Locked
SwordFish
Domoticz version: V4.11375
Re: New Dashboard Design
Post by SwordFish »
Nice Dashboard, keep up the good work.
I downloaded the latest version and everything is working.
But the train and traffic information doesn't work, I get no information when i click on it ( in the config if filled in true)?
Is there something I do wrong?
EdwinK
Post by EdwinK »
Indeed, when checking the console (F12 in Chrome) I see the following with a red warning:
GET http://www.feedrapp.info/?callback=jQuery112408370309590369325_1491052023481&q=https%3A%2F%2Fwww.rijdendetreinen.nl%2Frss%2F&_=1491052023482
GET http://www.feedrapp.info/?callback=jQuery112408370309590369325_1491052023479&q=http%3A%2F%2Fwww.vid.nl%2FVI%2F_rss&_=1491052023483
gjaa
Post by gjaa »
I did a clean install,
FiIled the both CONFIG files and this is wat I see
What is going wrong????
HansieNL
Post by HansieNL »
@gjaa
I hoped you could tell me... I got the same problem with 2 different browsers???
Dashboard also keeps trying to load long.
What virusscanner are you using? I use Kaspersky and after pause it works. I got also a message about fonts.net
Blah blah blah
EdwinK
Post by EdwinK »
Maybe a stupid question, but did you check if the ip-address of your domoticz-server is correct. I mixed up a number and got the result you are showing.
HansieNL
Post by HansieNL »
I think the virusscanner did stop loading the page because of an external file.
After pausing the scanner the page loaded correctly. I didn't change the ip address.
Blah blah blah
HansieNL
Post by HansieNL »
@robgeerts
Can you add the P1 Smart Meter USB please? And thanks again.
if(data.result[r]['HardwareType']=='P1 Smart Meter USB'){
	if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Energy'){
		var html = getStateBlock(data.result[r]['idx']+'sub1','fa fa-plug','Energieverbruik',data.result[r]['Usage']);
		$('.states').append(html);
		var html = getStateBlock(data.result[r]['idx']+'sub2','fa fa-plug','Energie vandaag',data.result[r]['CounterToday']);
	if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Gas'){
		var html = getStateBlock(data.result[r]['idx'],'fa fa-fire','Gas vandaag',number_format(data.result[r]['CounterToday'],2,',','.')+' m3');
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Hi guys, will check tonight, not at home right now. I noticed the problems about the train and traffic info too. The external site I'm using is not the best... I'll find another way ;)
Verstuurd vanaf mijn SM-G930F met Tapatalk
Bob123bob
Post by Bob123bob »
gjaa wrote:I did a clean install,
Same issue here using Safari on a mac
Did a clean install, changed domoticz IP on both conf.js and conf_default.js and have the same result
Looks like there is a issue with lang in console error log, default is language is en (english) not nl
Dynamic
Post by Dynamic »
This is the error in the console:
TypeError: _LANGUAGE is undefined   main.js:26:20
	<anoniem>
Workaround for the time being:
Put this on top of main.js:
var _LANGUAGE='nl_NL';
robgeerts
Post by robgeerts »
HansieNL wrote:@robgeerts
Added, could you test this?
Dynamic wrote:This is the error in the console:
	<anoniem>
Fixed this, I think, I dont get any errors anymore...
robgeerts
Post by robgeerts »
What if you clear your cache?
Or press CTRL + F5 at the same time?
HansieNL
Post by HansieNL »
@robgeerts
I'm using the P1 Smart Meter USB and the dashboard myself and works like a charm. :)
So code is tested already.
Blah blah blah
gjaa
Post by gjaa »
Updatet main.js and wetaher.js and everyting is working
robgeerts
Post by robgeerts »
Great! Now I can go to sleep without any worries! :)
EdwinK
Post by EdwinK »
A whole day without updates for the dashboard. Now what...
Baal
Post by Baal »
irishv wrote:Thanks for creating this. I've been wanting to build a better dashboard to use with a mounted iPad for a while now but could never get started. I run Domoticz on Synology NAS with the Aeon Z-stick.
I downloaded the files and was able to connect to my server, adjust language to english and weather to fahrenheit. My favorites come in, but everything shows as light switches. I'm trying to get contact sensors (doors) and motion sensors to say open/closed and motion/no motion.
Can you tell me how to change the language to english ? :)
robgeerts
Post by robgeerts »
If you have the latest version, you can add the following on top of CONFIG.js:
var _LANGUAGE = 'en_US';
EdKo66 wrote: A whole day without updates for the dashboard. Now what...
Haha, spent some time with the kids ;)
EdwinK
Post by EdwinK »
Smart choice
HansieNL
Post by HansieNL »
Small cosmetic change:
- Removed the hover class
- Removed text "Set "
Image Image
var switchHTML = '<div class="col-md-4 hover transbg block'+data.result[r]['idx']+'" data-light="'+data.result[r]['idx']+'"
switchHTML+='<strong class="title">Set '+data.result[r]['SetPoint']+'°C</strong><br />';
Blah blah blah
Locked
