Domoticz App
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
hekm77 wrote: Saturday 02 September 2017 9:52 In the Russian translation contains inaccuracies
Can you add the choice of application language?
Ill add it to the list!
fkok
Re: Domoticz App
Post by fkok »
App works great. Keep up the good work!
Clemen
Re: Domoticz App
Post by Clemen »
galadril wrote: Saturday 02 September 2017 10:13 Meet our new Domoticz app for iPad and iPhone!
I'm extremely h'APP'y right now, that we finally released the first verion of my iOS app!!
Apple Store:
https://itunes.apple.com/us/app/domotic ... ?ls=1&mt=8
More information:
http://www.hnogames.nl/domoticz.html
How to get to next page in configuration?
And what’s with the small weird ugly buttons?
solidum90
Domoticz version: Debian
Re: Domoticz App
Post by solidum90 »
I can't find app on App Store :/
I've an iPhone 7, from italy.
fkok
Re: Domoticz App
Post by fkok »
solidum90 wrote:I can't find app on App Store :/
Follow the link in the previous post!!! READ!!!
galadril
Re: Domoticz App
Post by galadril »
Clemen wrote: Saturday 02 September 2017 11:20 How to get to next page in configuration?
Can i get a view account to debug your system?
Looks like there is an issue with one of your devices
galadril
Re: Domoticz App
Post by galadril »
solidum90 wrote: Saturday 02 September 2017 11:23 I can't find app on App Store :/
bing69
Re: Domoticz App
Post by bing69 »
Ok app installed and purchased directly. Looks good. On some switches, I can not put a timer on a switch.
I can not find anywhere I can turn on a switch notification and i see no widgets.
Last edited by bing69 on Saturday 02 September 2017 13:06, edited 1 time in total.
Jem101
Re: Domoticz App
Post by Jem101 »
OK this is a bit odd, just like 'Clemen' who posted above, my installation just seems to hang up at the verifying connection stage, no indication what's wrong or if it's doing anything.
But if I go back to the initial splash screen and opt to connect to the demo setup that seems to work OK. From that point I can go to the settings tab, hit the server connection settings and edit the details there to point to my Domoticz installation and press the Verifying your connection settings at the bottom, I get a brief 'Loading' message and Ok appears. If I then go back to the Switches tab, there are all my devices listed and they all seem to work. Similarly the Scenes, Temperature and Utilities tabs are all populated and working, the Weather tab is completely blank but the Dashboard tab still show the devices from the initial demo and I can't get that to change.
If I force close the app and relaunch it, I get a brief 'Error not connected to any network' message at the bottom but then it goes away, the Dashboard tab still show the demo devices but the others (except for the weather) pick up all my devices.
So it would look as if there is something it doesn't like about picking up dashboard settings - weird or what?
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
galadril
Re: Domoticz App
Post by galadril »
Jem101 wrote: Saturday 02 September 2017 12:56 OK this is a bit odd, just like 'Clemen' who posted above, my installation just seems to hang up at the verifying connection stage, no indication what's wrong or if it's doing anything.
I found an issue for another user with the Barometer device (do you have one in your system)?
I already uploaded a hotfix request to Apple for a fix for this matter.
If you want i can debug the app with your devices, please send me the FULL json data from the next url on your system:
http://domoticz:port/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0
Jem101
Re: Domoticz App
Post by Jem101 »
Why yes I do have a (virtual) barometer device.
I've just dumped the entire son output to a text file which I'll PM across to you if that's OK? I've emboldened the section for the barometer device (it's ID 198) if it makes it easier for you to find and debug.
Best wishes
John
galadril
Re: Domoticz App
Post by galadril »
Jem101 wrote: Saturday 02 September 2017 13:52 Why yes I do have a (virtual) barometer device.
Best wishes
John
maybe you can remove the barometer device for now.. then test if it's working without..
the next beta will have a fix for that
G3rard
Domoticz version: No
Re: Domoticz App
Post by G3rard »
Thanks @galadril for bringing this app to the store!
I have enabled the log of the app and there is an error that the pressure value of my barometer is not a valid integer.
That is right because in my example it is a string (containing 1021.2). That prevents the connection to Domoticz.
So if this is changed it should work.
Not using Domoticz anymore
i000
Re: Domoticz App
Post by i000 »
Downloaded and purchased! We start the test all the devices!!
andi216
Domoticz version: 3.7243
Re: Domoticz App
Post by andi216 »
Hello
Cool app ... I bought.
I have a question.
I have Fibaro motion sensors. In the application there is also a push button next to the status. Should not I just see the status of the sensor without a button? By mistake, if you press the button, you can trigger the alarm.
poudenes
Domoticz version: 3.8993
Re: Domoticz App
Post by poudenes »
External try to connect. When i use https://<hostname> and using my username and password o can access it.
When i want use it with the app i get a error:
2017-09-02 13:11:39.525 Error: [web:8081] Failed authentication attempt, ignoring client request (remote address: 84.x.x.x)
someone know how to solve this?
Internal connection is working good!
BUT The best keep for last: Great design, paid for the full version !!!! Support this app and pay for it !! :D
galadril
Re: Domoticz App
Post by galadril »
andi216 wrote: Saturday 02 September 2017 18:10 I have Fibaro motion sensors. In the application there is also a push button next to the status. Should not I just see the status of the sensor without a button? By mistake, if you press the button, you can trigger the alarm.
I thought that you can also click the button/icon on domoticz web system right?
I try to supply the same functionallity
galadril
Re: Domoticz App
Post by galadril »
poudenes wrote: Saturday 02 September 2017 18:29 someone know how to solve this?
Do you use self signed certificates on https?? If so, please use proper certificate authority to sign the certificates (can be free like Let's Encrypt).
Else, please give me a view-account on your system, so I can debug why you can't connect..
poudenes wrote: Saturday 02 September 2017 18:29 BUT The best keep for last: Great design, paid for the full version !!!! Support this app and pay for it !! :D
Thanks for the feedback!
galadril
Re: Domoticz App
Post by galadril »
i000 wrote: Saturday 02 September 2017 14:44 Downloaded and purchased! We start the test all the devices!!
:lol: :lol: :lol:
Bandbox
Domoticz version: 3.8153
Re: Domoticz App
Post by Bandbox »
All,
First of all, a great app and purchased it directly. Personally, I find this app better than Pilot. The look and feel is much better. My compliments!
I do have one issue with this app. Although I am using the same credentials for remote access for address, port, etc, I am not able to control my switches. With Pilot it worked great, so I am sure my port forwarding in my router is correct. Via WiFi the Domoticz app work great, but not without WiFi.
Plz your guidance.
Thx Anton
