How to monitor your internet connection with virtual custom sensors
Rolandet
Domoticz version: 2021.1
Re: How to monitor your internet connection with virtual custom sensors
Post by Rolandet »
FireWizard wrote: Wednesday 06 May 2020 23:41 Hi,
You can install the Ookla speedtest directly on the Pi4.
I'm running into a little weird thing with that ookla version
Somehow the cronjob runs, but it doesn't update the output file nore my devices in Domoticz
Anyone have the same issue?
Custodes Septentrionum
Bigted
Domoticz version: 2020.1
Post by Bigted »
Rolandet wrote: Wednesday 27 May 2020 22:26
Does it update the file and sensors if you run it manually
FireWizard
Post by FireWizard »
Did you run speedtest-cli manually.
You have to do it once in order to accept their licence.
If you have done that, it will run without asking to accept a licence.
Rolandet
Post by Rolandet »
Bigted wrote: Wednesday 27 May 2020 22:48
Yes they do. No problem there
FireWizard wrote: Wednesday 27 May 2020 22:52 Hi,
Did that, numerous times.
Tnx for your responses.
FireWizard
@Rolandet,
Okay, so it is only the cronjob that doesn't work.
Did you use for all programs the full path?
Cron runs in its own environment and is not aware of any variables, such as $PATH
Rolandet
Post by Rolandet »
FireWizard wrote: Wednesday 27 May 2020 23:05 Hi,
@Rolandet,
Yeah i run the cronjob as pi
FireWizard
@Rolandet
How does your crontab look like.
Rolandet
Post by Rolandet »
FireWizard wrote: Wednesday 27 May 2020 23:15 @Rolandet
* * * * * /home/pi/domoticz/scripts/st2domo.sh
I've set it to every minute, so i can debug :) and with the 'faulty' version, this works fine
23:30h. SLeepy time. Time to dream of speedy internet. I'll read your answers tomorrow, tnx :)
FireWizard
@Rolandet
Can you also post the contents of st2domo.sh?
I assume this file is executable?
Rolandet
Post by Rolandet »
#!/bin/bash
#setup
host=192.168.178.20
port=8080
username=myUserName
password=MyPassword
pingidx=58
downloadidx=60
uploadidx=59
# no need to edit
speedtest-cli --simple > output.txt
ping=$(cat output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
download=$(cat output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
#output if you run it manually
echo "ping = $ping ms"
echo "download = $download Mbps"
echo "upload =  $upload Mbps"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$uploadidx&svalue=$upload"
it's chmod:
-rwxr-xr-x 1 pi pi   969 May 19 21:54 st2domo.sh
Rolandet
Post by Rolandet »
oh one other thing. I've been installing the right and 'wrong' version of speedtest-cli, removing, reinstalling etc etc
How can I be sure i've removed everything, to start fresh?
apt-get remove speedtest-cli enough?
I don't want to re-install my sd, cause I have an Atag one, and that's a real b**** to connect, and it finally works :)
FireWizard
@Rolandet
How did you install speedtest-cli?
apt-get install? Then it is okay
Rolandet
Post by Rolandet »
FireWizard wrote: Wednesday 27 May 2020 23:44 @Rolandet
Well, as we Dutch like to say 'Krijg nou tiete' It's working
Last night, right before bed I set the cronjab back to @hourly, and whadda-ya-know, it works !
Thanks for looking into this guys.
Chris12
Post by Chris12 »
Hi, I read the last few pages of this topic and searched for a solution to monitor my internet connection using a VPN connected provider.
But I could not find it what I'm looking for.
I want to monitor if my internet connection is connected with a VPN, so when the VPN is down I want to see that and get an alarm/message etc.
The VPN provider I have got rotates my VPN connection several times per day/week to get the best/fastest connection available all the time.
Sometimes the VPN connection fails, and I want to know when it does (without looking in my router to see if the VPN is (dis)connected)
My VPN connection is setup in my ASUS RT-AC86U (running asuswrt-merlin firmware) using openVPN, so all my internet traffic is always via this VPN.
I'm not sure this is the right place to look for a solution, if anybody has any other ideas feel free to post them or sent me a PM.
In the meantime I'm checking out the LUA forum as well as the status detection method mentioned there does actually looks into the asus config, so maybe that's the way to go.
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
sincze
Domoticz version: 2024.4
Post by sincze »
Moving from 2.7 -> 3.4.4. requires you to modify the necessary library names indeed. But you can use Python27 next to Python 3.4.4. without issue. So Should be possible to still use the old python version.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Thank you @safi78
I got it running. I first had some problems. The script was running well from commandline but not from crontab.
Finally I found out that I had to comment out these lines from the script:
#echo "ping = $ping ms"
#echo "download = $download Mbps"
#echo "upload =  $upload Mbps"
Then the script is working from crontab.
sundodger
Post by sundodger »
Hi all, trying to set this up on my Domoticz.
However when i try to run the script in Thonny to test it i get a syntax error on the IP address of my Domotcz machine.
See below.
I have no clue as to what would cause this, Any ideas?
Thanks.
Python 3.7.3 (/usr/bin/python3)
>>> %Run speedtest.sh
File "/home/pi/domoticz/scripts/speedtest.sh", line 4
host=192.168.1.150
SyntaxError: invalid syntax
Rolandet
Post by Rolandet »
can you post your entire script ? (minus the password ;) )
sundodger
Post by sundodger »
#!/bin/bash
#setup
host=192.168.1.150
port=8080
username=xxx
password=xxxx
pingidx=83
downloadidx=82
uploadidx=84
# no need to edit
Rolandet
Post by Rolandet »
I don't see anything wrong with the script at first glance.
Have you tried running it as a single shell scrip?
