application there is also a push button next to the status. Should not I just see the status of the sensor without a button? By mistake, if you press the button, you can trigger the alarm.
I thought that you can also click the button/icon on domoticz web system right?
I try to supply the same functionallity
Re: Domoticz App
Posted: Saturday 02 September 2017 19:02
by galadril
poudenes wrote: Saturday 02 September 2017 18:29 someone know how to solve this?
Do you use self signed certificates on https?? If so, please use proper certificate authority to sign the certificates (can be free like Let's Encrypt).
Else, please give me a view-account on your system, so I can debug why you can't connect..
poudenes wrote: Saturday 02 September 2017 18:29 BUT The best keep for last: Great design, paid for the full version !!!! Support this app and pay for it !! :D
Thanks for the feedback!
Re: Domoticz App
by galadril
i000 wrote: Saturday 02 September 2017 14:44 Downloaded and purchased! We start the test all the devices!!
:lol: :lol: :lol:
Re: Domoticz App
Posted: Saturday 02 September 2017 19:55
by Bandbox
All,
First of all, a great app and purchased it directly. Personally, I find this app better than Pilot. The look and feel is much better. My compliments!
I do have one issue with this app. Although I am using the same credentials for remote access for address, port, etc, I am not able to control my switches. With Pilot it worked great, so I am sure my port forwarding in my router is correct. Via WiFi the Domoticz app work great, but not without WiFi.
Plz your guidance.
Thx Anton
