Page 12 of 32
Re: Domoboard a New Dashboard using Domoticz as backend
Posted: Tuesday 10 January 2017 21:16
by squandor
Awst6000 wrote:squandor wrote:Make sure to use master if you are looking for stability. The development branch is used for testing and development which could contain bugs (however we would like to know them!).
Yesterday It was surely the master branch I downloaded. (The zipfile also contains the word 'master')
I recognize a lot of the errors in the posts above.
I'm not a coder but maybe it is wise to rollback the recent changes.
The strange this is that nothing has changed in the master branch. but we are looking into it. Work still goes on so sorry for the late action..
Posted: Tuesday 10 January 2017 21:38
by wez3
squandor wrote:Awst6000 wrote:squandor wrote:Make sure to use master if you are looking for stability. The development branch is used for testing and development which could contain bugs (however we would like to know them!).
Ok, It seems i was able to reproduce the issues. I've upgraded all my python packages and the issue came up.....
Posted: Tuesday 10 January 2017 22:37
by Awst6000
I just tried a testconfig that I downloaded on 05 januari (Python, plugins and Domoboard) and that works as expected.
I don't know if it is possible but maybe it is wise to include the Python plugins somewhere (Assuming one of them causes the problems)
Succes!
Posted: Tuesday 10 January 2017 22:54
by Felix82
Felix82 wrote:Snowtiger wrote:Snowtiger wrote:I installed all dependencies but still get this error :
xx@raspberrypi:~/git/domoboard $ sudo python2.7 server.py -c myconf.conf
File "server.py", line 4, in <module>
from flaskext.auth import Auth, AuthUser, login_required, logout
ImportError: No module named auth
As you can see i already did the python2.7 trick - also tried to install auth via easy-install but that did not solve the error.
I have been digging around - running on a Pi with Raspbian Jessie, python2.7 info
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
I have checked the sys.path if everything is included
['', '/usr/lib/python2.7/dist-packages', '/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/GitPython-2.1.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/gitdb2-2.0.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/smmap2-2.0.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/simplejson-3.10.0-py2.7-linux-armv7l.egg', '/usr/local/lib/python2.7/dist-packages/bleach-1.5.0-py2.7.egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-arm-linux-gnueabihf', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7']
looks alright to me, running direct in command line Python -
File "<stdin>", line 1, in <module>
Shoot me maar lek
Tot zover - iemand met Phyton kennis nog enig idee?
FYI
Im', running a Pi3, Full Jessie (11-2016). I also encountered the same error message after running server.py ("No module named auth").
I got rid of the message by running these commands:
Sudo pip install auth --upgrade
Sudo easy_install requests
Sudo easy_install auth
After running these commands i got the Idx "bla" is not... # them out in de .conf file
By solving this, a new one has appeared
File "server.py", line 156, in <module>
auth = Auth(app, login_url_name='login_form')
NameError: name 'Auth' is not defined
Got it running...
Don't now exactly what did solve it but i ran these commands:
sudo apt-get update
sudo apt-get dist-upgrade
sudo pip install *all components for domoboard (flas flask-auth...)*
in /home/pi/domoticz/www: sudo rm -R domboard
git clone
https://github.com/wez3/domoboard
cp example.conf myconfig.conf
removed idx id's which are not in my domoticz
sudo python server.py -c myconfig.conf
Posted: Tuesday 10 January 2017 23:13
by wez3
Succes!
We just pushed a fix to master for the "<something>" not in "Dict/OrderedDict" issues. It became clear that a newer version of python modules gave some different behaviour in an important part for Domoboard. The fix is here:
https://github.com/wez3/domoboard/commi ... 2ece9e7e8d
A git pull on master and/or dev should fix the issue. Thanks for communicating the bug, were not able to find it without you guys....
Posted: Tuesday 10 January 2017 23:17
by wez3
Shoot me maar lek
FYI
Got it running...
sudo apt-get update
git clone
Is this the fix for a raspbian "full" installation?
Posted: Tuesday 10 January 2017 23:48
by Awst6000
I just downloaded a fresh Domoboard-master and at first sight most things work again.
Although it looks like there is still an issue with traffic/verkeer. I'll look at that tomorrow.
Well done so far!
Posted: Wednesday 11 January 2017 0:14
by Snowtiger
wez3 wrote:Felix82 wrote:
.... Snip....
Got it running...
I am sorry, copied his commands, even did a 'pip --upgrade', system tells there is nothing to upgrade, but no luck - same error message ......
UPDATE - at last, got it running - did a
sudo easy_install --upgrade *all modules*
only requests was updated and it worked
I regret to say - I have no original copy of my install before I tried - so I cannot reproduce it - as an old IT guy I should have thought of that, got a bit rusty
One comment - tried to install Wunderground module in settings - missing module geocoder -
solved the problem
Posted: Wednesday 11 January 2017 1:04
by jhenrikb
Heres what I did to fix my issue of Domoboard (or any HTML custom frontpage) not working.
I installed Apache (
https://www.raspberrypi.org/documentati ... /apache.md) (allthough I doubt this has anything to do with it, but I still did it).
Typed:
sudo chmod -R ugo+rw /var/www (to change ownership over folder so I could read/write in them).
cd /var/www (change directory)
git clone
I uploaded my old config which was already edited with the right IDX's, IP's etc and it worked straight off.
Same with every custom HTML frontpage I put in the /var/www/html Folder.
So if nothing works for you, maybe that works.
Sincerely
John
Posted: Wednesday 11 January 2017 1:06
by Snowtiger
jhenrikb wrote:Heres what I did to fix my issue of Domoboard (or any HTML custom frontpage) not working.
Typed:
git clone
Sincerely
John
Thx John, I have it running now - it's running from my Pi user folder, nothing special
Posted: Wednesday 11 January 2017 7:57
by dutchdevil83
Anyone got the wunderground plugin working?
This are mine settings but can`t get it to work:
Settings part:
[general_settings]
[[wunderground]]
api = xxxxxxxxx
Dashboard part:
[dashboard]
[[display_components]]
components = wunderground[condition], wunderground[forecast]
Page part (under dashboard)
[[wunderground]]
[[[forecast]]]
location = Den Bosch, NL
[[[condition]]]
Posted: Wednesday 11 January 2017 8:43
by squandor
dutchdevil83 wrote:Anyone got the wunderground plugin working?
Settings part:
[general_settings]
[[wunderground]]
api = xxxxxxxxx
Dashboard part:
[dashboard]
[[wunderground]]
[[[forecast]]]
[[[condition]]]
location = Den Bosch, NL]
Hi dutchdevil83,
You have an typo in you're last line:
[[wunderground]]
[[[forecast]]]
[[[condition]]]
Maybe it will be fixed if that bracket is removed
Posted: Wednesday 11 January 2017 8:46
by dutchdevil83
Hi dutchdevil83,
[[wunderground]]
[[[forecast]]]
[[[condition]]]
Sorry this was a copy/paste fault, in my original config file this bracket wasn`t there..
Posted: Wednesday 11 January 2017 9:14
by squandor
dutchdevil83 wrote:Hi dutchdevil83,
[[wunderground]]
[[[forecast]]]
[[[condition]]]
And i just found out that the plugin is momenteraly only working on the develop branch.
Posted: Wednesday 11 January 2017 9:51
by dutchdevil83
squandor wrote:dutchdevil83 wrote:Hi dutchdevil83,
I am on develop branch...
Posted: Wednesday 11 January 2017 11:35
by Felix82
wez3 wrote:Felix82 wrote:Felix82 wrote:
FYI
Got it running...
sudo apt-get update
git clone
For me it is, it's running on the Full version of Jessie...
One thing i forgot to mention is that i used the "--upgrade" option after every "sudo pip install..."
Posted: Wednesday 11 January 2017 12:52
by squandor
Jep i see the problem and its in "Den Bosch"
formally wunderground names it 's-hertogenbosch but the plugin crashes on the ' character.
Posted: Wednesday 11 January 2017 13:34
by squandor
Just fixed the issue with an ' mark in an name for wunderground.
It has been pulled to the master branch of the plugins so you should see an update button in the settings menu.
Posted: Wednesday 11 January 2017 13:58
by dutchdevil83
squandor wrote:Just fixed the issue with an ' mark in an name for wunderground.
`s-Hertogenbosch still not working with version 0.2 ... Just tried with Rosmalen and this works. Anyway to delete text "Condition-Location- .."
Also all text is English, looks like the plugin isn`t looking at country setting for language. When caling API you can use lang:NL for getting dutch language for example.
- Spoiler: show
- http://api.wunderground.com/api/5f87561 ... Paris.json
- Naamloos.jpg (178.31 KiB) Viewed 2152 times
Posted: Wednesday 11 January 2017 14:32
by squandor
dutchdevil83 wrote:squandor wrote:Just fixed the issue with an ' mark in an name for wunderground.
i think that you must put 's-hertogenbosch in quotes: "'s-hertogenbosch" than it will work.
Sure. i was struggeling with the title if i should add the action to it. but i can change it so it will only show the city name if you want it.
