Page 12 of 17
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Posted: Tuesday 18 April 2017 22:04
by jandoedel99
On RPI 2 with Wheezy i have a problem in the wiki
Python-to-bluetooth
Next, Install Python3 and the required Python3 libraries that let Python script talk to Bluetooth.
sudo aptitude install python3
sudo aptitude install python3-pip
sudo pip3 install pygatt
sudo pip3 install requests
the first 2 lines are going good
the next 2 don´t install
What to do
Posted: Tuesday 18 April 2017 22:09
by pvm
Can you share the error message?
Posted: Tuesday 18 April 2017 22:40
by devros
Dunno why, but on my OrangePi myflora works only when i run hcitool lescan before script
so i modifed script that it runs hcitool lescan for few seconds, then all works
(also changed hcitool lescan to run without sudo)
i know that its quite dirty but it works... for me
here is my modifed script
#!/usr/bin/python3
import urllib.request
import base64
import time
import os
from miflora.miflora_poller import MiFloraPoller, \
MI_CONDUCTIVITY, MI_MOISTURE, MI_LIGHT, MI_TEMPERATURE, MI_BATTERY
# Settings for the domoticz server
# Forum see: http://domoticz.com/forum/viewtopic.php?f=56&t=13306&hilit=mi+flora&start=20#p105255
domoticzserver = "XXX"
domoticzusername = "XXX"
domoticzpassword = "XXX"
# So id devices use: sudo hcitool lescan
base64string = base64.encodestring(('%s:%s' % (domoticzusername, domoticzpassword)).encode()).decode().replace('\n', '')
def domoticzrequest (url):
request = urllib.request.Request(url)
request.add_header("Authorization", "Basic %s" % base64string)
response = urllib.request.urlopen(request)
return response.read()
def update(address,idx_moist,idx_temp,idx_lux,idx_cond):
poller = MiFloraPoller(address)
loop = 0
try:
temp = poller.parameter_value("temperature")
except:
temp = 201
while loop < 2 and temp > 200:
print("Patched: Error reading value retry after 5 seconds...\n")
time.sleep(5)
loop += 1
try:
except:
temp = 201
if temp > 200:
print("Patched: Error reading value\n")
return
global domoticzserver
print("Mi Flora: " + address)
print("Firmware: {}".format(poller.firmware_version()))
print("Name: {}".format(poller.name()))
print("Temperature: {}°C".format(poller.parameter_value("temperature")))
print("Moisture: {}%".format(poller.parameter_value(MI_MOISTURE)))
print("Light: {} lux".format(poller.parameter_value(MI_LIGHT)))
print("Fertility: {} uS/cm?".format(poller.parameter_value(MI_CONDUCTIVITY)))
print("Battery: {}%".format(poller.parameter_value(MI_BATTERY)))
val_bat = "{}".format(poller.parameter_value(MI_BATTERY))
# Update temp
val_temp = "{}".format(poller.parameter_value("temperature"))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
# Update lux
val_lux = "{}".format(poller.parameter_value(MI_LIGHT))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_lux + "&svalue=" + val_lux + "&battery=" + val_bat)
# Update moisture
val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
# Update fertility
val_cond = "{}".format(poller.parameter_value(MI_CONDUCTIVITY))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_cond + "&svalue=" + val_cond + "&battery=" + val_bat)
time.sleep(1)
# format address, moist (%), temp (°C), lux, fertility
os.system("timeout 2 hcitool lescan 5")
print ("predping")
update("C4:7C:8D:61:B4:DA","142","133","136","143")
Posted: Tuesday 18 April 2017 23:05
by jandoedel99
jandoedel99 wrote:On RPI 2 with Wheezy i have a problem in the wiki
Python-to-bluetooth
What to do
error is
pi@raspberrypi ~ $ sudo pip3 install pygatt
/usr/local/bin/python3.5: error while loading shared libraries: libpython3.5m.so .1.0: cannot open shared object file: No such file or directory
Posted: Saturday 22 April 2017 13:56
by micksel
Seems that on my Pi2 with the Domoticz image, the command isn't pip3 but pip-3.2
So close now but But I still recieve Error:
pi@domo1 ~/domoticz/scripts/python/miflora $ /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py
File "/home/pi/domoticz/scripts/python/miflora/domoticz.py", line 4, in <module>
File "/home/pi/domoticz/scripts/python/miflora/miflora/miflora_poller.py", line 12, in <module>
from subprocess import PIPE, Popen, TimeoutExpired
ImportError: cannot import name TimeoutExpired
And Sudo pip-3.2 install timeoutexpired won't solve anything
pi@domo1 ~/domoticz/scripts/python/miflora $ sudo pip-3.2 install TimeoutExpired
Downloading/unpacking TimeoutExpired
Could not find any downloads that satisfy the requirement TimeoutExpired
No distributions at all found for TimeoutExpired
Storing complete log in /root/.pip/pip.log
Posted: Saturday 22 April 2017 15:21
by micksel
I downloaded the new and updated miflora_poller.py from
https://github.com/open-homeautomation/ ... ant-sensor but still recive the same error
I found my ID using : sudo hcitool lescan)
C4:7C:8D:62:0C:81 Flower care
I edit demo.py with this but when I run it I get the following errors:
pi@domo1 ~ $ sudo /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/demo.py
pi@domo1 ~/domoticz/scripts/python/miflora/miflora/tests $ /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/demo.py
File "/home/pi/domoticz/scripts/python/miflora/demo.py", line 1, in <module>
I can connect with gatttool -I and Connect
pi@domo1 ~/domoticz/scripts/python $ gatttool -I
[ ][LE]> connect c4:7c:8d:62:0c:81
Attempting to connect to c4:7c:8d:62:0c:81
Connection successful
Notification handle = 0x0021 value: 00
[c4:7c:8d:62:0c:81][LE]>
(gatttool:9429): GLib-WARNING **: Invalid file descriptor.
Posted: Saturday 22 April 2017 16:36
by madrian
Coldman wrote:
[bluetooth]# scan on
Discovery started
[CHG] Controller 34:C3:D2:E4:13:E3 Discovering: yes
[/quote]
How can I connect to the sensor and watch RSSI with scan on?
Thank you
Posted: Sunday 23 April 2017 13:21
by madrian
I am triying:
@orangepizero:~/bluetoothctl
Discovery started
[CHG] Controller 00:1A:7D:DA:71:13 Discovering: yes
[CHG] Device C4:7C:8D:62:6E:22 RSSI: -59
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x02
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x98
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x00
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x41
And I see many Servicedata Value lines....how I can filter out only RSSI?
Posted: Monday 24 April 2017 17:49
by micksel
micksel wrote: from miflora.miflora_poller import MiFloraPoller, \
I solved this by manually update to python 3.4
Posted: Tuesday 25 April 2017 11:01
by micksel
I can see in the python script that the battery parameter is also sent when updating the values.
Like: domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
How can I see this value in domotics?
Posted: Tuesday 25 April 2017 11:03
by LouiS22
micksel wrote:I can see in the python script that the battery parameter is also sent when updating the values.
Right under the Devices tab
Check the little green battery icon, and in that row.
Posted: Tuesday 25 April 2017 11:29
by micksel
LouiS22 wrote:micksel wrote:I can see in the python script that the battery parameter is also sent when updating the values.
Feeling like an idiot, thanks.
Posted: Thursday 27 April 2017 20:24
by bertbigb
Dear All,
I bought a MiFlora Plant pin and followed the wiki.
I run domoticz on a raspberry 3
I discovered my device with the command
it showed C4:7C:8D:63:62:1E Flower care
I used the domoticz.py from the wiki
I updated this value in domoticz.py and when I now run
pi@raspberrypi_V3:~ $ /usr/bin/python3 /home/pi/dev-domoticz/scripts/python/miflora/domoticz.py
I get the following response:
1: Varen (weet ik niet)
connect: Device or resource busy (16) (many times)
Anyone any idea why this is happening? I tried already for a couple of hours but no other results. Do I need to change something else?
It is a bit a pity that I can't read the values of the flower pin into domoticz
Posted: Friday 28 April 2017 6:52
by micksel
I got that error message when I still was connected with my Phone. Is that the case for you?
Posted: Friday 28 April 2017 7:52
by bertbigb
micksel wrote:I got that error message when I still was connected with my Phone. Is that the case for you?
That was exactly the case, now it is working fine. Thanks for your reaction
Posted: Saturday 29 April 2017 14:56
by LouiS22
Got a firmware upgrade, new version is 2.9.4. I've upgraded, python script is still working (those who wonder).
Posted: Monday 08 May 2017 17:31
by ilpier
There is no way for Windows?
Posted: Monday 08 May 2017 18:18
by micksel
ilpier wrote:There is no way for Windows?
python exit for windows but not sure about all the moduls, maybe easier just to emulate a Linux system on win
Posted: Monday 08 May 2017 20:58
by bertbigb
I have a raspberry PI 3 with bluetooth, MQTT and Domoticz installed.
I can read through the lua script all my plant pins. So far so good.
What I would like is to send the values from the plantpins over MQTT to another domoticz system running on Synology.
From the PI, i tested and i can send messages to the other domoticz system on Synology
Can anyone help me to point out how to do or what to change in the script to make this possible?
Thanks for your help.
Posted: Monday 08 May 2017 23:57
by pvm
You can also make a slave Domoticz and have Domoticz sent these values over to the other one
